Visitor Agreement.
It also should be OK with gas and insurance.
Or if you have to go used, a Park Ave, since the LeSabre is essentially unobtainium with a bench seat.
Any opinions about the supercharged engine on the ultras. Is is better to stick with the base engine in terms of reliability/maintenance costs.
Didn't these cars come with the heads-up display. Any opinions about those?
While not every plastic intake manifold failed lots of them did so it is something to watch out for.
A few more questions for you if you don't mind.
Does the SC engine require premium gas.
How would you rate the overall reliability/repair costs of this model - let's stick with the SC
Do you think the interior trim would be in good shape for a 10 year old car - in terms of not coming apart.
This is one car I have never driven - nor sat in. So any impressions are appreciated.
The 3800 engine is an outstanding motor even with the SC on top a couple of hundred thousand miles with appropriate maintance should be no issue.
I would be a little hessitant about the HUD display though as I have heard of that having problems. It is a typical 1990's GM car so the drivetrain is great, the electrics are average and the paint/interior finish is poor. If the interior was well taken care of and stored mostly inside it might be ok. Otherwise it will likely be in poor shape.
The paint will also most likely be faded and comming off unless it was stored in doors and waxed constantly.
I don't understand this. Almost all the leSabres have bench seats. A few had a console in the middle designed for business papers, worktop, technology holder, etc. But 99% of the leSabres which were not made after 2005, I believe, have bench seats. Some comfortable cloth, some comfortable leather. The Park Avenue seats tend to be covered with a topping to make it slightly plusher in feel. But the Park Ave is 500 pounds heavier.
The UIM (upper intake manifold) once replaced rarely gives problems. In 99 they changed that design from the factory. Few failures in 2000 and later. Some people blame DexCool for failures of gaskets around edges leaking; some failed with an EGR plastic pipe setup through the middle. 1999s had a smaller diameter metal pipe sticking up into the UIM manifold's plastic out later separated by a small air space.
DexCool does fine if changed every 24000 or two years just like regular antifreeze.
The UIM is a $150 item with $120 labor at typical practiced garage. Some with medium mechanical skills replace their own (and do the lower seals as well). Watching antifreeze level in recovery tank for slow drop without a temperature explanation from season to season being reason to have a knowledgeable garage check.
The intake manifold problem is overemphasized--unlike Toyota's sludge or their and Honda's transmission failures/problems. I would avoid the supercharger myself because I don't want the extra maintenance for it, like frequent oil changes and possible failures and replacement.
I believe the Lucerne's 3800 has a completely different, metal UIM.
So engine life is essentially identical.
As for the cars, you definately want the Ultra if you can. I presonally like the last couple of years' designs with the more angled lines, but the early to mid 90s models were much better inside. better electricals and interior by far - it seems as if the bean-counters made it cheaper inside every couple of years until they got rid of it.
All of that said, though, you can find a 1-2 year old LaCrosse or Lucerne for cheap. Really cheap. We're talking under $16K for a LaCrosse CXS, which is effectively a FWD version of the CTS. And it has a much better interior than any of the older models had. The bench seat is nicer, too, IMO, because it makes the car feel much more spacious and open up front.
http://www.autotrader.com/fyc/vdp.jsp?car_id=212411646
One of about 50 or so selling for this price on autotrader. It drives *very* nice with the 3.6 engine. Zero throttle-lag and plenty of midrange power for city traffic. Nice Cadillac quality suspension as well. Much firmer and better than the LeSabre it replaces.
The guys I knew that raced those engines were running more then double that boost without major engine problems. The problem they had was that the final drive in the transmission could not take that kind of abuse.
No one makes a strong enough pinion gear for that transmission so you just buy the best you can, have it cryo treated, run high quality synthetic fluid and pray you make it through a season without a failure.
Plus, it's the law to keep them RF at least until they are 1-year AND 20lbs.
Thank you, I will get off my soapbox now.
2003 Buick Park Ave Ultra (white)
77,000 miles, good-excellent condition
* Premium sound, 12 disc cd changer, moon roof, leather, seat heaters and so on.
Listed Price: $15,879
I test drove this and I have to say it is nice! Somewhat floaty ride and no steering feel, but that's to be expected from an "old person car." The leather bench was very comfortable and I quickly got the impression I could drive this thing for hours without aches and pains. My only problem would be falling asleep at the wheel due to the comfort and ease of driving. Though I don't quite have both feet in the market yet (I told the salesman) I said I was interested. After standing firm that my buying range was closer to $12,000, he said he'd try to help them meet that number since it was on the lot for 120 days. After a stop in the manager's office, he came back with the figure of $12,700 +TTL. Not too bad, right? At least according to my blue bookings it isn't. Any opinions on all of this?
