The Future Of The Manual Transmission
1120121123125126205
    edited January 2011
    I never use the stupid foot operated parking brake in the van, but occasionally I'll remember to set the handbrake in the wagon. Bad habit I know but they always froze when I first moved north and I got out of the habit.
    I did a simple drain and fill once on the van at ~120,000 miles (that's the one with 150,000 miles now). Don't think I've ever had the Outback's transmission serviced - maybe when it hits 90k I'll think about it.
    I never warm my cars up but I do creep along for the first few blocks when I first get in them.
    Don't know what you mean by using a gear to change direction? Oh, you mean come to a full stop before putting it into reverse. Yeah, I try to do that.
    There were never AWD Supras. But you are referring to the '90-'93 All-Trac Celicas, which were indeed turbos and did tend to chew up their transmissions.
    The cheap crappy manual trans that Toyota put in the first three years of the Matrixes is yet another in a long list of shames from the cost-cutting shoddy decade just ended at that company. And yes, many of those did fail, enough for Toyota to issue a TSB.
  • plektoplekto Member Posts: 3,738
    Of course, whenever a vehicle needs a new clutch, I put in a heavy duty racing clutch for $50-$100 extra. So far I've never had to replace a clutch on a vehicle after the first time.
    OEM clutches are like OEM brakes and struts - usually it's just adequate inexpensive stuff they tossed in to get it out the door. A $200 clutch vs a $100 one is a drastic difference in most cases.
  • crkyolfrtcrkyolfrt Member Posts: 2,345
    yup, sounds right.
    while i have never actually ever had to have a clutch done, i have never done one myself other than helping a friend many moons ago in a cold damp under grd on his Datsun 1200. But Frank was the one getting dirty, i just held a light and handed him stuff and provided muscle at times.
    Since then i have read that there is an important step in re and re clutch - regarding changing plate thickness or if flywheel is refinished vs buying a new one.. it has to do with clearance during operation and the strain on the fingers i think, or might be extra strain in the throw-out bearing...i forget exact details, if u guys have done clutch often then u likely know this caution i'm talking about?
    I would refresh my memory on right steps if i ever had to do one, but it would never be on this car (unless I kept it to 700k mi or had a seal fail i suppose and contaminate it. I'd be dead from old age tho is my point on this particular car. Don't like the seat or the road noise) or a new one unless it was a faulty setup like Matrix XRS 6 speeds killing a clutch in 30k mi even with prev very experienced clutch users.
  • xwesxxwesx Member Posts: 17,676
    edited January 2011
    and never use a gear to change direction prior to coming to a full stop, even if you are fairly gentle on the throttle after.
    when tranny very cold, don't ask a lot of it till it is up to temp
    These two definitely make a big difference, but probably the first habit is the most important.
    I have never had an auto transmission fail. I had my '96 Outback to 220,000 miles and it still operated perfectly. My '98 Dodge G Caravan was at 215,000 when I sold it, and it was perfectly fine too. In fact, on that one, the engine was also still solid as a rock, having never been cracked open and still didn't leak a drop of oil (can't say the same thing for the Subaru!).
    My family (including parents & siblings) tends to keep their cars a long while, and the only auto in the group that had a failed transmission was a '92 Camry, purchased new by my father, that required a replacement at about 230,000 miles shortly after he sold it to my brother. Apparently, having a wife that is hard on cars and a high-mileage automatic are not a good combination. :P
    While I have a lot of manuals, none of them are overly miled up. Hah; I have a 41-year-old Chevrolet C20 with a 4-speed Muncie, and even it still has the original clutch! With only 73,000 miles on it, though, that is not too surprising I suppose.
    My '98 Escort, at just over 140,000 miles, is the highest mileage MT car I have. It is on its original clutch. I thought it was slipping earlier this year, but after I put my new winter tires on this Fall I have had no problems, so maybe it was just the old all-seasons slipping? I don't know - I never heard any chirping and don't generally push it very hard, but it is running strong right now. I was planning to replace the clutch in the Spring, but now I am going to see whether it holds through then and will reassess.
