Visitor Agreement.
In my case, this is serious because the brake lights activate my trailer brakes.
Anyway- after the last door handle replacement her battery would not hold a charge over 24 hours. I had to connect my multimeter into the vehicle's electrical system to find out where the current draw was. When I set up properly, I found the car was drawing 350 milliamps with everything turned off. I started pulling fuses and watching the meter. In my case, when I pulled the fuse for the power door locks, the meter dropped to 75 ma. You should do the same test. If the radio is indeed drawing over 50ma, then something is wrong. Either the power amp is on all the time or the lights are wired hot.
Good luck and keep us informed.
Chris
thanks for any help.
Bill
Had the truck 2 years no electrical problems.
Suddenly both head lights went out at the same time.
The high beams still worked so I aimed them down
and used high beams. The next day those went out too.
Bought a new dash board dimmer switch, put it in but it
didn't change anything, took it back out again, hoping to
get my $34 back.
Now it has dawned on me, what if it was the switch and
the bad switch burnt out both lights, and that is why the
new switch didn't seem to change anything? Do I need
to try new switch again with new lamps?
I looked at the fuse box, but the termanology is different,
"exterior lamps" only had a 5 amp fuse so I figured that
was for the outside yellow lights.
I saw no fuse maked "head lamps" of any kind.
Should I replace the lamps and try the new switch again?
Or am I missing someing on the fuse box, hopefully?
have a good year.
My first concern is what happened to me coming to work today. I was driving along and a red GEN light came on. I noticed that my battery gauge on the dash was much higher than it usually reads. Normally I would think that if a Gen light would come on then the gauge would show less voltage, but I don't know. Is this a sign that my alternator is going out?
Next problem. This happens rarely, but I need to get to the bottom of this so I won't be stranded one day. I put my key in the ignition, turn it and nothing happens. I hear a rapid clicking or just a click from under the hood. I turn off the ignition, try it again and it works. On one of the times I could not get the engine to turn over I disconnected the battery and cleaned the connections. Put them back on and all was well. This was probably about six months ago, and I've had this problem happen recently. So I'm wondering if it is my ignition switch. I've replaced this in the past around the same time I got the current battery that's in the truck.
Once or twice my starter would not shut off even when I turned the engine off and took the key out. One of the times it finally shut itself off, another time I had to get under the truck and tap the starter for it to get unstuck, so to speak. Yet this happened only a few times and I haven't had this problem in about six months to a year. I'm just now remembering this and thought it is worth mentioning.
So any help would be great. Is all I need just a new battery or is there more that should be done?
I'm looking for help with my '02 quad cab, does anyone know how to return the wiper motor to home position. When you shut off the wipers they stop in the middle of the windshield. Its like they dont know were the home position is. When operating they wipe the winshield perfect.
My reverse lights don't work i have two brand new bulbs in them and i have power to them both 13 to 14 volts but they do not work! whats wrong with the dam things!
Since Ive owned the truck the rear drivers side passenger door lock never worked and even the dome light would not work but this was not a major issue( I think underlying cause)?? I need help with the door locks anyone ???
One other note when the system would short out the door locks if hit would make the radio sound go mute until I turned the radio on and off.This also happened when the auto door lock speed sensor clicked in as well??
Im at a loss and have looked for any obvious shorts in wires and need help before I give up and go to the dealer.
HELP GUYS ANY IDEAS !!!
Any
I've replaced the power door lock and that does not solve the problem.
Darcy
