Cabover Campers & Camper Trailers (pickups)
Air cylinders for SCUBA diving are treated the same way, but they must be re-hydroed more frequently than propane cylinders - like every 5 years, I think, but don't quote me.
You might want to have a look at your dates...
The propane cylinder (a pressure vessel) is designed to withstand a certain amount of internal pressure exerted by the propane. The "design" pressure of a vessel is higher than it's "working" pressure, generally by at least a factor of two, or perhaps more. I.e., a vessel with a working pressure of 100 psi would have a design pressure of 200 psi, or more.
Periodically, pressure vessels are tested at a pressure that is 1-1/2 to 2 times higher than the normal working pressure, but less than the design pressure. In the above example, the vessel would be pressurized to somewhere around 150 psi to check for leaks and potential failure.
The "Hydro" part of hydrostatic testing refers to the method of testing, in which the vessel is completely filled with a non-compressible liquid, water for example, then more liquid is pumped in until the pressure reaches the desired test value (it doesn't take but a few drops or cc's to do this, depending on the size of the vessel). The inlet valve is then closed, and the vessel is allowed to sit pressurized for a period of time. If there is a leak, the pressure will drop rapidly.
Liquids are most often used for this purpose because it wouldn't be very smart to pressure test a vessel with air or any other compressible gas, because if the vessel fails you are likely to have an explosive condition, like a balloon popping (maybe a really BIG one, if it's high pressure and/or high volume). If you are using a liquid, and the vessel fails, you only get a little squirt of water.
In my case I have never had a propane cylinder recertified. Buying a new one has always been cheap enough at $20 or so, and it will be good for at least twice as long as a recertified cylinder. In your case, it may be a different story. I have no idea how much the larger cylinders cost. I also don't personally know of anyone who recertifies them, but I am certain that your local propane supplier (Northern Energy, perhaps?) will either be able to do it themselves, or will know someone who does.
Sorry to be so long-winded, but you asked...
Thanks again...
Ray T.
I bought an old pop-up camper last year, a 1977 Venture Buckingham ("the palace on wheels"!). This spring I plan to take it on a long trip, 2,500 miles round trip. The camper was apparently never heavily used, as the canvas is perfect and the tires appear to be original.
Not wanting to drive that far with 25 year old tires on the trailer, I plan on replacing them shortly. So my question is this: should I replace the original 5:30-12 tires with radials that are near in size (is it worth the 30% price premium?), or just go with the same type/size?
While on the topic of bearings, what greases do the rest of you folks recommend? I would like to try a full synthetic some day (like the Kendall blue stuff), but I want some real-world results before I switch over. My uncle turned me on to the red grease, and I have had good luck with it. It seems to hold up much better than the standard short-fiber wheel bearing greases I was using.
Texas Trucker
I've used synthetic oils for years, so I switched to the M-1 grease.
Vince, why would you feel any different about the sythetic ATF? It has the same advantages as synthetic in other applications. I would think a heavily loaded automatic transmission would be an ideal application for a synthetic lubricant.
Mike L
The bearings were recently re-packed, so they should be good to go.
Can't remember the name of the conventional long fiber grease I use, it was recommended in the Dexter trailer axle book that came with my trailer.
As far as trailer tires, I like the old style bias ply for small applications.
For large trailer applications, I have bought my last set of Goodyear ST trailer tires, we seem to kill them when pulling our trailers at 80mph down the interstate, and dragging them hauling butt over 11,000 passes that have rocks sprinkled on the road.
We are going back to LT tires for the trailer, and are going to be AR about covering them from the sunlight while not towing......
Mike L
Where to?
Any Off-Road on the trip?
Mike L
Mike (or anyone else) you want to come along? You can still get a reservation.
http://www.espritdefour.com/
I'm working on signing up. I want to bring Dorothy along as a copilot, so she can overcome some of her fears of offroading. Hopefully, the 'controlled' environment and instructors will make her feel better.
Mike L
Did you get a reservation? I have Doug's email if you need it, he handles things himself.
You can rent a Wrangler pretty cheap, or bring your dirtbike. You can take your PU over a few of the passes....
Vince, what time are you going down? My guess is you're heading down Friday night to be ready for the 8:00 Safety check. I'm bringing the camper. Doug said that is not a problem, and it didn't sound like we were going on any tough trails. Probably simpler stuff than we went on with Steve.
If not, do you want to meet somewhere? We will leave about 6:30-6:45. So we get to sleep in a little.
See you there.
Mike L
We are heading out east....eastern Labrador! and if time permits, Newfoundland also. Then we will have driven to every US state and Canadian province that you can drive to. OK, Newfoundland takes a ferry ride. It looks like it is about 3500 miles from CA to Labrador....about the same as from CA to Alaska!
Doesn't matter where you go, as long as you like it and everybody isn't there at the same time.
Mike L
this summer???
Update on the AUX Battery deal --
Tuns out GM does not intend to make the correction a Service Bulletin. My Silverado Sales Planner gave the following - Quote
The information is now in the TAC (Technical Assistance Center) system
available to every dealer. Because the correction involves changes to the
electrical system, we must only release this correction through authorized GM Dealers. We do this for your protection and for ours so that making the changes don't cause other electrical and computer systems errors.
Please go back to your dealer and have them contact the TAC for assistance in parts information as well as the correct service procedures for this update and change. If the dealer has difficulty getting the answers, have
the dealership use their Lotus Notes system to send me a note and I will ask to have the TAC contact the Dealership Service Manager direct.
