If it would make you feel better, you can certainly change the oil now, but it's not necessary. However, what you can do is take a look at the oil on your dipstick. If it has a lot of impurities and particles in it, go ahead and change it. Otherwise, just you're normal intervals.
Hope this helps.
Ken
I think that I should know as much or more than the great majority of customers about my product and I don't mind saying that I don't know the answer if I don't. However, I will always find it out if it is at all possible. I'm just glad that the work is appreciated. So thank you Cliffy and I'll take the compliment as long as you know that you're as deserving of the same.
Ken
Dave
With the $500 over invoice HL.
Ken
A word of warning, though, with the 235's (I'm assuming you didn't get the aftermarket spacers). When I first installed mine I had no problems with clearing the rear-wheel struts. However, when I had the tires rotated, one of the tires began rubbing. I guess not all of them were uniform size! Just something to be wary of...
I will take this opportunity to remind you that the best price is not always the best deal. Shop for an honest dealer and you will get an honest price and far less headaches when buying a new car. You may not get the "lowest" price but it will be honest.
Have a wonderful new year everyone.
Ken
2. I live in Gilbert, AZ and want to know if there are any mechanics around here that I can take my HL to for service (A/T, Alignment, checkups, etc...)? Or does anyone know how to research a good local mechanic who may specialize in Toyota's? I find the dealer service prices way too high.
2. Finding a reliable mechanic is not easy: word-of-mouth is usually best, from experience. You can start with the AAA web site, enter your zip, and check out their list of recommended shops for your area.
Hope this helps.
They had to order the center console by its many parts (and there are many), put it together, and then install it into my Highlander. It also involved getting a new side panel for the driver's seat as the console wouldn't fit in with the 2001 cup holders.
It was expensive (~$1400), but to me, it was worth the money. I love the way it looks and it now makes my Highlander the "perfect SUV" for me.
So, it can be done, but it's expensive and apparently not every dealer will be willing to do it.
I have two fairly big (95lb each),older, non-athletic dogs. To make it easier for them to get into the Highlander, I was thinking of removing one of the 2nd row seats so that they would have a bigger floor section to jump on to when the jump into the car. I'm then hoping that it will be easy for them to jump from the bigger floor section into the back section of the Highlander.
Anyone have any thoughts on this ? Is it easy to remove one of the 2nd row seats ? Thanks in advance.
I wouldn't hesitate taking even a FWD vehicle out on that, much like driving on loosely packed beach sand.
Then there is something some of us know, some all too well, as Pacific Northwest boiler-plate. Tracked or packed snow that was warmed by yesterday's sun and then refrozen overnight.
Even my Jeep couldn't, didn't, handle that.
I didn't want to invest tons of money to replace the deck, subs, component speakers, etc, plus Santa said I wan't THAT good this year.
I used Crutchfield (www.crutchfield.com) for research. I was looking for not too expensive, efficient speakes that would give a good upgrade.
I ended up with replacing all 4 with Pioneer TS-G1647's which are rated at
2-30 RMS
150 peak
35-22K
92 DB sensitivity
2-way coaxial
These are efficient and have a good low end spec.
These turned out to be close to the cheapest they had that fit, but still had decent specs.
They were $50/pr at Crutchfield but I got them on sale at $46/pr at BestBuy (reg $50/pr).
I also didn't want to deal with the install so I had BestBuy install them as well for $69 for all 4.
I also got an extended 4 year warrantee at $19.95, which I usually don't do but the salesman gave me a hint to only get the guarantee for 2 speakers and if there's a failure, then just say it's for whatever one fails.
So for about $180 I got 4 speakers installed with a 4 year guarantee, including reinstall.
The improvement was very noticeable. The treble is crisp and the boomy base is gone.
At pretty loud volumes there didn't seem to be any speaker distortion or amp clipping.
I used to have the treble cranked at +5 and now I use 0 or +1. I use +1 or +2 for bass.
I also set the fader a bit to the rear so I can then turn the volume up a bit and get more bass from the back. The bass is pretty good but not super but they are only 6 1/2"
The speakers they took out were a joke. They were lightweight single hard plastic cones. They looked like the kind you see in a cheap boom box. They didn't even have a 'whizzer cone' to improve the treble. The speakers in my wife's 96 Camry were even better.
The bean counter who picked these speakers should be fired. For an extra $20-30 total, they could have put in decent speakers
The installer said that he thought that the amp put out about 20 watts/channel.
If you are an audiophile or are into earthquake rap, these speakers may not fit the bill but it does seem that the speakers are the weak link and you can get a major improvement with just changing the speakers.
The 54 ft/lb spec is from the Toyota factory manual. You are right about the expense of those manuals but there is a cost-effective alternative. Most repair shops and dealers subscribe to alldata.com, which makes over a million pages of auto repair data available to the professional shops. You can subscribe to alldatadiy.com [do-it-yourself] for $24.95 per year for the first vehicle and $14.95 for subsequent vehicles and renewals. The site is also a good source for recall and technical service bulletin information. Its really slick and gives you many opportunities to use that new Snap-on torque wrench. Good luck!
