Visitor Agreement.
Anybody know if there is an appreciable difference in shutoff points between pumps at the same station and vs. pumps at a different station? In other words, if you don't fill up at the same pump that you used last time, how much might your mpg calculation be thrown off?
I bet that your speeds were at 65 MPH or less?
Yes, that checks with my 2003, which has only the 4 speed transmission. The CR-V does really well at secondary road speeds. Though my 27 MPG at 80 MPG isn't bad either.
Mine got better at around 3K, but you also need to drive conservatively in town; if you dip into the VTEC, the CR-V mileage plummets.
Unfortunately, that is the worst cycle for all conventional (non hybrid) vehicles. You will probably max out at 21-23 MPG, but I'm not sure what the 2005 (with it's 5 speed transmission) is capable of.
My tips:
Accelerate firmly, not gently or hard. Keep the RPMs below 2500. When you hit 2500 RPM, let off on the accelerator to let the transmission shift.
The idea is to get into high gear as soon as possible, and stay in high gear
Try and avoid stopping and accelerating by watching the traffic and the traffic lights
Plan your route to avoid slowdowns, traffic, and lights
Time the traffic lights if you can, accelerating or slowing so as to make the green. I see many people (daily) accelerating hard just to get to that next red light.
Yikes! Switch to a better fuel. Aamco makes good octane fuels, but I always use one of the following, who put better cleaning addatives in their gas: Texaco, Exxon, Mobil, Shell, Chevron. Over time, the fuel cleaners will help your MPG and engine longevity.
We just came home from a road trip to Nova Scotia from Ontario. It was about 80%highway. Total distance was 5440Kms. We used 509.71 Liters of regular 87 octane.
I figure we have about 9.36 L / 100 KM.
I think this translates to about 25 MPG for US gallons, or 30 MPG for Imp Gal.
The car is 2003 CR-V LX, a/c was on about half the time. Speed between 110-120 KPH.
My .02c worth.
Drove from central CT to Western PA and back -- 1177 miles
People, luggage etc weighed approx 600 lbs
Tires at 32 psi
Avg mpg for entire trip was 27.18
Best stretch was 335 all-highway miles with cruise control set at 65 in which we avg 31.6 mpg.
Minor note:
The only thing that bugs me about this car, and it shows up more on a long trip, is the storage pockets in the door. The top "pocket" is annoying because it has no bottom and interferes with access to the second pocket under it. I find it hard to dig stuff out of the second pocket, because it seems too narrow/deep. Good thing the little center tray is handy and there's a separate cranny for the cell phone..
We've been getting 22mpg ever since we got it wavering only a mpg difference either way occasionally. My wife is the primary driver and she is most definitely NOT a heavy-footed driver. Our driving is mostly suburbs/highway. Her daily commute in particularl is mostly interstate and rural roads so I was expecting her mileage to be closer to the highway rating than the city rating.
We love the vehicle overall. I'm actually thinking about getting an older used one for myself. But I have been a bit frustrated with the mileage aspect as this was a major consideration when we bought the vehicle.
I think it is a door handle, not pocket. I have 2005 EX and I only have a pocket on the bottom, no pocket with no bottom.
... except the door handle is right above the bottomless "pocket". I just wonder what the designers had in mind. Granted it's a pretty picayune concern, far outweighed by the very favorable mpg I've been consistently getting..
Taller papers don't bend over and yet you can reach into the lower part of the pocket if you need to.
Did you noticed an improvement in MPG since you bought the car?
Listed is 22-29 MPG....far from real life driving...
Around Dallas, I average 19-23 mpg with A/C.
Over the years, my milage has gone down. I think it may have to do with the new tires that I put on the vehicle, the Goodyear TripleTred. Great tires for traction, but noisy.
The change in fuel blend is the cause of your reduced fuel mileage.
JM2C
It is more likely that 2 mpg came from ethanol and the other 2 mpg from MTBE used in winter gas. Also the grade of oil will make a difference.
I usually do my own changes with Mobil 1 0W-20, but I had a freebie from the dealer, and went with their change. Supposedly they used 5W-20, and my mileage went from 30 mpg highway (summer) to 25 highway (winter). Combination of winter gas and non-synth oil are probably contributing to my MPG descrease. I will change out to Mobil 1 after 3000 miles on the dyno oil.
Are you using synthetic? What type of tires were you using previously?
But now it seems to be responding a lot better and feels more lighter to drive.
I always use Mobile 87 grade and tire pressure is usually 34psi. Till date I was pretty frustrated with the mpg but it seems to have improved now.
