Visitor Agreement.
Ford is replacing all the Firestone Wilderness AT's on Ranger and Explorer.
Fact:
Tacoma trucks can come with Firestone Wilderness AT's.
Fact:
Toyota is not replacing Wilderness AT tires on it's vehicles.
Suggestion:
Either there is nothing wrong with the tires or Toyota does not care too much about its customers.
Go check out the documented problems on Tacoma. There are may documented cases of Wilderness AT tires failing on Tacoma. My personal experience with Firestone tires is, when you get a flat, they will come apart real quickly and the tread will separate from the casing. Had that happen 3 times with Firestone FR 480's on a Caravan.
And no replacement tires from Toyota. . .
Putting a BBK supercharger on a Ranger boosts the power quite a bit. Not sure I would bet your title if you ever ran into a Ranger 4.0 with a charger system.
Steve Cohen
It appears the REPLACEMENT tires are doing the same thing...
This points to the problem being how Ford designs their vehicles.....
http://www.msnbc.com/local/rttx/a835234.asp
Vince-->In addition to above, yeah, Ford's engines make great torque down low (3000 for 2.5l and 4.0l, 3750 for 2.3 and 3.0l) 4000 on 2.4l and 2.7l, and 3600 for 3.4. I rarely go past 4000 rpm, and thats only in first gear on my 93 2.3l.
Anybody know why horsepower and Torque always is the same at 5252 rpm on every engine ever made(not just Rangers and Tacomas)?
Barlitz&All-->Re:Spoog's TSB's. Yeah I looked up a few of them specifically, and they could mean just about anything. One is the new 5 speed automatic transmission, that in case of repair, Ford wants them returned to the factory for a complete tear down to see why. Sounds good to me. Another TSB was something about an ashtray being available. TSB's could be new options available, technical instructions on any maintenance or repair, or yes, specific parts that need to be checked for problems.
Tony22r-->You basically like to take the facts presented, re: barlitz's alldata TSB info, and you say it was misleading. YOU are misleading by paraphrasing, over generalizing and lumping them all together. Do you realize that those TSB's identify the known problems, and ways to fix them? Innacturate speedo's? Simply thats about 3 gears and I speedo cable. It could be as simple as a cable coming loose. Brake vibration? The TSB is Brake Vibration/Inspection/Friction Material Replacement. In the worst scenario of this, you might need to replace the rotors and pads. Which will cost you under 100 bucks an axle easy. How much for Tacoma? Don't forget the standard ABS, and this does "vibrate" under full pressure stops, so it could just be consumer mis-information. ATF leaks from Radiator? You got lines that might just need more teflon, or just be tightened. Your "defective wipers" are wipers that turn on in the off position. Don't you think this is as common as you would have us think either. Your "squeaking" doors, are only on rear doors according to TSB. Ever hear of teflon grease or just WD40? Finally you say "It may well be that Ranger outsells Toyota 9:1, but Ranger also has NINE times the number of Defects, Recalls, and Service Bulletins!" Then do the math. 9(your figures) more vehicles with 9 times(your figures again) more defects, recalls, etcc? I GUESS THAT MEANS THE ACTUAL AMOUNT OF VEHICLES AFFECTED ARE THE SAME. You will see more coverage (media, TSB, whatever) because they will always be more on the road. Take the idiot factor into play, and you'll have plenty of consumers do the worst they can (or nothing at all) to maintain the vehicle properly. I thought Ford stood for First On Race Day.
smgilles--->Are you supercharged? because "my 3.4L has 260hp/295ftlbs. of torque" isn't naturally aspired or normal stock. Gotta keep to your class! Is it factory, and how much boost? Watch out for any supercharged 4.0l though!
Spoog--->Explorers only, not Ford. So it doesn't belong in the forum me thinks. Unless you think by generalizing two distinct brands (both best selling in class!) that you can cause grief on Ranger owners and prospective buyers? It's funny how Goodyear had 2 claims in the time that Firestone had over 1100 claims! You seemed to forget that fact that I've been thath posting over and over. So tell me again, how is that bad?
http://media.ford.com/article_display.cfm?article_id=8482
cpounsr--->The Tacoma's better keep their Wilderness's inflated! At least the vehicle is much lighter than an SUV so it's got a little less load to carry. And that's Firestone's argument on why the same tire had less claims on Ranger Vs. Explorer. Firestone just needs to admit they make a cheap tire with a thin firewall.
