Visitor Agreement.
Mountaineer's rims. The dealer replaced them all
under warranty.
Is it OK to mix synthetic tranny fluid with regular tranny fluid for a MT ('93 Sport)
Many thanks to the person who posted that Explorer maintenance page awhile back, it's been very helpful.
I am on a smooth surface. Any ideas?
shouldn't kill anything to mix 'em, I had a bottle of dura-blend ATF (partial synthetic) on my shelf when I changed PS fluid on saturday, and it was not scary or murderous towards me while I walked by. it it meets manufacturer standards, it will work.
something did move the tools around in the garage, though, and I may just sling a noose around that bottle of half-n-half, just in case.... ooh, so spooooooky....
what happens at 50,60, 65 mph? -- is the vibration gone? if not, something like an out-of-balance tire or dynamically unbalanced tire or goo on a driveshaft is likely. if so, there is a 4wd resynchronizing procedure that may need to be done.
NVH can be fun to find, good luck
Thanks for the input.
1.) On an inconsistent basis my steering wheel has a slight knock or ping. It's as though some one is hitting the steering column with a stick. Like I said it's inconsistent and irregular. It happens whether driving at speed down a smooth road or more predictably when slowing down over slight bumps (nothing off road. It doesn't seem to be affecting the steering but I can even hear it some times. The dealer claimed nothing is wrong? I can't stand having to keep wondering if my steering will fail somewhere not good!
2.) My windshield leaks when driving in heavy rain??? Is there a recall or did I just get unlucky?
3.) My oil pressure gage seems to fail the first few minutes of driving? It eventually comes on turning off the "check engine light" but wondering/hoping its not a more serious problem.
Again, any advice would be appreciated, either way I'll post once I find out what is going on.
cheers,
BT
1.) I have no idea what the deal is with your steering, sorry, can't help there.
2.) Windshield was probably replaced at some point due to a crack and its probably not sealed correctly (happens sometimes). Possibly take it to a windshield place and see if they can find the problem.
3.) Sounds like most like a pokey oil pressure sending unit, that is UNLESS you hear knocking, then its probably an oil pump. I doubt it though, I would check into getting a new oil pressure sending unit. Could also be the guage though.
Not to worry, Explorer are good trucks, sometimes quirky. Mine is a 97 Limited V8/AWD and its got its fair share of goofy quirks. Some I overlook, some I shake my head, some I fix. Just gotta pick your battles I guess.
2) yup, have a glass guy work on it
1) check your steering fluid color against new dexron III/Mercon fluid. any evidence of grey or darkness in it, replace the PS fluid just for jollies. I've done it several times by sucking the resivoir dry, filling with fresh fluid, starting up and turning the wheel slowly lock to lock three times, centering it again. repeat until you've used a couple quarts of fluid minimum, or until fluid is clean and vibrant as brand new stuff. drive on that a while and see what happens.
it might be a dying PS pump, and it could be worse. I just redid my PS fluid in trying to diagnose what seems like a whisper-clunk in straightening my wheel after a turn, usually cold, very occasional. not sure I have results yet. changing the tilt wheel position didn't do anything for it. my belt is good.
suspicions at this point that I have revolve around a chunk of crud in the rack (evil and expensive), an occasional hangup of the clockspring wire harness under the steering wheel causing it to brush against the wheel or column, maybe a chunk of plastic crap in the steering column that has warped under wear or heat and occasionally scrapes another, or the earliest starting of trouble with the PS pump. it's so marginal and barely there that there's really nothing to troubleshoot seriously yet.
but I have not noticed the issue for the past week, since I changed the PS fluid, and so I'm hoping it was just a little crudball moving past the orifice in the rack.
after something like 14,000, I checked the factory load of PS fluid, and it was a nasty greyish red mess. immediately changed it out using 3 quarts of dexron III/mercon. mileage is now 45,000. fluids are cheap, engines/racks/trannies/diffs/transfer cases are not, so I react to any evidence of unusual fluid load on my vehicles.
