if i break it, oh well
Good Luck,
E.D.
If you dont, you may be back at the dealer sooner than you expected. If not, its always better to be safe than sorry, and its worth the 60-80 dollars to have it checked again, especially if it fails again.
and also, if they cannot give you any assurances that the transmission is not damaged, this might be a clue as to whether or not it is actually fixed. ive had plenty of dealer experiences where it was, "if you dont ask, they dont tell." costly and painstaking
a few days ago i replaced the front and rear drum brakes, and starting yesterday, the rear driver drum locks up, even if i barely hit the brakes, therefore i have to start braking waaaayyy away from a suspected stop. and because its only that one brake, i fishtail immediatly. i have adjusted the rear drums, so they're all the way in. also, since it has been doing this, it shakes every time i hit the brakes.
-the broken rear handle
a tried your suggestion on removing the rear interior panel, but it wont budge. i've tried every position and placement, but it wont move! is there maybe a tool i can buy to make this easier, or should i just take it to the dealer?
~tom
Good Luck,
E.D. ISF
ive checked the rear drums once before, and did the whole emergency brake thing, all is well.
today i noticed the brakes squeak and squak. stopping squeaks like a squealy brake, but when i accelerate, the rear brake drum lets out a low pitched whine, sounds like a fog horn. this continues untill i speed up significantly, then it fades away until the next time i stop.
~tom
Questions in Response;
1. Obviously your sons car needed a jump, but did YOUR cars battery act normally before this jump? Meaning did your lights and electrical system seem normal to you, not dim or anything like that?
2. How did your DH know your battery was low, did he just see the battery gauge low, or did he test the battery volts with a voltmeter? Normally the battery should read about 12.7 volts with engine and everything off, and it should read about 14 to 14.2 volts with engine running and lights and AC OFF. WIth engine running and Lights and AC ON, the volts may read about 13 to 13.5 volts.
3. The alarm initiating when the battery charger was removed means there was a surge introduced, it could be because of a problem with the charger, or with your electrical system. Is the battery acting and charging normally now? Check it with a voltmeter, it you hav'nt already. Are the battery voltage readings in the normal range as I noted above?
4. The alarm should turn off if you turn the key to the on position, then to off. I hope it is off by now. If you can't get it to shut up, you may have to unplug the wires from the horns or from the horn relay (whichever is easiest to reach) until you can get if fixed at the Dealer or a Shop.
Good Luck,
E.D. ISF
-Cj
You're Welcome, Glad it's working for you!
E.D. ISF
E.D. ISF
Other things that could cause the problem are vaccuum leaks and other such stuff, but check the IAC first.
Good Luck,
E.D. ISF
BUT, since you said that "I have taken the explorer in over 6 times for the same problem", then obviously whoever was trying to fix doesn't know what they are doing, so I would strongly suggest that you take it elsewhere to be repaired. Ask them for the system pressures on the high side and on the low side, and post back here if you need further assistance.
Good Luck,
E.D. ISF
Thank you in advance for any suggestions.
~tom
Glad you got the problem fixed. Trying to diagnose and help over the internet is not as easy as being there, and being able to look at every detail. When new brake linings are put on, the drums or rotors would normally be checked for wear and trueness or taken to a machine shop to be turned. Yours must have had step wear in the drums, in which case they should have been replaced at the same time the new linings were put on.
In general, when working on brakes, you need to check everything associated with the brakes, while you are in there, things like the rotors, brake hardware, wheel cylinders, calipers, brake lines, cables, bearings, seals, bushings, shocks, suspension, etc.
was it windy out, and possibly just pushing the car around on the ice?
does the 4 wheel drive properly engage?
chadp1
thank you for all the replies
~tom
My 2 cents can be found at post #5366. I had these symptoms on a Ranger, finally got a trouble code and fixed it with a new fuel pump relay (little black box amongst others under the hood in the power distribution box). You might find other helpful info in that string of comments. Good luck. It's no fun being stranded like that - happens at the worst times. You say battery and starter are fine. I assume then you get the cranking of the engine but no turn over. That's the way mine was - starved for fuel.
If you decide to go this route do me a favor. Buy the part, keep it in the glovebox. Next time the problem occurs, slap that bad boy in and let me know if it doesn't start right up. I sure hope so .
~tom
Hope this helps!
Need to get your hood so you can open, most likely you'll be able to jump the battery to get it started, then drive to an auto parts store where they can do an alternator/battery check for you.
Also, to find other leaks, look for the green color near other fittings; or sticky residues. Oil leaks aren't usually sticky....
You might consider putting a bottle of Bars Leak in it, for a short term fix.....but something leaking that much I would really want to find and fix. And one more thing....I'd be carrying around a couple of jugs of water in the back, until you were assured this was resolved, just to avoid getting stuck somewhere.
~tom