If they have had that car on the lot for 120 days, most dealers turn their used cars over every 60 days or sometimes 90 days, then I think they can get down under 12,700. what part of the country are you in?
Try the Real World Tradein Forum Volvomax probably has a better idea what they potentialy have into that car.
There's no way thats a rental with 77k. Rental car companies dump their cars with less than 20k. They don't want to deal with an out of warranty car and they know the next buyer will want some warranty with their purchase.
That might have been a fleet car, but most likely, it was sold to some traveling salesman or something. The outside rep for Cannondale used to go through a VW every year driving to all the bike shops.
But that is not a rental either because it has too many miles as well.
I can't find my unlimited Carfax password right now but I am pretty sure it is not a rental.
And even if it is what is wrong with rentals? In my experience they get serviced better then private owner cars.
Also you need to see when it was sold to figure out how many miles are too many miles. That could have been sold mid 2005 as a 2006 MY car so it would really only have about 15,000 miles a year.
HUD was, I belive, an option (maybe standard on the Ultra). I personally liked it on an SSEI Bonneville I once had. You can turn it off when desired. If it fails, there's no requirement that it be repaired.
Unless you want a floaty ride, find one with the Grand Touring suspension option. I believe they are identifiable by a plaque on the dash to the left of the steering wheel.
I kept our son rear-facing until he was 2.5. It didn't prevent us from having conversations (even now that he's front-facing, I'm looking at the road most of the time), nor did it prevent me from pointing out trains, spectacular Christmas lights, cows, trucks, or anything else interesting/out of the ordinary.
I'm sure your son was able to appreciate Dad pointing out a train (can't see where you are pointing). He was probably sitting there looking up at the ceiling trying to see the train. It probably took him to age 5 to realize a train is not a white puffy ball in the sky.
Seriously, either way the kids are safe and that is the important part. I know my kids appreciated being able to see where we were driving. Plus it was tons easier to load them into the car.
It is the most important part, and kids are certainly much safer in a front-facing seat than none at all.
However, kids are safest sitting rearward as opposed to not, assuming they are in a properly sized and secured seat. Look at how few toddlers/infants die in car crashes in Europe, where children sit rearward until 5 or 6.
Communicating with a rearward facing toddler really isn't that complicated -- "Wow, pretty waterfall on Daddy's side!", "Cool, check out that Excursion stretch limo on your left," etc.
The differences are that a forward facing child, in a crash, will likely suffer neck/abdominal/chest injuries, same as an adult, as their bodies absorb the impact of a crash. Whereas with a rear-facing child, the CARSEAT absorbs the impact. We use a phrase, it is better to receive a broken leg in a crash sitting rear-facing, than a broken NECK in a crash sitting forward-facing.
If you would like to view crash test footage that shows a forward-facing child and a rear-facing child in the same test, please view the following link:
http://www.cpsafety.com/articles/stayrearfacing.aspx
Scroll to the bottom and you will see a link to the crash test footage.
Also, the most important thing is the safety of the child, not being able to show him/her objects you're passing. My child was rear-facing until 3 years old, and had no problems seeing anything, or communicating with us.
Please keep your children rear-facing until the child has surpassed the rear-facing weight limit of the seat.
Every "graduation" of seats is a DEMOTION in safety - ie - forward-facing is LESS safe than rear-facing, and being in a booster is LESS safe than being harnessed.
There are also new seats available that will keep your child harnessed forward-facing beyond the standard 40 pounds (if you have a 3-in-1 seat that says it is good to 80 pounds, that only means with the seatbelt! You have to take out the harness at 40 pounds and use it as a booster seat only!) These new seats are the Cosco Apex, Sunshine Kids Radian, and the Britax Regent, Marathon, Decathlon and Boulevard.
I posted this information for anyone who may be reading this thread, it is not intended for one person only.
Thank you for reading, and for keeping your kids safe.
Jodie
CPST and mom to 2 boys (and is looking for a new-to-us car to haul everyone around in!)
anyway, i am wondering if what you are saying only applies to crashes involving the front of your car. I mean, if you get slammed in the rear, a rear-facing carseat isn't going to fare better, is it? Or how about side impact?