Frey--->I think you're very right on Ranger vs Tacoma :: IBM vs Mac. (OR VHS vs Beta)
Smc--->Good question on tariffs. I don't know how much is built and where, but I do believe that California is the final assembly. No doubt the profits are still going over seas, and don't forget the 2-3 thousand in typical price difference. And that being practically 10% (give or take) the price of the whole truck, that more than makes up for any tariffs.
Eharri--->Don't forget peak horsepower is greater in supercharged applications, but it's definately not a flat power curve. Also, there is the parasitic drag a supercharger requires, it takes crank power to make power. But there is usually a MPG increase, and that cool sound at idle. But Toyota owners don't even want to start debating aftermarket parts availability...
Also, if the tariff was removed and Toyota's did cost less, Ford would charge the amount of the tariff less also. Tariffs are protectionist in theory only. In reality, tariffs set the low end of the price scale.
Tariff = bad for consumer
I will keep looking
Btw, in my area (baltimore-washington d.c.) the price difference between the ranger and tacoma is less than $2000 on the high end. It seemed that there was about a $1000 difference in MSRP between the taco I bought (with abs and security system) and the Ranger I test drove.
Tarriffs, although Toyota pays Tariifs for its vehicles its still cheaper for them to build factories over here and assemble them here, rather than just ship the whole vehicle over here. Another interesting topic,it seems Toyota and Honda ,Nissan have all sorts of problems with there vehicles in there own Country but keep it totallly hush to the USA, It seems most of there money is made in the US. I read this in one of the other topics.
John
Jacob Davis
He was only responding to your post in 1590 where you compared the Ranger's 16 TSB's to the Taco's 10. I think you were trying to make the point that Tacomas aren't as good as people think they are.
Funny, after he posted what the TSB's for the Taco were, it was suggested that we don't concentrate on TSB's.
1500 miles on my 2001 Taco. No sqeaks, rattles, shimmies, shakes or problems.
God's speed,
4x4 system. The Ranger has a pulse vacuum system. Flip a switch your in 4 high, switch the switch again your in 4low. I have had two Rangers. My first went to 96K with no problems at all. I presently own a 98 Ranger 4x4 offroad pkg Ranger. I put a K/N charger kit, and some P265x75R16's on. I have about 43K with no problems. I live in Oregon, right by the Cascade range. I have had my truck buried in snow, and the suspension in mud and goop (only did this once it was one heck of a mess to clean up), loose soil you name it. I travel from the Coast range to the deserts of Eastern Oregon. The 4x4 system never failed on me when switching to 4high or low. The RAnger offers a limited slip diff, Toyota does not. If you plan on offroading a whole bunch and in severe, I mean really severe terrain the locker would be better that Toyota offers. I don't think you will want to take your new $24K Tacoma into places a locker is really supposed to be used.. The Ranger offers the best overall pkg for the everyday 4x4 user. More power, more torque, better rear diff, more towing. Opt for the Ranger. But, get rid of the Firejunkers and get some real offroad tires like a 31" BFG or Goodyear. This makes the whole look of the Ranger change and gives the you much better tracking.
Good luck!
Complaints Database
Report Date: June 26, 2001 12:41:25 AM
ODI ID: 731922
Make: TOYOTA TRUCK
Model: TACOMA
Year: 2000
Date of Failure:
Incident: No
Fire: No
Number of Injuries: 0
Component: TIRES
Summary: THREE WEEKS AGO I PURCHASED A 2000 TOYOTA TACOMA PRERUNNER WITH FIRESTONE 265X75X15 WILDERNESS AT TIRES ON IT. AT THE TIME OF PURCHASE I QUESTIONED THE DEALERSH
ODI ID: 559264
Make: TOYOTA TRUCK
Model: TACOMA
Year: 1999
Date of Failure: Wednesday, November 01, 2000
Incident: No
Fire: No
Number of Injuries:
Component: TIRES
Summary: FIRESTONE WILDERNESS TIRES (P225 R14) FAIL TO KEEP CONSISTENT PRESSURE AND ARE WEARING, CONSUMER HAS EXPERIENCED 3 FLAT TIRES AND IS REQUESTING THAT THE TIRES B
ODI ID: 554638
Make: TOYOTA TRUCK
Model: TACOMA
Year: 1999
Date of Failure: Thursday, June 01, 2000
Incident: No
Fire: No
Number of Injuries:
Component: TIRES
Summary: AT ABOUT 6,000 MILE THE CONSUMER NOTICED CRACKS AND CHIPS ON ALL FOUR FIRESTONE WILDERNESS AT II TIRES AND IN BETWEEN THE TREADS, CONSUMER ALSO NOTICED PREMATUR
ODI ID: 745687
Make: TOYOTA TRUCK
Model: TACOMA
Year: 1999
Date of Failure: Wednesday, August 18, 1999
Incident: No
Fire: No
Component: TIRES
Summary: MY FIRESTONE WILDERNESS TIRE EXPLODED JUST AS THE OTHERS HAVE BEEN DESCRIBED. YET MY TIRE SIZE AND MANUFACTURER LOCATION IS NOT ONE THAT IS BEING RECALLED. I
Hmmm EXPLODED?!?!
