Visitor Agreement.
I added a trailer hitch myself. After I bought the car I called the dealer and got a quote of $650 to put on a hitch. Instead I went to etrailer.com and ordered one for around $130. The wiring harness cost a couple of bucks more. The hitch itself was a piece of cake to install, just bolt it into existing nuts that are welded to the frame. The harness that came from etrailer required me to take apart the interior of the Santa Fe, so I returned it and bought a harness from Pep Boys and spliced it into the rear lights. Everything works great. Yesterday, etrailer sent me an email giving me a discount code of x25y. Supposedly, it's good for a 10% discount. Perhaps it will work for you, too.
Hope this helps.
thnx
This vehicle has the 2.7 V6 and has plenty of power and very good acceleration. The only problem we have had is two days ago the check engine light came on and the error code was that one of the cooling fans on the radiator did not come on. It is going into the dealer this afternoon to find out if it is the fan motor or a sensor of some kind.
Based on the last fifteen months of ownership we would buy another Santa Fe AWD with no questions asked.
If TCS is working, you shouldn't have any significant wheel spin. That's what TCS is supposed to prevent. When a wheel begins to lose traction, TCS is supposed to kick in and stop the wheel spin. If you are experiencing wheel spin like you would without TCS, then maybe it's not working. Are you sure you have TCS? Does the TCS light come on and do you hear a grinding noise when it lights up?
My '01 Santa Fe is coming up for its 30K mile service and I plan to do the oil change and antifreeze change myself. I've had the transmission service done by a local garage, as I've never done a n autotrans fluid/filter change. I've done many antifreeze changes on previous cars, and expected to find a drain tap on the SF -somewhere- near the bottom of the radiator.. Nothing found! Has anyone done an antifreeze drain/flush/fill on an SF who can tell me -where- the drain's at??
Thanks in advance,
Dave Frandin
daveATfrandinDOTorg
If that is the case, then I'd be suspecting you have a FWD vehicle, not a 4WD, and need to get that resolved, or, your limited slip differential is not operating properly. This should work hand-in-hand with the viscuous coupling for the rear wheels. The possibility of both these not working seems remote to me, so definitely get it checked out. I could be talking out the wrong end here, but this certainly doesn't sound like 4WD/AWD to me, either.
I also did the tranny fluid change myself, mostly because the dealership wanted a mint and I didn't really trust Iffy Lube to do it with the correct fluid. From what I understand, you actually need to use genuine Hyundai ATF, and the stuff that says its compatible may not actually be. Not to induce widespread panic or anything, but you may want to have a friendly chat with your shop and make sure it really says "GENUINE DIAMOND ATF SP-II M" or whatever on the bottle. If not I'd try to get them to change it out with the correct stuff, as Hyundai definitely has justification to deny a warranty claim on a tranny using the wrong fluid.
It was actually pretty easy. Hyundai has a great resource out on the web for us do-it-yourselfers at www.hmaservice.com. Click on WebTech and you can get tech documents for every Hyundai ever sold in the US. It's better than a Chilton's book because you get the actual factory procedures, etc, for doing the maintenance work - oh, and because it's free! I even used it to swap out my spark plugs at 30k. Probably NOT recommended if you have a V6, as it's quite involved. I was glad my wife never saw how much of her car I had to tear apart to replace those plugs...
Anyway, this was probably TMI, but if you need any more info let me know.
Good Luck,
Jason
-Jason
Okay, here it is. Go to www.hmaservice.com and click on Service Information then WebTech. Select your year, model, and engine from the drop downs and then click on the Shop tab. The trans fluid change procedure is under Transaxle/Transmission | Automatic Transaxle System | General | Basic inspection items. Don't be surprised if you don't end up refilling with the full amount specified in the book, since that amount is for a bone dry tranny - pretty much impossible to get without pulling the tranny. I'd dig a little deeper to see what kind of fluid your shop used, since you have a 100k mile powertrain warranty on the line and the right stuff is something like 3-4$ a quart.
Good luck,
Jason
From everything I've heard and read, Mitsubishi makes the Diamond Type fluid. There are shops that use the tranny flush equipment and use special additives for each job, depending on the fluid requirements.
My local Jiffy Lube did my tranny flush at 30K after I verified that the additive bottle label said it was Diamond Type SPII and suitable for Hyundai vehicles. Plus, I did this for my own anally retentive peace of mind. I figure if there's any issues, I won't mention the flush. At worst, I can sue Jiffy Lube and/or the additive manufacturer if it causes a warranty repair issue . I've got 16K on that first flush and have noticed no changes in the way the shifts work, fluid use or slippage. Next change, though, I'm having the dealer do it at 60K.
You do realize that the tranny flush is not required until 100K under the normal maintenance schedule?
From TSB 03-40-019 on the HMAService site:
USE OF NON-APPROVED AUTOMATIC TRANSMISSION FLUIDS:
Only Hyundai SPIII is approved for use in Hyundai vehicles beginning with the 1996 model year. Use of aftermarket additives or other types of ATF, such as Chrysler/Mopar ATF+3, Dexron and Mercon, are not approved for use in Hyundai vehicles and may affect driveability or damage the transaxle. Damage caused by a non-specified fluid is not covered by your new vehicle limited warranty.
Pretty cut and dried, if you ask me. Use the stuff from the dealership.
-Jason
Dave
Docknow
I personally have no experience with the 3.5 or the 5 speed auto. The majority of the people owning these seem to be very happy with them. However, do keep in mind that almost all the transmission shift issues are occuring with this combo. I have owned a 2003 LX/4WD with the 2.7 and 4 speed auto since September of last year. We've put 8900+ miles on it and have had no problems other than a bad vent valve in the gas tank early on. That was covered under warranty and caused no inconvenience other than a "check engine" light. My wife and I have been very pleased with the reliability of our current and previous Hyundais. We've been buying Hyundais exclusively since 2000. My wife, for the first time since I've known her, is not reluctant to drive the Santa Fe when we're on longer trips.
