The Future Of The Manual Transmission
1131132134136137205
    So, I take it that your OBC's AVERAGE MPG computation doesn't slowly decline as you sit idling at a traffic light.
    edited May 2011
    Let's not lose sight here and just remember that the MFD. scan gauge, etc, etc., are really just a GRAPHIC "behaviorial modification" tool. The real issue is for EACH situation, variable, environment to activate the lowest fuel draw throttle position. So the more of these one strings together, the HIGHER the fuel mpg,. The lesser of these one strings together, the LOWER the mpg. In effect, that is what hypermiling is all about. The manual transmission delivers in most cases , greater structural mpg and probably more importantly greater range.
  • oregonboyoregonboy Member Posts: 1,650
    MPG = miles / gallons :)
    zero miles / 1 gallon = zero MPG :(
    zero miles / 50 gallons = zero MPG :surprise:
    It never goes negative.
    Maybe if you coasted downhill in reverse? :P
    It doesn't display negative but it most definitely "goes" negative. Burning gas while stationary will ALWAYS "negatively" impact MPG computations.
    If you take a look I think you'll find that modern day automatics on the highway are outperforming stick shifts by a goodly amount.
    That's due to the torque converter being bypassed the majority of the travel time and the aforementioned fuel cut technique. The Automatic's ECU can shift down sequentially 4 times or more to sustain minimal engine RPM doing coastdowns. Can you imagine any stick driver being consistently attentive enough to do all those downshifts and at precisely the right time...just before the engine RPM gets to low...?
    Personally I find that I sometimes fail to "properly" upshift into top gear, 6th in my case, unless or until I happen to notice the tach indication.
    edited May 2011
    I have looked and reported numbers do not support your opinion/hypothesis. As we have discussed in this thread and probably others, there are scantly enough numbers of M/T's to compare it against A/T . A lot of passenger vehicles do not offer M/T to again a scant few that are so called "base" models. The macro of this is of course the 80 A/T /20 M/T % split in the passenger vehicle fleet. Secondly, on automatics that you can compare it with say the VW Jetta TDI DSG vs 6 speed manual the EPA numbers have of late (so called "modern" automatics are the same 30/42 each. The real world numbers are in (STILL and remain) favor of the 6 speed manual by app up to 17% that I have seen. So while BOTH can and do hit the EPA nuumbers, again the real world range of the 6 speed manual is larger.
    Longer term, the 03 TDI 5 speed manual is ahead of the automatic by easily 5-7 mpg. (app 17%) And either of these is considered a fuel miser @ 46.5 average vs 39.7 mpg
    Wrong again. Your "instant MPG", as you called it in post 6703, NEVER "goes" negative.... it goes to zero. That will reduce the average over time. Which will. as you said, " 'negatively' impact MPG computations". But that is just putting spin on the original misstatement.
    Perhaps that was your was of admitting that you were in error? :blush:
    I think the biggest factor driving this is gearing. In most cars whose AT variants use less fuel than the MT versions, the AT has a very tall overdrive that allows for very low RPM at highway speeds, while the top gear on the manual is shorter and the engine turns higher RPM at the same speed.
    On a side note, gearing is also why there are a lot of cars where the highway mileage penalty of going to the bigger/more powerful engine is very small, or nothing. The version with the bigger engine gets an extra gear, or a taller top gear. Check out the MPG on a Toyota RAV4 with the V6 vs the 4-cylinder.
    I don't think that saves as much fuel on coastdowns as just pushing in the clutch.
    edited May 2011
    "..admitting...you were in error.."
    No, it was the OBC programer's choice, or program spec. writer's choice, to not have the computation continue beyond zero. Your instant gas mileage does in fact go negative at those times just as reflected in the continuing declination of average mpg computation.
    Or maybe it was/is a simple display shortcoming, no ability to display a minus sign.
    Did you by chance flunk math...? I got all the way to algebra II before flunking out, bailing out, actually.
    "..just pushing in the clutch..."
    Just pushing in the clutch will still require enough fuel to not only keep the engine idling, at the same time power must be provided to the the A/C compressor, the alternator (ENTIRE electrical system), the power stearing pump, the water pump, and the oil lubricating pump.
    Have I missed anything, maybe that 300 watt stereo..?
