Mystery car pix
17197207227247251421
    robr2robr2 Member Posts: 8,805
    B2 VW Quantum.
    lemkolemko Member Posts: 15,261
    That's it.
    edited April 2013
    Daewoo ... Nubira I think?
    edited April 2013
    :):(:D :confuse: :shades:
    (no message, but the tools are back).
    That's what one would think it is, but it's not a Nubira. Think Russian!
    Those lazy bums didn't even change the grille!?
    OK, GM tie-in, so I'll guess Chevy Nubira?
    tjc78tjc78 Member Posts: 15,947
    It's a Doninvest Orion.
    ***Cheated w/ Google*** :blush:
    2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
    fintailfintail Member Posts: 57,200
    edited April 2013
    With that grille and headlight assembly, 1986-88.
    To be replaced by the Passat for 90, an even more troublesome car that is virtually extinct on NA roads now.
    That's it.
    Subaru XT.
    That's it. Looks like it could've come out of Darth Vader's TIE fighter!
    Edmunds member RSHolland owned one that made him swear off VWs forever.
    VW is funny, no? They have both extremes. Haters with a bad previous experience, and rabidly loyal fans.
    There seems to be no middle ground among the VW owners I've met.
    Shucks, bad time to leave the computer. Knew that one. paisan owned an XT6 that I drove.
    Funny thing, back in the day my grandparents were thinking of a new car, and I recommended that 1990 style Passat. My young eyes thought it was so modern and German looking, and it was fairly priced. They also didn't have the horrible rep yet. Good thing they actually bought a Taurus - even though those can have issues, theirs was OK. No doubt the Passat would have been on a tow truck all the time.
    I'd roll the dice on a US built new Passat, but many of the others scare me.
    The new one got dulled down. Doesn't do anything for me, though a TDI is always interesting.
    Dull, but handsome enough, and a loaded TDi for ~30K isn't the worst value out there. Probably the most reliable Passat ever, too, as it is shaped for this market.
    With the Accord averaging 30mpg per CR and the Altima 31mpg, the appeal of a diesel (36mpg) diminishes for me, since diesel costs way more than gas around here. You break-even on fuel cost.
    And both of those cost a lot less, and have better tech. Passat doesn't even have a backup cam.
    Wagon's also gone.
    The only real advantage is the excellent range, and Altima is still close.
    Diesel makes sense for larger heavy vehicles. Will be a tough sell on smaller lighter things, as gasoline engine technology improves and mileage shoots up.
    I suspect actual transaction prices on a loaded Passat vs EX-L aren't too far off. But neither are the fuel costs, and the latter will have lower maintenance I am sure.
    imidazol97imidazol97 Member Posts: 27,164
    edited April 2013
    :surprise: > :):(:D :confuse: :shades:
    Did they take off the limit on how many could be in one post?
    :):(:D :mad: :cry: :P ;) :surprise: :blush: :confuse: :sick: :shades: :lemon:
    edited April 2013
    How'd you manage that? When I tried to post the 6th Emotorcon, I got a pop-up that essentially said "enough already". :confuse: :D
    edited April 2013
    imagejpg
    Post. Edit. Add 4. Post edit. add4. :)
    I have been missing the emoticons. It felt good to load up on them in that post.
    Sneaky LOL.
    andys120andys120 Member Posts: 23,398
    explorerx4explorerx4 Member Posts: 19,355
    Ford Atlas concept pickup truck.
    2023 Ford Explorer ST, 91 Mustang GT vert
    Yep, Ford dropped one off at the home office garage today for the rest of the crew to admire.
    If you know the code you can put in as many as you like !!
    grahampetersgrahampeters Member Posts: 1,786
    G'day
    Possibly a Reliant Scimitar, but not sure of model. Proof that Reliant could makes something more than awful three wheelers
    Cheers
    Graham
    Dang, I thought it would last a while but yes, that's a 1966 Reliant Scimitar SE6A
    I'm more familiar with the Scimitar GTE, which I believe was more commonplace>
    None of the Reliants were ever imported here and I have never even seen one.
    On the bottom of the plate with the '5' on it, it says 'Mobil Economy Run'.
    That's correct, the car is an entrant in the UK Mobil Economy Run.
    G'day
    You are better than me on the models. Somewhere in the depths of my memory there is some story of a connection between the Scimitar GTE and the Volvo 1800P. Ogle designed the GTE (and also the Reliant Robin and Bond Bug).
    The Scimitar GTE was vaguely famous in Britain as Princess Anne was given one for her 20th birthday and then replaced it with several later models (some reports suggest eight in total); she is a notoriously quick driver, as speeding tickets and press coverage attest. We would occasionally see her driving too fast when we lived near Gatcombe Park in the 1990s
    Cheers
    Graham
    bhill2bhill2 Member Posts: 2,474
    That is a Daimler (I don't remember the model designation. It may have just been '2.5' because the car had a 2 1/2 liter V-8.
    edited April 2013
    I think they were called 2.5 or 250. D registration suffix would be ~1965.
    Yup, you picked up the ridges on the grille shell that cosmetically distinguish the Daimler V8/2.5 from it's near twin , the Jaguar 3.8/Mk.II.
    The Daimler's little V8 is the same one used in the SP250/Dart roadster.
    i'll take this opportunity to ask a question. Were the differences between the Daimler 2.5 and the Jag Mk. II just the engine and minor cosmetics or were they different in other mechanical ways or in their interiors?
    G'day
    In general, Daimlers were slightly better finished than their Jaguar counterparts. For the 250 V8, this extended to a walnut dash and full instrumentation and I think slightly fancier leather interior.
    In general terms, Daimler models attracted a price premium because they were seen as more exclusive. I seem to remember this was about GBP10,000 by 1990.
    The engine was about 50kg lighter than the 3.2l Jaguar 6 and the stance of the car is different if you see them side by side. I have a vague recollection that springs and dampers might be different as well.
    They came standard with an auto transmission. I have a couple of mates who are mad keen Jaguar fanciers and could tell me all the differences; however my eyes would glaze over first!
    Cheers
    Graham
    G'day
    Well I can place the year as 1956 from the double bill at the theatre.
    Cheers
    Graham
    Side of street with theatre:
    1954 Plymouth with a 1953 model parked close behind it. 1956 Buick further back. Other cars look too grainy. Looks like what might be a 1955 Ford among them.
    Other side of street: 1955 Mercury, 1955 Buick.
    Oh no mystery to former Subaru XT owners---my Subaru mechanic used to call those instrument holders "landing pods".
    on the right, 53? Buick, 55 Mercury 57 Olds.
    Unless there is a very similar car out there, that it is a Checker. If so, it must be a later model, as it has different tail lights than I am used to seeing.
    Nope, not a Checker but it does bear a definite resemblance, especially in wagon form but it has no relation to any Checker and was not even made in the USA.
    G'day
    By golly, you are finding the oddballs. That is a Humber Super Snipe Estate, I guess from mid 1960's. Tail-lights vary by year and this was before the last versions which I think ran up to about 1970
    They were fitted with raised rooves and used as ambulances in Australia, assembled at a plant near my present office.
    A great uncle had a sedan until the late 1970's. They were very posh for their time.
    Cheers
    Graham
