Visitor Agreement.
Top Fuelers too loud and pollute the air?
I love to smell that nitro when the fumes get to the stands (Pomona, used to go to OCIR). The sound is great if you wear earplugs and ear muffs over those. The noise that is irritating is the 500 car alarms that go off after every TF or FC run. Must be the ground shaking.
My brakes squeak when I drive in a very dusty place or a gravel road. A day or two later they are OK.
Ryan,
Hey, I'm jealous!! Our bus tour of Indy only went 25mph max. I would have liked to have taken my truck around the track. The museum was impressive.
Did you ever drive up to Detroit and visit the Henry Ford Museum? No, it is not all cars, but it is all interesting. The only place I've ever seen an engine with a 3 foot bore and a 6 foot stroke. That's 73,000 ci for one cylinder.
Mike L
Anyones antenna coming loose alot??? Maybe i should stopp hitting the tree by my driveway eh???
Oh yea the tail light guards have worked. Something dont know what hit it i can see a mark missed the light and hit the guard. Probably one of the neighbors balls.
Ryan
Coincedence? Hmmm...
In Texas, it's easy to tell when you're approaching the line between a "wet" county and a "dry" county, because that's where most of the liquor stores are!
erikf2
Do you know how many counties there are in Texas? Just wondering. Was looking forward to visiting Six Flags in Dallas. pulled in to the lot Monday morning, found best parking, then noticed park was closed....boy was I pissed....LOL!! Reminded me of that Chevy Chase movie.
Dean
To Buy or not to Buy, is the question.
John
One of them is a trailering package. That along with the Z71 option, makes for a very stiff ride. It's a short box reg cab, so the back end sticks up too much as compared to the front. Is raising the front an inch or so feasible? Would I have to go to the aftermarket to do it?
It's a very nice truck, and now I know why you guys are so proud!! It's a black and pewter LS, and I have not been able to drive straight home from work yet!!
Chris
Nick
4x4 (autotrac),rear,front??????? Just wondering.
Also on my silverado when does the 4 wheel fluid need replacing. Rear fluid??? Just curious with winter coming up
Ryan
Nick
Ryan
Nick
Also whats this do not lube (zerks) if it is below 10 degrees??? Damaged could be caused?
Ryan
Nick
I just thought you guys would enjoy seeing this
one!
Article and more pictures are at:
http://www.thedieselpage.com/duramax/dmaxownr.htm
Hunter
Roger - Don't let Firestone get away with that. Their web page says 'CUSTOMER SATISFACTION;
Did you notice any apprecialbe ride change (Softer / Less bumpy etc.) with the 265 Gr C's??
75v
Yea i know the expansion and contraction crap. It was odd when i read it. It was 11pm kinda late to be thinking.
Also my rear leafs appear to be fine. How do you know when they are bad? Ive been told look and there should be a gap at each end. (where they meet and its a circular shape. Wish i could take a pic i cant describe it to well.) Well on mine the gap is still there. That pic is bad. The slant of the driveway makes the truck sit perfectly even i know it bugs the heck out of me. If i back it in the rear sits real high. If i park it in the street it looks normal. If i get home before dark tonight ill take some pics for you.
ITS SNOWING WOOHOO!!!
Ryan
As for ride differences, I couldn't tell you? The Stones came off with a whopping 41 miles on them, and they certainly weren't aired up enough anyway. With 50/40 front/rear, the C's ride well enough. I will say the HD does seem to ride a little stiffer than the regular 2500's I've driven, but it isn't offensive. I like it. My wife wanted to know why it was so jerky/bumpy, when she first rode in it, but what the hell does she know! The only bad effect is my keys rattle around and hit the shifter and make too much racket. I need to see if I can shorten the chain up to keep it from making so much noise. Have a great weekend everyone.
ryan -
can't help on the blazer...wife's jimmy is 2wd.
on the rado...the tech at the chevy dealer where i get my alignment done recommended swapping the rear diff fluid within the first 10k miles. he recommended mobil 1 75w90 (i think? - check your manual) and that, if you don't do much serious towing or hauling that it will last up to 100k if you want to let it go that long. he changes his ('98 z71) every 50k. also said if you do any significant towing or hauling, consider changing up to every 25k.