WARNING to others... PS fluid use varies among different cars, including different years of otherwise identical explorers... check your manual and make sure you use what it recommends. there were some posts way, way back of folks who had trouble using "modern" fluid in an "older" system. "trouble" meaning both the rack and PS pump were shot due to the wrong fluid.
it seems to me that if you had a real coolant leak at the back of the block from under the bell housing, it would be a crack into a coolant gallery from a bolt hole or a porous block area. the crack may be a "forklift upgrade" repair, while a porous block section might be fixed (at least for a while) with high-temp epoxy.
unless somebody else has any real clever suggestions from a lifetime of doing heavy service, I'd say it's time for a dealer call here. check your credit record and card limits before going in, because I don't like what I'm thinking here.
a cold engine on a hot day in my 2000 exploder's V8 is occasionally a recipe for a no-start even under those conditions. so after I have spun the motor 3 seconds and nothing happens, I take a sip of 7up and try again. starts the second time every time.
Thanks, raydav
for that matter, the parts manual should cross the spring number to application, so they should really have been able to pick one from a lighter load model.
keep in mind that if you change the springs, you can't tow any more, and other performance aspects of the truck will be altered. because I suspect you're looking for a cushy ride, and there really isn't one in the exploder/mountie. it's a pleasant ride, but it's a truck, and mink floormats can't change that.
IMHO that will wreck the value of the truck. the next buyer will have been looking real hard for a V8 tow-package, and with gutless suspension, it will be a potential killer with a load on. they aren't that common on the lots, the V8-tow combination, and that is a premium truck unmodified.
a potentially better option, although more expensive, is air shocks on your present system, so you can dial it softer or harder. then instead of little road shocks, you can get sway and dizziness. towing shocks are going to be valved wrong for a cloud-ride, anyway.
if what you REALLY wanted is a buick with kick instead of a multipurpose truck, the best option of all is to do a lot of test drives and trade this mountie in on something else. if you're looking for zip, I suggest you start looking for things with turbos. you are also likely to get better mileage on a ride really suited to what you're wanting.
if it's important enough to you to start doing suspension rebuilds, you might as well get the right car all the way around. gutting a tow vehicle is going to end up killing somebody two or three owners down the line who checks out the VIN, sees high-capacity, and loads it up. I have issues with the concept.
So, if there is any real damage, the hub isn't rebuildable. Good news is these are regreasable. The wheel sensor can be pulled out which gives a 0.380 hole. There is an O ring 0.2 inches down the sensor. This allows the first section of the sensor hole to get rusty. The sensor may be damaged when you pull it out. An oversize thread zerk fitting with a wrap of tape works great to grease these from the sensor hole. It easily builds enough pressure to push grease out of the front and back seals. My old hub is still good enough to make a great rotary weld table out of it. Think prevention.
Don't let the lower horsepower number (160) worry you. The engine makes a lot of torque and will do whatever you need it to do.
thanks,
kooz
if you get a ford OEM part for it, there should be sealer already on the part.
I am trying to complete today since my sons needs the vehicle to get back to school.
Also does 70-90 ft-lbs sound too much for 3/8 bolt?
Please also email me to donnapaca@aol.com with any help.
Don
Does anyone have the part number for the part for the above problem? 98 ford explorer.
Another problem is an intermittemt vibration / grinding sound when taking off from a stopped positon. Last service was done at 36k where they flushed the transmission to check for any residue of metal which mayb have been caused by grinding - none found - any thoughts before I spend a lot of money trying to dignose the problem ?
The grinding and vibrations I get from the exhaust still remain, and they don't bother me or my wife at all because they only happen when the truck idles and only very rarely.
These are just some suggestions, and may or may not be the solutions to your issues, goodluck!
BTW, I would get the thermostat changed ASAP! The grinding that I am refering to will not harm the vehicle, it just annoys some people.
For the temperature problem, you need to first have the sending unit's output tested with a digital multimeter to verify that the gauge is reporting the sender's signal correctly, then have the engine temp tested with an infrared sensor near the sender to verify that it is sending the correct temp signal. If the electrical is working correctly, then you have a legitimate overheating problem that you can't ignore. It only takes a few overheat cycles to ruin engine gaskets. Your problem could be anything from a bad thermostat, leaking intake gaskets (common on the 4.0), or leaking head gaskets. All can cause rapid temperature spikes, especially early on a cold morning.
All the quick lube places offer a full tranny fluid swap, but offer Mercon/Dexron III with a 10 oz. "additive" to meet Mercon V requirements.
The Ford dealer tranny service will use straight Mercon V, but only drops the pan and changes what's in there, leaving the new fluid to get dirty in under 10K miles.
Is there any risk in using the quick lube Mercon/DexronIII additive approach? I can't seem to find any research data or complaints about ruined transmissions.
