Dodge Ram Lighting and Electrical Problems
                    2000 Dodge Ram 1500 pickup.  When tryed to put on high beams headlights would go out, after a couple of attempts they would come back on.  Replaced high beam switch on column and now the high beam indicator light on the dash stays on all of the time and the low beams appear to be very dim.
I get a violent bouncing from side to side once in a while usualy on the freeway at higher speeds the only way to stop the bouncing is to pull over and stop. It only doses this from time to time and there is no set patern .the stering wheel dont shake or pull the truck continues straight but whole truck bounces very hard from side to side almost as if wheels are coming off the ground, The dealer can not find any thing wrong. any suggestions on a way to stop this bouncing?
cdn.4x4grl@yahoo.ca
In my pre-delivery inspection of my 96 3500, I noticed the brake lights stayed on... not good for a brand new truck just off the carrier. Dealer service department took care of it before delivery. Usually it's a fuse/relay issue, but in your case, I'd say there are two additional things to look at...
- for the headlights, you likely got something wet while off-roading. You probably want to check the power module and see if there's water in it - and get it dried.
- for your reverse lights, you likely have a wriring issue between the trans and the light connection. There's a solenoid that is triggered when the shifter is properly engaged in reverse that activates the reverse lights - that would be my first suggestion.
And as mentioned in the post box, please, do not include your email address in your posts. We can't protect you from spammers or other malicious use that way. just make your email "public" in your profile (use the Prefertences" link in the left margin), and only logged i members will have access to it.
kcram - Pickups Host
Thanks alot for the information! I will pass the information on to my friendly neighborhood mechanic!
As for my e-mail address (oops) I will see about removing that information.
Thanks again, Christina
I noticed that I have NO brake lights. I keep blowing the fuse and can't figure out why. I changed the stop light switch under the dash, checked all the light housings and still keep blowing the fuse, anybody have any suggestions, I could use the help...Thanks Bill
apparently there is something frozen in suspension I took it to a leafspring shop for 800.00 they fixed it my truck the steering shook also
Did you find out what was happening with your truck?
Please let me know.
That is correct
Sure enough 30 to 40 seconds after starting when cold is normal...but 2 minutes is not. Especially when I live in Southeast Texas.
Thanks for the advice.
Thank's in advance for your help!
~tom
David
Brake, Park, and Hazard Lights work. No turn signals.
Fuse block under hood looked OK.
Fuse block by Drivers Door looked OK.
Original Bosch flasher unit ( 0-332-209-150) under dash by steering column replaced with car Quest Flasher unit (FSH 7127)
Turn Signals still not working. What is the minimum voltage these flasher units will operate at ? Or do I have, two bad flasher units now ? Thanks - jander
A component that could cause this is a defective Central Timer Module.
Best regards,
Dusty
Dusty
