Honda CR-V Real World MPG
1235717
  • mnfmnf Member Posts: 405
    FYI if you speed in Montana bring cash back in the late 70s when the speed limit was 55 if you were speeding it cost you $5.OO up to 10 over then it would double. Just a month ago had to go over and see some clients I was caught going 92 in a 75 :blush:. Cost $40.00 CASH on the spot it felt like 85 I told the HWY patrol :P
    Matt
  • drive62drive62 Member Posts: 637
    $40 for 17 mph over the limit? We pay a lot more here. With such low fines it seems like they are encouraging people to break the law.
  • harvey44harvey44 Member Posts: 178
    In my experience with Hondas - engine life is a non-factor. The last two that I sold had engines that would have lasted many more years/miles. Other factors came into play. My 98 CRV had perfect compression and a majorly rusted underbody. Sometimes I wonder if changing the oil so frequently makes sense from a cost standpoint. Actually I had a 1971 Volvo "from birth." It had 275,000 miles on it when I sold it and of all the issues it had the engine wasn't one of them. Same thing - all those 3,500 mile oil changes over 17 years might have been a waste.
  • kipkkipk Member Posts: 1,576
    That is a good question and I have wondered the same thing many times.
    In or about 1985 I bought a 1978 Chevy Beauville G20 long van with 350 V8. There were about 98K on the odometer. Oil was pretty dark and it was leaking or blowing a lot of oil. I knew the engine was in trouble but everything else was nice and worked. So I bought it because I knew I was going to do some modifications to the engine for the purposes of towing a 30ft camper for our family
    As it turned out, most everything inside the engine was worn out. About the only thing useable were the block, the head cores, and piston rods.
    It did a lot of towing for a few years and is now basically used for trips to Home Depot, storage and anything else a large box on wheels is good for. The valve covers leak as well as the rear seal (Chevy trademark). The engine is as quiet as the day we rebuilt it and it doesn't smoke at all. The oil is still changed every 5K or once a year these days.
    2003 was the last year it had to be inspected, but even then it always passed with half or less than half of the allowable numbers. This engine has about 100k on it now. I don't believe that we built the engine any better than it was when new. I sincerely believe that reasonably regular oil changes made the difference.
    With todays high revving engines with their tight tolerances, I believe regular oil changes are a good idea. I do it every 3750 miles because of the extended warranties and I don't want Honda to say we neglected anything should there be a problem. However, when the warranties are over It will be every 5000 miles. ;)
    Kip
    I gave up on short interval oil changes too Harvey44. The manual for my minivan recommends a 7,500 mile interval. See the Engine Oil - A slippery subject Part 2 discussion for more on the oil wars.
    Anyone else checked their gas mileage lately?
  • johnny19johnny19 Member Posts: 2
    Just got a new 2006 CRV 2WD LX with automatic.
    Got 30.15 miles per gallon on first long trip with about 1000 miles on the odometer; 350 mile trip with A/C on half the time; 68-70 mph with cruise control. Filled up before and after trip at the same pump.
    I'm impressed! My 1997 Honda Civic only gets 35-36 mpg. The CRV is almost as good!
  • vipinguptavipingupta Member Posts: 21
    I hope your CRV was out of break-in period, as Honda suggestes not to use Cruise control during break-in period.
    When driving in "HILLY" areas, the Cruise control tends to cause a little more shifting of the tranny to maintain that exact speed. Of course the result is varying engine rpm which is good for the engine break-in
    On relatively flat roads the Cruse control will tend to keep the engine at a constant rpm. This is Not good for break-in. :cry:
    Kip
    Good point. I hadn't thought of that, but the hilly terrain on the interstates/turnpike caused some 5th to 4th downshifts going up hills. Not good for gas mileage, but that apparently didn't suffer too much.
    Have you heard of anyone else getting 30+ on a trip? I drive easy, but 70 mph with A/C on half the time isn't 'easy' for gas mileage.
    Last trip we took in the '03 CR-V 4WD with 4 speed auto yielded slightly over 30 mpg for the trip.
    That was with the cruise set at 2500 RPM which was about 67 mph. We ran the air about 1/3 the time. North Georgia X-ways seem to be either up hill or down. Very little flat ground.
