GO for it!
As for rolling on turns- It won't roll going 40MPH- My huband is a bad driver and it has not flipped yet. Just watch for the sliding in wet and snowy weather.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
http://www.aisin.co.jp/english/products/auto/index.html
That will make these rigs collectors items!
Only problem is it goes through a lot of gas! Feels like I am filling it up twice was much as my old Dodge Neon. I do not have the exact gas mileage I am starting to keep track of that. Anyway, what could be causing the car to be eating gas? Anything I can check or do? Thanks all!
Give us the MPG ok?
tracker 22-25 city/highway
neon 28-34
i am curious, before you purchased this tracker, did you reseach MPG? these 2 vehicles are also apple to oranges. and with that in mind you have to expect a difference not only in how they operate, but what they are used for and over all sizes & weights. the tracker is built on a Truck frame which is heavier and stronger.If you bought the tracker as a gas Miser then you bought the wrong vehicle. but if you bought it for its room, and ability to drive through all-season conditions, then you made the right choose. my 99 tracker 2-door is a tank. i drive it in places that make others nervous. as a matter of fact, i did so Today. I drove through water so deep it was up to the bottom of the door. and went over rocks that would loosen your teeth from all the bouncing. this is why i bought my tracker. my tracker which is a 2.0 4x4 is about as good if not a little worse on gas than my 2-wheel drive V-6 ford ranger. i roughly get 20mpg in my tracker. but i do have a little bigger tires and aggressive tread which isnt quiet on the road nor made to save fuel. but in snow! move aside cause i am coming through... lol
SIZE-215/75R15
TYPE- http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&t- - ireModel=All-Terrain+T%2FA+KO
You'll find your tracker to be a smart investment, a trusted friend, and a go anywhere tank! When I can tell you about a buddy's 94 model still going, with only two timing belt changes and a new clutch all this at 175K, well that is a testament to the good design of these great little suvs. Never mind what the rags say, these are true utility rigs that can go pretty much anywhere, turn on a dime and give nine cents worth of change!
My only complaint is that Suzuki did not drop the Aerio engine and its 145 horses under the hood of these rigs. 127 HP is a bit weak, especially in W PA with all the hills and stuff, but otherwise, I think its a fine motor.
How isyour 4WD shifting now? MIne was pretty stiff when new, but has since loosened up a bit and now its a piece of cake to go into 4WD.
I hear cooper weathermaster tires are good for mud and snow, I have a set on order to mount on the extra rims I got from a fellow yahoo group poster.
mudders
http://www.coopertire.com/us/en/ProductDetails.asp?ProdType=LtTru- ck&id=28
i almost bought these tires b4 going with my B.F.GOODRICH all-terrain ones. i am still considering the DISCOVERER STT...
arkainzeye@hotmail.com
blop25@yahoo.com
