Visitor Agreement.
Steve - Where'd you get them at that cost? Did you install yourself? Is it difficult to put them on?
oltroll - How bout you? Did you install them? Do you know how much drilling into the frame is involved in the GMC Model? The Web site only had info on the Ford Applications available. I have a 01 GMC 2500 HD ExCab LB. If you have a moment to e-mail the pics, I'd love to see them, Especially the one by the gas tank door. merhow89@yahoo.com
I requested information from Tork Lift via e-mail asking for pricing and a brochure but haven't received a reply from them as of today.
At first I attempted to buy them through a local dealer. When the dealer wouldn't come through I ordered them direct from Central Welding.
My rears literally took 10 minutes to install, they slide into the square cross-tube of my Ford factory receiver and are secured with a simple clamp that prevents them from sliding out, no holes to drill. The fronts took about 15 minutes per side and most of that time was spent using the bolt fish to get the bolts inside my frame rails. On my Ford I have to pull the chain near the fuel filler door slightly to get it open, no big deal.
As for information, if you call Central Welding and ask for Robin she will answer any questions you have.
Steve Heywood
2001 F350 4X4 Supercab
2002 Lance 1010
Don't skip the second battery. It's easy to run a battery down to the point that it can't turn over an engine. Without a dedicated battery you will be nervous and guilty every time you turn on a light or the heater kicks on. Get the battery, relax, and enjoy being warm.
If you want to convert to a power water pump later it's pretty easy. The cheaper method is to use a little hobby-type pump with a switch. My old camper was that way. The other is to install an on-demand system like most campers have. The pump is around $100. Either takes a little plumbing and wiring but isn't tough if you are handy.
I looked at a brochure for a Northstar popup today. It's pretty nice and has options like toilet, shower etc. The dry weight is 1800 lbs, wow. Almost as much as my Lance. They say their campers are a little heavier because of the quality construction.
Talk about heavy, is anyone familiar with S&S campers? Made in Montana. Their largest model, with a full side slide-out, is about 4000lbs wet! And they don't even show them on dually trucks.
I'm reading my camper brochures from the RV show I went to a month or two ago. Lance has the fanciest and largest brochure but they don't give any specs at all. How crappy. The extent of the specs are statements like "large holding tanks..."
I installed an accumulator tank in the water system today. It did stop the pump cycling as advertised. Now the pump stays off longer, then stays on longer, but the water flow is steady. I also wanted it to reduce the hammering in the water lines to reduce the pump noise. A lot of the noise is caused by the rigid water lines vibrating the structures they touch. I used a flex hose out of the pump to the accumulator, then attached the camper semi-rigid line to the other side. This combined with the pump isolation and insulation I did previously really worked great. The pump is just a small background noise now, a world of difference from the stock mounting. I tried to put a link to the accumulator but Edmunds says it's too long. Go here and search for "accumulator" at the bottom of the page, then pick the first one on the list.
https://www.rvpartsoutlet.com
I'll let you know how I like it after I take the camper out next weekend.
cory
The roof should be re sealed about every 2-3 years. If the caulk is yellow and flaking it this needs to be done. Look (inside) at the overhead bed area in the corners by the window for leaks, also around the window. If there are stains in the corner this indicates that the roof needs re sealing, and the front window if the stains are around the window. Check around the toilet mounting bolts for cracks in the plastic. There were problems with some of the early '90 models. Vent caps may need replacing also. Get on the roof to see if the caps are chalky, or cracking. Look through all cabinets for water leaks from the fresh water system, especially around the hot water heater. Check all appliances for operation. Look at the corners where the jacks attach for any deformation, and that the jacks are mounted with the correct number of screws (12 I think but not sure). The tie downs should also be solid with no evidence of being pulled out or over stressed.
I've had mine (Lance 6000) for 10 years and very happy within it. If you have more questions just ask.
Good luck
cory, you may be able to get some help from www.lancecamper.com if you send an email. Or you could try more owner forums like http://www.lanceowners.com. I have some older brochures, if I get a chance I'll take a look.
The advice docsilva gave is good. My camper has cracks around the toilet mounting holes but it hasn't caused any problems. I resealed the roof a year or so ago and it was the first time since new. The old seal was very yellow and cracked but the camper didn't leak. I'm sure this is an area often neglected, you know, out of sight out of mind. Don't expect to find many campers that have been resealed. As long as there is no evidence of leakage then it's okay, you can always seal it yourself. Most campers (and RVs) aren't used much so you shouldn't have trouble finding one in good shape. What I found is that Lances really move fast on the used market so you need to ready to respond when an add comes out. Good luck!
Napa RV Sales has new Starcraft Starblazer fully equipped popups for $6995
Bonessa Bros. has a 4Wheel camper for $7850. No mention of equipment.
http://www.rvtraderonline.com/adbrowseprocess1.html
Mike L
Have a good day.
cory
The Squire morphed into the Lite series later. They may have removed even more stuff to get the weight down. Mine is stickered at 2223 lbs wet. That doesn't include "options" what ever those are, probably the jacks. I've never weighed it but I assume it's around 2500 lbs loaded which would put the whole rig around 8000 lbs. I do need to get out and weigh it.
