-September 2024 Special Lease Deals-
If you go to most autoparts stores they will read the code for free and reset if necessary.
The pipe easily unscrews from the pump. I clean mine with gas and a small wire brush about every two years. You'll have to purchase a new oil pan gasket.
If you let this go for very long you could have serious problems, I broke a rod in a 2000 318ci, this destroyed the motor. This was due to wearing out the rod bearings do to improper lubrication.
But to help, I own a Chilton manual on every vehicle I own. It won't help with dignostics, but it will explain how to dismantle and/or install any part on the vehicle.
I am having the same problem with my 06 Durango. We replaced the battery and the tire pressure and cargo lamp lights are on. How did you fix this problem?
Brad
Please help!!!
It would be easier to go the Chrysler garage and pick up 4 new pins, but I completed the job at home on a Sunday.
I reconnected / spliced the other end of the wires into 4 different areas. I do not recall at this time where those 4 wires went - but 3 of the 4 were over my the air intake for the air cleaner (passenger front fender - above the tire, under the hood).
I did have some roadside dive mechanic tell me it was a crank sensor,a common problem on durangos according to him, I don't even know what that is.
Any help would be appreciated
Matt
The question now is how did it get there. Does anyone know?
ps i had the rotors checked left side lil more worn then right thats it
radiator fan clutch. when it's at idle , the fan is turning very slow and thats when it starts to overheat. my problem is how do you keep the water pump pully from turning when i try to remove the clutch from the water pump. theres probly a tool for this, but i'm not sure. any information about this would be appreciated .
Also I may be misunderstanding the situation with your RPMs, but 2100 @ 70mph is normal.
I am having these same problems and my durango is a 2000. I am wondering what sensor it was that was replaced and what size motor you have? The model of the tranny would help also if you know what it is.