    If we had used the AC more, the mileage would have probably suffered more. The 4 cylinder pulling the CR-V's weight and shape is starting to "PUFF" when A/C and hills are added to the mix along with 67 mph wind resistance.IT most always shifted back to 3rd on the longer hills.
    We filled up that morning and again that evening when we got back, at the same pump. Round trip about 200 miles.
    This is not really a good measurement. The gas tank may have been cooler on the first fill up. Therefore it would have held a little more gas when compared to the second fill up due to the tank being warmer from outside air temperature plus heat from the road. The warmer tank could have caused the gas to expand some which would have "filled" the tank with a little less actual gas on a quick fill up. Or, I may have CRAMMED a little more into the tank on either of the fill ups.
    On a 200 mile trip, 6.6 gal would be 30.3 mpg. Adding or subtracting just .4 gallons could yield 2 MPG more or less.
    If you want to "Record" the best mileage, fill the tank with the front of the car lower than the rear. Even better if the right front is even lower than the left. That will set the tank at an angle to let most of the air bubble out the filler tube. Do it on a cool morning so the gas is contacted more than it will be later.
    Then on the "Check the Mileage" fill up have the front end higher than the rear with the left rear at the lowest point. This will allow the air pocket to be far from the filler tube and hard to get rid of. Therefore the tank simply will not take as much gas. Do this during the hot time of the day, when the air and road have heated the tank, and the gas is already expanded slightly.
    Those two conditions will yield a better average than usual. However the needle will fall off the "Full" mark quicker and the next fill up on flat ground will be disappointing! :cry:
    Kip
    Thermal expansion of the tank isn't really an issue. What you should be focussing on is the volume of gasoline you put into the tank and you get that information from the display at the pump. Of course, the gasoline itself is subject to thermal expansion but most gas station tanks are underground meaning there will be very little variation at a given station.
    "Have you heard of anyone else getting 30+ on a trip?"
    I took a trip in NM at high altitudes (5000 ft +). About 2/3 of the trip was at 60 MPH, the remainder was on the interstate at 80 MPH (getting back from Colorado, don't ask how I managed to get that far north :blush: ). It was a total of about 360 miles. MPG was 31.1 as I recall. I should mention that I filled up at the same station before and after the trip, and that I used 88 octane (medium grade) because NM sells 86 octane as regular fuel - and the manual calls for a minimum of 87.
    My normal highway MPG was between 25 and 27 @ 77 MPH. I got around 20-21 in town. But the 2003 had only the 4 speed transmission.
  • saabgirlsaabgirl Member Posts: 184
    ... 31.6. Got it on a trip through upstate NY last summer traveling from PA to CT. I stopped on Rt 17/84 (?) for gas, got right back on the highway, set cruise for 65 mph. 300+ miles later, pulled off at the Roscoe Diner and filled up at the station across the street. Tires were at 32 psi, there was approx a 500 lb payload on board and most of the 300+ miles were through mountains. My CR-V had about 4,000 miles on it at the time.
    Please go back an re-read my post. The tank being heated will cause the fuel inside the tank to expand.
    A cool tank with cool fuel already inside it will accept more cool fuel than a hot tank with hot gas already inside it.
    If you heated the fuel tank itself enough to cause it to expand enough to make any difference in it's internal dimensions (volume), it would probably be on its way to an explosion.
    The volume will vary on temperature of the car's fuel tank, and placement of the car.
    Another factor is how the tank was filled.
    Some pumps are painfully slow while others move along at a good pace. Some folks prefer to fill until the 1st click off. When doing this, be sure you are at the same pump facing same direction with the same pump trigger setting.
    Ever notice how a fast nozzle will click off, then running it very slow will allow some more to be added? Sometimes as much as a gallon can still be crammed in. Fast moving liquids tend to pick up air which causes expansion. Then the air escapes and the liquid settles to a lower level.
    You can test this at your kitchen sink with water. Fill a plastic milk jug at full tap volume. As soon as the water and air mixture get to the top, (Which would shut off a gas nozzle) shut off the water. Watch the level settle. If no more water is added, the jug is not full.
    Now do the same thing with the water running much slower as the level nears the top. It may fill to a point that there is very little or no settling.
    Kip
    That's a matter of heat capacity. Since the mass (weight) of the gasoline you're putting into the tank is greater than the tank itself the final temperature of the tank + gas will be closer to that of the gasoline. Of course, both will eventually reach ambient temperature - long after you have filled your tank.