The jacks cost around $1500 total. I bought the wireless remote version so that added a few hundred. I think the jacks are $1100 or so, and the mounting kit is $200 and remote $200, rounding a bit. That is big money for a convenience item but I'm happy I did it. It makes the camper more useable so I get more out of it. It also makes the load/unload process so much more enjoyable and safe. I just got back from a trip and I used them to level the camper. I may not have bothered with the old jacks in favor of wheel chocks. In this case I pushed a button and it was done. Yea! Installing the jacks was a medium-big job. It took me a few weekends plus many weeknights after work. Mostly it's just slow running wires nicely and being careful when drilling to not create a bigger problem. It's not a job for a novice but if you've done house wiring then it's similar.
I don't take the camper off when camping very often. I usually want it with me when I go somewhere anyway, that is a nice thing about having a camper. The main reason I'd drop it is to go off-road and play. The problem is that you have to come back to the same spot at the end of the day and more often than not I'm wanting to travel and stay each night somewhere new. I hear (mostly here) that RV parks often don't allow dropping a camper. I've done it, and it doesn't take long, but usually I find it impractical for the reasons mentioned.
Ron
http://www.thorindustries.com/scripts/wdb.exe/pgget?st=th_fwork&pg=th_frame&cmp=6&year=2002
Thanks for the confirmation on the horizontal tanks. I'll poke around the web and see if I can find something official.
I guess I'll have to come out of my cave more often.
Jim
Most tanks in the last 4 years or so are OK. I think the new tanks have a triangular shutoff handle on them.
Mike L
If you have any experience with the Michelins or any suggestions I would appreciate your comments.
Ronnie
I do a lot of camping now, but don't have a camper. It's all been tents and open air stuff so far. I'm well into the 50+ crowd now, and find myself becoming a tad less enthusiastic about making and breaking camp. I've been going to Hunting/Fishing/RV/Outdoor shows for a number of years and have always found the time to look at campers. Lots of choices out there.
I have a box-stock '00 F350 CC LWB PSD 4x4. I have a Class IV hitch, though I'm not necessarily leaning towards towing.
If you have a moment, would you mind sharing a few thoughts about what works well and what doesn't? And maybe why, in either case?
Thanks...
The Michelin web site lists performance attributes of their various tires and those lists show that the LTX M/S is better for snow than the ATs.
They are pricier than other brands - I paid around $120 a tire at America's Tire Co.
Now if they are differenst sizes, or load ratings, you better double check.
Mike L
Thanks in advance
Ronnie
What type of camping do you like to do? Do you go off road? Do you stay in campgrounds only or is primitive camping okay? Is convenience really the motivation for a change or are you looking for more, like warmth, comfort etc.?
I'll give you an abbreviated version of my standard speech. Your choice comes down to towing or not. The obvious advantage of towing is that you can drop the trailer and use the truck for local use when camping. In a way that's not so great. I find it very nice to have my stuff with me, and to have a safe haven to retreat to when I'm out all day sight seeing or at the beach or whatever. Also I have a dog and with the camper I can leave the dog inside and go see attractions etc. And of course you can drop the camper and use the truck for excursions. It's not as easy as a trailer but it's not hard.
The other advantage of towing is that you can have a much larger rig. Truck campers can't compete there if that's what you want.
The best thing about a camper is mobility. You get the most important attributes of an RV (shelter, heat, food support) yet you can still go almost anywhere. You don't need to worry about pulling in some unknown little road or campground that you may not be able to turn around as with a full size towable. If you like primitive camping, the camper actually gives you more freedom than tent camping in a way. You have a large water supply and aren't dependent on ice for refrigeration. Plus the weather doesn't matter much. Now, you can't do serious off-road driving with a hardside camper, nor can you squeeze in forested areas that don't have much vertical clearance. But short of that you can go pretty much where ever you want. With a popup camper the off-road limitations almost go away.
Enough rambling for one day. What do you think?
The only one I have experience with is the Tekonsha Voyager. I found that it needed to be adjusted constantly, depending on load (empty trailer vs. loaded trailer, road conditions, etc).
I'm looking at a Tekonsha Prodigy instead. Any opinions out there?
Can someone explain the difference between Inertia Activated Braking(Voyager) and Proportional Braking (Prodigy) in "true layman's terms"?
I'll be towing approximatly 4000 of loaded horse trailer with a 1250 lb truck camper on the box (plus gear weight in the camper). Thanks for any info.
Valves were ~$20 each, plus $10 for two new hoses that feed into the reserve valve.
Have had both filled several times, no problems.
We did the switch over real quick, no air introduced.....
Get the valve with the right sized dipstick/bleed for your sized tanks.
PS. Went to LT255/85-16 Coopers on the 2500HD, love em.
You can also get a fifth wheel unit of the medium variety, again almost without question up to 30'. If you go 5th wheel you loose cargo area in the bed, otherwise it is a very good way to consider.