Let me know how you make out in the dealership. Thanks! -SC
My Dealer Did and following are the Parts On Order to make it GM Official
PN15372010 -- Cable ASM, AUX BAT POS -Q: 01
PN15372009 -- Cable ASM, BAT POS -Q: 01
PN15305003 -- Block ASM, AUX BAT POS C -Q: 01
PN1517031 -- Nut, BAT POS FUSE BLK CB -Q: 01
1-Remove the aux pos bat cable incl the 125A mega fuse.
2-Remove the aux bat cable between the 125A mega fuse ant TP2 solenoid.
3-Order above parts / Probably before you start #1
4-Install new aux pos bat cable that connects the new block assy 40 amp(Side A) and to the TP2 solenoid.
5-Pull 40amp Maxi-fuse located in Power Dist (UBEC) near Stud 1.
6-Install new aux pos bat cable from block assy 40 amp(Side
Then it goes on which is strange SO not sure if they know what their doing after all --
Note this cable will be double stacked on top of the trailer B positive at stud 1. If the condition we discussed is resolved without completing every step, the remaining steps do not need to be performed. Please communicate your results back to GM TAC by either calling for further assistance if these steps do not resolve the condition or by faxing the closing information using the precall worksheet TA-99. This recommended diagnostic approach was developed for this vehicle based on our discussion over the phone. It should not be used for other vehicles with similar symptons
DAH!!!!
75V
So, after reading the above, is your aux battery working to your satisfaction? I would have to get out my schematics to understand what they are attempting to do. Maybe you already understand it and can explain better?
Mike L
Agree that the country is much better than the cities.
But the young San Juan mountains in SW Colorado are still my personal favorite. And driving a 4wd or riding a dirtbike at 12,500' elevation for miles on end is hard to beat.....
I haven't made it to the black hills yet, though...
Grew up in the East, there really isn't anything exciting for me east of the Missip.
-Main power is connected to one side of the TP2 relay already.
-The other side of the relay goes to the aux battery and to the new 40 amp breaker. This charges the battery when the relay is on and leaves the battery connected to the trailer when it's off.
-The output side of the breaker goes to stud A which has the trailer wire.
-Pulling the 40A fuse separates stud A from the main battery so it becomes just a junction point.
That should do it. You loose the 125A fuseable link between the alternator and aux battery but I guess that's okay. Pretty unlikely the battery will short out. And just to think, it only took six months (?)! Actually I'm surprised the factory took the time to do that. I guess it pays to be persistent.
The only reason for using stud A as a tie point is: that is where the camper wiring terminates. Otherwise, you would run the camper wiring to the aux battery/fuse/relay.
Is anyone planning a trip up here to Alaska this summer if you are let me know I can give you some tips.
Normally, we try to keep weight down low to reduce that top-heavy swaying. Don't know what kind of truck you have, but usually there is room for the auxillary battery under the hood. Most manufacturers install a 2nd battery for diesels, and the space is there for a non-diesel. Then you wire the 2nd battery to the camper and use a relay to isolate it from the main battery when the engine is off.
Another place to mount a 2nd battery is in the bed in front of the wheelwell. Either side. I have one mounted to the camper, just in front of the passenger side wheelwell. The space normally is wasted space. I chose the passenger side because the driver side is heavier from all the appliances mounted there on my camper. That battery is so I can have some power when the camper is off the truck.
The solar should help keep the battery charged when you are parked. I don't know how much electricity you use, but I've never run down my aux battery when camped for a couple of days. And even when I drained it by leaving the refrig on 12V, running the truck for a few minutes brought it back enough for the night.
Mike L
Mike L
Just my $.02 worth.
I remember Ford back in the 70's (?) had a locking door to the outside in that area. I never knew what it led to, I assume a storage bin. I'd love to have such a bin to hold jumper cables etc. Why doesn't any manufacturer offer it? Anyone remember those doors?
P.S. I think the roof is a not a good idea. Raising the cg is bad as mentioned, also if a tree limb or overhang hit it the result could be nasty. In an accident the battery could fly out if not really well restrained.
The battery is tucked up against the side of the narrow portion of the camper. I have a 1/2" plywoood frame for it and some heavy shelf brackets to help support the weight. And I also have a couple of straps from the camper, under the battery and back to the camper. It is a small battery, but it is still heavy and with potholes, etc. the forces can be quite high. I used a wheelchair battery, so it is a deep discharge type, but small like a lawn tractor battery
All in all, I think mounting it to the bed of the truck with a disconnect plug would be a safer idea, but I really wanted some power when I offload the camper.
Vince's idea of mounting it under the bed is a good idea. Some hot rod or race places carry steel battery boxes that could be adapted.
Mike L
So, no I don't have to raise the camper so the battery clears the wheelwell.
On my truck (don't quote me, this from a sometimes defective memory) I have 8-9" from the top of the wheelwell to the top of the bed. With a short battery, no problem.
If I pull the camper off in the near future, I will take a couple of pictures. We are leaving on vacation the end of June, and I don't think the camper will come off before that. But, maybe it will.
Mike L
Heck of an idea. I wish I had thought of that when I had mine.
I'm waiting for a mtn sled that has seating like the REV setup, as a dirtbiker, I really like to stand up, and whoever brings out a REV designed mtn sled first will get my next dollars.
Headed to SteamBoat Springs first week in June with travel trailer. Interested to see if the 8% taller effective gearing (went to LT255/85-16 tires on the 2500HD) really affects my tow performance. Any of yawl that live in southern Wy or N. Colorado, how's the snow load up there. We were hoping to camp in the back country, and dirtbike and flyfish for a week. AZ is so dang dry, they're gonna close the NForests completely in the next coupla weeks.