    Again, you should be focussing on your total miles and volume of gasoline pumped.
    Take a look at the article Steve cited - as soon as we get the link straight! :)
    lol, did it again.
    Try this one:
    Question of the Day - Is Cold Gas More Dense? Part 2
    Thanks, Steve! :)
    ....the final temperature of the tank + gas will be closer to that of the gasoline
    That depends on how much is added during the fill up.
    Driving on blacktop roads the gas and tank can reach very high temperatures. But let's just say the gas temp is 100. The tank holds 20 gallons and it takes ten to fill it with gas that is say 65 degrees from an underground tank.
    During that fill up the average in the tank will be 80+ degrees. Park the car and the next morning you will be able to add more gas.
    I believe that everyone that reads these post can remember a time or two when they filled the tank late the day before and the next morning it was not quite on the full mark or fell off very quickly.
    It is all the little things that add up to make a difference from tank to tank.
    For instance, one afternoon recently I stopped and filled the tank on my Pilot. It took about a half a tank. (10 gallons) The temperature was near 90 degrees and I had been running on blacktop roads. No doubt that the tank and the gas in it were hot. I put about 20 miles on that tank before arriving home. That night my wife decided that we were going to take a 300 mile trip the next morning.
    We left about 7am. The temperature was in the middle 60s. About a mile from my house is a service station. I wanted a full tank for the trip to check mileage. It took 2.1 gallons to top it off. So for that 2.1 gallon tank I had gotten 9.5 miles per gallon on 20 miles of back roads driving 55 mph with no traffic. :cry:
    So what happened? On the day before, It was hot and I most likely sat in the car while it filled at high pump speed. When it clicked I removed the hose. Chances are good that I could have squeezed another gallon into the tank just from the gas settling. The next morning the tank and the gas in it was 25-30 degrees cooler than the day before, prior to adding fuel. I was also at a different pump at a different station.
    Under ideal and very similar conditions, mileage figures will vary from tank to tank. How it is filled, when it is filled, and angle of the car can and will make a difference from tank to tank.
    Over the long haul and several tanks of gas, things will average out to a true overall MPG. However, for tank to tank readings, care must be taken.
    That's my story and I'm sticking to it!
    Kip :)
    Good! I'm sure we glazed over a more than a few eyeballs with our talk about thermal expansion coefficients. ;)
    Carry on!
    It sure wore me out! :sick:
    Have a blessed day !
    Kip
    Well, this article may deglaze your eyeballs in preparation for the work week:
    'Hot' fuel costs billions (Star-Telegram)
  • joebert52joebert52 Member Posts: 1
    I'm 53, my wife a few years younger, and we're both getting beaten-up from normal, in-city driving in our brand-new 2006 AWD Auto CRV. We have 1200 miles on the car, having driven it mostly in-town and some on the interstate. We've also made one 300 mile trip and I first noticed the discomfort at about the 250 mile point. My neck felt like I'd wrapped a blanket around it - it was so tight and sore. Since then, I can't drive it without feeling pain. Not sure if my wife's hurting yet directly from the car, but she is in increased pain...
    The CRV was my first choice and after probably 20 different cars we settled on it because of the firm seat for my wife. It was only after we'd driven it on the road for the extended period that the pain became obvious.
    What's the collective wisdom? Anyone else found that driving a CRV is jolting and uncomfortable? Is there anything that we can do to lessen the pain? Is there anything that Honda can do?
    In regard to the other cars we test-drove, the RAV-4 was even more rough, but a 2006 Forester was smooth as silk! Also, an Accord was pretty stiff in suspension. Are all Hondas stiff and rough riding? Is the CRV stiff because it's on a truck frame and the Forester smooth because it's on a car frame?
    Our brand new, 1200 mile CRV may have to go if we can't make some changes. We may go back to the 2006 Forester, if we can find one, though I still like the Honda better...
    Sorry to hear that the Forester and CRV are both on car frames. It must be a weird deal I owned a Forester 04 but just bought a 06 CRV and have 2500 miles. I have not noticed a huge differance between the two mine both have leather and if anything i think the leather on the CRV is softer the Forester does drive more like a car though. The one thing that I have learned over the years on cars not all are a perfect fit for all. Good luck..>>M
  • stevengordonstevengordon Member Posts: 130
    I'm a year behind you and I've noticed a bumpier ride in my 2004 CR-V than in the 1999 Accord LX I drove previously. You feel the bounce in crossing railroad tracks or crossing bumps or pavement dips. And this is driving around town.