    "Oh, you mean come to a full stop before putting it into reverse. Yeah, I try to do that."
    Right, sorry it took me so long to reply, missed it first time around i guess.
    Park brakes rarely freeze on anymore, but i too remember back in the day.
    Here is an excerpt from a post i did for some unappreciative, irritable woman on a dif thread. Some people are hard to help..
    Of course I'm guessing u already know this but some readers may not.
    *Have you ever seen someone in parking mall bump into the car in front or rear when they park? Well if u don't have your parking brake set, then all that force of the bump, is exerted TOTALLY on that tiny pawl and the slot it fits in.
    Have you ever parked on a steep hill or heard someone else as they pull it out of Park after being on steep hill without the parking brake? Have you ever heard that loud clunk? Well that is that tiny pawl slipping out of the slot with all that force exerted on it. As it passes the leading edge of the slot, imagine all that force is now on only a tiny 'edge' of the pawl. It is like taking a file or chisel to the end of it. And guess where the metal bits go? *
    Gosh u did well with the Gr Caravan. Weren't those the infamously troublesome 4 sp Ultramatics?
    Oh, don't worry. Soon, the entire car will roll down the hill... that's one way to "solve" the problem. ;)
    And, yes, even *I * have had a car slip out of park once on a hill The parking brake held, but barely.
    Yes, it was the 4-speed. Honestly, from everything I have read about them, they are only troublesome in the fact that they require ATF +4 fluid and are VERY picky about it! If you run Mercon or Dexron in it, it's toast - period, the end.
  • igozoomzoomigozoomzoom Member Posts: 801
    "My '98 Dodge G Caravan was at 215,000 when I sold it, and it was perfectly fine too. In fact, on that one, the engine was also still solid as a rock, having never been cracked open and still didn't leak a drop of oil."
    I remember hearing the tale of one lone Chrysler minivan from the 90s that hadn't needed a transmission replacement yet... thought it was an urban legend, but apparently it was true!!! =)
    Being (kinda) serious, obviously you take care of your vehicles and you know the bad habits that eventually lead to major failures...and then you don't do them! It's astounding to me the number of people who ARE AWARE of the impact their driving behaviors will eventually have on their vehicle, but they still keep doing those same things!!!
    The Chrysler minivans from the mid to late 90s were pretty (in)famous for transmission failures. Actually, make that basically all Chrysler FWD V6 vehicles from the 1990s went thru transmissions like most people go thru underwear! They were obviously 'fragile' and very few of their owners treated them as such.
    My sister had a 1996 Caravan with the 3.8L V6 and 4-speed automatic and it started misbehaving around 110k miles. It would suddenly decide to downshift from 4th to 2nd while she wasy driving at 65mph, then refuse to upshift. She would pull over as quickly as possible, put it in PARK, shut off the engine, swear profusely, then re-start it and it would shift perfectly for as long as three or four months or it might do it all over again the next day! Around 115k miles, it started being very stubborn to go into 4th/OD. It would just linger in 3rd for miles and it might take 20 miles at 70mph before it would suddenly upshift into 4th! Once it started that, it was pemanent, not an intermittent quirk like the other thing.
    She and my brother-in-law weren't in any position to buy another car (or to even repair the one she had) so she kept driving it until it had almost 130k miles on it. My parents felt sorry for her (and my mom wanted a new car) so they gave her the '03 Explorer that mom had at the time. I was shocked that it kept going (in one gear or another) for 20k miles after it first started having problems. Most A/T failures progress very quickly from the first sign of a problem...