    Some time ago some marque (MB, BMW..??) began installing a higher than normal size 12 volt battery and then, up to a point, only allowed the alternator to be functional during coastdown periods. Regenerative braking in its simplest form.
    With an automatic in coastdown fuel cut mode all of that power is provided via the drive wheel traction. Think of it as REAL-TIME regenerative braking without the HV battery.
    Your instant gas mileage does in fact go negative at those times just as reflected in the continuing declination of average computation.
    NO, it goes to zero. While you sit at a light, or whatever, you are using some amount of fuel, and traveling zero miles, thus an instantaneous zero MPG.
    Please explain to the room how you can travel negative miles.
    You're either being to literal or tongue in cheek.
    Whatever, Bye.
    edited May 2011
    Yet another classic statement of yours:
    "If you take a look I think you'll find that modern day automatics on the highway are outperforming stick shifts by a goodly amount."
    When I said "classic", I should have said, "classically incorrect". While there are a few (as in very few) automatic transmissions out there which turn in better EPA estimates than their otherwise identical sibling with a manual transmission, I don't believe there is even one example that shows a margin of more than one or two miles per gallon; so much for a "goodly amount". The flip side is that in the majority of cases, the manual transmission equipped cars equal or better their automatic equipped stablemates.
    Don't believe me? Cool, look it up.
    Then there's the whole "EPA estimate" thing; anecdotal evidence suggests that cars equipped with manual transmissions have a much easier tiime consistently besting the EPA estimates by relatively huge margins while the automatic world has a difficult time even matching said estimates.
    "that's because you are in neutral. Try going downhill, in gear, foot off the gas. "
    I have - same result
  • colin_lcolin_l Member Posts: 591
    wwest appears to have been attempting to say that the behavior negatively impacted economy, not that the actual MPG was negative, which is of course impossible.
    What I can't figure out is why he didn't simply state this.
    Yes, it adversely affects miles per gallon. Of course.
    No, you cannot accrue actual negative MPG. It goes no lower than zero. If you were tracking gallons per hour instead-- for argument's sake, pretend your Porsche is an aircraft or something ;) -- that also goes no lower than zero but has no real ceiling and can rise very high.
    The other major argument over the past few days was in regards to fuel consumption while coasting. Of course the engine when coasting is still consuming some fuel. If it were not, the engine would cease running. Try this with a very low tank and you'll see. Just as you cannot idle without fuel, you can't coast without it either. The fact that the throttlebody isn't open means nothing. All fuel injected engines have idle circuits just as carburetors had before them.
    edited May 2011
    That's the crux for me, and at least in an automatic, coasting keeps the engine turning allowing the fuel to completely shut off. So it's more fuel efficient to coast downhill at 70 mph than it is to idle at a stop light. And it's more fuel efficient to coast in drive than in neutral.
    People report that their factory manual says that fuel injection shuts off under deceleration. Others say that the fuel injectors will only go to zero pulse if the catalytic converter is hot enough, and perhaps if the engine is going at least 1500 rpm while coasting.
    Or so the theory goes. :)
    The hypermilers are all out with their Scangauges figuring out how fuel efficient their cars are in various gears, whether their car's ECUs actually allow the injectors to completely shut off, comparing coasting in gear with coasting in neutral, shifting manually through D-3-2-1 to keep the fuel shut-off turned off, etc.
    edited May 2011
    Each oem engineering arm is free to approach the problems/issues in their own ways and come up with solutions. From the various feedback, it does not appear to be (MANDATED) standardized solution.
    I think also with the push in the new 2012 35 mpg fuel standard for those engines in those cars that do not have a SOLID place in the new scheme/schema/pecking order, there will be a constant improvement effort from minor tweeks to all out effort (spare no expense) to boost mpg. "No fuel draw" downhill or at rest throttle position is one "minor" one.
    So for example, the idle shut off option that the Toyota Prius has (and for years) will probably become more common place. I understand that the oems have for years been putting them in selected models in Europe. So depending on how much one idles, it can range from .5 mpg (barely measurable) to 1.5 mpg (my swag).
    In the overall picture, "the sword is dangling over the head" of the (SLUSHBOX) automatic transmission. 1% to 17% better mpg (with the older than the hills. 5/6 manual transmission with engine management and gearing tweeks) are really very hard to ignore. So for example, the population bearing the DSG (better mpg than the slushbox and lesser than the 6 speed manual transmission) is almost not measurable. Hybrids with their almost EXTREME price premiums, offer a only an app 20% mpg advantage. However again it truly depends on the conditions you find yourself driving in. Hybrid population is est @ less than 2% and that is after more than a decade of policy support and full court media press.