    I compare it to driving a pickup truck. You're higher and the car body reactions to the road terrain translate (or magnify) into body movements.
    That said, my typically poor back and neck condition doesn't seem to suffer when driving the CR-V. Last summer, I drove cross-country, averaging 700 miles a day. No unusual pains or degree of pain.
    My experience is that I get some neck and back soreness sitting down in the typical low sedan (a Civic, for example) and then climbing back out. Not so with the CR-V.
    Wish I had the magic solution for you...perhaps time and seat / seat back adjustments may make you more comfortable. And you may acclimate to the higher and rockier ride. Good luck!
    Interesting, thanks! ;)
    I'm 53, my wife a few years younger, and we're both getting beaten-up from normal, in-city driving in our brand-new 2006 AWD Auto CRV....
    The CR-V is built on the Civic Chassis.
    As stated by another poster, the seating position is reasonably high when compared to a sedan. The higher seating position and taller suspension will result in more MOVEMENT to the occupants.
    I have a '03 Pilot and my wife traded her Maxima for an '03 CR-V when she realized how much better her back felt after riding in a more upright position in the Pilot vs the more lay down position in the Maxima. Another plus is the ease of getting in and out of the CR-V vs a lower sedan.
    The CR-V is more fun to scoot around town than the larger and more cumbersome Pilot. The Pilot seats feel more comfy and roomy, and the ride is smoother. Therefore we take it when we go on road trips.
    After nearly 3 years of owning the Auto 4WD CR-V we took it on a 200 mile trip. I was not looking particularly forward to the rougher ride and "HARD" seats for that period of time.
    Long story short...After just a few minutes on the road, I kind of forgot that we were in the CR-V. When we arrived at the destination and again at home, we both felt as well as though we had been in the Pilot.
    FWIW: I'm under doctors care for problems with both my neck and lower spine. (Too many hours and crashes on cross country motorcycle races when younger.)
    I learned several years ago the benefits of sitting more upright. Many people have the seat back tilted too far back for the "chair" type seating, such as in the CR-V. That will cause strain in the neck and shoulders.
    I am 65 and my wife is 60.
    Kip
    Couple thoughts for you:
    Are you having trouble entering and exiting your CR-V because it is higher than the car you might be used to? My missus has a tender back and will occasionally attibute a tweak to climbing aboard, but has no problem once we're underway. The CR-V has no A-pillar grab handle, but does have a handle above the door and the leading edge of the door can be used for a boost.
    How's your driving position? You should sit upright. You should be able to reach the firewall with your left foot flat on it. You should be high enough to easily see over the steering wheel. You should be far enough from the wheel that your elbows are slightly bent with hands at the 9 and 3 o'clock position. Driver and passenger can get additional lumbar support for cheap with rolled up bath towels.
    My guess, based on your description of your driving pattern and that driver and passenger have complaints, is that the problem may be related to getting in and out of a vehicle with a fairly high stance.
    The CR-V is nimble, and my missus sometimes objects that I whip it around. Could that contribute?
    Do you have running boards? I notice they make people step over them which could stress tender joints.
    Hope you find help for your problem. If you continue to have problem go try a Saab 9-5 on for size. In addition to my CR-V, my missus and I also own 9-5s. IMHO,their seats are ergonomic heaven, perhaps even therapeutic with the warmers turned up to roast. Prices on two or three year old models coming in off lease are very good. Good luck.
  • blueiedgodblueiedgod Member Posts: 2,798
    Some people like SPORT HANDLING and some like boat like rides. That is why there are BMW's and Hondas (sport handling) and Buicks (boat like ride)
    You can try letting more air out of the tires, or checking the tire pressure. CR-V's come off the boat with tires inflated to almost 40 psi to prevent flat spotting, and the dealer is supposed to adjust the pressure to whatever the OWNER's MANUAL says. Short of that, there is nothing you can do. Sport handling is all about the keeping the tires in constant contact with the pavement, not boat like cushy ride.
    CR-V is car based as well, not truck based. Look under it, there is no frame, it is just a Civic on steroids.