    My parents bought a new Grand Cherokee back in 1995 and it had a horrible reputation for transmission failures! Even one of the mechanics at the Jeep dealer told me that they some days they'd have five or six Grand Cherokees in for transmission replacement under warranty. That was the bright spot for most affected owners- they usually failed in the first 20-30k miles. But it wasn't uncommon for the replacement to fail after another 50 or 60k miles and that wasn't under warranty. Anyway, I was always waiting for my mom's to die on her at any point! It's been 16 years and 210k miles and I'm still waiting....I bought the Jeep from them when mom got her '03 Explorer and it's still going strong. The trade-in value was a joke with the the high mileage (around 175k at that time), so I paid them $4000 for it...I was fond of the old gal, even though I only use it on weekends or when I need to haul something that won't fit in my Mazda3.
    It's sort of amusing, the '95 Jeep Grand Cherokee had horrible reliability ratings in Consumer Reports and every magazine or website review devoted at least one full paragraph warning potential buyers to look elsewhere. But it has been the most reliable, trouble-free vehicle that anyone in my immediate family has ever owned! My sister and I alone have owned more than a dozen Hondas and I've had an Acura and now a Mazda- most of them great cars and only two with MAJOR problems...but none as rock-solid reliable at that old Jeep!!! Ironically, the two that had MAJOR problems were mine (of course) and both of them had Consumer Reports' highest ranking for reliability!!! One was my '96 Accord and the other is my '06 Mazda3 that I'm still driving....
    2015.5 Volvo S60 T6 Drive-E Platinum, 2012 Mazda CX-9 GT
    One of my neighbors was a carpet salesman so he drove tons of miles, and got Grand Caravans every couple of years or so. Every one of them had transmission issues, yet they were so cheap he just kept buying them, maybe 3 or so.
    EVERYONE that I know that have had Dodge minivans have had to R/R @ least one A/T !!!! It would seem that manual transmissions are THE hidden value (if indeed they are even available in models that folks actually buy). Even when they fail, they are far cheaper to R/R than an A/T when they do.
    edited January 2011
    My '89 Voyager's transmission was fine. But I only drove it 90,000 miles in ten years. Seems like minivans in general are harder on transmissions. Odysseys have a bit of a reputation too.
    Back when I got my first minivan, you could actually buy a Caravan with a manual transmission. The good ol' days. Like now with most cars, the MT minivans were hard to find. Doubt that many dealers stock MT Mazda5s.
    edited January 2011
    Wow, I just have to totally disagree with you and I have no idea you and your family are having such bad luck?
    If this was 1970, I would totally agree with you. Back in those days it was pretty common to have a transmission overhaul around the 80,000 mile mark.
    With modern cars, given proper care an automatic transmission can easily go 200,000 miles and more! Our elderly 1993 Explorer's transmission has never been opened and it has 165,000 miles! AND, it's a FORD!
    "resale value is horrendous"
    Totally incorrect. Our store didn't keep cars with over 100,000 miles but when we appraised one we drove it and made sure the transmission and everything else worked well.
    The cars that are hard to sell are cars with manuals. They would sit on our lot unless we got lucky and just happened to find a stick lover.
    FWD and/or F/awd vehicles with manual transmissions in the wrong hands (and that be 90% of the general public) can turn deadly in a NY minute. If you agree that FWD and/or F/awd vehicles are patently unsafe in adverse roadbed conditions then quadruple that for ones with manual transmissions in the hands of an inexperienced driver.
    Now that VW has come up with a solution for this problem we might see an uptick in the rate of decline of manuals but I think the die has been set. Except for trucks and RWD or R/awd sports cars stick shifts are headed for the history books.
    As you say, it's the driver. A Radio Flyer wagon in the wrong hands can be deadly. No one else seems to agree with your patently unsafe arguments.
    The real coup de grâce for the gen-three Chrysler vans (not sure about before or after!) is the electrical gremlin. I swear that they have the most trouble-prone electronics of any vehicles of the era. Or, at least, among the worst!
    Based on your description of your sister's transmission issues, it was likely an electrical problem that first occurred at 110K.
