why don't you cut and paste your link over to
3 Series Maintenance and Repair
See you over there!
Visiting Host
I have 07 328iX, RFT with 25K (16" tires). The noise as many described here is too bad. I want to replace the tires with regular tires (NOT RFT) but I am not sure about the following things (I do not have good knowledge about tires, machanics...):
1- First, can I replace the tires at a tire shop (not the dealership) without affecting BMW warranty (I original and extended warranty)?
2- Will the tire pressure system continue to work with non RTF tires? In general is it ok to not use RTF (I am not sure if it affects the all wheel drive system).
3- Since the car did not come with a spare, where can I buy a spare and its toolkit?
Any recommendation for what to do is welcome.
Thanks for your help.
A1: Yes, GFTs (Gets Flat Tires) will not affect your warranty.
Q2A: Will the tire pressure system continue to work with non RTF tires?
A2A: Yes, the TPMS system works regardless of what kind of tires you have mounted on your factory rims.
Q2B: In general is it ok to not use RTF (I am not sure if it affects the all wheel drive system).
A2B: GFTs work perfectly well on your car with no other changes, and many-many folks have long since switched to GFTs.
Q3: Since the car did not come with a spare, where can I buy a spare and its toolkit?
A3: Your dealership can order you a kit.
Best regards,
Shipo
So what do you guys recommend? Fix a flat with compressor, Conti Comfort kit, buying a tire and wheel and leaving it in the trunk? Any solutions or suggestions would be very welcome.
I'll see if I can ride out the winter and see if 3G RFT will be out by early next year.
http://www.tirerack.com/tires/tires.jsp?tireMake=Continental&tireModel=ContiProC- ontact+SSR&partnum=245HR7CPCSSR&vehicleSearch=true&fromCompare1=yes
So you guys think it is better to have the full size RFT spare?
Now, which wheels should I get and which jack & tools can I use (reasonably priced)?
With the full spare, how do I secure/store it and the tools? I think saw a pic somewhere of someone with a really neat net setup. Anyone has a link or any info?
Thanks again for helping!
One of the fellows said that his neighbor went in to a dealership and created a scene....at which point the service manager came out and agreed to replace the tires. If you scream loud enough....you will get looked after, otherwise....be prepared to shell out $2,000 !
Also...just an fyi...the reason BMW went to this technology has nothing to do with safety but rather has to do with their bottom line. Remember that they no longer provide a spare tire which saves them money. Safety is just the spin so don't be fooled !
Frank
You landed in a discussion specifically about the run-flat tires. Have a look at our list of BMW 3-Series discussions. I'd pick one that has your year included (e.g., 2009 BMW 3-Series) and post there for more on-topic feedback.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Be warned though that I had to get a set of new wheels as well (I never liked the stock wheels, UGH), a jack and tire wrench, just in case I get a flat. I know it's rare, but I'd like to be prepared for the just in case. Good luck with yours.
As a general comment, a lot will depend on how low the pressure was and tire deterioration, what kind of puncture, etc. Some have failed and shreaded within a few miles. But normally due to running with extreme wear, (inner wear on rear tires) or running low pressures for too long and then using in anger.
I'm not sure how we can see BMW failing to give us information. I know the USA is different that the UK, you seem to have labels covering every eventuality, where over here in the UK we have to take more resonsibility for our decisions
HighlandPete.
:P :P :P
The jury is still out on what I think about run flats, only have 5k miles on the tires. Not psyched about buying 4 tires when I only need one.
I maintain 33 psi in front and 36 psi rear and check no less frequently than every 2-3 weeks. The car has never seen the high side of 110 mph (I don't track it, and if I get stopped, the trooper wins - I don't like losing) but it does take corners aggressively.
Will I buy another set of ContiProContacts, based on my own experience, when these wear out eventually?
You betcha.
If we are talking about the concept, then I'm the first to play the under developed technology line. I've posted on here over the years and many other forums on this subject. I've had big debates with BMW UK, had Bridgestone involved, had a Bridgestone field engineer in my car, to pass opinion on the ride quality. Currently I run conventional tires on my second wheel set. I even changed dampers to try and improve the drive on run-flats, at cooler spring/autumn temperatures.
I cannot forgive BMW for not having spare wheel space. Even on run-flats we do travel remote, and I don't trust getting home even on a 'flat' run-flat tire. So a spare uses valuable space.
No, I don't suppport an under developed technology, BMW got it wrong and we are having to live with the issues, as feedback shows how poor the thinking was.
HighlandPete
Always good to hear from you, Pete.
