Fuel Economy EPA Estimate System
Check the link to see for yourself.
Have a great day!
Tires: 37 psi front/ 35psi rear
60%highway/40%city (one full throttle 0-100mph run just to test her out )
Georgia/South Carolina (25-65F)
This tank: 27.9 mpg (200.2 on 7.168 gal) computer said 29.6 mpg
Last tank on conventional oil--Switched to Mobil 1 synthetic
I have 177k miles on my '96 LX Auto, and get 26-27MPG in my commute to Birmingham (A lot of stop and go with about 50% interstate mixed in).
Time for a timing belt very soon.
My '95 Accord I4's second engine of probaby more than 100K miles "eats" oil (3 quarts of oil for 4 months of over 6K miles). I do not want to spend much money to fix the oil issue. What's your advice? I am thinking about donating to charity to get tax deduction.
Thats progress though. Has to be heavier and more powerfull every year - when will people catch on that the two cancel each other out, and mpg suffers.
We need the diesel!
If you follow the link, you'll see that the 4-cyl actually does just as well under the EPA as the 2007 model, and that the 2008 V6 does better than the 2007.
From the EPA's www.fueleconomy.gov website:
"...Manufacturers test their own vehicles—usually pre-production prototypes—and report the results to EPA. EPA reviews the results and confirms about 10-15 percent of them through their own tests..."
The Gov numbers can be a good guideline, but CR is what the car is more likely to get in actual driving.
I can almost always get spot on (or better) with CR highway numbers. The EPA numbers are all over the map. Some cars do way better, and some do much worse.
I would be very suprised if the new larger heavier Accord is more efficient in real life. They may have changed a few things to make the car perform close to the old one on EPA tests though.
Approx 600 miles of my total mileage has been highway the rest of the miles are trips generally under 10 miles with the engine just warming up. With the very cold December we experienced in New England I was not surprised to see my mileage drop under the 19 MPG stated as my vehicles lower limit. One 8 mile trip home from work took an hour and fifteen minutes due to major snow and the resulting snarled traffic. These winter months aren't going to help fuel economy so as we get into the warmer months I'll occasionally post my MPG and I'm pretty confident they will improve, though I'm not disappointed as the mileage I'm experiencing is right on par with that posted on the sticker.
Though the lower "city" number should not be surprising given the added weight in the 2008 car, that Honda chose to produce a new Accord with lower (instead of higher or, at minimum, the same) mileage than the previous model is a disgrace.
Honda needed to figure out how to get some weight out of its new, larger Accord or somehow further improve their engine technology and they failed.
Or maybe the 09s might get that extra 1 mpg back and then some. The first year of a generation usually has a few kinks. Maybe they'll lose the button-"happiness" in the center stack.
I just filled my tank yesterday, and my MPG for the last tank came out to be 21.88 with almost all city/local driving in cold weather with some snow. That is the lowest ever ever since I started calculated my MPG!!!:( When the weather was a bit warmer(before Dec), I usually average around 27~29 with more highway miles in the mix. My highest mileage was around 32(31.86 to be exact) with about 70% highway. This car is overall great in fuel economy IMO but I still wish it could be a tad better in cold weather. I use 5w20 Mobil1 synthetic engine oil.
I of course expect better mileage comes spring time with weather getting warmer(hopefully sooner) and more highway miles.
It seems you are getting similar mileage... Is your Accord a 4 cyl or a V6? I wouldn't be so worried if it's a V6.
Amen, bro. The winter blend Valero around these parts of our left coast seems to have arrived carrying about a ten per cent fuel economy penalty.
That being said, we can look forward to the warmer, more fuel efficient season ahead where my 6M coupe regularly returns 27-28 around the state capital and pushes the 40 MPG barrier on the Interstate when reined in to about 2200 RPM.
Here's to the Honda engineer: performance and economy!
ez....
3k miles on the odo. I don't drive like a granny, but I also don't wind it out very often either. In my day to day commute I rarely get above 4k RPM and generally cruise around at 2k RPM.
Sporin, if you are getting 27 now, it will certainly get better! I have gotten numerous tanks of over 30 and 29.x MPG after the car was more broken in and with more conservative driving. That's not in winter months, of course.
Based on the average 2 MPG loss I've found on every car I've owned in the winter I'm confident in 28-30 combined this summer. :shades:
2 MPG increase in warmer weather(I expect more) is definitely easily attainable, especially after the car is broken in.
In the city I get anywhere from 25-28 MPG.
On the highway, I've gotten up to 35 MPG(490 Mi/tank!) flat out with cruise.
I didn't take it TOO easy, but I did average 73 MPH on the interstates. Add in about 100 miles of US Hwy (4-lane) with red lights and varying speed limits (35-65).
Winter blend fuel hurt me on this one I believe!
For those who don't know, I have a 2006 Accord EX 4-cyl, with the 5-speed Auto.
My maintenance required indicator came on during my trip, and reached 10% before I filled up at home. I'm dropping it off today to have "B 1,2" performed (I'm at 29k miles).
With that new air filter and fresh oil, I bet I'd have done better!
PS - for those curious about it, my low-fuel light came on at 472 miles while I was taking a sharp curve at the I-65/I-459 interchange. I think it came on a little earlier than normal.
Really, 36 MPG on any trip is more than impressive to me! Gotta take mine on an 100% highway trip to see how well it does
I've made this trip at least a dozen times, but I usually fill up in Birmingham, and then after I get off the interstate, which yields better mileage since it doesn't have the US Hwy driving in it (I've had 40 MPG twice, and typically get 37-38).
I can't complain though!
90% highway/10% city = 22-24mpg
Best tank = 24.8 MPG, Worst tank = 20.2 MPG
Little disappointed I can't get at least 30 MPG on all highway.
Who needs a Civic when you can have a 40 MPG Accord!
This time I had my sunroof "popped" to pull fresh air through, which hurts aerodynamics.
Dudley has gotten similar mileage as myself.
At 55 MPH my car would have to unlock the torque converter, or even downshift to 4th to tackle some of the hills on this trip.At 72 or so, the engine is spinning fast enough to have enough torque as it is (2400 RPM), but slow enough to run VERY efficiently.
I was so surprised when I got this kind of mileage for the first time - tickled to death!
After about 346.4 miles of mix driving (~170 mile highway), I pumped in about 15.89 gal of gas. The mileage per gallon comes out to be an unsatisfied 21.80 mpg. This is almost worst than the EPA rated city mileage. :confuse:
Do you think if there is something wrong with my engine? If this is the case, should I bring the car to the dealer and have them check it out? Is anyone else getting the same low mileage for their 08 I4’s?
BTW winter is killing me. My 10 tank rolling average was as high as 35+ mpg and just recently slipped below 30 mpg. Of course the high yesterday was 2 and I let the car idle for a minute before I load the kids in (-12 in the morning when I started it). And we don't even have winter blend fuel here - not a metro area.
I wouldn't worry about the mpg of a brank new car just yet. The dealer fill may not have been complete. I do think the extra heft of the 08 models may keep them from getting quite the mpg of their predecessors. Of course Honda is always tweaking so I expect better at mid cycle refresh, and the diesel may be here soon as well.