    Like you say, though, the transmission is also quite fragile. Abuse put them down quickly and they required relatively frequent fluid changes. I can't recall if the factory spec was 30 or 50K miles, but I think it was 30. Several folks with whom I spoke told me that it should be done every 15,000 "just to be safe!"
    I didn't have the van from new, but purchased it from a Chrysler mechanic who claims he had serviced it since new (he bought it from the original owner when she came to the dealership to trade it in). It had 170,000 when I purchased it, with the last 15,000 having been his miles and the rest were from the original owner (who had a 50-mile one-way commute). I changed out the transmission fluid at about 180K, using Amsoil Universal ATF (which worked perfectly, despite all the doomsday prophecies I was told) when I did so due to the superior cold-flow properties versus ATF +4, and I worked that van hard.
    About the last thing it did for me before being severely crippled by electrical gremlins was take my family, heavily loaded, on a round-trip journey from Fairbanks, AK, to Erie, PA, and back over the period of about ten weeks in 2009. I think it had about 198,000 when we left, and it had 212,000 when we returned home! :shades:
    However, were a manual available on the gen 3, I would have looked long and hard for one! I imagine, though, that I would have had to pass on the AWD to get it. Aside from the AWD, one thing I really appreciate about Subaru (which is our current family car) is the fact that I can get a manual on more than just the base model, even if they have eliminated them from their top-level trim. *sigh*
  • fintailfintail Member Posts: 58,408
    In 1998, my dad bought a T&C...transmission puked up 6 months later! Ridiculous.
    For my high torque MB, it's a 45K mile or so service. For the fintail, with its weird fluid coupling setup...maybe once a decade.
  • andys120andys120 Member Posts: 23,669
    Still peddling that nonsense? In fact AWD/FWDs are less dangerous for inexperienced drivers, regardless of trans setup since the tyro driver's natural reaction when taking a turn too fast, which is to get off the throttle and brake, will work in a car with FWD or AWD but some RWD vehicles might go into a snap oversteer especially on a slippery road.
    How come accident rates have gone down since the widespread adoption of vehicles w driven front wheels?
    edited January 2011
    The government statistics really do not back up the quoted opinion. The two last years (in arrears) indicate the fatality and accident and coincidently DD percentage being @ historical LOWS !!!!!
    http://www.nhtsa.gov/
    Counterintuitively, I have also never gotten 112,300 miles (from crappy 3rd rate) oem tires either . The nexus being: front wheel drive, front transmission , 5 speed MANUAL transmission. I think most to all would agree front wheel drive and front transmission vehicles have their unique issues.
    "..@ historical lows.."
    That may well be the result of TC, HYPER-ACTICE TC, being so widely adopted by FWD & F/awd manufacturers. Some credit also to VSC but that applies to both drive types.
  • benjaminhbenjaminh Member Posts: 6,539
    gimmestd: A late thanks for your post.
    Another reason to drive a manual--you need to actually drive rather than talk on the phone and text.
    It does happen my son is unusually responsible so far. Here's hoping he can take to a manual when the time comes.
    Now, do I teach him on the Accord mt or the Mazda mt? Both are smooth shifting, and so I suppose it doesn't matter much. But the Accord was a loaded c. $26k model, while the Mazda was a more reasonable $15k. I think maybe the Mazda is the ticket....
    Oh, and I don't know if I should admit this around here, but Honda replaced my clutch for free on my 08 Accord with c. 35k miles. I do a lot of city driving, but I got the idea there was a secret recall or something. I didn't ask them to replace it, they just did it one day when I went in for an oil change.
    2018 Acura TLX 2.4 Tech 4WS (mine), 2024 Subaru Outback (wife's), 2018 Honda CR-V EX (offspring)
    edited January 2011
    That is so FAR down the priroity, variable, statistical, lists on that site that it hardly even rates a mention. Indeed you could make the case that one reason why accident and fatalities are @ historical lows is there is not a rash of tire blow outs.
    edited January 2011
    The easiest way to decide is to find out from the garage/s you would most likely take a R/R clutch job and ask which is cheaper to do. Honda's of late have developed a reputation of consumeable parts wearing down VERY quickly.