"Travelling remote" is my #1 objection to RFTs, even if they ever do address the noise, wear & cost issues. The damn things aren't available except in large cities & I've driven hundreds of miles from large cities in the middle of the night & on the weekend.
A few years ago I was in northern Nevada one Sunday morning about a hundred miles north of Winnemucca (not a large town, but the only "nearby" town) when I had a flat with my full-size-spare-equipped car. Took a 15 minute break to change it (lots of stuff to move to get at the spare, otherwise it would have been quicker) & took the flat tire to a shop in Phoenix the next day -- total non-event.
With RFTs it would have been a much bigger deal.
Wait a second...
I called my dealer because I was wondering about tire rotation as I have over 5k miles on them now and they told me BMW does not recommend rotation because of the camber angles on the wheels. Is this BS? Are you doing the rotation yourself?
Since I had bought the wheel warranty for about $700, I thought I could claim vibration in the steering wheel and have then give me two new rims. Instead, they checked out the wheels, test drove it, etc and told me that, although they wouldn't give me new rims, they would rotate the tires and hopefully, this would correct the problem. In fact, the issue may have been in my imagination the whole time, but they did the balancing & rotation AND charged me for the work!
Basically, my plan backfired. Nonetheless, the rotation did no harm, and actually gave me the marginally better traction in front.
Bottom line: If your tires are wearing evenly, there is no need to rotate. If they are not wearing evenly, you probably have a balancing or alignment issue that rotation will not help, and could even hurt.
Hope this helps.
I had 1 flat indicator once which I tested it and was 18 psi, I pumped it up, drove it for a couple of days and I noticed the psi would go down 2 or 3 a day. I took it in and the dealer said they found a cracked wheel which was leaking the air. The tire was not leaking. The tire/rim protection paid for the wheel which was ~$500. (I had them replace all 4 tires for $1,200 - a little more expensive than Tirerack)
The car also developed vibration at 75+ mph speed and I took it to an indie shop and they fixed it (so it was a balancing issue).
I am hoping the 2nd set to last 50k+ miles until the Bridgestone 3G RFT are available. Last I heard it should be out in spring 2010?
Now, if I could just get the ignorant inconsiderate buggers to not scratch my car in the parking lots, I'd be in Nirvana.
Having said that, it Bridgestone comes out with the 3rd generation tires AND they prove out in time, I may reconsider. With all the negative feedback on the EL42s, it is doubtful. They just don't seem to have their act together despite a ton of marketing.
I bought the car for handling. That does not relate necessarily to a "stiff" ride in that subjective sense. It does relate to roadholding, cornering, braking etc. The RTF's are substandard in this department. Regarding harsh rides, that is why I also have a Honda S2000, a very purpose oriented sports car... From the other posts on this sight I wonder in BMW is even listening? Seems pretty telling.
I have been reading and replying on this site for 2 years now and there is far more negative responses re: RFTs than there are BMWs on the road. I am one of those negative responses.
Have a 2006 330i optioned to the hilt which then includes Sports Package with tires than cannot be rotated because of their differing sizes.
FIRST ORIGINAL SET: ran for 24,000 miles and became close to "treadless". All mechanical in steering was diagnosed perfect. Had new tires installed by BMW dealer. He advised that my driving habits wore tires prematurely. Well at age 64 I guess we are a bunch of harsh drivers.
SECOND SET: At 46,000 the dealer states that they are unsafe to drive on. "THEY DO NOT TRACK".
Well - I knew that as when you drive on the highway and you hit the slightest surface imperfection, the steering pulls to that side. Lucky for little ice where we are. Now at 66 years of age, the same dealer did not mention my driving ability or lack of it. I "thought" that over the past 50 years of driving with no accidents, I knew how to drive everything from VW beetles to Corvettes (and everything in between) which includes 4 BMWs.
BRIDGESTONE RFT's are death at any speed. AND a wear rating of "1" !!!
We won't talk about the the practicality of the beasts. That has been dealt with here over and over by people far more qualified than I.
So after 46,000 of a mix of city and hwy. driving a THIRD SET (RIGHT> 3 (not 2 but 3) of tires is needed. It does not take a rocket scientist to figure out that one set could have been bad and the second.............BAD TIRES
At 66, my wife and I want to live a "few" more years. Will not buy BRIDESTONES AGAIN. BMW has same on new models. WILL NOT BUY ANOTHER BMW with them mounted.
Car is GREAT.
People who put them on such a finely built automobile are IDIOTS!
John..Springfield Oregon
Are the Bridgestone RFT what's included with the 335? I will definitely put over 50,000 miles in 3 years and no way do I want to pay for 3 sets of tires!
Don't worry about the tires. Most of these people complaing are kids and don't know the first thing about cars.
