-mike
-mike
-mike
-mike
As far as the wheels go, the only one that can determine if they look good or not is yourself. You are the owner of the car. Have fun with it! Dress it to your personal appearance and how you like it. You are the one who should care the most about it, everyone is always going to have their subjective opinion on cosmetic upgrades no matter what you do to it. If you really want a suggestion on a wheel that is popular with that vehicle, then go to your local tire/wheel shop and they can give you suggestions since they install custom wheels on these vehicles all the time. If you want uniqueness though, that would be up to you to decide.
Good luck and have fun!
-mike
i will be very thankfull.
i dont really wanna swap the engine yet, i jus wanna enhance the performance of the engine like super or turbo charging or changing the cam. those sort of things.
-mike
-mike
-mike
I'm a gung-ho kind of guy, as is evident, cause i have never really worked on cars very much. i have the talent, just not the experience.
I need to know exactly how transferable these engines are. like, will i need a new tranny? will i need a new distributer?... actually i have no idea what else i will need besides the engine.
I have a friend who did this very same swap, but he isnt all that accessible. (work and school and stuff) so I need help from you guys.
any info you can spare would be awesome, web sites, tutorials, anything!
thanks!
JensAroo
-mike
someone told me it would be more time efficient to just put a 2.0 block on my 8valve head
is that true? will i need a different tranny? (cause these trannys swap, but the 16v has different gears) different computer? different wiring?
ugh
thanks!
As a mechanic who worked 15 years in a Volkswagen shop I´d pretty much like to help you. But as I learned meanwhile, the US-version engines sometimes are significantly different from their original German/European counterparts.
As 8valve gasser the old ´90 Jetta was available here with 1.1, 1.3, 1.6 and 1.8 liter engines, and I guess your´s is a 1.8 liter.
In general I can tell you that the 2.0 block definetly would´nt match with the 1.8 8V cylinderhead, due to bigger bore and different gasket layout. It doesn´t make much sense anyways, because basically it´s the 16V cylinderhead including the multipoint injection system being responsible for increased power. You will have to swap the entire engine and related auxiliaries to obtain satisfying results.
If you could check out the engine codes (the Passat 2.0 16V should be 9A) I might be able to give you some advice.
Could anyone out there help me?
I recently over the weekend swapped a 94 Camry engine for a 92 Camry engine. Reason being was that the rod had cracked the block of the 94, thus the swap. At any rate, the fuse boxes on the two engine are different (do not ask me as to why is that). We dropped the engine wired everything up to fit the fuse box for the 94 even though the engine we put in the car is a 92. Now the problem is the car will not crank, although everything else is working properly. We checked and re-checked the wiring.
Now should we re-wire the harness to fit the 92-fuse box since the engine is a 92?
Please can someone help me?
I was wondering if anybody could help me? I was thinking about doing an enigne swap on my 1989 Nissan Pulsar NX Coupe. It already has a 1.6L and I want to upgrade to a 2.0L GTI-R. Could this swap be done? And if so, what all parts do I need. Like mounts, fans etc. Some people say that it could be done but the problem is finding a front wheel drive manual tranny that will line up to the engine. My car is FWD and the pulsar GTI-R engines only comes with AWD Transmission. Has anyone out there did this swap before? Thanks guys I'm new to this site so I jus Want to say hello to ALL!!!!!!! :shades:
The other issues include wiring harnesses, ECUs, maybe a cross member. I've done swaps of WRX motors into 1st Gen Imprezas and it's usually a PITA due to a lot of things not working/aligning properly.
-mike
-mike
-mike
I'm not sure why you'd want to mod a 2-year-old top-of-the-line nissan pocket rocket anyway. ???
-mike
i realize now i misspoke in my last post. I said I don't know why you'd want to mod the car, but what I meant was I don't know why you'd want to replace the engine. Mods, of course, are always welcome.