    So for example VW went from a slushbox to a DSG (-7 mpg off the 5 speed manual) and essentially the EPA mpg is @ par with the 6 speed manual (30 C / 42 H) In mpg terms that is a pretty good solution. As I have said before in real world terms the mpg on the 6 speed manual can be STILL up to 17% better than the DSG.
    Another hard to ignore issue is the 20-40% better fuel mileage of a TDI ( and mated to a 6 speed transmission).
    When you put the various factors together with higher mpg as a goal, the results can almost be astounding. So for example, 03 VW Jetta the gasser 1.8 with automatic gets real world 24.1 mpg. The 03 TDI with 5 speed manual gets 46.5 mpg. The mathmatical translation: mpg on the diesel with manual transmission posts 92.9% better. From the diesel side the 1.8 gasser with automatic is 48% worse.
    You can bet your BIPPY that all automatic manufacturer's INTENTIONALLY bias the EPA extimates in favor of manual transmissions. There is an actual human in the driver's seat throughout the EPA driving simulation testing procedure.
    The one's "driving" an automatic have a rather easy time of it. On the other hand the ones "driving" the stick shifts must be CONSTANTLY ATTENTIVE in order to have the car in the absolute PROPER, most OPTIMAL, gear ratio throughout the driving simulation.
    Now, just what percentage of the public owner/drivers of stick shift will be that constantly attentive...?
  • cdnpinheadcdnpinhead Member Posts: 5,631
    Never happen, based on what I've read here over the past several weeks.
    edited May 2011
    Then if you'd bet that way, you'd have lost some serious monies !!!
    Let me call your attention to the 2004 Toyota Prius EPA bru ha ha. Toyota advertised 60 C and 50 h mpg. While this is a swag, there were a lot of NON Prius owners who bought where mpg was a high priority.
    UPSHOT this small small small minority of folks (dissed and pissed Prius owners) was able to change the EPA test which had existed for 3-5 decades to change the tests in favor of ... hybrids (Prius). Even at that, Toyota took easily 5 years to get back to even 50 mpg and it took a HOST of redesigns and modifications to do so.
    Indeed one has to be WAY more attentive driving an AUTOMATIC transmission than stick owners to get the advertised mpg in the favored vehicle PRIUS.
    Let me put it another way. If I drove the Prius the way I drive my TDI's I would get FAR less mpg than the Prius !!! If I drove my TDI's like you have to drive the Prius to even come close I would get far better mpg than the Pruis !!!!
    Yes, by a goodly amount...
    Given that just a few years ago now automatics were falling far short of stick shifts in this area.
    The core, fundamental, differences between automatics and manual transmission have been the losses associated with the torque converter and ATF pump in the automatic.
    About 10 years ago now the constant pressure, ATF line pressure, was done away with in favor of a new "real-time" ATF line pressure control design. There is no substantive level of ATF line pressure unless the transmission is in the process of shifting from one gear ratio to another.
    The second development was the result the adoption of a more robust torque converter lockup clutch. Nowadays the Torque converter need only be in the drive line if the road speed is such that the traction load would stall the engine.
    As you can see, it is likely that these 2 developments alone brought the automatics FE up to a par with the stick.
    Then there is the need for constant attentiveness on the part of the driver, the inadvertent biasing toward the stick, and the practical, REAL-WORLD, FE comparison suddenly becomes questionable, VERY.
    The icing on the cake comes from the adoption of the fuel cut technique. Even if done on the stick shifts it will forever remain dependent on the whims, constant attentiveness, of the driver to match the newer automatics.
    The future of the stick shift will now go the way of RWD.
    Only of use/desire in the sporting, sports use, world.
    edited May 2011
    Again the population of A/T and M/T is app 80%/20 %. The real reason manual transmissions will probably lose population share is mpg past standards (25 mpg and the upcoming 2012 35 mpg) is not really a national priority!!!!!!! .