Seems to have improved from 21/22mpg to 24 mpg till date for city traffic.
I'm looking @ Toyota, thinking Matrix, Corolla, or Prius, mostly to save on gas $$ and have a reliable car. From what I'm reading here, Matrix doesn't sound like a good bet on either count.
I'm looking at a loaded 2006 XR Automatic.
Comments/insights are much appreciated!
You are on the CR-V forum, which is Honda - do a search for toyota/matrix board. Or XR car.
I'm looking Toyota, thinking Matrix, Corolla, or Prius, mostly to save on gas $$ and have a reliable car. From what I'm reading here, Matrix doesn't sound like a good bet on either count.
Go with the XRS, 6spd manual version. The engine is made by Yamaha.
MPG per fill up
22.7
24.0
22.9
24.5
23.4
25.0
Overall average 23.98 1221 miles, 50.9 gals used since first full tank.
I'm pretty happy with the mileage thus far, and I am really happy to not be using premium, which was required for my Audi. Ouch. I'm hoping that it picks up a bit as the car is broken in, but even if I only average 24 I figure I'm doing pretty well. My Audi averaged about 28-30 MPG on the highway, but using the premium was killing me.
I am very happy with my new CR-V.
TB
Switch to 5W-20 and you will get better mileage, I use 0W-20, but it is no longer available from Mobil.
What edmunds is listing is not that much of a difference ( 2MPG less for the EX AWD), I wonder if real world is the same.
I heard people being very dissapointed for the EX MPG...
Thanks to all LX and EX owners!
Dan
I'd love any suggestions, is this something I should discuss with the dealer?
regards,
kyfdx
Since MY '02 every CR-V sold has a 15.3 US gallon capacity. Some may think that is "smallish". To me it seems correct for a vehicle this size.
Oops. You are correct as to fuel capacity. Pardon my transposition. I think preference on this matter depends on driving patterns. My second vehicle is a 4 cyl '99 Saab 9.5 which gets about the same mpg as the Honda CR-V. However, the Saab tank holds 19.8 gallons. Granted the Saab is a "cruiser" rather than a "runabout," but the extra range is nice to have on a long trip. For me, two more gallons in the CR-V tank would be nice.
run it to the low-fuel light... then run it on down to E.. then run it down until the needle has left E behind..
I've still never been able to put more than 12.8 gallons in it... I get the feeling that 2 gallons of that "capacity" is above the fuel filler pipe.. lol.
Because of it's interior size and other features I think people forget that the CR-V is a small, entry level SUV, and it has the mechanicals to go along with it.
14.8 gallons on my 2003. Never want to be that low again - in any vehicle!
Only one I ever got lower was an '89 Hyundai Excel - I had .3 gallons left when I filled it up... in the desert too. Stupid to let a car get that low just because I missed a turn off for gas.
First, I salute your determination to get to the bottom, so to speak, of the fuel capacity question. You prompted me to check my vehicle log. Yesterday, with the needle near E, I filled up and, lo!, it took only 10.8 gallons to fill the 15.3 gallon tank, using the automatic shutoff on the pump. I flipped through the pages and discover that the absolute max I ever pumped into the tank, with the red warning light on, was 12.6 gallons, a couple tenths behind you.
I opened the 2005 Owner's Manual to look for an answer to the relatively generous reserve capacity. I think I found it on page 62 in the Gauges section: "Avoid driving with an extremely low fuel level. Running out of fuel could cause the engine to misfire, damaging the catalytic converter."
And..generally.. I never do... Today, I had to fill up at 276 miles... The light had been on for about 20 miles, and I was about to get on the freeway for an 18 mile ride home... A little above E.. 12 gallons on the nose... 23 MPG..
I'm relatively happy with that mileage... Just think, if I was able to use 14 gallons of the 15.3 gal. capacity, I could have put off buying gas another day... and driven another 46 miles..
We generally get 21-23 MPG with about 8000 miles on our '05. Most of that is short trips in town by my wife, to and from work, which is about two miles through town each way. We got as low on 17 MPG and as high as 25 MPG. We have yet to drive it when it has been broken in during the non-winter months, though, so I'm expecting to see some better tanks this coming year. Also, I seem to get about 2-3 MPG better than when my wife drives, but we're working on that.
PS - My 1990 Ford F150 is getting somewhere in the neighborhood of 8-10 MPG this winter, or lower...
:sick:
I do not know any of you try to use diferent gasoline, but if I use Exxon/Mobil Supreme gasoline I got around 22 - 23 MPG, if I use Exxon/Mobil Plus gasoline I got around 25 MPG.
Any body know why? appreciate for the answer