    My guess is that they are using offshore parts to save costs. recycled steel unfortunately makes its way into almost all of the parts in order to cut corners and save a few dollars, and they simply lie about it to the auto maker.
    Go buy a bolt at Home Depot and then one that's made in the U.S. and test to see how hard it is to break each one. It's quite enlightening when you consider both are supposedly made to the same specification.
    "Honda's of late have developed a reputation of consumeable parts wearing down VERY quickly."
    In that sentence, would an automatic transmission be one of the consumable parts you're referring to??? =)
    [thumb up] ;)
    For your sake and mine (others also) , I hope not. But I would be in make believe land if I didn't say I suspect what you ask is indeed TRUE.
  • hondaihondai Member Posts: 3
    When I was shopping for a subcompact, the only requirement besides a good price was it had to be a stick. Smaller cars to me are more fun to drive with a manual transmission, and seem to have just a bit more pep to them -- at least when you need to wring it in a pinch. I wish my Grand Cherokee had a stick shift instead of the auto...
    You can look at the Honda VFR1200 motorcycle with the option of autoshift...I'm sure it's beautiful but I'll stick to the 6-speed Blackbird or original VFR750...
    I kinda like the Ford 500s...i wonder if one could be had in a stick? But being the cheap bastage I am, I'd have to buy a used one a couple of years from now.
    Are you aware that Honda has suffered three widespread transmission failure issues between 1999 and 2005!
    The three issues affected the following models-
    4-speed automatic in the 1999-2001 Odyssey and 2000-2002 Accord
    5-speed automatic- Models recalled- 2002-2004 Odyssey, 2003-2004 Pilot, 2003-2004 Honda Accord V6, 2000-2004 Acura 3.2TL and 2001-2003 Acura 3.2CL. Recall included more than 1.1 million vehicles!
    5-speed automatic on 2002-2004 Odyssey and 2003-2004 Pilot
    *There were two different issues with the 5-speed automatic and the 2002-2004 Honda Odyssey could be affected by either one or BOTH on certain models.
    The following issues were never acknowledged or addressed by Honda, but the number of problems clearly indicates a major flaw-
    2001 and early-2002 Civic
    2003 Accord
    Center for Auto Safety- from 07/01/10 to 12/31/10
    Total of 267 transmission complaints, 169 were Honda/Acura vehicles (63% of total)!!!
    In 2006, a class-actions suit was filed by owners of Honda and Acura vehicles with failed automatic transmissions. Models include 2000-2001 Accord, 1999-2001 Odyssey, 2000-2001 Prelude, 1999-2003 Acura 3.2TL, 2001-2003 Acura 3.2CL. This extended the warranty slightly beyond the already-extended 7yrs/100k miles. Honda also had to pay $5.5 million in legal fees.
    Thousands of vehicles that had transmission replacements failed again, requiring yet another replacement! At least a few of them even required a fourth replacement!!! Imagine how the owner of a new 3.2TL Type-S felt dealing with repeated transmission failures in their new $35k sports sedan???
    Apparently, it's not over yet...here's the link to a story published just yesterday in the New York Times-
    http://wheels.blogs.nytimes.com/2011/01/08/honda-transmission-problems-seem-to-p- ersist/
    All automatics, of course. There's something to be said about mechanical simplicity.
    edited January 2011
    By way of 20/20 hindsight/ history, it would seem the 04 Civic A/T (as a class) dodged a fairly expensive "bullet".
    Sienna minivan over the weekend to shuttle some folks around that were visiting, and I must admit, a manual shift option doesn't make much sense for that car. I can't imagine I would have preferred a stick, the thing had zero appeal for someone who likes to drive and the auto shifted pretty well, especially since you could put it in 'S' (surely that isn't for "sport"??!! That thing had zero or even NEGATIVE "sport" about it!) and shift through the gears manually with the gear shifter.
