Despite the old epa's ratings, you should have NEVER expected to acheive those ACTUALL numbers. 40 mpg on the highway? 36 is pretty damn close to me...
with regards to mileage, you have nothing to complain about.
i was thinking, what if its the fuel guage itself that is defective? What if the light comes on, the bars are all gone, but you could still keep going? I would suggest even having that checked out!
How does a defective fuel gauge affect fuel economy? As far as I'm aware, there are only two valid and repeatable methods of calculating MPG figures, 1) divide the number of gallons used at fill-up into the number of miles driven (which provides questionable results for any individual tank of fuel but rock solid results when evaluated over time), and/or electronically (which allows for great tank versus tank analysis but isn't necessarily "dead on balls accurate" in absolute measurements). Regardless, neither of those methods involve the fuel gauge what-so-ever.
FWIW, many folks with high mileage (as in high MPG figures) cars have been buying a "Scan-gauge" to help them learn how to eek out every last mile from a tank of fuel. Our current cars (as in those in the Shipo household) provide the same information via the driver information center, however, if/when I pull the trigger on a pair of Civic EXs, I'll probably buy a pair of these as well:
http://www.scangauge.com/
Best Regards,
Shipo
Anybody who feels they have a problem with mileage should purchase one. It will show them if they have a problem, and will help them get better mpg.
A civic should get 40 mpg highway quite easily if driven at the speed limit. CR got the Civic at 43 mpg going 65 mph - actual test.
BTW my lifetime average in my Accord is now at 31.7 mpg (almost 5,000 miles so far) and my best full tank is 41.3 mpg (549 miles driven on 13.3 gallons) at 65 mph with no A/C. 2007 4-cyl stick shift.
Yeah, the ones in our cars currently return a plus or minus five percent reading as well (usually less), I'm thinking that that is the margin of error in the basic ODB-II software. It's also nice that the Scangauge can also pull error codes from the system. ;-)
Best Regards,
Shipo
From my point of view, unless it is a luxo MUST have thing to you, paying the extra freight from VP to LX to EX is not worth the money, especially if it is only to save fuel mileage. Those EXTRA 1000's of dollars can buy a lot of commute fuel.
Best Regards,
Shipo
Finally, I am NOT complaining about my economy but simply explaining to anyone who will listen why THEY probably won't get the 30/40 numbers but may be able to come closer to the new EPA numbers because they are more realistic and coincidentially in line with what I actually get. That is all, read into it whatever you see fit.
As far as your getting consistantly better than city estimates...congradulations you have the routine down pat. Most of us, including me, are still trying to find that routine. 2006 EX sedan automatic....22-24 mpg depending on season. Captain Kirk to engine room... "Scotty, wring some more fuel economy out of her".....Re: "that's all she will do captain".
I do understand that if you have a heavy foot and get into "VTEC" mode, mileage will drop significantly, however, there is plenty of evidence to suggest that if you want good mileage from a Civic, good mileage can be had.
Best Regards,
Shipo
I also. 22-24 mpg is about what I can expect to get on a Z06 Corvette in deep city traffic, hammer it from stop light to stop light, or if I run it HARD AND hammer it between 90-120 mph for hours on end, which of course can be VERY problematic on our roads. That is why a 25-28 mpg is more the norm.
"I will also go on the record with this: If I bought any car and it was averaging 5 mpg less than the estimated city mileage, the service manager and I would be having a meeting of the minds. I know those numbers are estimates, but I've also had cars that did better than the estimates, and I've never had a vehicle that consistently got worse than the city mileage. "
So, what do you expect him to do? I have this problem on a different model car where my city mpg is about 25% below the old EPA numbers but I just don't know what the service department can do. If you have realistic advice then I'll try it. Thanks.
