Visitor Agreement.
My Miata has clearly been in a scrape or two...the paint on much of the driver's side of the car is nice and shiny, but the passenger side front fender is quite faded. That said, the car drives solid and with some maintainence / upgrades that I've done, it performs so well that most people believe my car to be 5 years old rather than 15.
I also pulled and dismantled the EGR valve. Its a nice unit, with an electric stepping motor and a valve passing hot exhaust gas. I use good detergent regular fuel (major brand) and the valve was in clean & in great working order.
After reading info from Autotap.com, I realized the O2 sensors are cheaper to replace every 100k (with the timing belt). Evidently, a bad O2 sensor can ruin the 3 way catalytic (CA) converter and cost you some major bucks.
Luckly, the 3way passed the smog test but is now performing in the mid range of the testing.
Its cheaper in the long run to change the sensors on a regular basis and use good gas.
The computer and check lite in the car can be reset by disconnecting the battery, but the car cannot be smogged until it is driven awhile (50m) and accumulates enough check cycles (computer operational history).
Has anyone else ever seen something like this? I ran continuity and it says it is grounded. HELP!! :confuse:
I also would like to know what did you do to have the coil replaced at the dealer...
Also, it is pulling to the right a bit. We are not too concerned about this (planning on getting it aligned asap), but any information about the pulling would also be appreciated.
Chuck
Pls help. I am nearly bald now... :mad:
and received the same code. Did you replace yours?? or have it replaced??
Was it difficult?
So, I had normal tune-up (plugs, wires, filters, etc) and the light stayed off for a while, then came back on solid. The coil pack was replaced in May05 (2 of them?) and light went out again. Now it's back on again, with code P0291 (? my mechanic doesn't write well - it's 291 or 241) that states 'warm-up cat efficiency bnk #1'.
Can someone suggest next steps on this? I've read quite a few forums today and see all kinds of suggestions, but haven't seen anyone mention this particular code.
Anyone have a suggestion to correct this?
Ron
I have a squeel from the left side on mine, might be brakes, because the pitch changes with speed and when I apply then. Anyone think it might also be a wheel bearing or axle issue?
I'll probably have time to look at it this weekend.
-juice
I think 99s or 00s had some clutch chatter.
Besides that you don't see much of a pattern of problems. These are very reliable cars and pretty much always have been. If miles are high consider a compression test, look for no more than 10% variation in pressure between the cylinders.
If it was not starved of oil the engine will last forever.
-juice
Some things to keep in mind:
90-93: The first of the first NA's with the 1.6L motor and (this was important for me and my 4-year-old copilot) no passenger ari bag.
94-97: Motor was stroked (I believe) to 1.8L and the passenger airbag arrived w/o a shut-off switch. The shut-off came in...
99-00: First of the NB's. Still the 1.8L motor but now a shut-off switch is in the picture.
01-05: NBs now have VVT and the recommendation for premium fuel with the tremendous 2 hp gain that comes with it.
If you're going for an oldie, the overall condition of hte car is far more important than miles, packages, etc. Around here, good Miatas from this era were tough to find...I ended up travelling about 3 hours.
Good Luck
I have a black top so can't help you with the tan question.
Aftermarket wires tend to be better and last longer. The current ones are fine after 30k miles of use.
Any used model you get, you should do a full service on it to get a "baseline" so you know how old all the fluids are. Even if you get receipts, IMO.
For instance, the seller showed me a receipt for a full 30k service, and I found that indeed they had changed the front diffy/gear oil. But not the rear. It looked like melted chocolate and was overdue for a change.
So do it anyway, even if the seller can provide proof of servicing.
-juice
90-97 was called the NA, 99-05 was the NB, the new one is the NC. As the NCs arrive the NBs seem older, so prices should come down even further.
Supply is plentiful, they've sold about half a million of these!
-juice
Good luck in your search.
does the noise on the left side get louder as you increase your speed?? and does the noise reduce or disappear when you press your brakes?? I had a similar problem if it is this problem that when I drove faster, the noise from the left front tire side became louder. When i took it in to check out the problem, my bearing had to be replaced since it was a bad one. Maybe thats what you have.
Anyone has any idea on whats going wrong here and how I can fix it.
KP
It's strange, intermittent even. I guess a squeel that sounds like the brake wear indicator and yes it is speed dependent. It change pitch when I apply the brakes, but that still might be the bearing under a different load.
I'll jack up that side and see if there is any play with the rims. Time to rotate the tires so I'll check the brake pads too.
Any symptoms in particular to look for, besides a little play?
-juice
Tops - cloth looks a bit better to most folks, and some said it's more durable. Still, I've stuck with vinyl up until now. My original top lasted about 10-11 years, which is fine IMO.
-juice
I have a 2000 Miata that had this problem all summer. I had the 60K check up done and several other trips to the station about this in particular. I really appreciate the help because it's been driving me crazy! Last weekend I didn't think it was going to "kick in". I'm headed to the dealership tomorrow to get those things replaced - just wanted to express my gratitude!
-Matt
Mgray
On my Subaru, the lights blink at first. A few cycles and it goes back to normal.
Worth a try if you have keyless.
-juice
Here are the instructions for resetting the radio code.
For most 1990 - 1996½ factory radios:
To determine if this radio has been set with an antitheft user code, remove battery power from it for at least 45 seconds. When battery power is restored with no user code set, the radio's operation is immediately restored. If a code is set "cod e" flashes in the radio's display.
When "cod e" flashes in the radio's display after battery power is restored, and you know your antitheft user code, the radio's operation can be restored by following your Owner's Manual "If Antitheft system is Activated" procedure. If you don't know your antitheft user code, or to remove one previously set, follow the same procedure three times entering an invalid 1 to 4-digit user code each time. Once an invalid 1 to 4-digit user code is entered three times, "err" flashes in the radio's display. When flashing "err" displays, the radio is now set to accept the following re-set procedure.
Press the # 1 button
Press Stop/Eject
Press Am/Fm
Press Clock Button
-- -- -- -- Will appear.
Enter code 4 9 8 9
Press F/Forward & Reverse at the same time and hold for a couple seconds.
The code should now be removed. Follow the instructions in your manual to set a new code.
-juice
Any and All ideas are requested. How/where is the Injector Pulse sent from. I wonder if the rat could have gotten under the hood one night and cut that wire, but I can't see any damage in the injector area or Cam Angle Sensor area.
http://www.sgforums.com/?action=thread_display&thread_id=160157&page=0
A CAR saleswoman who took a customer out for a test drive on Saturday evening, died after the man lost control of the sports car and veered into oncoming traffic on Upper Paya Lebar Road.
The brand new Mazda MX-5 flew over the road divider, smashed head-on into a black BMW, flipped over it and came crashing down into a van in the other lane.
The driver of the silver Mazda managed to stagger out of the badly-crushed car alive, albeit a little shaken up.
But the saleswoman, Ms He Xueli, 20 , broke her neck as a result of the impact.
Paramedics also found that she had suffered a cardiac arrest.
She was rushed to Tan Tock Seng Hospital but died an hour later in the operating theatre.
The driver of the Mazda, a 24-year-old warehouse supervisor, has been arrested by the police and is out on bail pending further investigations.