it's easier to do than your engine oil, i did mine at 7500 i think. pull the drain plug, allow it to drain. replace the drain plug. remove fill/check plug. fill. replace fill/check plug. you don't even have to put it up in the air. nick's idea of letting the dealer do it the first time (to clean the magnet) isn't a bad idea either though. although with your dad being a mechanic, i'm sure he's taken a diff cover off before and could prob'ly help you with that... the mobil 1 gear oil runs about $10-$12 a quart (give or take) and i think i got mine at advance auto.
bco
crossfire -
i've heard one way to raise the front is to tweak the torsion bars. i don't know how to or how hard it is...but i've heard it's the easiest way to "level out". also...if you haven't already considered it, the bilstein hd shocks made for the new rados are great, not too expensive and a reletively easy install. others have had success with the edelbrock's. i have the bilsteins and feel they improved my ride dramatically.
bco
bco
I am thinking maybe next wk ill go get it changed. If it lasts 100K mls shoot ill just have them do it.
Ill find out about the blazer later on today. The guy tried to bs my dad on the phone yesterday and tell him it will leak some oil. Boy he didnt know he was talking to a mechanic.
For some reason though my dad wont work on the new blazer. To compact in the engine compartment or something. He always works (changes oil brakes) on his. I guess when you get free oil changes you take it in. And plus he isnt getting any younger.
Ryan
When you try to they deny, bring up unrelevant stuff, or flat out ignore the questions or replies.
Its a no win situation
Ryan
wants to claim that i admitted to making stuff up. i give a rip what that guy thinks of me. when he puts together a coherent argument i may re-engage with him. until then, i'm leaving him alone. he's the kind of guy that, if consumer reports said the sky was green and the grass was blue he'd go around telling everyone it was so. period, end of sentence. i've got better things to do with my time than worry about him.
bco
'01 Ext. Z71 LT, Carmine/Graphite, locker, 3.73, w/trailering package.
Anybody seen those little antennas roof mounted over the drivers head on the new ones? On-star or cellular option?
smikes
j/k the Z71 pkg makes you seem a little younger. The fender flares would have taken about 5 yrs off your age.
Merry christmas you have a great present.
SHOW PICS!!!
Ryan
(smikes i hope you know im joking on the old thing)
Do you let your dog ride inside your truck? How does he/she do getting in? I have a 9 mo german shepherd who's not a jumper, who will probably ride behind the front seats whenever it's raining.
WHen he rode in my truck i had the seat up. He could barely see out the front window which bothered him but he could see out the side. He was happy. In my dads blazer he rides on the back seat or on the console between the 2 bucket seats hehe.
Oh yea the first time he got in my truck he was scared because of the nerf bars sticking out i think he kept looking at em funny.
Ryan
http://people.ne.mediaone.net/mpalombo/index.html
Ryan, Thanks man, I wasn't aware of the age adjustment.
My truck is Dark Carmine and I'm 35 BUT Z71 (-3) and Fender Flares (-5)... I'm not even 30!!! WoHoo
Do I also get some off for 2 tone, that means the truck isn't all carmine?
Mark
Ryan
If anything it adds to the yrs cause your trying to disguise the true color of your truck
Ryan
Mark
They look bigger than 245's, but the webpage doesn't mention them.
Mike L
I was looking at your wish list, and have one of my own going already. With no money down, I'll be able to get some of the following sooner, than later: Line-X UTR, CD Changer, Bazooka subwoofer, speaker upgrade(?), chevy splash guards, rubber floor mats, clear front end protection (X-Pel?), and maybe one of those really nice sunroofs.
I haven't had the money in the past to dress out vehicle they way I want it, but this time... well you only live once...
smikes
I want the molded splash guards but It says on the Chevy web page that you cannot use them if you have the flares.
I know what you mean.... This is the most expensive vehicle I've ever owned and I'm decking it out. Like you said "you only live once" Lets just hope the economy stays like this (not betting on it, but I hope)
If you want me to post a pic of your truck send it to me and I'll put it on the page.
Mark
Um hardest part was taking off the rear wheels.
You use 2 existing fender flare holes (tabs that pop out easily) and 1 drilled hole to attach each mudflap. I looked for about 3 months before i got the truck for flaps that would fit my truck w/flares. These were the only ones i found. They work great too. They pretty much keep my nerf bar by the front wheel nick free and the rear end chip free.
Let me know if you need anymore information on them
Pics/questions etc.
Ryan
Hunter
PS im leaving school right now to go deer hunt and for the week off for thanksgiving. Whohoo!!!