    We also talk about cutting consumption, green, etc.. However, consumption has NEVER been higher !!! The end (REAL) goal, as consumption GROWTH grows slower (104% to 103% to 102%), year over year is that prices of per gal fuel will RISE !! That is on no less an authority than PO's energy secretary. If I may paraphrase him. WE/They have to find a way to get the price up to European prices @ app $10.00 US. If and when that happens (unless they have by then an automatic transmission that can out perform a manual transmission) you will actually see an upward M/T trend. Europe is upwards of 90% manual transmission.
    Just saying it (over and over and over again) doesn't make it so. The fact remains that very few automatics are able to eeek out even a single mpg advantage over their manual siblings in the automatic biased EPA tests. You can talk (write) all you want, but the numbers simply don't back up a single word you've written.
    You'd think that if manuals helped the manufacturers meet CAFE standards, they'd be cranking out a lot more of them and offering driving events at the dealers to show people how easy it is to drive them.
    You are right. One may as well argue with a fence post. :sick:
    As for Mr West's assertion that negative MPG exists: the only way to do so would require either negative fuel consumption or negative miles traveled; hence my earlier joke about coasting downhill in reverse to achieve the negative 99 MPG that he claimed at idle.
    It's really not that difficult to understand.
    WHAT? I am going to bias my results on something that makes my car cheaper with lower transaction prices and lower profit margins? Riiiiight.
    edited May 2011
    In actuality it is the low sales numbers that allow the manufacturers to get away with the FE "deception". High enough sales numbers and the buying public would begin complaining about the HUGE disparity between the EPA numbers and the real world FE.
    In the meantime the low sales, high profits, CAFE contribution, are all to the good. Sales only to the manual transmission affectionotoes who are not likely to complain about the FE disparity, or even take notice, apparently.
    edited May 2011
    Passenger cars with stick shifts have now become a "boutique" market, higher prices for a less expensive to build vehicle. You haven't noticed that automatics have become standard equipment whereas stick shifts are now a higher priced option..?
  • stickguystickguy Member Posts: 53,928
    Part of the differential (on the highway at least) must come from gearing. Especially on smaller engine cars, you can end up at 2700-3000 rpms at 60 in a stick, while the AT is loafing along at 2000 or so (+/-).
    Seems to be a Toyota I4 engine mounted in some unknown vehicle. Does unknown vehicle include a F/awd system..?
    I think it's the way you name the systems that had me confused.
    There is no AWD Sienna 4 cylinder.
    There is a FWD Sienna 2.7l 4 cylinder.
    I read F/awd as "Front or All Wheel Drive". Now I'm thinking you meant them as one in the same, i.e. a system that switches between those two modes.
    My 08 Miata is geared ridiculously short. Some times when I'm in 6th I think I'm in 4th. The revs are high enough that it feels unnatural.
    6th is taller than 5th on the 5 speed manual. The auto is geared much taller than either of the manuals.
    You get good throttle response on the highway, but I still think 6th should be a tall cruising gear.
    I think it's more of a matter of only the top sporty model offering a manual, in some cases.
    But you see plenty of manuals in the compact and sub-compact segments.
    My 2001 Miata was like that, but at least you could conceptually justify it (being a tiny sports car and all).
    What amazed me more was that the Scion tC I bought (with the torquey lump of a 2.4l camry motor) was geared darned near as short. Probably doing close to 2900 at 60 in 5th gear. And absolutley no reason it needed to be that short. Now, if it had a deep overdrive 6th gear too, it would have been fine!
    I think the issue really is what the combination is optimized for. On a 03 VW Jetta TDI, 2700-3000 is really at the upper limit of the sweet spot. I can cruise at any of the RPM mentioned, all day/ night (or 672-700 miles) and still get 48-50 mpg. Of course, I'd be cooking along at 80-95 mph. In that same car if I peg it at 75 mph with bursts to 80/85 to fight road hypnosis, we are talking app 59 mpg (826 miles)
    New categories - "we have 12 mostly new categories like Most Wanted Car We Can't Have, Most Wanted Exotic, Most Wanted Cheap Car, Most Wanted Fuel Sipper, Most Wanted Hatchback, Most Wanted Hot Rod Division…things you actually care about."
    2011 Edmunds' Inside Line Readers' Most Wanted Awards
    edited May 2011
    "Passenger cars with stick shifts have now become a "boutique" market, higher prices for a less expensive to build vehicle. You haven't noticed that automatics have become standard equipment whereas stick shifts are now a higher priced option..?"
