Visitor Agreement.
Ford finally agreed to help with the replacement engine. Instead of $4500 for a FQR reman. long block installed, my cost will be $1800. And my engine warrenty will be extended to 6yr. and/or 100K from date of initial purchase (in my case, Dec. 1999) So I'm reasonably happy with that, since the car had 52K miles and was out of warranty when the engine self-destructed. Now we'll see how it all works out when I get the car back after the engine R&R. No telling what kinds of nuisance problems will crop up as a result of the engine swap. Perhaps I'll have it back in another week or so.
if they don't, on anything, there will be Hell to pay, and probably often.
but I'm one of those damn looney cranks who enters a dealership for the first time through the parts or service doors to see what's out there in the future if I do buy something there....
As of today Ford is buying that Explorer back and I am getting another one hopefully this one will be a good one!
I am glad you have a happy ending to your lemon. The Ford Engineer on mine claims that the skidding down hills when in reverse is merely gravity! He says it is my driveway, but, I tried it on another hill and down it went. Let's see what he says now! I bought my car just before you bought yours. Did you have to get a lawyer? Good luck with the new car.
the location of the thing, right above the oil pan, made it about impossible to change without raising the block. that engineer was following in the wonderful tradition of the 302 V8, I guess... when it came out for the Boss Mustang, you had to lift the engine to replace #3 plug, and it helped for #5 as well I was told at the time. eventually ford advised dealers to punch a hole in the fender liner and use a part (something-or-other) plate to cover it after changing the plugs.
that engine ran hot, and needed a lot of plugs, as well back in the early 70s. it's been nicely tamed for a long time, but there is a tale that a few of them develop piston slap after a while. no signs of any issues in mine.
took ford a while to get into production with the V10-turned-V8, but there isn't a major rumble about engine issues with that engine that I have seen yet. if I hadn't gotten a 2000 or 2001, I would have gotten the oil seal fixed and some other work done on my ranger, and waited out the experiences of the pioneers a few years...
sorry you had the bad radiator of the month, modine has been good to me several times for replacements. one bad part can really raise your awareness of how intertwined mechanical systems are
Sorry to be off topic
My wife's 2000 Explorer has the 4.0L SOHC V6 which seems to be ok, but we have had two issues with it in 50K. The first being the timming chain tensioner and the second being a stuck thermostat. My sister in law had a 2001 Explorer 5.0L that had no problems at 46K. Sometimes, it's hard to argue with simplicity :-/
BTW- It is a 2000 4.0L SOHC
Thank you for your thoughts! That may very well be it. I will let you know how things turn out.
my 90 ranger had a lazy 02 sensor for maybe a year or two, but it never set a code... one evil 27-below night on an open lot far from work, past midnite, I couldn't get the freakin' car to run. it would start great, warmed up enough so the temp needle JUST moved... and the computer came out of programmed mode into real-time... the sensor was way off base, and the engine chug-chug-chugged to a stop. several times I did this and got madder and madder. finally, I got past warmup, and off I went. next morning, they found the problem and fixed it.
I think I have a lazy sensor on one side of my current exploder, when I did a test run with a kitted OBD-II unit, one 02 sensor didn't show any tracking changes. have to recheck in the next week or two and correct if it's still doing that. as you can maybe guess, I'd rather spend the money ahead of being stuck someplace late, cold, and alone.
http://216.239.41.104/search?q=cache:gFJKs_qcw30J:www.babcox.com/editorial/bf/bf89936.htm+ford+oxygen+sensor+rich+bank&hl=en&ie=UTF-8
Thanks for the tips. You could very possibly be right. I will have to see if cleaning the MAF sensor works first. Again thank you for your incite :-)
Wijoco-
Awesome website! I was completely entertained by it for a good solid 20 mins. I am out of town right now, but will be back tomorrow to start work on the wife's truck. On the day that I went to Autozone the staff there were not having a good day. The lady that checked my codes didn't give me the specific numbers. I wish she had, but she was more excited about her cigarette. Not exactly stellar service, but I have someone else that I know with a reader that I will contact tomorrow. I do have a chiltons manual for the Explorer. Are the codes in there accurate? Will the reader indicate if my O2 sensors are "lazy" or if they are "out of range," or is that something that you have to quess? I did change the air cleaner recently that was moderately dirty. I am currently getting great gas mileage 20+ MPG average and it runs really smooth. I will get back to everyone here that is interested as soon as I find out whether or not these things worked. If not, I guess I am going to be purchasing two new oxygen sensors :-) goodnight all!
There are around ten different O2-related Ford codes. You'll get a numerical code from the scanner, then take that and look in the emissions section of your book or Google it and find the verbage. It was probably P0172 and P0175
This is what I found out:
The updraft bank 1 and 2 O2 sensors gave a PO175 as being stored indicating a rich condition. The guy that helped me at a local garage had this awesome computer reader with color display and live graphs to show you what the engine was doing at that very instant. It showed that the O2 sensors were working very well and that the code was set due to there being some other issue (so the code was set because the O2 sensors were out of range). So the guy cleared the check engine light and looked at the engine trying to find any cracked hoses or tubing going into the intake. One other suggestion was to clean the MAF sensor as indicated on this message board. So I went to an auto parts store to find the little star key with the peg in the middle to get the MAF sensor screws out. I took it off (looked clean) and washed it with some electrical parts cleaner. Everything seems to be fine for now. I have driven it probably a total of 60+ miles since the code has been cleared and it has not come back on. Ah, the marvels of modern science and computer technology!