    It changed gears more often than I expected if you left it in 'D'. I find that annoying but that's one of the many reasons that for any car I actually own, there have to be three pedals.....
    Was it a new Swagger Wagon, or the previous generation? Only the SE is tuned to be even remotely sporty.
    On my 2007 I only select gears manually when I'm driving up a steep hill (to lockout overdrive) or when it's snowing (to lock out 1st gear).
    It was the new model, but there was no swagger about it, it was just an LE with roly-poly handling and absolutely no driver feedback from the steering wheels.
    I have driven the previous model quite extensively, and I can report that the auto trans in the new one is very sensitive to any change in gas pedal position - the thing will shift gears all over the map if it thinks you want more acceleration. Indeed, it's totally over the top. More responsive, yes, but better? No. Especially since you can use the shifter to select the gear you want to be in.
    But that's why three pedals are the best way.....no computer trying to read your mind and CONSTANTLY getting it wrong.
    I have a RAV4 while my Subaru Forester is in the shop, and it is the first Toyota I have driven in the past ten years or so. While the suspension is very nice for the type of vehicle and it does have pretty decent steering feedback, the gas pedal is feather-light, meaning it is hard to keep a constant speed as you go over frost heaves, bumps, etc., as any movement will cause your foot to push or release the pedal. That part is quite annoying. In addition, it is an AT, which means I find myself stomping the floor looking for the clutch quite often. :blush:
    I will be very happy to get our car back!
    Does the RAV4 have the 4- or 6-cylinder engine? I spent a few weeks last fall test driving almost every small SUV on the market. My mom's best friend had just divorced her husband and wanted to trade her 4WD Suburban for something a lot smaller with better fuel economy...then again, almost ANYTHING is smaller and easier on gas than her truck-a-saurus!
    We looked at the RAV4 and test drove it with both engines. With the 4-cylinder and automatic transmission, acceleration was barely adequate. The A/T was designed to upshift as soon as possible and, once it gets into 4th gear it doesn't downshift willingly when you need to accelerate quickly. The only way to coax a downshift at 55mph or more was to floor it and wait for a few seconds. It reminds me of my mom's '86 Olds Cutlass Supreme. If you floored the gas at highway speeds, you could hear the 4-barrel carb (sounded like a jet taking off) but it took several seconds for the transmission to give you a lower gear. The noise was instantaneous, but increase in forward velocity took a while. =)
    The RAV4 with V6 has TOO MUCH power, at least in the FWD version. Who needs 269hp in a small SUV??? It was difficult to get moving from a stop without barking the front tires. I can only imagine how fun it would be in the rain!
    We also drove a Subaru Forester and it was one of my two favorites. The Hyundai Tuscon was the other. I was surprised to find both of them with manual transmissions on the dealer lots! But the Tuscon is only available with 5MT on the stripped base model. The Forester offered it on a few trim levels and the dealer told me that they sell quite a few with the 5MT. Subaru drivers are a different breed than the average car buyer, and that's a compliment! Most of the ones I know prefer to be involved in the driving process, which translates into preferring a manual. BTW, I was very impressed by the Forester with the 224hp 2.5L turbo, even though it still has the outdated 4-speed automatic instead of a more modern 5- or 6-speed. We also drove a 2.5X Premium with the manual shifter, but she decided that she'd be happier with an automatic!?!?
    To my disappointment, she decided that her favorite was the Ford Escape..ugh! She ended up with the Mazda Tribute, a sibling to the Escape and Mariner. The Mazda version saved over $2000...mainly because the dealers just want to get rid of them! The one where we purchased her Tribute told me that it was only the 3rd one they had sold al year (and this was in July).
    I checked out the Mazda3 and Mazda6 while we were there. I was pleasantly surprised to find so many of them in-stock with the manual transmission! Mazda and Honda seem to be the only ones who actually stock manual models. The vast majority of other cars that offer a manual transmission must be ordered by the dealer, rather than keeping them in stock.
