Visitor Agreement.
I see an alarming trend of warped rotors in this discussion group. Is it abnormal for rotors to warp at only 30k miles? Almost seems like a defect of some sort.
GregB
http://www.tacomaterritory.com/%7Efaqsection/content/dsabldrl.htm
http://www.motorists.org/issues/drl/
http://www.lightsout.org/story.html
Seems like DRL's are a waste of fuel, annoy people and are unsafe.
As I said, I can't speak for the HL, but the DRL's on an 01 RX can be disabled by disconnecting the voltage dropping resister under the battery support/mounting plate.
Being a very firm believer of the safety aspects of DRLs I only disconnected mine once I discovered that halogen bulbs have a dramatically shortened life when operated as DRLs below their design voltage.
Back when, I always tried to remember to turn on my low beams when traveling on two lane roads.
In my 01 RX I wired a SPST relay 12 volt coil into the DRL ciruit in place of the resister and now the DRL circuit is used to turn on the RX fog lamps.
So, I still have "DRLs" and I can use my fog lamps without the interference of the low beams.
My 99 911 C2 was/is of canadian origin so it came with HIDs as DRLs (a little TOO much) but Porsche also included the parking/street lamps in the DRL circuit.
When I picked up my 01 C4 at the factory I was told that the DRLs would be activated at the US POE. They weren't.
So I wired the left and right street/parking lamps to the seat heat circuit and discovered that the europeans have a special 5W bulb in the HID headlamp housing for DRL capability.
Seems to work perfectly all around.
My insurance company (USAA) reduced my rates with DRL.
So, it apprears at least to USAA that DRL are not unsafe.
Just my .02 cents worth
Best regards, Philip
I just cant get to a dealer right now to try this out
Your replies would be helpful here, with the above questions. Also again Glad to hear that even knowing about it you bought the HL and happy. I am new to toyo and here the HL is very reliable, thats what I need, and it seems comfortable enough to drive down to FLA from NYC with the family. :-)
I have noticed no problem with the front windows open, singly or together. I wouldn't give it another thought.
"Be careful when accelerating, up-shifting, downshifting, or braking on a slippery surface. Sudden acceleration or engine braking, could cause the vehicle to skid or spin."
NOTE: "ENGINE BRAKING"
(DO NOT LIFT YOUR FOOT FROM THE THROTTLE QUICKLY!)
Or else quickly shift into neutral.
The Sequoia is predominantly a RWD biased vehicle, what did you suppose will happen with a FWD or AWD with front torque biasing?
Same manual, Page 143, center column yellow high-lighted CAUTION note.
"Under certain slippery road conditions, full traction of the vehicle and power against 4 wheels (4WD mode) or rear wheels (2WD mode) cannot be maintained, even though the active traction control system is in operation"
I read this statement as verification of a firmware time-out to prevent the ABS pump/motor from being over-taxed and over-heating due to continuous pump activity requirement.
This statement would likely also apply to ANY Toyota or Lexus vehicle with ACTIVE Trac and/or AWD using braking to apportion torque, HL, 4runner, GX470, RX300, RX330, Sienna, and obviously the Sequoia.
You likely have only about 45 seconds of continuous Trac or AWD "duty", then you're left with a vehicle that has 3 open diff'ls.
And obviously the ABS and VSC would now also be non-functional until the time-out expires (unless you need to do a restart cycle??) and the pump can again be activated.
What is the cause of warped rotors?
I don't see how this can happen in normal driving.
Am I missing something?
Leaning toward Duelers due to price. Has anyone anyting good to say about this tire?
Rotor thickness variation can be caused by a number of caliper or rotor issues and results in the same complaint, pedal pulsation during braking.
Call me anal, but I rotate my own tires and torque the lug nuts myself (star pattern 80 ft-lbs). I even take this extreme measure when having new tires put on. I drive to the tire shop and park just outside their work area. I jack up one wheel and put the spare on. I jack up another wheel and then take the 2 loose rims inside. I wait until they are done and repeat the process for the last two rims.
This all came about after an incident in 1988 when I had my brand new Supra's lug nuts cross threaded by a tire shop using a air wrench. I had 8 out of 20 studs snapped trying to remove the cross threaded lug nuts. Things only have to happen once to me - I learn and never let it happen again.
I have about 400 miles on it so far and I'm extremely pleased with it. I traded a '01 Suburban for it, so I went through a period of mourning for the lost room, but I'm o.k. now.