It's certainly possible to exceed the old formula EPA estimates in some cars. My old car, a 1999 Chevy Cavalier (manual trans), was only rated for 34 mpg highway, but on numerous trips I acheived in the 38-39 mpg mark. The formula seemed to be to stick in the 60-70 mph zone, and pay careful attention to keep as constant a throttle as possible.
Indeed I for one am glad for the counterpoint. It illustrates the range and versatility, etc, of the Civic platform. If the EX is a screaming bargain, then the VP is a SCREAMING bargain; sans the goodies and 4 wheel disk brakes. I LIKE these things also, but they are really not too noticeable or even essential on a purposeful daily point a to point b commute (one translation: BORING).
Best Regards,
Shipo
Another thing I was impressed with was the EPA difference between manual and automatic SEEMS to be the least, of models I was interested for the point A to point B commute. I of course lack empirical contrast as I run an auto. Another data point might be 48-52 mpg in a 5 speed MANUAL TDI, same commute. Honda has done a good job mating the engine to the transmission in that regard. Many WILL disagree, as individual unhappiness' due to their situation/s on the mpg issue, is at issue. I think the EPA difference is 1 mpg between auto and manual. So if I were to SWAG the mph for a manual under the stated use, a min of 1 to a 3 mpg improvement, which would go from 38-42 to 39-45. A counterpoint might be because of the extra control,etc, I might not gain anything.
I'd suspect though that it mainly is how good is your foot, or cruise control, as the case may be. Either auto or manual trans should do their very best with minimally varying throttle input - constant speed on the highway can make a huge difference in mpg. Also, I suspect that the civic would be much like my Chevy - push it much over 70 mph, and mileage will drop through the floor (certainly the EX's rpm's start climbing quite a bit over 70).
I'll be adding some major highway miles in mid-July, so will get a better handle on just how the car does on highway cruises then.
Having said that, there are indications a twin turbo on a diesel sports car (shaped like a Corvette) does get 48 mpg on race day, 70 mpg for a steady 65 mph, AND with no guarantees of getting that mileage, doing a 0 to 60 run of 4 seconds! Woo Hoo!!
P.S. The reason I went with an auto in this car was after driving home from Connecticut after Christmas. I-95 from New Jersey to Baltimore was a crawling parking lot (as it often is - the holiday notwithstanding) and I said that's it - no more manual tranny car for me (not as long as I live in the eastern USA at least).
By way of reality figures (Corvette auto vs manual) is along the lines of 18-20% losses vs 11% losses.
Honda racer types are more dialed into this than the more utilitarian markets.
You are having a cow on your own interpretations, NOT on what I said.
If i fill up with ten gallons, and i have a defective fuel guage, if my tank says i'm empty, i'll never know it unless i get it checked out, or decided to wing it and keep driving. Going by the guage, therefore, would insinuate i'm getting a lot less mpg than i actually am.
I don't calculate my mpg by what my guage says, i go by what i fille up with; but a defective guage, like i said, could make you think you've got nothin left when you do.
thats all i meant.
That said, I still maintain that a defective gas gauge will have no bearing on mpg.
Best Regards,
Shipo
Kilometers liters of gas L/100KM MPG Hwy ( Local )
498 37.77 7.584337349 30.76515753 70 ( 30)
504 41.73 8.279761905 28.18116463 60 ( 40 )
412.4 37.56 9.107662464 25.61945332 20 ( 80)
451.1 41.05 9.099977832 25.6410881 10 (90)
575 41.58 7.231304348 32.2671156 80 (20)
Total KMs: 2440.5
Total liters of gas used: 199.69
Average mileage: 28.5 MPG (US) or 8.18L/100KM
The odometer has about 7000KMs on it now. Civic DX-G Automatic
For comparison, my 2001 Altima (2.4L engine) gets about 20 MPG on average under similar driving conditions. I know my Civic mileage number is not very good, but compare to my Altima, it's still way better. The Mazda MX-3 I sold before getting the Civic got about 23MPG on average. All automatics.
What does 30-19.3% mean?
The Sandman
