http://members.troublecodes.net/hondadude/95AccordEGR.htm
http://www.autobatteries.com
have lookup tables for auto batteries.
Mrbill
i had a '94 that i loved too. i had a "non-linear" fuel gauge. it would read full when filled, but drop pretty quickly and not a function of how much fuel was actually in the tank. this didn't bother me much. i always computed miles driven (via ODO) vs. fuel pumped.
then, knowing the size of the tank (capacity) and my fuel economy, i knew how much i could realistically and safely go once the light came on. i was in the habit of resetting my ODO between fills, and always filling.
if you are really bothered by it, call or take it to an independant. he can probably put a new sender / meter unit in the fuel tank or re-calibrate the existing metering unit.
see part #28 here:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- cgry1=Accord&catcgry2=1994&catcgry3=2DR+LX&catcgry4=KA5MT&catcgry5=FUEL+TANK+%28- 1%29
Over the past year, I have had two different brands/sets of directional tires (Yokohama Avids & now Michelin Exalto A/S tires). I keep experiencing erratic handling, mostly noticable on the freeway. Road texture, especially grooved pavement seems to trip up the car's handling, causing erratic lateral movement as if the car riding on rails. In the past year, 3 mechanics checked out my steering and suspension system and found nothing wrong. My alignment has been checked many times over the year and is fine. I did have new Monroe Sensatrac strutts installed before these sets of tires. This was my second set of Sensatracs, where the previous set were fine. I have the stock alloy rims. Not sure if old age or corrosion on wheels could cause this problem.
Rotating the tires front to rear seems to change the handling behavior somewhat. I did hear from one mechanic that directional tires are more prone to these type of handling problems. I wonder if anyone else has experienced these type of handling issues. Thanks
I would very much appreciate any tips or advise on what to check for. Thanks in advance
This is absolutely typical.
My 1996 Accord LX has never gotten above that 3/8ths position except when it actually overheated due to a cooling fan motor failing, which caused the temp gauge to rise when I would stop.
Re-connecting the engine coolant lines was pretty straight forward but re-connecting the Auto-transmission cooler lines was a little bit tricky. The ‘bowl’ type surfaces of the copper connectors must be positioned and tied properly to prevent transmission fluid from leaking.
148K miles and the T-stat is weak, not warming up properly.
Caution: if you let the engine overheat too much, you will damage the engine.
Also after 80kph it constantly make the sound.
I don't think that it is from transmisson as it shifts smoothly and the noise is also from the right side of the car,
Any idea would be appreciated :confuse:
Warning: Always use jack stands! if any part of your body will be under the car.
And recently, i noticed my car thuds when sitting still. My dad recommends octane booster or mid grade gas. Have a full tank so i can't try anything now but i'll report back. Other than that, I got all the other problems fixed:
-Bubbling Tent - New Tent - $90 ($30 for removal)
-Squeaking wipers - New wipers (The non $3 kind)
-Check Engine light - New O2 sensors -Free
The only unresolved problems are the squeal, slow power windows, and now the thudding.
-Cj♥Accord
-Cj
The NOX and HC numbers were fine. This age vehicle in my state (PA) still requires an actual tail pipe measurement. The mechanic is telling me that I need to replace my catalytic converter. An expensive repair (labor and parts about $500). The car has 152,000 miles on it. There were no fault codes in the computer. I asked about the O2 sensor but he thought there should have been a check engine light or code come up if this was faulty.
I had changed the oil, air filter and ran a can of fuel system cleaner through prior to inspection. This probably explains why the HC and NOx were good. When I picked the car up, I forgot to ask for the actual printout with the ppm readings, so I am not sure how much over I was for CO.
Any inexpensive things I can try first before spending all that money on a cat? I have read adding some denatured alcohol can help. This sounds kind of scary and where I live the fuel is already 10% ethanol so I am not sure how much this will actually help. Is it worth changing the O2 sensor? How hard are these to change? Thanks.
i suppose i'd see if the air flow sensor was working properly, and also put new plugs in the vehicle if they haven't been replaced in a while, maybe adjust the idle if it is high.
i suppose if you can safetly put the car on ramps you should be able to replace O2 sensors, but i'm not sure how you test to see if they are OK. i mean if the system isn't reporting they are not working properly, then i presume they are OK.
have you priced an OEM vs. aftermarket CAT?
if you can use a socket wrench, i doesn't seem like it should be too bad.
the oem CAT seems pricey:
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&cat- cgry1=Accord&catcgry2=1994&catcgry3=WGN+LX&catcgry4=KA4AT&catcgry5=EXHAUST+PIPE+- %282%29
aftermarket (for example) is much more reasonable:
http://www.racepages.com/rp_custom/cc_basket.php?makeid=15&modelid=360&year=1994- &catalog=catalytic_converter
hope it's useful.
how much did you try to start the car before you left it at the gas station?
if your 96 is a 5sp man, it could be that the clutch switch is dirty, and just needs to be cleaned, or that it is sticking sometimes. I have been having the same problem on my 97.
