It's cheap insurance to change the coolant every 2 years or 30,000
also change the thermostat while you are at it
Changing the coolant with the good stuff (silicate free)
It will increase the life of the water pump and protect the metal parts in the cooling circuit and allow better cooling efficiency
The job was valued at over $5000. (3600 on extended warrantee, the rest on regular warantee. I did have to pay $50 for half of a 4 wheel alignment
They found the rear bushings were worn out. This was causing rear end sway plus noise over bumps and excessive tire wear on the edges.
To replace the businings, the had to replace both swing arms assemblies which also include the bearings for the rear wheels. The springs were sagging so they replaced them also. The net effect was an entirely new rear suspension for free. The car is 2003. The work was performed 2008.
Previoulsy I had another $3000 of waranty work done on the front end including new stabilizer bar mounts, and at least one new bearing.
The trick is finding a dealer who is hungry for the business. Some just don't care. When I first had undercarage noise with the highlander, I took it to the dealership that sold me the car. They told me they were going to have to do a diagnostic and road test (at my expense) before they would tell me if the work was under warrantee.
Next I took the car to another dealership closer to where I work. They were happy to undertake a comprehensive warrante repair. They are a somewhat remote from the city core and hence eager to go the extra mile.
One more thing to keep in mind. The parts took a long time to get and I had to do without the highlander for more than two-weeks.
Its important to get these things done under warrantee becasue after the warrantee is up, it would cost less to scrap the car and buy a new one
Since most owners will not own a torque wrench this is most likely simply a way to get you to "visit" the dealer.
They only suggest doing it if you drive under the "severe" classification.
I would not recomment loosening then re-torquing.
If it aint broke, don't fix it.
If I drove freeway only at 80-85 mph, it would get 21 mpg
my new 08 HL gets 21 in mixed drving and 23 on the freeway
I personally wouldn't put a 5 year old tire on one of the driving wheels. I'd keep it as the spare.
"Safety advocates have urged NHTSA to set tire expiration dates -- and NHTSA is yet to rule on those. Sean Kane, president of Safety Research & Strategies, submitted details Wednesday of 108 accidents linked to tread separation of tires more than 6 years old that resulted in 85 deaths."
circlew, "BMW 3-Series Run Flat Tires" #694, 25 Dec 2006 7:58 am
I am hoping to provide 12 volts to the cargo area power outlet full time, but need to understand the wiring first. None of the wiring in the compartment in the left rear is "hot" with the ignition switch off.
Right now they said if it is the #2 cylinder ring, they would cover it. If not, I would have to cover the repair since it was a 'goodwill' fix. I've done all the maintenance and was planning on keeping it for 13 - 15yrs. (I had my Honda Accord for 13.5 yrs
and never had any issue except upkeep maintenance) I feel as if they should fix it since there are problems out there and they didn't fix it right the first time - even thou it was done as 'goodwill'. Any help or advice would be greatly appreciated.
loadlor
My '92 LS400 now has 162,000 miles....
I'll be sure and post when the belt fails, if........
Last Spring CEL comes on. Check oil, level is low. Add oil. Continue checking oil and note continued consumption. Discussed with dealer and they top off oil and I bring back twice. After 500 miles oil is 1 quart low. Next time after 900 miles oil is almost 2 quarts low. Dealer agrees oil comsumption problem.
Also, have intermittent exhaust smoke on startup.
I'm aware of and have the paperwork for the oil sludge settlement of which my HL is covered. Make my case to the dealer that blue smoke and oil consumption is cover under this settlement. They remove valve cover ($125)and say no sludge problem therefore not covered under the settlement. Dealer says must be something else. SA tells me $5K to rebuild engine if that is the problem.
I call number on settlement paperwork (Toyota corporate), give them details. They have dealer SA call me back and say they need to again remove the valve cover to determine the problem (another $125). He says that they may have to do some type of pressure test, doesn't give cost. He also says that if problem is valve guide the cost is all mine. If the problem is bad rings, Toyota will share in the cost, whatever that means.
If anyone can provide any input/advice on this topic it would be greatly appreciated. I know very little about engines.
Also, I read on Edmunds (post 10840) that a clogged PCV valve could cause excessive oil consumption. That's apparently a $10 item. Can anyone verify if this could be the problem.
Does anyone know the cost to repair valve guides or the cost to repair bad rings?
thanks in advance for any solutions!!
I checked the light bulbs and they are fine, I checked the fuses and they are fine, the lights works fine but when ever I put my foot on the breaks the right side break lights comes on but not the left once.
First I thought it must have some sort of circuit board because I can only see cables come in on one place and the electricity must be distributed from there but I called Toyota and they said it didn't have a circuit at all. So now I'm confused, why would I get the regular lights to come on but not the break lights and only one the left side.
EdB
Phil
Thanks for the info..
Eric
E
I did have to have some valve covers replaced and cleaned. I would have to relook at my paperwork to see what they actually did. I took it on a short trip and didn't notice any problems after that.
During my test drives I drove from Minneapolis to Des Moines and back. I have not driven it down there in the last year or so to check on oil consumption.
Hope this helps you.