My question to all you experienced owners, Is there NO automatic door locks of any kind on the HL? I am finding it hard to believe that the locks can't be programed to lock automatically, either by moving into gear or starting the ignition, or by obtaining some preset speed (15mph ?). Wow! Every car we have purchased in the past 10 years; Chrysler, Toyota, Honda, and GM of various makes have all had that feature. My In-laws 02 Avalon even has it. Am I missing something in the owners manual? Conversely, is there a way to have it set-up now?
Thanks for any feedback on this...
JE
The LTX is a much better tire, but if you are going to go the extra $$ for the Michelins, go $50 more and get their new Cross Terrain tires. I have these on my truck, and they are really really good. Smooth and quiet on the highway, and great traction in the snow.
If you want to stay in the lower price range, you might want to look at Yokohama Geolandars - they have been rated better than both the Bridgestones and the Goodyears.
Dealer said he could sell me a used 4runner for the price I paid.
I've have researched the question you asked for myself a couple of times and have not found that there's an auto lock feature for the Highlanders available. At least not on my 2001 & 2002 Highlanders.
If you have any success in locating any such feature or add-on I would greatly appreciate you posting your results here.
Best Regards, Philip
I'll continue to research the subject. Thanks again.
J
on my Camry and HL - works just fine, allows some
customized setting, long range. Both were professionally
installed by the specialized shop. The security system
would run about $320 installed. The security with remote
starter - $100 more. In case of my Ltd. HL, the shop was
able to add the remote starter to my Toyota factory security
system - works very well with just one remote.
Comments?
Wanted the lighted running boards.
I read so many post that folks say "Im done... will never by another: insert name here _______."
First: I own a 2001, V6, AWD non-limited
Second: I live in northern New Hampshire where traffic is light. I do not have any stop and go traffic to speak of, and most of my off-interstate driving is in the 45-55 mph range.
Now, with that said, I have never achieved less than 20 mpg, nor greater than 24 mpg. I find I get the best mileage in the summer (even with occasional A/C, and I think it is because the government stipulates oxygenated fuel in the winter and it gets lower efficiency.
Efficiency drops as speed increases, that, I think, is what the feds held to the 55 mph speed limit for so long. At a steady 45-55 mph, I consistently get 24 and slightly better mpg (summer). At 65-70, it drops to 22-23 mpg. I do not drive over 70, so I have no idea about that, but I suspect (based on another post several months ago) at 80-85 it would drop to 17-19 mpg.
I try to drive as steady as possible; anticipate stops and slow down in advance; no fast starts; and I have started using synthetic oil. Actually, I hope my mileage will improve a bit with the synthetic oil. I may have experienced a slight improvement already, but the real test will come this summer.
I know this is not what you wanted to know, but hopefully others will have more information.
Happy HL'ing to all.
DISLIKES
Outside wind noise, more with a crosswind
Vibrates when engine running, foot on brake and shifter in drive.
Odometer hard to see during daylight.
Not enough foot room, size 12 foot.
Painted dash.
LIKES
Smooth ride.
Quiet strong engine.
Looks good.
Lots of cargo room
Comfy seats.
Head rest no problem.
Good warranty
Lots of back seat leg room, and easy to park.
Would I buy my HL again
Not if I noticed the vibration. Beleive it or not I had the same problem with my trade in, a 1994 Nissan Maxima. Nissan never could figure the problem. Said " the vibration within tolerences".
Dislikes:
Uncomfortable front seat(short cushion)
Drivetrain noise
Road noise from tires I think
Likes
Great handeling for an suv
Smooth shifting transmission
OK gas mileage(avg. 20+/- mixed driving
Very solid (no rattles)
Good looks
Dislikes: (mostly minor)
Electronic odometer (off when key is off)
Odometer and trip meter at same location
Paint easily scratched
Poor sound system on unlimited
Likes: (all the major things)
Quality; fit; comfort; no rattles
Engine, power, smooth, quiet
Shifts smoothly and quietly
Very reasonable fuel efficiency
Handles well in snow
Doors do not lock automatically
Two way moon roof (especially canted position)
Other:
I have had no problem with vibration
No warped rotors; sludge;
Toyota service has been more than acceptable
Sure, I would buy another Highlander (but I do not plan on doing so for many years to come) I still drive a 1992 Acura, and it has plenty of good miles remaining even at 160,000 miles.
About 22MPG overall, lots of time above 80MPH.
Actual mileage posted somewhere over on RX300 thread.