Our seat is, I believe, a 3 stage. I know it has 3 tilting positions and 3 harness positions. The first tilt is for rear facing only. I believe the directions read something like "keep child rear-facing until 1 year old, or 28 lbs (i'm not confident of that number, but its definitely higher than 20. could be 30), or until xx inches tall." So it gives 3 criteria. Our child hit the weight and height criteria before 1 year.
edit: ah, i just went and read that site. They are talking about frontal crashes. They do say that most accidents are frontal. oddly enough, out of 5 accidents I've had, 2 were side and 3 were rear. So my personal experience is different. I tend not to run into things.
they also comment about the height and weight of the child. They say 30 lbs, so I think that must be what my childseat instructions call for.
We have no problem talking to each other.
I also think the focus is on frontal crashes since those are the most serious & most common. Rear end crashes usually aren't cause for as serious injuries, esp. spinal.
Sorry everybody-I didn't mean to start such a heated discussion.
I do need a "new" used minivan. Any suggestions for one in the $10-12,000 range?
If I were in your shoes, I'd look at 2/3 year-old Chrysler and Dodge minivans, or 2002-2003 Siennas/Odysseys.
The Oddessy and Sienna are hardly "mini" vans. They are bigger than some full size vans. That said, given their size they are very easy to drive. I don't care for the Sienna before that, it has the turning circle of a bus and I found it hard to see. I also didn't like how I had to look down to change the radio. It does have a smooth ride and powertrain though.
The Mazda MPV can also be had pretty cheap, and has some features the Chrysler products do not have. Like 2nd row windows that go down and a storage well behind the rear seats.
As far as child seats go, I think the main thing is to just use them, and use them properly. My oldest is 7 1/2 and almost 5 foot tall and she complains that many of her friends don't use them anymore. Good thing the law here is 8 and 80 or I don't think any of them would be using them by that age.
alltogether: a 2-3 year used GM minivan is also an option. The MPV is a great size and value but you do sacrifice significant interior space. If you have 1 or 2 small kids, it's probably not a problem. Plus there is no gas mileage savings or driving advantage over the larger "minivans". You can get a leftover 2006 for around $17-$18k.
How about - Child Car Seats that Fit or
Air bags: are they safe for children & children in car seats?
Those pretty much cover the topic.
MODERATOR /ADMINISTRATOR
Review your vehicle
I did check out the MPV but didn't like how it drove-weird for a mazda. I haven't driven a GM-I'm thinking there is more usable space in the Chryslers?
Hey, did your '96 have the ability to take the third row and move it to the second row so you can sit three, after removing the second row seats? I thought I read that somewhere...
My wife did not like the Mazda for that reason also. She said it was too narrow.
I think at this point I'm leaning towards the '05-it won't be loaded but it's more than I have now (nothing). At least I won't be stuck at home everyday.
Thanks for the help!
During the summer (rummage sale season for my wife :sick: ), we leave one half of the rear out. Still fits the 3 kids and gives her the room she needs.
I highly recommend Weathertech heavy duty floor liners for the floor behind the third row. Protects the carpet from wet, dirt, sand, dogs paws etc.
They had a '04 on the lot w/45k for $15 (170hp 2.0t, leather, moon, etc). That struck me as a lot of depreciation, but I guess 3 model years old might be about right. I didn't get to drive the used one yet, but it seems like they are at a much better price range for me.
Basically, I think my most realistic short list is the 9-3, Impreza WRX and a Mazda6 (12-15k, less than 5 years old, under 50k miles, stick).
I just sent a Saab 9-3 equipped with the moonroof and the 18" chrome wheels to the auction w/ 55k ... I am hoping to get $9.5k for the vehicle but I am not optimistic about that.
I would RUN away from the Saab as quickly as I could. He had the vehicle in the shop at least 25 times in 3 1/2 years on electronics, the moonroof ... never a dull moment with THAT beast. The annual maintenance alone is expensive.
All of them say stay away from the 9-3. The later ones might e better then the older ones but in general they advise against a 9-3. If you want a SAAB you would be better off spending a bit more money on a 9-5.
So we conference called the dealership. The driver and the technician are now best buddies - heck, they ought to be. I mean when the technician asks the driver how he liked his Christmas card ...
Great dealership, great service, miserable car. Sent it to Manheim rather than sell it to an employee.
Hopefully, never again.
Now if I can just find one that is in the price range and not trashed by modifications.
