Visitor Agreement.
Also, addressing concerns that leach engine power like dragging brakes, under-inflated tires, poor wheel alignment, and worn suspension components is critical.
Once you know you fixed everything BROKEN on the car, intake and exhaust (which arguably make more noise than power) are about all that there is in that motor. Be nice to it and let it save you gas money while you save up for something faster.
One mechanic told me I have several oil leaks from these areas that need to be replaced, distributor 0-ring, valve cover gasket and oil pan gasket. Also, after running for a while my engine light goes on. Can this be making my Honda shake a lot?
Will a nice tune up fix the problem?
I already coughed up $700 over 2 years since I had it. I really don't want to spend more. Thanks
Cybercool
These can also be DIY items. Valve cover and spark plug holes is pretty easy. I haven't done an oil pan, but I have done distributors and don't remember them being terrible. You should look into a factory shop manual or a Haynes/Chiltons at the very least. Your local library should have those as well.
You can pull the code for the check engine light and it will help you debug the problem. There are instructions on how to pull codes in the repair manuals.
No, that sounds like a motor mount issue. If a timing belt was installed with the balance shafts out of phase, that could do it too but I would be more inclined to think motor mounts.
I wouldn't cry about spending $350/year to keep a 15+ year old car on the road. If you are worried about spending that amount, you aren't in a place to be looking at performance modifications.
Cybercool
When starting up my 93' Accord, gas already in tank, engine cranks after long startup. After adding more gas (regular) I noticed hesitation when depressing gas pedal. I had a friend install a new fuel pump back in Dec 2007. Can this be a fuel gauge pressure problem? Where should I start to look for problems? I don't want to spend too much $$$
cybercool
-mike
I'd like to know if adding a cold air intake part and flowmaster rear exhaust will add more HP to my accord and maintain a nice oxygen flow system?
Cybercool
-mike
I read online somewhere it said the cold air intake part and flowmaster will allow more oxygen flow and will control better fuel consumption. Is this somewhat true?
I don't want more loudness, I've seen flowmasters that dont make too much noise, it has that nice varoom sound.
Thanks, Jim
-mike
One thing I've heard about with those air intakes is that the air filtration isn't so great - which makes sense given the claim increased air flow.
The problem I see with these is that with the modest gains you might get in performance, you're also allowing impurities to enter which would otherwise be filtered.
Depends upon what you're after but, for my money, I wouldn't bother - you're just setting yourself up for problems down the road.
Just my 2 cents...
Also helps the environment cause it is re-used rather than thrown away!
-mike
I am curious if anyone has done this yet and if they were happy with it. There is a HUGE front sway bar available as well, but the 2+ hours of removing and re-installing the front cradle doesn't appeal to me (gotta love Honda, like how on the '93 you have to take the entire suspension apart to replace the front brake rotors...).
So, 4 cylinder Accord, 17mm rear bar, front strut tower brace...looks like its south of $200. Anyone done it?
Let us know how it works out!
-mike
Motorsports and Modifications Host
I am scrounging for parts right now and we will see how it goes. I am not expecting miracles with stock 205/60R16s either. Maybe a lottery win will get me to 215/50R17s.
I think these suspension "tweaks" will be the first mods and maybe next year look at soft-sports or the H&R "OE" series springs and Konis or Bilstiens. A little lower, a little tighter would be nice.
I don't now who this manufacturer is, but an N/A car might see 10 hp from a good reprogram, often at the cost of torque in the case of a modern engine, but no mileage improvement. What a reprogram often does is set the timing permanently to a higher octane fuel. So, in order to get those extra 10 ponies, you'll be required to use premium in your Accord.
Steve, is there a forum on Edmunds (that I could maybe direct cski to), talking about car stereo?
We don't really have a generic, all encompassing stereo discussion. Most of the make/model discussions have a stereo discussion.
That's how I found myself here, thinking 'modifications' might have audio chat.
ateixeira, "DVD/Entertainment Systems" #407, 4 Jan 2013 9:05 am
Or just go there and go up a level to Maintenance and Repair and start a new discussion.