  • sky23213sky23213 Member Posts: 300
    A little more on topic, gas is down to $2.51, and that was at the "expensive" gas station by us. Nice!
    "CR-V is car based as well, not truck based. Look under it, there is no frame, it is just a Civic on steroids."
    I take your point, but aren't some of the big trucks now going unibody?
    However, I don't think it is "Civic on steriods". Honda started with a Civic platform, but ended up with something very different. My wife has a 2002 Civic. It has a much longer turning radius, for example.
  • birdieboybirdieboy Member Posts: 2
    06 LX FWD auto
    Just bought this car brand new, I haven't finished a tank yet, almost to half and only 117 miles on it. If this is what I can expect to get I'm going to be sick. I know I need to try a few tank fulls, but I haven't talked to anyone around here who has a CRV that is getting more than 18 mpg in the city. That's about all the driving I do. I can't believe they can advertise 18-26, and all the reviews in consumer guides give this car a great rating and supposedly one of the best mpg for small SUV's. This is my first SUV, it's fun to drive but I can't afford 16-18mpg for a whole year, that's almost half what I was getting with my last car 29mpg/city 96 saturn with 120k. I was figuring to lose maybe 5 or 6 mpg but this is ridiculous. If this car can't get 20mpg I won't keep it more than a year. Can anyone give me any hope?
    Slow down your OK I have only 3000 miles (SE AWD) and I am getting 21 in town and 26 on the hwy with a 23-25 on a mix. Give it some time..... >>M
    My wife gets 21 around town and I get 23 with the '03 CR-V 4WD, 4 speed automatic. She gets 27 in the road and I get 31. The difference is about driving style.
    If your first tank is the one you got from the dealer, it may not have been full.
    You need to go back to the beginning of this thread if you need inspiration. :)
    Kip
    "I was figuring to lose maybe 5 or 6 mpg but this is ridiculous. If this car can't get 20mpg I won't keep it more than a year. Can anyone give me any hope?"
    You need to learn how to work with the car to maximize MPG. I got 18 MPG in my 2003 CR-V, then when I implemented some basic techniques, I got between 20 and 22 MPG in the city. My highway MPG ranged from 26 @ 80 MPH to 31 @ 55 MPH.
    If you search through this tread, I and others have posted ways of improving driving habits.
    Thanks, maybe I just have to be a little more patient never owned one of these before, they're fun to drive but all my past cars were economy that got 28 to 30 in the city, so it's a little bit of a shock for me. My daughter started college this year so we'll be driving hwy miles every so often, see what we get there. Do you know what that D3 on shift does, someone said it was an overdrive, do I want that on driving the highway?
  • kyfdxkyfdx Moderator Posts: 270,584
    D3 locks out overdrive... You definitely do not want to use that on the highway...
    Just put it in Drive and forget it...
    A good way to build confidence in your car will be to curl up in a comfortable chair with your owner's manual. Lot of great stuff in there, including an explanation of when to use D3 (no, not highway, unless, possibly, you're in a blizzard). Good luck.
  • dromedariusdromedarius Member Posts: 307
    In my experience, the mileage gets progressively better as the engine breaks in. We have a 2005 SE, and we are getting at least the EPA rating (27 mpg) on the highway at the 15,000 mile mark. At about 10,000, we were only getting about 25 mpg.
    On a sidenote, I sold my 1990 F150 and bought a 2001 Chevy Prizm - talk about awesome gas mileage! For those of you not familiar with the Prizm, it's just a rebadged Corolla. I'm getting right around 40 mpg on the hwy in my little 5 speed! Right now I'm feeling pretty good having two four cylinders in the family garage, even with gas prices coming down.
    :shades:
    Our 2006 EX MT is getting about 24-25 around (not really city driving, but suburbs) -best I ever did was 28.5 highway. Have about 7000 miles on it. If I kept it at 65 mph I bet I could get 30 out of it.
    Mark
  • richbraverichbrave Member Posts: 8
    I started out getting about 24 city and 29-33 on the highway.
    Now 4 yrs later, 19-21 city and 22 highway (on a good day).
    My honda mechanic told me that's it being caused by two things. The ethanol in the gas (10% drop in fuel economy) and the A/C compressor problem that's going on with the CRv's.
    Guess it's just a matter of time before my compressor blows.