The problem with the tires is running with lower pressure, nothing wrong with the vehicles. . .
OH, this is interesting. . .
ODI ID: 738253
Make: TOYOTA TRUCK
Model: TACOMA
Year: 2001
Date of Failure: Friday, December 01, 2000
Incident: No
Fire: No
Component: SUSPENSION:SINGLE AXLE:REAR
Summary: PAYLOAD RATED AT 1674/LBS ACCORDING TO THE SALES BROCHURE AND SALEMAN. WE ADVISED THE TRUCK WILL BE USED FOR DELIVERIES OF 600-1200/LBS. LOADED 800/LBS AND THE
Hmm what happened when 800 lb was loaded?
5 Stars vs 1 star crash rating and it shows. . .
Http://www.fordranger.com/4l/22510.html
SUPPOSEDLY unreliable '95 Ranger
72,000 miles, still running like new, dozens of 2-3 hour road trips without a single mechanical hiccup.
http://www.hwysafety.org/vehicle%5Fratings/ce/html/summary_smpickup.htm
The result of which is that both the ranger and tacoma get an acceptable. With the taco you will probably break your left leg and your bumpers will be damaged. With the Ranger you might break your
neck depending on the head restraint.
Here is the NHTSA's crash test results:
http://www.nhtsa.dot.gov/ncap/cars/2001Pkup.html
This one shows that the ranger is a four star and the taco is a three star
Rangers are overall a little heavier, but its available 4.0l V6 in a regular cab vs. a v6 in Tacoma's Double cab would definitely be unfair. I drove both in 2001 trim, with automatics, and I know the Ranger had more grunt.
Issteelman->A button could break, but at least it's not a direct link to your transfer case. Which do you think would be cheaper to fix? I really don't think either are prone to failure either, because we would have heard about it here. (TSB's, spoog, something)
smc--->Actually your first link is giving the Ranger a Good Rating on neck injuries, while Tacoma is Average. Looks like it's the "head restraint design" that's marginal/poor on rangers. Of course there is a disclaimer on the left side of that page, stating that heavier vehicles fair worse in "kinetic tests" while typically fair better in real world crashes due to mass/force difference against the lighter vehicles. Another interesting note is that they tested 1998 vehicles. Check out this link for average costs to repair on 5 mph crashes...
http://www.hwysafety.org/vehicle%5Fratings/low_speed_smpkup.htm
Steve Cohen
Oh yea, had to shoot the cow, wasn't dead after I hit it doing about 50mph.
I just love the way these Toyota boys try and try to make their 190hp/220ft/lbs of torque more than the 205HP and 240ft/lbs of torque offered now in the Ranger. Just face it.. The Toyota is SECOND in HP and Torque along with its torque curve when comparing a Ranger..
For one a vehicle no matter what make is NOT an "investment". Ask any financial planner and they won't tell you to "invest in a Tacoma" LOL!@!
Toyota has lost its way in the value area. Tacoma's are spendy when comparing option for option to a Ranger.
I'm hearing rumors around the net that Toyota has caved and is going to offer a limited slip diff in 2002 model year. Too bad for all those Tacoma owners that have one wheel drive! LOL!!
if you want quality, DON'T buy a ranger. good luck.