    Let's see here automatic versus manual pricing:
    Acrua TSX: same price
    Aston Martin DB9: Automatic $5,300
    Audi A3: Automatic $1,480
    Audi A4: Automatic $1,300
    BMW 1-Series, 3-Series, and 5-Series: same price (new as of this year)
    Buick Regal: same price
    Cadillac CTS: Automatic $1,250
    Chevy Aveo: Automatic $925
    Chevy Camaro: Automatic $1,170
    Chevy Corvette: Automatic $1,250
    Chevy Cruze LS & Eco: no automatic availability
    Chevy Cruze 1LT, 2LT, & LTZ: same price
    Dodge Challenger: Manual $995 (includes LSD, engine, steering, and trim changes)
    GTB Fiorano Coupe: same price
    Fiat 500: Automatic $1,000
    Ford Fiesta: Automatic $1,095
    Ford Focus: Automatic $1,095
    Honda Accord Coupe: Automatic $800
    Honda Civic: Automatic $800
    Hyundai Accent: Automatic $1,000
    Hyundai Elantra: Automatic $2,250
    Infiniti G Coupe IPL: Automatic $1,900
    Kia Forte: Automatic $1,000
    Lotus Elise: no automatic availability
    Mazda Mazda3: Automatic $800
    Mazda Mazda6: Automatic $1,000
    Yeesh! I could go on but you get the idea.
    So, let's look at this list; there is one (yes, count them, ONE) car where the manual transmission is an extra cost option, and that option includes extra goodies not on the Automatic trim. Call the Dodge Challenger a wash price wise. With this one exception, where are all of the cars with stick shifts which "are now a higher priced option?"
    'Nuff said!
  • tallman1tallman1 Member Posts: 1,874
    Right next to all those "automatics on the highway [that] are outperforming stick shifts by a goodly amount." ;)
    There's no question that automatics help the manufacturers meet CAFE standards, by shifting to the top gear as early as possible and robbing the driver of every last ounce of driving enjoyment he might otherwise have.
    Automatics, in addition to hybrids, are also the reason that EPA dumbed down all its numbers in 2008, so that buyers of auto-equipped cars couldn't squawk as much about how their cars weren't meeting the fuel economy standards displayed so prominently on the window.
    So now we have this ludicrous situation where automatics are finally achieving fuel economy that is in the range of the EPA numbers, while manuals are now wildly exceeding them at all times. Me, I just take the highway number and add 5 to know what my average fuel economy will be, and I'm always spot on. ;-)
    I would agree. Essentially what you described is the real world drill.
    Then there are a few of us who get 1 or 2 mpg better than the EPA rating on our car with the automatic (and that's before they reworked the rating - now I get ~4 mpg better in town than the EPA rating).
    I think when you drive a car like a grandma...er...environmentally conscious law biting model citizen in the community, it doesn't matter so much which trans you have and you can get sticker or a lil better. If you drive somewhere between normal and aggressive, however, I think the manual takes a smaller hit than the auto. Chasing my friends around on road trips in 3 generations of Accord manuals, I have always beaten their Automatic MPG and similarly with a G35 6-speed manual and my friends automatics.
    edited May 2011
    Essentially you seem to agree with the past posts I made on greater range of mpg with the manual transmission,( msg #6711 to cite just one).
    If I may add to your Honda example/ issue, they have actually done pretty well in the equalization of EPA mpg (M/T vs AT). So for example, on my Civic the epa difference between M/T and A/T is minus -1 mpg as I recall. I would also swag in a M/T, far better than the 38-42 mpg I now get with the A/T.
    Gee, I know some grandma's who are comfortable and safe cruising @ or close to xxx speeds. (hard to make it to grandma status, if grandma kills herself in a car wreck) I hope you are not hanging around a bunch of folks who had their licenses pulled (or close to it) because of age related health issues, and ...STILL drive.
  • volkovvolkov Member Posts: 1,306
    So I decided to do some experimenting. There are many places I just coast as our city is a bowl.
