Visitor Agreement.
So the oem's have responded. So for example, the 2003 Jetta TDI 1.9 T has a 19 to 1 compression ratio. You almost have to listening and know the diesel sound to really (differentiate) know anymore.
If the mazda's high compression creates more low end torque, then that, mated to a manual transmission, would be a good thing.
The thing about a lower mechanical compression ratio is that the manufacturer can then boost the motor even higher (thus producing even more power) without reaching certain mechanical limits (i.e. clearances and mechanical stresses).
For "OUR" roads and freeway systems, there is literally nothing better than the turbo diesels and mated to a 5/6 speed manual transmission/s.
This is NOT to imply that I am unhappy with the Civic.
BMW - EPA
2012 Mazda 5 Sport Manual - Short Take Road Test
Lord Vader, your mini-minivan has arrived.
BY JUSTIN BERKOWITZ, PHOTOGRAPHY BY PATRICK M. HOEY
May 2011
VEHICLE TYPE: front-engine, front-wheel-drive, 6-passenger, 5-door van
PRICE AS TESTED: $20,040 (base price: $19,990)
ENGINE TYPE: DOHC 16-valve inline-4, aluminum block and head, port fuel injection
Displacement: 152 cu in, 2488 cc
Power (SAE net): 157 hp @ 6000 rpm
Torque (SAE net): 163 lb-ft @ 4000 rpm
TRANSMISSION: 6-speed manual
DIMENSIONS:
Wheelbase: 108.3 in Length: 180.5 in
Width: 68.9 in Height: 63.6 in
Curb weight: 3393 lb
C/D TEST RESULTS:
Zero to 60 mph: 8.3 sec
Zero to 100 mph: 23.7 sec
Street start, 5–60 mph: 8.6 sec
Standing ¼-mile: 16.5 sec @ 85 mph
Top speed (governor limited): 124 mph
Braking, 70–0 mph: 186 ft
Roadholding, 300-ft-dia skidpad: 0.78 g
FUEL ECONOMY:
EPA city/highway driving: 21/28 mpg
C/D observed: 22 mpg
Shell
The stick-shifted Mazda 5 tested here isn’t dripping in evil black paint, it’s not especially powerful, and it doesn’t turn asphalt into pudding with its tremendous power. We still feel justified in calling it Lord Vader’s van, though, as long as we’re speaking Dutch, in which vader simply means “father.” What we mean is that the Mazda 5 with a six-speed manual transmission is the ultimate dad van.
More Power, More Ratios, More Refinement
A manual transmission goes a long way to ease the sting of what is, simply put, a dorky family vehicle. But dorks and nondorks alike will find much to appreciate about the 5. Although the 2.5-liter four’s 157 hp and 163 lb-ft are something to brag about only to friends who are still piddling around in Lancia Appias, when paired with the six-speed manual transmission, they proved enough for an 8.3-second run to 60 mph. That’s a significant improvement of 0.7 second over the time we got with an autobox-equipped 5.
original
Pulling off that 8.3-second sprint required an abusive launch that netted a bit of torque steer (surprising from a vehicle with only 163 lb-ft) and an immoderate amount of wheelspin....
But it's amazing that a Mazda5 will be the pants off of a sports car from the 60s.
Update: I just looked at Mazda's write-up on their new SkyActiv-D engine for the first time, and guess what? Yup, you guessed it; a compression ratio of 14.0:1. Go figure.
Edit: Forgot to mention that, given my druthers, I'd opt for a diesel with a low mechanical compression ratio and a high boost limit versus the other way around. Why? The lower compression ratio engine will be able to generate a significantly greater amout of power for any given displacement.
I can't agree. I've found consistencies with real-world vs EPA only within a manufacturer. For example, I could exceed EPA highway in 2 Hondas, in 2 Nissans, and in 2 BMWs I've owned. I was always 2 mpg below EPA highway in 2 Chryslers and 2 Mazdas.
I would say it had to do with automatic vs manual, but 1 of those bimmers and 1 of the hondas were autos.
So for me, personally, I need to look at which manufacturer I'm dealing with and adjust accordingly.
say spirited stirring? But when my wife is aboard I can meet or exceed the EPA
ratings. Yes,she keeps my "speed demon" in check.
My point was just that you can't compare an EPA rating in one car to your personal experience in a different car. Now, if one goes on a site that collects real world mileage experience and it shows that Miatas and 5-series get similar mileage, then we have something to talk about.
I do have some anecdotal evidence to add to that. In a mix of city traffic and two lane back roads, I've been averaging between 26 and 27 MPG in my Miata. On the same route, my old '98 BMW 323 got about 21-22. Both cars are 5-speed manuals.
My Lexus gets a tad over 17 MPG. Ugh.
Living in such a cold climate, I take a massive economy hit in the winter that affects my overall averages. The combined estimate on my Forester is 22 - I have averaged 23.4 (calculated) after 27,000 miles. The Escort's EPA combined is 28; mine is just under 31. I strongly suspect that each of those numbers would be at least 1 mpg better in a temperate climate. I will say, however, that these cars, with manual transmissions, do fare better in winter driving than their automatic counterparts! :shades:
My GF turned to me...my head started to recoil like a turtle into a shell...and she said:
"Man, that was some sexy driving!"
