Dynamic Racing Stage 2.5 Heads $2000 -Dynamic Racing DR 500 Turbos $1500 -ACPT Carbon Fiber Driveshaft $1000 -Autometer Cobalt Gauges (Boost, Water, Oil) $550 -Apexi D2 Exhaust $800 -ATR Downpipe $300 -Dynamic Racing Fuel Pump $200 -Clifford RSX 3.5 Remote Start Alarm $200 -Lightweight Alcohol Injection Kit $200 -Accel Thundercoil Spark Plug Wires (Brand New) $95 -NGK Iridium Plugs (Brand New) $50 -Boost Controller $20 -Dunlop Super Sport Tires (Brand New on Rear) $350
The dash light on the right had side and 2nd one up - What does that mean? Because It flashes and sometimes stays on when I turn my wheel to the right - but only if I'm driving, never stopped.
I would like to fix it but I don't know what it is. I just replaced the thermostat and the water pump. Plus the timing belt just got replaced also. All the fluids are fine! I am so confused! Please let me know asap.
wmalange@yahoo.com
Try this.
Turn and hold your steering wheel as hard as you can to the left. At the same time, push in your key as you rotate it backwards to the off position.
QUESTIONS: How can I get that belt out and are there and tricks to putting the belts back in. Could I have possible engine damage judgeing by the play in the crank pulley? Someone please help me!!
Here's the problem in a nutshell: Car goes in gear but doen't move. My mechanic thought it was the clutch. He took the tranny off to find a relatively new clutch in there. So before he starts guessing,I thought I should research on my own.
PLEASE HELP!
You might be able to with a socket set and some u-joints snake a plug socket on it.
When you do get it, put REAL GOOD plugs in it so you don't have to bother again for a long, long time.
when you do the exhaust you should at least get a k&n air filter also ">
Also, I want a stock bumper. The one that came with mine is aftermarket and I hate it.
Please help! Thank you!
i live in ma so there may be some shipping involved i would hurry if i was you thought i have alot of people making offers on these parts joninstasi@aim.com
thanks a lot!! my email is jlmyers07@hotmail.com if you can help me!!
