webmyzer
I bought the 98 used with 23k miles form Hertz and for insurance bought an extended warranty. It cost $1200 and covered bumper to bumper for 5yr/70k taking it out to 93k miles. During the warranty period I had one claim that wasn’t covered by a factory recall amounting to $200 for a squeaking dust seal (dusty climate related I expect) on left front wheel.
The 98 has the 4.0 SOHC engine that makes 205 hp, and most of the other things you find in a mid-level auto/truck.. And the SOHC engine really hauls butt compared to the OHV model. It still drives very well still with 140k+ miles, warms up quickly and doesn’t run rough even when cold, nor consume any oil.
My philosophy is to do the maintenance myself if it isn’t covered by warranty and doesn’t involve fluid disposal. Just bought a house with a garage so why not put it to work.! I had it in to J-lube several times for replacement of all of the fluids as the manual recommends (with synthetics always).
At around 70k I replaced the factory shocks with Bilstein heavy duty models and also changed out the sway bar bushings for neoprene performance set. This really tightened up the ride and made it feel much newer. I did the 100k tune-up myself (plugs and wires) for $120 in parts saving $400 in labor, again making it run like new. I had to spray out and oil the door locks with WD40 a few times as they froze up in winter (dust I think caused it). And I needed to replace the front two Ox sensors. The 4.0 SOHC has 4 Ox sessors, part of the reason it makes 205 hp. At that point it was running/handling so well that I spent $700 on the high-end Michein SUV tires. It was sweeeet for a vehicle that was paid for!
At around 125k I hit a major obstacle, however, with front end problems. The seals on the Rack were leaking and the lower balls joints were worn badly, causing a knocking noise when going over any types of bumps. I was worried about the whole front end seizing up or coming apart at highway speed, so something had to be done. These two items sounded like more work than I wanted to do myself but the estimates came back at around $1300. Due to my new mortgage, I broke down and bought the parts and attacked the problem myself.
Let me tell you that replacing the rack without having the car on a lift was like aligator wrestlng in a pool of power steering fluid. The whole job is somewhere around 10 bolts total, but I had to summon every bit of my previous shade tree mechanic experience and military training to get the old rack out and get the new one in. Ditto for the ball joints. However I got it all back together in a single day so I was felling quite proud. I did have to spend $120 on a ball joint press tool and a few sockets but I probably saved $6-700 on labor.
Be warned: do not even attempt to do this job without good jack stands, and a torque wrench. You have to get those front end bolts factory tight and the cotter pins replaced, or you risk disaster some dayfrom your front end coming apart. And the vehicle needs to be supported very well so it doesn’t fall on you when tightening up those bolts. Consult the manual for the proper torque settings and jacking/supporting procedures.
I think Ford could have avoided these front end problems by installing a 98cent power steering filter and a few 25 cent grease fittings in the ball joints. I did on the replacements!
Since then I also had to replace break pads on the 4wheel disks. I didn’t turn the rotors. It takes the pads a little longer to seat, but if you use synthetic grease on the pad backing plate you can avoid turning the rotors in my opinion. The only other current problem I have is with the radio display, which I expect can be solved inexpensively.
Anyway, I have a new job and I commute 50 miles rt daily, so with gas at $2 plus I am thinking about a Saturn SC at 39mpg. But I will hang on to the old explorer (145k miles now) for pulling the bass boat (which the SOHC does pretty nicely) four wheeling, and other hauling([non-permissible content removed]) chores. Cheers! (My glass is half full)
What did they charge you to do the flush?
Any info or discussion on this problem would be helpful.
I'm starting to look at Toyota 4Runners...
Have you had it tuned up recently? It sounds like a bad spark, bad sensor (Mass air flow, oxygen), or bad fuel flow (fuel filter?, fuel pump)
Chipmunks living under the hood?
A good tune should be able to find the problem.
I only get 14-16 in my V6. Had there been a V8 on the lot I would have bought it instead.
I'd love to "waste V8 power" for an mere 2 mpg!
Hope this helps!
check the air pressure in your tires and make sure you have a clean air filter. best bang for your buck. 13mpg is very low, was it always this way?
i had a '97, same drivetrain. lowest ever was 14 mpg, highest 20.
That's probably all it is. Does it do it year round or has it just started?
Could be making more noise because of the colder weather....plastic contracting some and squeaking.
Need some advice,
I took my vehicle to dealer for transmission recall additive insertion.
Rough shifting is as bad as ever, maybe worse.
It clunks when it downshifts, especially when I slow down quickly.
I can't stand the annoying noise and I fear it eventually will fail.
I have 32K miles and the extended deluxe warranty.
Should I live with the klunk?
Take it back to dealer and demand it be fixed?
Is it normal and really no indication of a potential reliability issue down the road?
What can or should be done basically?
TP
-Larry
The Explorer was a V6
I will say I don't have the clunking issue, but this truck shifts like no other Explorer (my third one) or Ranger (I've had 3) that I've had.
It feels like it would if I were shifting it with a manual transmission. You know, a slight back-off of the throttle, shift, then back on the throttle. Not the usual simple shift up to the next gear like I'm used to.
These things have electronic throttle controls (no linkage) I think and I don't think any of the others did. Maybe it's just different since it has total control of the throttle.
-Larry
When the tranny is going it will be more like a slipping under load. The engine revs will be higher than normal for the same amount of work.
When you hesitates , do you mean like a hiccup?
if all else fails just buy the vehicle you WANT the way you want it and be prepared to deal with any issues that come up ..GOOD LUCK :shades:
The toyo is above average quality, the ford is average. Toyota has much higher resale value, but this model will cost hundreds more to insure per year than the explorer. If you are tall, you will feel like Lurch with your head sticking out of the roof and you will have to tilt your seat back to see past the sun visor.The japanese cars are made for short people. Quality isn't exactly enjoyable...I think you would appreciate the ford more.
The wife & I just purchased a 97 XLT, with ~118,000 miles, fully equipped with the 5.0L and tow package. I found this site, looking for answers to a particular question.
Have been driving it a week, and the engine/tranny are great, and the suspension is tight. Other than a few cosmetic burps (to expect with an 8 year-old used vehicle), the truck has been wonderful. Although getting used to a solid rear-axle, and the power of a V8 again---my first car was a 1966 Oldsmobile f-85 (330 Jetfire under the hood)---has been an experience.
Anyway, we received ~2inches of rain yesterday. Made various trips around town, with no "adventures". About 1 mile from the house at 10pm at night, I drove through a large pool of water----deep enough to splash up onto the rooft, on the front passenger side.
After parking the car, and locking with the keyring remote, the car unlocked and the interior lights illuminated. This unlocking cycle continued for over an hour, at which point I pulled the dashlight fuse and went to bed. This morning, I drove the truck around the block, locked the car (by the keyless remote pad), and everything seems fine. No more apparent "lock phantom".
Any ideas about the lock cycling, which seems directly related to the wet weather? Could there be a short in the outside keyless remote, or is there a sensor/motor within the motor compartment that could have gotten wet?
My father owned a repair shop, so I can fix pretty much any problems. I've read that the locks/wipers are major "phantoms" on the Explorer, but this was just insane. The locks would literally "unlock" every 5-10 minutes (even when they were already unlocked), almost like clockwork.
Any comments/suggestions, would be greatly appreciated.