    In my 5MT WRX only the steepest parts of the big hills allow me to coast in 5th. All moderate hills just slow me down if I leave it in gear and then I have to add throttle defeating the purpose. 2L/100km is the lowest the computer will read out for fuel consumption, so I have no accurate idea of whether coasting in gear on the really steep sections is better or not. I do know that there are only a couple of places I can do it. There are some very shallow hills I drive all the time, and with pulse to 35mph I can glide in N (or clutch pedal in) for 1/3 mile, and show lowest consumption. In 5th with clutch engaged maintaining the same speed, consumption registers 2-3 times higher, and I slow down if I don't use the throttle.
    As to the premise that AT do a better job, our Suburban coasts downhill in gear on the bigger hills, but if I swap between N and D, the fuel consumption is 1L/100 km better in N than D.
    Of course, this is using the computer read-out, and not a scan guage, but it should be internally consistent in both cases.
    So I did a very quick search for the nonbelievers who can't seem to do it themselves.
    Would you believe the folks at popular mechanics?
    How about Jeremy Clarkson?
  • joeyrabjoeyrab Member Posts: 65
    More proof that we Americans are getting lazier and lazier.
    God forbid you drive a manual and have to put down your Starbucks Latte and cell phone....
    I rock an iPod and a BlackBerry and drive a stick; of course the BlackBerry runs through my JawBone and my iPod is controllable through my steering wheel controls. :)
    Oh! And I hate coffee, Starbucks included. :P
    edited May 2011
    I was just going to say, my vices are my Blackberry and my Super Big Gulp (and the occasional hamburger and fries when I am REALLY on the run) and none of them prevent me from driving stick......welcome to the age of hands-free connections.....now I just have to get one of those Camelback-thingummies to dump my Super Big Gulp into, and I will truly be hands-free! :-)
    Misinformation regarding zero-fuel use coastdown mode persists here, but thankfully and thermodynamically it does occur perhaps ONE BILLION TIMES DAILY (!yes!) daily in fuel-injected vehicles worldwide. For example, every fuel-injected vehicles manufactured since ~1980, or late 70s.
    This all helps to keep oil imports lower, thankfully! Hoo Rah!
    If WW's and others misinformation were true about fuel being required during coastdown, the world & laws-of-physics would indeed be different and posterior porcine aviator egress would be rampant everywhere !
    In truth, the zero-fuel-use-coastdown mode is equally useful/used/unavoidable regardless of diesel vs gas, or manual vs automatic. Many people find zero-fuel-use-coastdown counterintuitive - perhaps they are ignoring the energy input from the wheels being turned by the road.
    in the thought experiment world, try this one, it's fun:
    make the vehicle weigh 100,000 lbs and have it turn an electric generator on the way down that loooooong hill.
    then with an onboard tesla coil or a really long unreeling extension cord or traintracks third-rail-in-reverse, you could power a whole town with the energy, as well as powering all the car electronics/etc, all with zero fuel use.
    A good/analogous question for the train/subway buffs is whether trains regenerative braking can apply power back into the third rail to power cars going up a hill further down the track? Why not? Probably no manual transmissions in trains, huh? (don't make me go find one example of a train with a manual transmission just to make it relevant to this forum, ok?)
    Also, don't try to run a modern car downhill or any other way zero fuel in the tank! Many of them have fuelpumps cooled by the fuel itself. With no fuel and empty tank on your long downhill zero-fuel-use cruise, your fuel pump will cook itself trying to maintain fuel pressure even though no fuel is being injected...
    All the electronics will run fine at 13.8 Volts DC all the way down the hill, powered by the alternator which is turned by the road/transmission/gears/etc.
    cheers - see you all in a few weeks - keep up the manual transmission talk/clamor/demand and let's all clamor for the 2013 CHEVROLET CRUZE DIESEL with 6-SPEED MANUAL TRANSMISSION !
    The world wide market gets so called "American" diesels, why not US ??
    That post about coasting was absurd. No passenger car uses 1 gallon per hour. More like .15 to .4 gph at idle. At a reasonable .2 gph that car would get 150 mpg at 30 mph and 300 mpg at 60 mph. Really makes me lose faith in Popular Mechanics.
    My Accord confirms this. I get about 300 mpg coasting down hills at 70 mph (on scanguage).
    General rule of thumb is you get about 4 times your speed in mpg if you coast in idle. So 30 mph = about 120 mpg. 15 mph = 60 mpg. Obviously the slower you go the less advantage to coasting in idle.
    BTW I would love a Cruze diesel with 5mt. Especially if they gave us the wagon/hatch or a little more leg room in back.