Sirfile
I've balanced the new tires once they were put on. Do I need to bring it in for an alignment when I put on new tires??
If you want to check things out yourself. Replace wheels one at a time with the spare and see if you can find the problem one. This is assuming the spare is still the same size as your replacements. You stated the new tires are wider and taller which sounds like you went to a larger size. The same size from different manufactures should have the same overall diameter within .1".
Both are very good in the snow. The HL Limited came with everything included whereas Honda nickel and dimes you to death. If you want a moonroof or heated mirrors and seats you have to go up to the MDX. The quality of both is very good with the edge going to Toyota.
Our HL just passed 1 year and has only been in for maintainence and the gas tank clamp recall.
The Pilot has had a number of nagging little things but nothing major (we got it in June).
I live in the Boston area where snow & ice are common in the winter months. I don't know much about VSC (Traction Control/Stability Management), but I would think it would provide added safety in winter driving. Correct ?
I found a dealer who will sell me a Highlander, Limited or non-Limited, at invoice. The Limited model has VSC. Any opinions on which model (Limited or non-Limited) to buy ?
Ken
Thanks for pointing out the differences between the two models. While the additional options on the Limited are nice, I don't think they're worth the money by themselves. I am concerned about safety and for added safety I will pay the extra money for VSC, if VSC actually provides added safety. This is what I'm hoping to get opinions on.
As for testing a Highlander with and without VSC, I would think that's kind of difficult. Wouldn't one have to drive the car in a fairly dangerous manner, such as taking a corner too fast, to get a real-world feel for what VSC provides. I guess I would rather have folks provide their expertise/experience on the matter in a forum such as this.
Thanks again for the info.
I bought the LTD to get the VSC and side air bags for safety and would do so again with no hesitation.
GregB
If you're a careful and conservative driver, I don't necessarily think that it will make a HUGE difference in the overall handling of your highlander, but as I said, part of that will be based upon what you think if you drive one with and one without the system to see how they work.
Hope this helps.
Ken
Release when you hear a beep. Then start cycling through the tone and fader setting until you see one that wasn't there before: midrange, which looks a little like IIID. If you set it to about 3 or 4, you will think you have a different radio. The system still leaves a lot to be desired, but it is better.
If you turn off your ignition while the system is on, you will lose the midrange setting and have to repeat the process. Most of us have figured this out after 2 or 3 hundred resets.
Unlike the Porsche PSM the T/L VSC is non-aggressive, I. E. "Soft", possibly for the woman's touch. These are, after all, simply minivans that are just macho enough to satify the men in their lives.
VSC with FWD vs AWD. Save the expense, short term and long term, of AWD by buying the FWD with VSC. The HL and RX AWD system isn't. On dry or high traction conditions it is truly AWD, not that it's useful at those times. On adverse roadbed, slipping, conditions it quickly, instantly, converts to a 95/5 F/R torque distribution ratio, basically a FWD.
The only real shortcomings I have found with the VSC is the short duration of availibility and total lack, seemingly, of traction control. Not sure if it's concern about the ABS pump overheating or just simply low pump reservoir capacity, but it kicks off fairly quickly and then cannot be activated again until you have driven about 200 yards.
We have owned our Highlander Limited for a few months now and have loved it. I have a few questions for seasoned owners.
1. When auto climate is selected and heat is on in winter why is the AC automatically on? Will this decrease gas mileage?
2. Is the paint on Highlanders susceptable to easy chipping? We've had two major chips so far.
3. Is there a timer on the heated seats. It seems if they are on for a awhile they start to get cooler or is that just us getting used to the heat?
4. It says there are 8 speakers in the stereo system. I only count six. Are there two subwoofers hidden somewhere. Also is there a separate amplifier apart from the head unit.
I tried the following test.
I parked on a dirt road that was somewhat hard packed. From a standstill - I floored the gas pedal for a quick second or two. I observed the spot where I was stopped. All 4 wheels has dug into the firm dirt. Now if what wwest claims is true - only 5% torque is going to the rear - then why is there 4 equal sized divots in the dirt? From the effort required to dig into the hard packed dirt - I would conclude that each wheel received 25% of the torque.
To say that high traction is AWD, yet slipping conditions are 95/5, doesn't make sense. If there is high traction and AWD comes into play - that should suggest that the drive train always splits the torque 50/50 front/rear
wwwest - please stop implying the HL is not AWD 50/50 when you don't have one
I would politely suggest that wwest stick to the Lexus RX300 forum.
Any thoughts about or experience with the Auto-Dimming mirror option ?
It seems kinda gimmicky to me, but maybe that's just because I've never used one, nor heard anything about them.
TIA