Thanks again for eveyones help. It is great to give out advice and help others in times of car troubles. However, it is twice a great when people help you out when you have an issue:-)
Have a great weekend!
JRC
I need to look at the back window wiper motor of my 1999 Explorer Limited. I can't seem to get movement in the plastic lining that covers the entire 5th door. I removed the top screw (under plastic cover) and removed the flexible door handle on the inside (two screws). And then... there is not a millimeter movement. Please can anyone help me with this one. I have been trying for two day's and I'm about to burn the lining of...
thanks,
Roland
Hellevoetsluis
The Netherlands
The "kerchunk" like running over loose manhole cover. Dealer could not "duplicate customer concern" at least 2 or three times so nothing was done. This has been "fixed" 2 yrs later, when testdriven by service manager - who noticed a chattering sound when car going into higher gears. (is this the same problem?) How does this affect car in long run? Thirdly the egg smell was addressed only recently as well - they wrapped the source of the leak?? Finally the ABS indicator light was on. The first time I took it in they said unless it was currently on they could'nt diagnose the problem - go figure. My family and I were driving in Detroit on wet pavement - ABS light was on. As we were rounding a curve (on wet pavement)we almost lost control of the vehicle. - very scary. When I took it in they couldn't diagnose the problem because the light was not on nor were they overly concerned with our safety. For a few weeks the light stayed off as they reset something in ABS system at the same time thy fixed the chattering - downplaying the whole thing. The next time the ABS lightcame on we were headed out of town to the hill country of Pittsburgh - light stayed on the entire trip. The next day I took it in and wouldn't you know the light went out. So I said I'd bring it back the next day. As I was leaving the lot - it came back on!!! I brought it back in the next day knowing the light would come on. I le them know that my confidence in the car is seriously in doubt. They finally diagnosed the problem as having a short in the rear sensor. They found the "code" to fix the problem - they could have found it earlier I found out - it just would have taken time to check all the codes. They made it sound like it could'nt be diagnosed unless the light was on - it's just easier to diagnose when it is on. I am frustrated with the dealer's service department and the salesman who sold us the car and the car itself. We seemed to have a lot things go wrong at only 35k miles. Is this normal? Should I write the owner as I'm not sure he is aware of this. Okay for now. lwm2 10/13/2003
I think you have done right by removing those screws. However the whole back door cover is secured to the door with what I think are called christmas tree clips. They are just straight pegs that have little ridges on them that get caught in the actual clip in the door (does that make sense to you? haha). To get them out I think that you can push the whole door cover up, as in towards the top of the door, and this will leave the clips behind in the door and you will have to pull them out (no biggie). I have another way to but try this first. That is unless this is the hard way to do it and there is a much simpler way to do it that I have not mentioned? Any others here have any ideas? Goodluck!
before taking the liner out, pull the rear wiper to "service position", which is lift up on the wiper arm to clear the body clip, and pull it forward so the wiper is outside that clip and hanging in air. drive around the block, and try to run the wiper again. if it works, and stays working, kewl. if it works, but won't restart again once it's back in the clip, lift up a little and to the left at the motor shaft, to bend that mount bracket a little bit. it may save a lot of work.
I'm starting to wonder now if that's related to the rotten egg smell that happens when the truck is under load. Guess we'll find out when we replace the ERG tube.....thing is $68 at the dealer....OUCH.
Other than that the truck has been great, have put 10k on it since July....just turned over 51k this morning.
My wife and I are little people so it's not excessive weight, either.
I currently own a 1997 Explorer Limited with 52k on it and the leather all through the truck is in excellent condition, including the driver's side seat. Not too bad considering its an Alaskan truck.
Must be the new *cost cutting* leather that Ford is using these days. Seems things just get cheaper and cheaper while vehicle prices get more and more expensive.
My friend has a 1991 Explorer, V8, auto trans, Eddie Bauer ed. The SUV starts up fine and runs great but if you stop and turn off the engine (for example, to buy gas), you will not be able to turn it on again until about 15-30 minutes later. This problem only happens when the SUV is driven for a while and then turned off. It always starts up fine after it sits for a minimum of 15 minutes.
Does anyone else have this problem or know what the problem is and if there's an easy (cheap) fix for it?
Might want to have it checked for stored codes in the computer, good place to start I guess.
Mine on occation will be a tad hard starting after a fill up or after shuting it off and then restarting it soon after. Its the worst if parked on an incline. I have always just chalked it up to be a bit fussy. Hopefully I don't end up with a no start condition, my truck is pretty reliable thus far and I'd love to keep it that way.
I wasn't thrilled, but now I'm glad, its been excellent and still manages to average 18 mpg.
Thanks for your advice everyone. I will print this page out and give it to my friend on Monday. ^_^
it could be a leak in a cooling hose, and airflow and position of the hose makes the water run over the bell housing. if so, you are lucky, it's a cheap fix.
it could also be a head gasket starting to fail, check that out immediately.
I strongly prefer to think that it's not a crack in the engine block at the rear, possibly from hitting a shellhole or jumping the wrong stump on a nasty trail, which is almost certainly going to take a new engine to fix it. chances of that happening on the daily drive are slim to none, and slim is out of town this week... but for completeness, it must be mentioned.
moral: you want to know more, now, and I'd have it towed, not drive it, to your favorite garage if you can't find out where the coolant is coming from. my bet is on a cooling hose somewhere near the back of the engine, before it goes to the heater, but I'm not betting large without looking myself.