    Honestly, I am not certain, but I strongly suspect it is a 4-cylinder. It is the AWD version rather than FWD, but it is January in Fairbanks, so the roads are (and have been for months now) encrusted in ice. Since it has your run of the mill stock all-season tires on it (far better than Subaru's OEM rubber for the Forester, though), I am not going to say it does poorly on acceleration because I can easily break it loose. The rubber does well enough to zip it along at 60 mph comfortably (for me, but I love winter driving!) through minor twists and turns, and I didn't have any problem coaxing it to hold speed on the hills. I only drove it 30 miles, though, so hardly enough time to vet its virtues and faults. Even so, I like the power delivery of the EJ25 (always have), and have so far managed to steer clear of the turbo as a matter of principle (because I know I would love it), so I doubt I would be too harsh on the RAV4 4-cylinder even on dry pavement.
    I find that when it comes to power delivery, it is all about feeling the car, not forcing it.
    To diverge a bit, the interior of the RAV4, while spartan, is quite comfortable. My wife liked it immediately more than our Forester for two reasons (and reasons often cited, even though I cannot say I agree): 1. The headrest is not as intrusive (read that PERFECT in my opinion!) as the Forester, and 2. The center console area is narrower, allowing more room for the right leg.
    In terms of purchasing, though, we didn't seriously consider the Forester's competition simply because the drivetrain of the Subaru is so vastly superior. It is the kind of car in which my wife can feel comfortable driving our children to school in the midst of an ice storm (well, she might not be comfortable, but she'd still be willing to do it), and I can turn around and not hesitate to plop them in the back seat for a light off-roading adventure on some snowmachine/dog-sled trails.
    Have any of you seen that episode of Alaska State Troopers on National Geographic where the Trooper makes a visit to the "Fairbanks Ice Track?" Well, I spun that car around the track a time or two, then took it over the dike and ran some trails on the other side. I just don't see that RAV4 doing either of those things very well. ;)
    "Swagger Wagon" refers to the SE model, FWIW.
    Steering is numb and artificially heavy on mine, too. Haven't sampled the new 6 speed, though. Mine has the 5 speed auto.
    4 banger for sure. The same V6 easily breaks traction on dry pavement in my heavier minivan.
    Here in Cda, the Tucson doesn't offer AWD with the manual. :(
    And that one also had the very intrusive head restraints. I think you will find that this is more of an issue if people sit with the seat back more upright than others. Also, tall people will find it less of an issue cuz as you raise the restraint it goes back with the angle of the seatback.
    I like the seatback fairly upright (not all the way tho) cuz of my ruptured disc in my back. I can touch my toes, but forget about leaning back more than a couple of degrees.
    Interesting about driving on the snowmobile trails. I wish we could do that here. They will arrest you for trespassing if you are caught on them in anything but a snowmobile with a paid-for sticker.
    Snowmobilers especially hate ATVr's here for some reason. And because the trail is frozen, it is not like the ATV's can gouge the trail...it makes no sense. I guess tho after a fresh snowfall they can leave some mark if they are aggressive. We all seem to be our own worst enemy all the time..
    As for Subes, my only comparo experience regarding AWD and autos...the only AWD i had that had the most trouble with my hill if i stopped and tried to take off in the middle of it, was my XT6. It was an auto and Subaru does not manage torque to the rear wheels the same as the 50/50 split with their manuals. I have had all the AWD's over the years, and the very best was your typical viscous coupling set up, and of course a truck type 4x4 setup were you lock the fr hubs and then have 2 to 3 to 2 WD. The absolute best AWD I ever had, and wish i had bought that car new, was an 88 Camry 4 cyl, stick 4x4, viscous coupling which had an optional-use locking centre dif sw on the dash. Amazingly I only had to lock it once and it was after it had turned mild and i was pushing through 4" of slush-type dense wet packy snow, that before it had turned mild, was hardpacked frozen highway-like road base. ANd the most amazing thing about the Camry, was it had worst tires for winter I have ever had since living here...summer oriented quiet, smooth type all seasons.
