Visitor Agreement.
Had it in a dealership 6 months ago, transmission had acted up. Had been bucking in reverse, and slow moving forward. Drove 40 minutes to dealership, and they couldnt get it to fail. So took it home.
Now, the reverse is out, and I am told that it looks like the planetary letgo exploded. Either way, it can not be rebuilt. For a ten year old vehicle to need 3k+ in transmission work, vehicle itself is only worth 4k - 5k.
It does have 125k miles, from reading previous, it sounds like I have been fortunate that it lasted this long.
I know my list of options is short, but any suggestions would be appreciated.
I have the same problem exactly with my 98 Ford Explorer. I replaced the under the hood Ford Relay and nothing happened. Cannot find a fuse identified for the horn but still the symptoms are exactly the same. Both horn and cruise control went out at the same time. Have you found a fix yet?
This is not a "back yard" procedure. Have the car towed to a FORD DEALER. There is a machine that the dealer uses to perform this procedure.
UNBELIEVABLE!
colorado
My parents had the car before me and said that it made a chirping noise a couple of times when they had it. When it did they took it to an old time mechanic who said all it needed was some lubricant somewhere around the front wheels. Whatever he did took care of the noise for a long time. The problem is that they don't know exactly what he did, he died a couple of years ago, and my current mechanic tells me that there is no moving parts to lubricate that might cause the noise.
Can anyone offer any help?
Steve
Mike Sheehan
Good Luck.
http://www.ford-trucks.com/article/idx/12/085/article/Ford_Explorer_Blend_Door_F- ix.html
A Pain to remove? I have commented on the multifuntion switch before, I have replaced the one in my wife's 97 XLT, it was so easy, it was like a walk in the park, easier than falling of a log. No need to touch the steering wheel ot air bag. On the steering column behind the steering wheel, remove a few screws to remove the plastic covers, unscrew the stem for the Tilt, Unplug the wiring connectors, Remove the 2 screws that hold the multifuntion switch to the steering column, and its off. Install the new one in reverse order. Easy as pie!
E.D in Sunny Florida
Thanks all!
the dealer will fix it since it has less than 36k miles on it. :shades:
my wife keeps asking me to get it fixed, but it kind of reminds me of when i was younger, so i'm leaving it on for now.
My wife used to do this in our Escape because she'd hit the gas before the tranny had a chance to engage. Sometimes it takes a couple of seconds for the gears to align and if you hit the gas too soon you will feel that banging sensation. She'd do it when shifting from P to D and sometimes from R to D. I haven't noticed if she's doing it in the Explorer too as I haven't been drunk enough to be a passenger while she's driving. :P
Could that be the problem?
it broke againb 6 months out of warranty and ford fixed it free.
given its a common problem i would try to get a free fix. i would be surprised if they said no.
if the dealer wont do it for you call ford directly.
What do you guys think is wrong and what is a fair repair cost? Also, I need to drive to Cleveland on Tuesday (about a 270 mles round trip)...can I drive it with the light on and get it fixed later in the week?
