Mrbill
With the car running, put it in drive first and have someone stand off to one side with the hood up and watch. Hold your foot firmly on the brake and start pushing don't on the gas. If the engine raises up or rares up, you have a busted motor mount. If it doesn't rare, try the same procedure in reverse. Simple test and it will tell you if you have a bad mount. Good luck.
if so, with the vehicle in drive (fwd), are they pushing from the front to try to move the vehicle backwards, or are they in the back, trying to push the vehicle forwards?
2 People are needed.
With hood up, engine running, person 1 should stand to the side (beside the front wheel, perhaps).
Person 2 should be in the car, with foot firmly on the brake pedal. Person 2 should then press the gas when the car is in drive, while keeping his/her foot on the brake.
Repeat that process with the car in reverse.
Person 1 will be looking to see if the engine raises up/moves around from its original position.
Does this help, and is this what you were meaning, wanger1?
I have replaced the starter, both battery cables, rotor and cap.and battery.
I also was wondering what the chances are the starter is bad It is a pep boys starter.
I was wonder if it could be the ingtion switch ,or maybe a relay
I do not know where to go from here or what to test next.
The previous owner cut out the aftermarket stereo and I don't khow which wires are for what.
Thank You!
Apxracer
Thank You!
Apxracer
an hour online and I found this free site.
-apxracer
I pulled each spark plug boot off individually to confirm spark and noticed that when I pulled the left most boots (driver's side) there is no difference in the engine. It is however evident when the right side is pulled as the car almost stalls.
I also measured the fuel injector resistance and it was 1.7ohms which is within spec. Can it be the ECU and where is this located? Also the manual said to check the resistance of the injector resistor terminal which I also cannot seem to locate...it should be a connector harness of 5 pins that is located around the strut tower of the left fender apron???
The plug appears to be slightly fouled but not overly wet...so where do I go from here. I was thinking about testing the injectors by swapping them to the working cylinders but I have strong feeling that it could be the ECU or some other electrical sensor...
Thanks in advance,
Peter
The PCV on that model is in a weird place. While standing in front of the car lean over and look down in between the intake tubes. It is actually in the top of the intake, but because of the location, it is hard to see. It should be at the other end of the tube coming from the valve cover.
Mrbill
japanese carburetors are very difficult to rebuild and you don't want to go in there unless you really have to.
I own an '88 LXI hatchback with 217K miles. Needless to say its had many parts replaced over the last 20 years, but it has the original O2 sensors. I'm always reading how O2 sensors should be periodically changed, especially from places that sell them! So, I get no check engine light, I get good gas mileage, as high as 37MPG, and the car runs great and passes emissions. I'm guessing those little buggers would be a PITA to come out after all this time.
My question is are their others who have never changed their O2 sensors? Should I relax about not fixing what's not broken?
Gage .. generally stays the halfway mark but out of the blue starts climbing to HOT .. may be hot foe 15 seconds then back down below the halfway mark on the temp gage .. then go back up .. after a while goes up and stays up at HOT.
Fan runs when AC is on (but car still runs hot even when fans are on) does not run otherwise.
When HOT and I cut the car off and open hood even though the fans aren’t running I can hear a humming coming from back of engine close to firewall.
Just paid $187 to get fixed .. they replaced sensor and thermostat .. worked great for one day then started doing the HOT bit again.
??????? HELP !!!!!!!!
Any and all help will be greatly appreciated.
Just a tip - when the car IS running hot, try rolling the windows down and running the heater. It'll pull heat out of the heater core of the engine and help it cool off. I've had to do this when my radiator fan quit working in my '96 Accord. It kept me from the shoulder since it stayed in the safe zone long enough for me to get to the dealer.
http://carmaintenance.wordpress.com/2008/07/04/why-does-a-car-engine-overheat/
With a blown headgasket, the exhaust gas is able to be pushed pass the gasket and into the coolant fluid. This air and pressure causes the waterpump to not be able to circulate the fluid very well, and the exhaust gases are very not so you also overheat. Hope you don't have this problem.
If you just have air in the system from draining and filling, most of the time it will clear itself with some heating and cooling cycles. Engine heats up, pressure builds up, it blows the air (at the highest point) past the rad cap and into the overflow tank. When it cools, it draws coolant back in to refill.
Sometimes you may also have to purge the engine block air, some vehicles have bleeder screws near the thermostat.