Must be more than that, my computer display and calculated FE have both improved by over 12% now the good weather is back.
I use one of the tripmeters to log long term and set it for winter when I put on the snows and change when the summer rubber gets put back on. The combination of winter gas, cold weather and squishy tires really adds up. The difference for my wife's Prius is over 20%.
I wound up with the Accord (which I preferred, but the nearest dealer was 180 miles away and warranty work is a pain). Sure the Camry is not sporty, but I will take a Camry with a stick over a 5 series with an automatic any day.
BTW I read the take rate for the stick is about half on the Fiat 500. Not bad.
I fear the Accord will be next. They have already cut the stick off of the higher models alienating half the stick drivers. ( would love an SE with leather and a stick). The resultant slower sales of stick will help them justify cutting it in a few years. Looks like a Passat diesel may be my next vehicle - of course they just dropped the wagon.
I struggle with the taste of US car buyers. Normally I would say to each his own, but people making stupid decisions (big SUV over a wagon etc.) effect what is available for me to purchase.
Ouch! I'm thinking I'd rather have a clapped out old Rambler with a "Three on the Tree" before I'd have either of the above.
Between summer and winter, yes, there is a huge difference in economy. I record all my fills and have a pivot table set up that summarizes by month, but I haven't gone through it to look at the difference between the warmest six versus the coldest, or, for an even starker contrast, the three most extreme of each.
I was simply thinking about fuel economy in terms of climate, though. In temperate regions, the cold is not nearly as long or as sustained, but there are still moments of cold and "winter blend" fuel is used, so there is an economy hit (even if not as pronounced).
Even in Prince George, I doubt the hit is as severe as it would be in Whitehorse or Fairbanks. I could be wrong, though!
A friend of mine with a Prius ("older" one at this point; '06 perhaps?) said her economy is 30-35 in the winter and 50-55 in the summer. What is that, about 40% or so? I don't think my gas engines are quite that different, probably more in the order of 25%, but they don't have as much rotational resistance in the winter as a hybrid (nor a huge, cold, battery bank!).
I have always wondered why they don't offer a warming blanket for the traction battery in the Prius or other EV's. A friend's EV Ranger conversion will go 75 miles in Summer no problem, but won't even start up if left out at -30. It has become a 3 season vehicle as a result. A second plug in battery warmer would fix that.
BTW I mispoke just pulling the 20% figure. She consumed about 6-7l/100km in winter and 5l/100 in summer. That's more like a 30% swing depending on which denominator you use.
I do plug in my vehicles (block & oil pan heaters on both) if temps are below zero (F) - most of the time anyway. I sure don't appreciate the -22F limit on the temp gauges that are installed on Subaru's and Toyota's. We spend a large chunk of winter below that mark!
Looks like that would be easy to kludge up and you could even power it with one of those flexible solar panels fixed to the roof with magnets when you aren't parked in the garage.
I forget who said this originally but it so happens that I drive a Five series Automatic (2000 528iA) and I 'd rather drive it than any large FWD sedan even if I could still drive a stick. I bought mine used so it cost about the same as a new loaded Camry but I never even considered one.
Rear Wheel Drive Rules!
I'll start.
The base model Acura TL used to come with a very nice 6 speed manual. Now it's gone on the base model. No way to get it for love or money.
I'll start:
2011 Buick Regal
Beats lighting a charcoal fire under the car (don't miss that, lol).:shades:
Sounds nice.
My 5er with a stick was simply the easiest, best balanced, and most enjoyable car to drive of any vehicle I've ever strapped on short of a late 1980s RX-7. Like it or don't, believe it or not, a new 535i 6-Speed manual is an absolute dream to drive.
Another poster on here probably hit the nail on the head with me. If I actually took a German car out and test drove one I'd probably quit criticizing them all the time. Took a drive in a friend's 2001 VW Jetta this weekend and it's 5-speed shifted very well and the car was quiet on the freeway, too. A nice car, though somewhat cramped feeling. Oh well, it is a compact car, what do I expect, eh?
Our 2008 Mitsubishi Lancer GTS compact would probably feel cramped to passengers, too. Doesn't diminish my love for it, though.
I gotta go standard tranny next rig and stick to my guns this time. Demand a stick. We are so retarded in this country...on the phone they said my Lancer would be a 5-speed stick. When I got to the Mitsubishi dealer, the car was gorgeous in their showroom but it was an automatic CVT! What the? The kid working sales for them doesn't know the difference between a stick and an automatic...and he was drawing a paycheck from Avondale Mitsubishi in Avondale, Arizona. Am I missing something or is that retarded to high heaven, folks? :sick:
Conversely my 1995 BMW M3 had a fantastic clutch. It was relatively firm, but not like a V8 Mustang/Camaro. It had a longer, easy to feel engagement range. And the shift linkage of the 5 speed ZF was like magic. It could effortlessly and precisely go into any gear at any speed with no slop.
Switching from the 540, which shifts like a truck, to the GTI is always a shock and takes me a 3-4 runs through the gears to readjust. The MR2 is definitely closer to the GTI in shifting ease. I'd probably rank that as #3 behind the 350Z.