Best of luck! I think you'll be very pleased.
(I know, I ask a lot of questions but I figure I'll get less biassed info here!)
What I need to know for some of you SF owners is, what did you like/not like about your SF? How has it held up since you bought it? Are you happy and would recommend me buying one as well? Any opinions you could offer would be of great service to me. Thanks you in advance.
Avidmarc
10-year/100,000-mile Powertrain Limited Warranty that covers most engine and transaxle components.
(* doesn't cover things like gaskets, belts, hoses or items covered under the B2B)
5-year/60,000-mile "Bumper-to-Bumper" New Vehicle Limited Warranty Coverage that covers nearly every new vehicle component with limited coverage of normal wear items like windshield wiper blades, oil filters, and engine fluids. Tires are covered by the tire manyfacturer's warranty exclusively. (* Light bulbs and AC recharging are covered for 12 months/12,000-miles.)
5-year/unlimited-mile 24-Hour Roadside Assistance that covers towing (including accidents), lock-out, flat tire, and jump-starting
5-year/100,000-mile Anti-Perforation Limited Warranty that covers corrosion-related rust-through of body sheet metal from inside to out
8-year/80,000-mile Federal Emissions Design and Defect and Emission Performance Warranty that includes the catalytic converter, engine control module and onboard emission diagnostic device
7-year/70,000-mile California Vehicle Emission Control Systems Warranty that includes 7-year/70,000-mile coverage on selected parts
3-year/36,000-mile Paint Limited Warranty
* my notes
As for whether 3 people can fit in the back seat, I'd give a conditional "yes". The middle of the seat is not as comfortable as the outboard ends, but seems to be okay for kids. As an adult, I wouldn't want to sit there for a long time, though.
Gas mileage depends on the configuration you buy, FWD or 4WD, 2.0 liter, 2.7 liter or 3.5 liter engines, and on the 2.0 liter base, whether you get a manual or auto transmission. For myself, with a 4WD 2.7, we average 20 mpg commuting 40 miles a day, mostly highway. In town driving results in closer to 18 mpg and trips can sometimes produce 24 mpg.
Does Hyundai sell an extended warranty? They do, but only through dealers and (I believe) within 30 days of the sale. I don't see the point myself, as it seems rather redundant. Were you aware that you can purchase extended warranties as late as 50,000 miles as long as the vehicle is less than 10 years old? I.e., I'd only buy one when the factory warranty was about to expire and I had had problems I expected to recur or anticipated having problems with something in particular.
Hope this helps!
Back seat is really pretty roomy - wide enough for 2 adults plus a toddler seat, and enough legroom so my 6' father in law can sit behind my 5'11" self with no knee smashing.
We have a FWD with the 2.7 V6 and it gets around 20 in town, with as high as 24-25 on extended road trips. Only once or twice have we failed to break 20 on a tank. I understand the 3.5 engine and AWD don't do nearly as well.
Ours has held up really well so far, coming up on 3 years and about 43k miles. We really like the smooth ride and the back hatch design is fantastic - really easy to open and close, even for my tiny little wife with a handful of groceries and a screaming toddler. Oh, and we LOVE the heated seats, especially days like today when it won't hit 20 degrees. I'd like a little more power and a couple more inches of adjustment on the driver's seat. Maybe a third row jump seat like the Highlander, which is about the same size.
Bottom line, if we wrecked it today and needed another car we'd look hard at another Santa Fe. Unless we outgrow it quicker than we're planning we'll probably keep it for at least another 3-4 years.
-Jason
1. No padding on the door arm rests
2. Backup lights are marginally useful
3. The transmission likes to stay in third gear too long sometimes when you're coming from a stop and going up any kind of grade
Otherwise, I find the Santy to be great for our purposes, which includes daily commuting and long trips with lots of stuff packed onboard.
The only thing I really would like to have is a passthrough in the middle of the back seat. It's been a very dependable vehicle for us.
As you can tell, the issues I have are very minor. We have had things that have gone wrong, but so has my MB. We happen to have bought both cars from dealers who have great reputations for service and have bent over backwards to please us. We live about 25 miles from the town where these dealers are and they have both made sure that we are on our way as soon as possible. This is the one variable that I can't stress enough. Make sure you check with other Hyundai owners in your area for their experiences.
Hope this helps. Good luck.
Tim
Anyone reccomend the 2.7 engine over the 3.5 or visa versa....what kind of city mileage can I expect from either?
-Jason
Jeff
Even with the extended warranty I am hoping that I never have to use it.
accessory group 4 (ABS)
tow hitch
front and rear mudguards
cargo trays
The local dealer is quoting me a price $20,100 before taxes and title.
Sounds like a good deal. Any comments?
What do you consider easy? =;-)
This link <http://www.geocities.com/elusor/install/foglightmod.htm> should give you some ideas.
PS: 1st tank was 21.5mpg and 2nd tank was 23.3mpg!
(3.5 V/6 AWD 5sp auto)
I always like to have a manual available to me without going out to the vehicle to get it.
2004 Hyundai Santa Fe GLS 4wd
· 3.5L
· Merlot
· Cargo Tray
· Cross Rails
· $21,808 After the rebate, plus tax and fees
Basically, any turn or bump I make, it makes a squeaking noise. It is annoying.
Anyone else have this problem and if so, were you able to fix it??