I have a 97 5sp man LX with 151k miles. Driving down the highway, sporadically something mechanically will begin to create a slight vibrating sensation, kind of like a flat tire feels, but not nearly as extreme.
it has been doing it off-and-on but yesterday it got significantly worse. Any speed between 65 and 85, it would do it, but ONLY when I would press on the gas. The car doesnt pull one way or the other, so i dont think it is the tires, or the alignment.
anybody know what may cause this!?!
If the test station is close to your home (which it is in my case...) you need to drive the car A GOOD 1/2 HOUR (better on the highway) before getting into the test station, to let the engine get well into its operating temperature....
thanks for your suggestions. Do you think if it is either of those thiings you said, or maybe even the transaxle I need to worry about it immediately? I dont drive much--pretty much once a week a drive 80 miles round trip to indianapolis and back.
Like I said, it is very sporadic
the problem is that I am a poor college student and at this point i cannot afford a mechanic. Should I avoid going to Indy until I can get the problem fixed? should I not drive at all?
what do you think?
thank you
I am new to this discussion, so please forgive me if I'm asking a question that was already answered. Anyway, about a week ago I had my timing belt replaced in my car, a 95 EX, and because I am not the original owner I asked the dealer to check my spark plugs and all of the fluids to see if they are due for replacement.
The dealer didn't really tell me anything about the fluids, but the dealer did inform me that the spark plugs were incorrect for the car. Now I had asked my brother before I even took it in to do the timing belt if this could be a contributing factor to the lower than average fuel economy of about 22 mpg. I have been in the habit of checking my fuel economy at every fill-up and it has been at 22 since I got it back in April of 06.
I've checked the tires and the air filter and have changed the oil every 3500 miles or thereabouts. My question after this long winded set of paragraphs is, could the lower fuel economy be due to the spark plugs? I have already bought the plugs and want to put them in so that I can start clean on those things.
Many of the questions that I commonly get when I post a question of this sort is what my driving style is like and I have never really written it down very completely. Generally I drive around in town, but most of my driving is on the freeway going to visit with my brother. Since I drive mostly in town I keep the revs under 3000 for normal acceleration and occasionally get it above 3500 during passing maneuvers and attempts to make a light before it turns. On the freeway I keep the revs at about 4300 for normal acceleration and generally cruise around 75 mph, occasionally 80 to pass.
I have also post similar questions in the Honda Accord: Engine questions discussion and the Honda Accord: Real World MPG numbers discussion. Again sorry for a repeat if this is a question that's already been answered.
Thank you for any response to my questions.
Thank you for any responses.
I don't have any experience with the I4, but I'd say for a V6, driving what you describe as your typical driving -- you're getting a very normal average gas mileage. And yes, driving with the wrong spark plugs would naturally affect your gas mileage. Just don't expect a miraclous improvement once you replace them with the right ones.
Thank you for your time in responding.
Now I have 2 other problems:
1- Bad millage: Around 13.5 liter per 100 km (17.5 MPG) is this normal?
2- The oil engine smells like gas although I changed it as soon as I got the car last month, (I don't see blue smoke)
Any idea?
Depends on your type of driving. What is your typical driving route (and be sort of specific)? Someone in the Corolla forum was concerned with their low mileage, until they mentioned they commute a short distance (only a few miles, 3 or so) but it took her 20-35 minutes to get there (averaging 5 MPH sometimes).
What is your commute like?
With a 4-cylinder 95 Accord, on strictly highway you should at least see 27+ MPG. I used to average around 29 MPG on 80% highway driving in my 1996 2.2L LX Accord auto.
I remember I got 23 MPG in the highway last month and that was the best I got since buying this car.
I know that cold weather also promotes to bad millage but I don't know how much, It's very cold where I live.
Typically, cold season hurts mileage for two main reasons:
1.) The "Winter Blend" of fuel most companies use delivers lower mileage than the fuel typical of summertime weather. I noticed a 2 MPG drop across the board with winter season on my two Accords. I was seeing 29MPG in my 2006 4-cylinder and 28MPG on my '96 LX 4-cylinder. Now, those numbers have dropped to about 27.5 on average for the '06 and closer to 25 MPG for the '96. The '96 is more noticeable because I park it outside, and sometimes get the engine warming the interior to de-ice the windows before I leave, which leads me to issue number...
2.) Warming up your vehicle is a time when you are getting 0 MPG. I don't warm mine up unless there is ice on the windows. It isn't necessary to warm your vehicle to normal temperature before driving away, as long as you drive modestly (under 4,000 RPM or so)until the engine warms up to normal.
Maybe you are warming up your car some, since it is SO cold?
In case you're confused I don't mean the window above the back deck that you see through the rear-view. Thanks for any advice.
1.) Set the system how you normally would to defog windows (You know the drill - set air/conditioning on, moderate amount of heat, and ventilation to FRESH AIR).
2.) Instead of setting the vent output to the "defrost" setting (the yellow-graphic button all the way to the right), set it to where the air comes out through the dashboard vents (the button all the way to the left). This way, fresh, dehumidified air can circulate the cabin most easily and quickly. Simply point your vents straight out, and air will flow to the rear, and begin defogging your side windows.
Hope this helps!
