My Mitsubishi 3000GT VR4
My 1992 3000gt a/c is not working correctly. It will come on and work fine then the snowflake will turn to a red dot. I turn off the a/c all together and then turn it back on and the snowflake will come on again but then after about 25 seconds turns back to a red dot. I had the freon checked and it will not hold anymore so that is ok. Can you help?
But if you don't want to stand up for a rebuilt engine, the best approach in my opinion is to purchase a factory workshop manual either through Mitsu or eBay, and remove the heads and camshafts and have a qualified machine shop do the measurements and the machine work. If you could tow the vehicle to them so that they might check the cylinder bores, this would also be a good idea.
One problem is that by the time you machine and rebuilt heads and camshafts and get all the gaskets, tools, etc you will need, you might have been better off just buying some rebuilt cylinder heads.
plz help because i am abought to drop in the 6g72tt in it and i kneed it 4WD
replaced plugs,throttle body gasket and upper plenum gasket.
obd1 scanner showeed no codes wrong.
still runs a little off
HOW DO I GET IT OUT OF LIMP MODE
I WIL LISTEN TO ANY IDEAS including ones that involve balpine hammers
joe
This is what I was told by the dealer in KC, but the engine blew before I had a chance to replace mine. That's all I know...
i will give it some thought and investigation.
joetir
I was also wondering where else my oil could be leaking from?
I have resealed the oil pan and replaced the oil pump. Do you think it could be a bolt loose somewhere or an oil galley.
I was also a little stumped when I seen like whitish smoke come out of my exhaust, but it smells like pure gas. I cleaned out the injectors, it seemed to help a little. Do you think I should go have the injectors cleaned professionally or buy new injectors?
Jordan
And with the white smoke, I cleaned my injectors again and it stopped smoking. So I would maybe try the injectors and see what happens. If my injectors get dirty again, I will probably go have the cleaned professionally.
Let me know what happens with you.
is there a cure for limp mode?
has it ever been done before?
i would like to hear at least one success story for this terrible condition.
please
joetir 92 es,dohc......stuck in limp mode
Problem #2...I noticed that the car sometimes puts out white smoke while idling. Can any one tell me what this is and is it expensive to fix. This will determine if I will drive this car or sell it. I suspect the oil pump may be what causes the low oil pressure reading, and maybe the valve rings are causing the smoke. But I don't really know. HEEEELLLLPPPPP!!! Please. Thanks, Orlando 845-416-5922
I don't know whether your turbo has cooling, or adds another possible cause in addition to the headgasket.
Did you start beating and winding out this engine?
Make sure you aren't sitting with water in your oil (height of oil is high, or milky foamy oil), or oily residue in your radiator.