My two cents about what you should do.... go to a campground and start talking and asking how people like their campers and I'll bet you get invited in to look around. The camping community are some of the nicest people in the country, that is my opinion anyway.
I would strongly advise getting a slide out unit, no matter what type of camper you go with.
Good Luck
P.S. I tow a 27' Terry Resort with my F250 4x4 SC V10 and it is sooooo easy for the truck to habdle it.
I wonder if the propane fill places will know the exemption? Ya right, that is a different problem !!!
Markbuck, where do you buy the new valves? Never thought about replacing the valve - and I have one valve that has gotten difficult to open sometimes.
Mike L
http://www.amistadpropane.com/opd.html#1
I have a horizontal cylinder on my recreational vehicle. Are OPD's available for that kind of service?
Presently, the Code does not explicitly address the issue of OPD valves on horizontal cylinders. This has presented some difficulty as horizontally oriented cylinders that were manufactured prior to October 1, 1998, are unable to be retrofitted with the OPD's that are available at this time. There is currently a proposal in the Code process that would exempt this style of a cylinder from needing an OPD if visibly marked that it has no OPD and was manufactured prior to October 1, 1998, and if none of these safety devices are available for this style of cylinder. While the foregoing is a proposal for the 2001 edition of the Code, it is not now known if this suggested amendment will be approved. Without question, OPD's are still required for these cylinders that have been manufactured after September 30, 1998. An attempt is regularly made to make propane marketers aware of changes in the Code. We would be happy to answer any further questions you may have.
HERE IT IS, DIRECT FROM THE NATIONAL PROPANE GAS ASSOCIATION
http://www.npga.org/
Q: I have a horizontal cylinder on my recreational vehicle. Are OPD's available for that kind of service? :
A: The 2001 edition of NFPA 58 (the LP-Gas Code) recognizes that horizontally oriented cylinders that were manufactured prior to October 1, 1998, are unable to be retrofitted with the OPD's. As a result of this fact, the Code now exempts these cylinders from having to be retrofit with OPD valves. Any such cylinder must have a label affixed to it to inform the user and the refiller that an OPD valve is not installed.
HERE IS MORE
http://damouth.home.attbi.com/Tips/OPD.htm#Recent
Recent Exclusion of horizontal DOT tanks: Owners of older RV's that use horizontal rather than vertical propane cylinders should read the following information:
The new OPD (Overfilling Prevention Device) valves will be required on 4 lb. to 40 lb. propane cylinders from 1 April 2002. However, the currently available new valves are designed only for vertical cylinders and cannot be used with horizontal cylinders. Therefore, horizontal cylinders manufactured prior to 1 October 1998 have been exempted from having OPD valves, provided they are so labeled. (Such cylinders manufactured after 1 October 1998 do already have OPD valves).
This information is on the website of the National Propane Gas Association. See A pamphlet addressing commonly asked questions from propane consumers..
Since propane dealers do not seem always well-informed, it is suggested that RV owners with pre-1998 horizontal DOT tanks should print this article and carry it with them, in case a dealer balks at filling a cylinder without an OPD valve.
The relevant part of the document is on the second page:
A: The 2001 edition of NFPA [National Fire Protection Association] 58 (the LP-Gas Code) recognizes that horizontally oriented cylinders that were manufactured prior to October 1, 1998, are unable to be retrofitted with the OPD's. As a result of this fact, the Code now exempts these cylinders from having to be retrofit with OPD valves. Any such cylinder must have a label affixed to it to inform the user and the refiller that an OPD valve is not installed."
For more information on this general subject, see the following documents from the National Propane Gas Association:
HERE IS A HORIZONTAL TANK FOR SALE, $79
http://www.betterpropaneshop.com/mall/dot_5-20lbs.asp
AND ONE FOR A LITTLE MORE
http://www.rvpartsoutlet.com
MANCHESTER 20 Lb (5 Gal) LP Tank/Horizontal
$93.06
5 gallon capacity propane tank designed for horizontal use in LP compartment. Comes with built-in sight gauge for accurate tank-level monitoring. 17-3/4" OL X 13-5/8" H X 12-1/4" D X 8" B.
http://www.npga.org/public/articles/NFPA_58_State_Adoptions.pdf
Here is a page with a link to another official fact sheet to print
http://www.nfpa.org/Codes/Interpretations/FAQ58/FAQ58.asp
I don't know how comfortable you are driving a full size truck, but you won't regret it when you have the trailer behind you.
You won't get any better mileage with a Dakota V8 than a full size Chevy. While the smaller truck may be more convenient to drive, the large truck is safer. All three manufacturers have 4 door trucks now if that what you want. Go try them out.
But, I've never had anyone check the certification date on a cylinder before they refilled it.
Mike L
My horizontal tanks will be 12 years old soon so I'll go ahead and buy new ones at that time because of age and the OPD issue. Unlike Mike, I have been refused at a fill station due to the tank age in my old camper. I'm sure if you kept trying places it wouldn't be hard to find one that doesn't look but it's not worth the grief for the money in my opinion.
