Visitor Agreement.
system lights up/stays on, for no apparent reason? watched it and in a few seconds it flickered then
went out by itself. occurs both with trailer attached and by itself.... No electrical problems
since purchased 22000 miles ago.
right rear tail light on the attached trailer come on for no reason at all?
seems if it were the brake switch all the lights on that circuit would flicker
at the same time but they don't. 1. I hope the battery doesn't run down,
2. hopefully the truck won't go up in flames from a short under the dash or
where ever the problem is?
I have a 2002 and it is doing the same thing. Did you get your problem fixed and if yes what was it? Ive already replaced fuses, headlight switch and checked everything else but no luck with the problem.
Chuck
Apparently, Dodge has a corrosion issue which causes this. Dealer price for module: $830.00 plus 1.5 hrs labor = $1000.00
Will continue searching, for now.
im having basically the same problem with my 93 cummins did you find any sloution to this ? thannks
Witch WATER enters the BOTTOM of Box Through the weep holes
kcram - Pickups/Wagons/Vans+Minivans Host
If it were an ECU failure, you'd have likely gotten Check Engine lights because the battery would still be functioning. A kill switch disconnects all battery power to prevent the vehicle from being driven.
door message center say's key in igniton but it is not bell ringing aswif it is. batteries have been
replaced alternator has been evaluated
flashed all other modules. Was advised there was a service order pertaining
to the modules. Do not know witch ones. Truck has sat for three days I have
checked it each day and have not had problems. My trailer sensor was also
replaced approximately two month prior to problems
I found this blog at HIDextra, and it's very informative and helpful for RAM users! I know that Dodge is so normal to have issues at Aftermarket HIDs.
I would suggest that take some time to read this so we can understand better our HID system and to find the right kit for ya'all! :thumb:
http://blog.hidextra.com/dodge-ram-hid-kit-install/
1. I tested the light bulbs in the passing side assembly and the lights worked.
2. I tested the assembly on the passenger side and it worked.
If I had pulled the wires to hard could that wire have become disconnected further back?
Where or what should I check next?
