I think this terrain compares favorably with other parts of the country, for example over the Smokeys from Asheville to Knoxville, Tennessee. But is there some way you could test-drive the 4 cylinder on such a route so you can tell first-hand if you'd be satisfied with the power under those conditions? I'd like to hear from someone who has driven a 4-cylinder across the Rockies, on I70 perhaps.
Several other comments: (1) I've never done it, but the owner's manual says you can tow stuff with the 4-cylinder; (2) The downshifting should cause no engine damage as it doesn't come close to redlining; (3) After a 3,000 mile trip to Indiana and back to Massachusetts, mostly interstate miles, my oil level was about midway between half and full on the dipstick. Driving in town for another 1,000 miles hasn't changed the level any additional amount. I'm about ready to schedule the next oil change.
I need the 3rd row seating.
- this is when the window is up all the way the glass pulls away from the inside weather strip and then you get road noise - but if you lower the window 1/8 - 1/4 inch the noise quits.
does anyone have access to this tsb to see what it says andwhat the fix is, and if its for this problem?
Remove the carpeting and trays from the rear - the pre-wiring is underneath, on the driver's side. You will heed the converter, as the Highlander uses separate bulbs for brake and turn signal, trailers use the same bulb for both.
Also, confirm with your dealer that their converter comes with the flat 4-pin plug. There are actually 2 converter parts kits out there. If you need a 7-wire plug (trailer brakes), that'll require yet another adapter. Nice that Toyota didn't bother to explain all this, eh?
I bought the hitch receiver from my dealer, it came with the converter and a flat 4-pin plug, somethinh to consider if you don't have a receiver yet.
or search this board.
Manual
As far as the hitch, I bought it from my dealer's parts dept. I think it was around $250. Since we have a professional mechanic in the family, I didn't feel the need to pay the dealer for installation.
buying one this year.
All the above is pretty unremarkable until I explain that I worked in the auto repair industry for decades, and many years were at a Goodyear dealership both as sales and installation (small dealer, you had to do both). That I would buy tires sight unseen only because of the comments made on this board is a testament to the quality of information here.
Thank you all (at least those that recommended the Cross Terrains).
Phil
You must remove the two side carpet covered floor panels, the rear plastic trim strip at the bottom the "trunk lid" Next remove the tool tray, then remove the left tray. Look for the two afore mentioned plugs May be hard to find (covered with tape) but they are there. The 10 pin plug will plug into the converter which you must purchase from Toyota part # 08921-48860 list is 65.00......... but negotiate.
You must either fabricate or purchase the four connector harness from Toyota price quoted to me was $50.00. This four wire cable , plugs into your trailer connector. If you can find a 4 pin connector that will mate up with the 4 pin plug in the vehicle:then go to wally world...purchase the 4 wire harnes w/ the flat plug and you're in business....'cept fer puttin all the pieces back together...CAREFULLY... so,s not to scratch/damage anything. I'm gonna try to purchase a 4 pin connector plug and solder it to the 4 wire harness w/the flat plug purchased from Wally-world.
By the way...I opened the converter and has an I/C pack ,transistor and some (isolating diodes??)...all mounted on a printed circuit board...all for only 65.00... BUY TOYOTA STOCK ! ! !
hope this will ...help someone
I still find it amusing that the Highlander has a 140 mph speedometer! Same as
Camry, stupid! It's also very hard to read the instruments in the day time, poor!
But we like this vehicle very much.
My parents new auto Carolla gets 42 mpg, why spend extra for a hybrid!!!!!!!!
On the highway, I've gotten 22-25.5 depending on load, speed, traffic, weather, and terrain.
- '05 Ltd AWD
Took a trip from Michigan to Maryland and back last weekend. Got 23.5 mpg on the way out and about 21.5 on the way back. (Way back was windy & rainy). Was a little surprised that the highway mpg wasn't better than that. I suppose if I kept it at 55 it might be a different story. I have seen mpg readings above 24 when traveling 45 to 55 consistently.
The computer's mpg readings are 0 to 1.5 mpg better than actual, depending on how much parked idling I do.
Your trip computer experience jives with mine although for me, it's never been less that .5 mpg optimistic.
Hybrid and Diesel SUV Roundup (Inside Line)
According to Information Edmunds' has:
2007 Model Year Highlander
What Edmunds.com Says: The Highlander will become even more humanized in its next version, borrowing plenty of cues from the FT-SX concept vehicle.