  • dvdgamerdvdgamer Member Posts: 2
    2007 EX FWD
    Driving style, road conditions, Hway or City, sure makes a big diff. I traded in my 1999 CRV EX AWD, and I think I was getting 20MPG overall on my old CRV. I was disappointed because I was hoping for much better mileage. But I do like the drive and everything that comes with it, so stuck it out with a CRV.
    The real time MPG indicator in the new CRV really helps a lot in understanding how economical you are with with your driving. First two fill ups, I was only getting an average of 20 MPG again. But since I'm able to see real time what my MPG is, I understand why this is so, and wasn't really in panic mode at that point
    In fact I was expecting this since I was doing a lot of idling (staying in car while wife goes shopping w A/C on),
    a lot of ogling at the new car, admiring the interior etc ;) , mostly mall/city driving (less than 20% hway). But since I do have the MPG indicator, I can readily see that my bad driving habits are causing me to expend more gasoline than should be - aggressive acceleration, etc... At the same time, with relaxed or conscientious driving, I readily see that my MPG can go 30 to 40 on a good drive, esp. at Hways.
    We were at an outlet mall during my last fill up (Ontario Mills), and was going to drive back to Orange County. Traffic was light, and I decided to test how good mileage I can really get if with relaxed driving. By this, I don't mean to go slow but as steady as possible and less gas pumping. So we were actually doing 80 at stretches, and not going slow, just doing it, I guess, the right way.
    I was very impressed with the mileage I was getting. In fact close to OC, and just before the uphill driving, I was actually averaging 35MPG! After the uphill drive, mall trip and city drive, I got home and our final MPG was 29.2. Not bad, in fact, so much better than I expected.
    So I'm impressed, and think that the advertised mileage for the new crv (23City/30Hway) is just right. I just need to learn the good habits, and consider the conditions under which I'm driving b4 I start complaining again of how low mpg I'm going to get in future drives ;)
    I wish more people would come to mileage boards saying the exact same thing (...I need to consider the conditions I'm driving...). Some people will complain that they only get 13 MPG in a car supposed to get 23 MPG...they fail to realize that living in MANHATTAN, NY isn't your average "city" commute! LOL
    More power to ya with your new CR-V. I have an Accord I-4 2006 model (same engine as CR-V)...your mileage will improve another MPG or 2 as it breaks in... passing the 10,000 mile mark I saw a marked increase from averaging 29 MPG to averaging around 31 MPG (my car stickers at EPA 24/34)- this is mixed driving, so I'm MORE than pleased!
  • redfish5redfish5 Member Posts: 2
    I have had my 2007 EXL AWD in Whistler Silver Metallic for 9 days. It is hands down a great vehicle for today's type of driving. First tank got 24.5 mpg (60% hiway,40% city). Second tank (just filled up) 25.7 mpg..... :) sweet !!!!!!!!!
  • daryll44daryll44 Member Posts: 307
    Actually, I wish there was a way to turn off the realtime MPG meter. It makes me nervous going up hills, etc, watching 5MPG etc. I get about 20 MPG on my new '07 CR-V around town and did slightly better on my old 2005 CR-V. The meter just makes me nervous. Is there a way to turn it off?
    Don't look at it. ;)
    I can see it now the people with nothing to do will be saying looking at the meter will be like talking on a cell phone. By 2008 there will be a switch :)
    ....MNF
  • fnamowiczfnamowicz Member Posts: 196
    I wish there was. The constant dancing bar graph is too distracting and also the odometer reading belongs on the speedometer There is no need to show trip a or b and your total driven mileage in smaller numbers at the same time.
  • acarpersonacarperson Member Posts: 13
    I put around 900 miles on our brand new CRV. Made two round trips to Kernville from L.A. area (about 220 miles one way). 1st trip: on the way up (elevation gain of 3000') we got 27MPG, back got 29 MPG. 2nd trip: up, got 29MPG, back got 31MPG. The 1st trip there was a lot of stop and go traffic going both directions. 2nd trip had hardly any traffic. When no traffic our speed ranged from 60-80MPH.
    Not too bad for a brand new SUV.
  • terry92270terry92270 Member Posts: 1,247
    :P
    Same is said about the graphics on Hybrids. It is dubious to think they will remove it, before the interior "refresh" in five years.
  • lzclzc Member Posts: 483
    A small strip of black electrical tape should do the trick. :D
    Agreed. It's more annoying than useful.