    edited January 2011
    I can definitely believe that regarding the Camry! My family had an '85 Camry FWD but, even so, it did exceptionally well in snow/slush conditions, though I am really not sure why. It had decent all-seasons on it (we lived in eastern Oregon) and we didn't see that much snow, but we never had any qualms with taking it out in inclement weather. My father did have chains for it, but I cannot remember using them more than twice when we had to deal with moderate snow drifts. When the snow started drifting, though, you usually stayed home because no wheeled vehicle is going to get through 5-20' snow drifts! Essentially, all of the cut banks would simply fill with snow as if the roads had never been carved.
    When my wife and I purchased our first car as a couple back in 2000, I was looking for a 4x4 Camry or Corolla (1991ish), but they were a scarce commodity. We found a couple that were thoroughly trashed, but no more. So, we went with our 1996 Outback (auto - the wife wouldn't consider a manual at the time).
    Regarding the snow trails, all the trails I use in the winter are 4x4 / logging trails in the summer, so I don't see how they can really gripe about the multi-use. Share and share alike, I say....
    edited January 2011
    I read your jump the dike post this morning and then ran the in-law to a doc's appointment an hour away. Coming back home, I took a left at a T intersection from one little highway to another, and lost it going between 25 and 30. There's a convenience store on the corner with two driveways and I managed to steer in one driveway at about a 30° angle to the conveniently empty parking lot. Couldn't clutch the AT so just let off the gas and steered.
    If there had been a cop around I would have eased up to the door and gone in for a coffee. As it was, I just whipped back out the other driveway and continued down the road like I intended to do that. :)
    My wife lost it at the same intersection about 6 weeks ago going in the other direction. There's good plowing here and that spot is well sanded. I was hoping to get through the winter on my Avid T4s (5 years old, 24k), but maybe I need to rethink.
    Buy dedicated winter tires on separate rims. Winds up hardly costing anything since your summer tires last longer. Much safer in the snow and ice and no more slide through/around intersections. I like to say. Not being able to go doesn't get you hurt, it is not being able to stop that does. AWD or 4wd does nothing to help you stop, but good tires do.
    I hear you on hitting the clutch in a pinch - it sure is nice to be able to instantly freewheel. Another advantage of a stick in the snow and ice. Also being able to instantly cut and add power really helps when you are trying to rock to get out of a rut - much better than an automatic.
    edited January 2011
    When I drove the Outback down from Anchorage to Boise, it had studs mounted on steel rims. In Boise, you drive to the snow, so I sold the spare set of rims and tires and got around fine on all-seasons. Little did I know I'd be moving back to the snow belt in a few years. :sick:
    I'm having trouble remembering now. I think I can rock the car easier with the AT that I could with the manual when I get stuck in snow. The last time I got stuck in my 5 speed FWD Tercel, I had to crawl under and kludge the chains on. It was just a little ol' bitty ditch that I couldn't rock out of.
    Of course, rocking didn't help a few weeks back when I got stuck on the shoulder making a U turn. Had to shovel each of the wheels out about 3'. I suspect that digging is easier on either transmission.
    Hahaha; I inspired you to get frisky with the slick roads! Sounds like you pulled it out in the end, though. ;)
    Heh, I was hauling my 85 year old mother in law and trying to be careful.
    The heck with the transmission type, it's the tires (ok, maybe a little bit the driver :blush: ).
    With an MT you don't have to change gears to rock, just engage and disengage the clutch. Much faster than shifting gears.
    With the AT you do have to shift gears because the car is still going when you let off of the gas. So if you are comparing shifting gears in both, then AT may be a tad faster in some cases depending on the configuration of the shifter.