What We Know: Scheduled to appear in the fall of 2006, the next edition of the Highlander will ditch its utilitarian design for a shape closer to the FT-SX concept shown at the 2005 Detroit auto show. Although its will grow in most dimensions, the next Highlander will retain a manageable, easy to drive size. A larger V6 is expected with output in the 280 horsepower range. Like the current model, it will be offered in both front- and all-wheel drive, with a hybrid option virtually guaranteed. A hybrid version of the current Highlander is scheduled to go on sale this June, more than two years prior to the fully redesigned version of the vehicle.
I traded in a next-to-new 2004 RAV4 as the front seats, particularily the pass. one were just not comfortable. I still don't have many KMs on the new HL but I'm enjoying it a lot already - I find it very comfortable and like the look of it more each day. I was also seriously considering a Nissan Murano which I like the styling of but in the end, Toyota reliability, resale and quality won me over. I also read a lot of comments on the Murano on Edmunds and other sites that scared me off the Murano. My wife has a '99 Toyota Solara SLE coupe, V6, which has been an excellant car for us and that made the decision easier also.
Later on the Fall, I will be getting 4 snow tires for it along with 4 new alloy wheels(not Toyota, aftermarket ones as Toyota wheels are too pricey). I hope to put many carefree and enjoyable KMs/miles on my HL over the next number of years. I passed on the Extended Warranty but may buy it before the 36months/60KMs window passes.
The Highlander is a proven vehicle and, although conservatively styled, it is a very sharp looking crossover. I'm pleased.
PS - why I keep getting the US flag instead of the Cdn one is beyond me, I checked my profile again just 20mins ago and it showed Canada as residence???
How much snow do you get where you are? I wouldn't rush out to get snow tires unless you travel a lot on road that don't get plowed. We had 77" of snow this year and never had a problem with the OEM tires (Michelins).
You need to set the flag to Canadian using the "Preferences" link at the left of this page. Let me know whether that solves the problem.
IMO, it is worth having even if you never pull a trailer.
Thanks again,
I'm used to driving a new car pretty gently the first 1,000 miles, but the climb from Phoenix to Sedona, then the trip back across the desert in June kind of precludes easy driving.
Does it hurt a new vehicle to hammer through hills and heat?
Thanks...Rod
The drive from Sedona to SD will involve a lot of down hill at the beginning, and flat interstate for the remainder, perhaps 2/3s of the trip. Try to vary your speed, and you should be fine. I have an 05 Highlander that I bought in Scottsdale a couple of monts ago, and have almost 4,000 miles already. (A trip to vegas and one to San Diego really added the mileage)
Have you already established price and dealership? If not, read my post in the prices paid forum...it may help you. post # 1515
Enjoy your new HL, and keep in touch with the forum...lots of great folks here.
Jeff
I guess I'm stuck in the old school mentality with cast iron cylinders, etc needing a significant break in period.
I'm sure the newer motors are fine with a bit of speed variance, that way I can still drive at reasonable speeds (75-80) during the trip.
I'm working with Camelback in Phoenix, got the 2WD LTD with all options except the two biggies, DVD and Nav (no reason for the DVD, and I can use Mapquest or Thomas Brothers for a lot less than $2K), for $33,600 OTD.
We live in Encinitas CA but own a place in Sedona, so I'll register it in AZ. The car is the same in all states in terms of emissions, but I couldn't find the color/options I wanted anywhere in CA (Oasis green/ivory leather without the DVD and Nav).
Take care...Rod
I noticed on your other post that you were able to achieve 25 mpg at 70-75 with AC running. Is that consistent? I talk to others that claim it averages 20 mpg. I'm debating between HL V6 fwd and new Avalon. Most of my driving is hghway in Mid-Atlantic / Northeast region. Also, do you detect more wind noise above 60? Thanks.
Our AWD V6 gets about 22.5 mpg on the highway so the FWD might do a little better. This is where the EPA ratings may be helpful. Although they won't predict your actual mileage, they should be fairly accurate on the differences from model to model. With the Avalon's 31 mpg highway rating, I would expect it to be substantially better than the V6 FWD HL at 25 mpg. The Avalon looks like it would be a terrific highway cruiser.
I can see why the hybrids do so much better in the city, (some shut off the engine at stops) as I can watch my average mpg drop like a rock just sitting at trafffic lights....In fact, this week I had an appointment to meet someone, and decided it was best to sit in the car and wait...details unimportant, but it was 105 degrees outside, so I sat with the engine running at idle with A/C on for 10 minutes..Average MPG for that tank dropped from 22.5, to 21.1 in 10 minutes...there was 210 miles of "city" dirving on the clock at that point....
I still don't believe the initial cost of hybrids justify the higher MPG, hence my decision to buy the 05 HL Limited.....
Just my humble experience and opinion..... :-)
The other unknown with the Hybrids is the cost of battery replacement 6 to 8 years in the future.
