We tried to get Dodge to buy back this vehicle but they would not !!!! it now has over 36K on it so it is past Lemon Law status.......... :mad: :mad: we are fed up with Dodge and all their 5 Star dealerships.........when I worked in a dealership if we could'nt fix something right the first time it cost us our elite status.
This Magnum has 22 invoices on it if you look it up on car fax , I will never be able to re-sell this car only trade it in and get hosed by some other dealer.............
ANYBODY HELP !!!!!!
By the way I live in California.
Since my first post I took it to the dealer with my list in hand, they fixed everything except now I have this awful clunking noise in the front end. Only heard when going 30mph or less over bumps. It sounds like I'm going to lose the wheels. I've researched and have been told it could be the swaybars, tension struts, swaybar bushings?? I don't know what these do, but I'm going down today during my lunch to have a tech go for a ride with me. No doubt, the car will clunk like a junker.
We've been looking for something else that'll be better for winter driving anyway. I haven't made up my mind, but if they can fix this issue and everything else is fine, maybe I'll keep it. I guess some have good luck and others have bad....I think I've got the bad.
My husband thinks the previous owner ditched the car....we found a pine tree limb stuck in the underside of the car!! We think it was driven hard, of course you don't know that until you sign on the dotted line!
For example, if you have a tire or wheel problem, you should post in the Dodge Magnum Tire/Wheel Questions discussion (Posts from here have been moved there to get it rolling)
If you don't see a discussion that seems to fit the issue you want to ask about, feel free to start a new one. If you happen to create a discussionthat duplicates an existing one, we can take care of that as we go.
Thanks for your understanding and help as we organize things!
Anybody have this problem as well?
Either way, I believe your 2005 model should have been covered under the 70,000 mile warranty.
The first time I took it to the dealer they changed out the 02 sensors. It didn't help. I should also say that it is somewhat sporadic and seems to depend on ambient temperature so sometimes it wont do it.
The second time I took it back (one week after o2 sensor change) they reflashed the computer with upadted sofware from DC.
The third time they said they couldn't repeat the problem and nothing was done.
I now have had it at another dealer for two weeks and they say they cant repeat the problem either (it is in the 80's almost everday now).
We like the car but we are at wits end here. My wife (who noramlly drives it) is scarred of it. I am now willing to start changing out coils and all the various sensors because I figure that will be less costly than trading it. Any ideas? :confuse:
I wish you all luck. I cannot tell you how I love my Magnum, and I hope that those of you who are having problems get them straightened out so that you too can fall in love all over again with this great vehicle!
What can be wrong
Kos3
I have a 2006 Magnum SXT with the 3.5 engine, True duals cat back and a Cold air intake.
I have had the same issue with the engine stumble (cold) that has been spoken of here.
To date is has note been an issue, or much of one.
It occurs on cold start up and could be as some has suggested weather related.
Starts up fine and seems to idle o/k, but on light exceleration it stumbles engine light flashes, The light usually goes out right away. I have only had the light stay on over night once but the day it was to go to the dealer it went out.. This has only occurred to me about 8 times in the 85000K (53125M) I currently have on the car.
It occurred yesterday (damp weather)I thought why not, so I just gave it more peddle and it cleared right up.
I have spoken to a dealer re this and they state that unless I can get it too them with the light on they cannot tell what the issue may be ?? Sound right, I thought these things were supposed to remember what happened when the light comes on??
Other than this issue it's been a great car so far. I'd go as far as to say I love this car.
VCLS
I have that bounce when idling that i read about and i do not know if it is all connected.
i keep getting cylinder 5 misfire detected. i have taken to the dealership 2 times now and will be going again because of the same problem. they said the computer was not picking up any problems and that i should try using better fuel. I did that after the second time in and also put in injector cleaner and it came on again. But i also have a shake at 60 and higher speeds. they keep saying it is a bad tire or something but i think they are connected in some way because it seems like after they have had it that it goes away for a day. sorry about being confusing and rambling but really getting frustrated because i hate my NEW car right now and it is a little bit of a drive to keep taking it back every other week.
I will post the out come. I am luck to still be in warranty otherwise Dodge would have one less unhappy customer to deal with. :confuse:
This happens after the above scenario only. Otherwise the engine runs flawlessly.
Any help would be appreciated as I want to gather as many ideas as possible before tearing into it.
The thing is, other cars I have owned start up almost instantly when the key is turned; case in point: my '87 Buick Grand National, after having been stored for three years, roared to life the moment I turned the key. Why doesn't my Magnum?
The car rides and handles as well as the 300, but the engine is rough overall. In particular it has trouble picking up speed gently say from 20-30mph. The transmission takes several seconds to search for the correct gear and it sounds like a 1940s pick-up truck! Major disappointment. The dealer ran some diagnostics but all that has resulted in is a drop in mpg - from 22 to 20.
Do you have steering noise problem when turning?? If so run it to the dealership and have them inspect the differential discs BEFORE the warranty expires!!!! A little know fact that Dodge knows about but is not on their service bulletin radar (yet). :mad:
It could save you up to $500!!!!
I applied that fix to my sister's 3.2 Concord which was exhibiting the same symptoms -- bingo -- all gone.
I also have a comment re. 5.7 engine shaking at idle. Calm down everyone, it really is normal. This engine has an agressive cam with plenty of duration, lift & overlap -- it is the only way to get that free-reving hefty performance out of a pushrod engine. Compared to the hi-output pushrod V8's of years ago, the 5.7 hemi's "shakes" are barely noticable. It can't be "fixed", so either enjoy it or change cars. Some folks just don't know how well-off they are with this wonderfully civilized reincarnation of the hemi -- it even has the unmistakable hemi sound, although well muted.
The reason, is this: sometimes, when I pull up to a light, the idle is smooth and sometimes you can feel the car shaking a bit. The presence or absence of the shaking correlates with idle speed; when the engine is ticking over at just a tad over 500 rpm, it shakes a bit, but when the idle settles in at say, about 650 rpm (I am obviously estimating here, with an analog readout on the tach), it feels smooth.
So the issue is that I have never seen a modern, computer-controlled engine idle speed vary by that much, even in cars twenty years older.
It's just a glitch in the engine management system that shouldn't be there (I noticed no correlation with ambient temperature, how hot the engine is, A/C use, etc).
Pop the hood, look @ the left side below the wiper, there should be a long access panel with some tabs, push the tabs open the panel and the filter should be in there!.
Hope this helps.