Hmm, in order of recommendations:
First:
Ford Explorer Sport Trac (described as a cross between the Ranger and Explorer)
"... well rounded vehicle in this class...Handeling, braking and acceleration are all good... uncomfortable ride and noisy engine are low points...0-30 in 3.2 cc, 0-60 9.6, 1/4 mile 17.4...took under 25 seconds to tow a 5,000 l. trailer to 60mph."
Second:
Dodge Dakota
Third:
Toyota Tacoma
"... reliable workhorse but a poor choice for an everyday...vehicle...fairly refined and efficient powertrain...best fuel economy of class...On any road the Tacoma has a tiring ride...rough pavement sending sharp shocks into the cabin...feels clumsey with slow heavy steering...ungainly on the course,,,0-30 3.2 sec., 0-60 9.6 and 1/4 mile 17.4 sec....took 28.6 sec. to pull...5000 lb trailer to 60 mph."
So it took longer to get to 60 mph towing 5,000 lb for the Tacoma and the acceleration times were equal to the Ranger. . .
http://www.grapeape.rockcrawler.com/trips.htm
Is there a Home Depot at Tellico, North Carolina or just some of the finest 4 Wheeling in the east?
Case closed spoog, your wrong again!
Enjoy!
Maybe next year the Tacoma will improve enough to compare with the Ford's "uncomfortable ride and noisy engine" .
Toyota Tacoma - Unanimous pickup of the year over Ranger 1998- fourhweeler
Ultimate 4x4 winner in head to head contest with Hummer, Wrangler, And Range Rover- Toyota
May issue, 2001 Four Wheeler
" The ranger rattled like a rattlesnake offroad:
-edmunds.com
" If buying a used ranger, take it for a very,very long test drive" - edmunds.com
Good comeback!
I think the reference was mainly directed towards the TRD package.
CR was reviewing the vehicles in the light of a passenger vehicle.
There were positive comments regarding the Tacoma in offroad situations.
spoog, by you just don't learn not to take me on:
Tacoma, a solid 3rd place in Aug 2001 Consumer Reports review, ahead of the S10 Chevy. . .
Consistainly reviewed in this manner by Consumer Reports:
-Ranger recommended by Consumer Reports as a Best Buy, 1995, 1996, 1997, 1998, 2000. . .
-Ranger XL a "Top 10 Best Buy" Fourwheeler magazine 2000
-Ranger "Best 4X4 Compact P/U" Fourwheeler magazine (was 1994 or so)
From Edmunds:
WHY WE BEGAN THE MOST WANTED LIST
Our staff members get the same question over and over: What's the "best" car or truck?
There isn't a single "best" car or truck that will meet everyone's needs.
When somebody asks us what the "best" of the crop is, we respond by quizzing the inquiring mind about her needs and wants in a vehicle.
Still, readers want to know what cars and trucks we'd buy given the resources.
-Ranger, selected by Edmunds as "Most Wanted 2000 Compact P/U"
http://www.edmunds.com/reviews/mostwanted/articles/43047/page017.html
-Ranger, selected by Edmunds as "Most Wanted 2001 Compact P/U"
http://www.edmunds.com/reviews/mostwanted/articles/43048/page019.html
smgilles->Is it factory, and how much boost? I'm also curious on any MPG increase you may be getting...
smc/smgilles-->Those grill guards are only as good as where they connect. If they connect to the bumper supports, or just weak front frame rails, they do little but add more mass to the front. Like smgilles said, the grill guard will probably be fine, but the whole front frame or engine bay will be in trouble.
remainedsilent->Interesting what you say about Ford's and Recalls. Never had to take mine in, EVER.
Great Dane--->How's the new truck? Haven't heard much from you lately.
My gas mileage varies, if I stay out of it and drive rational I see an increase in gas mileage
(on the interstate), if I have a lead foot (in town) like I did when I first got it my mileage dropped on average 1-2mpg. I have to admit it is hard not to zoom everywhere:)
I have been very pleased with it (pretty quick for a compact pick-up). Some guy in a full size dodge dropped a brick in his pants after I went right around him. He asked me at the next light what I was running and I told him Toyota had put a new v-8 for the Tacoma. You have to love ignorance (now I know why he was in a Dodge). The best part is that Toyota will cover the supercharger for 60month/60,000 miles just like the rest of the powertrain.
