Soph
Does anyone know where I can get OEM parts for the Fujitsu unit other than Toyota? I have Googled with no luck also a good manual. Also shouldn't I be able to hook up an external receiver to the unit to see if it works as I do with my laptop navigation? If so is the receiver connected to the ECU or the indash unit? And last how do I remove the indash unit? In the mean time I intend to take this up with Toyota.
Thanks in advance.
On a side note, in general, if you are a person who keeps your car beyond the bumper to bumper warranty, it may make sense to skip the factory navigation. Two reasons, the maps go out of date in a couple of years and dealers charge crazy amounts for a map update.
Secondly, the newer units like in the Landcruiser also control other things like the heat/ac, radio etc. So, if the unit fails you are forced to fork out over $5000 for a replacement. It may seem a bit inconvenient, but for the number of times I use it, I would just rather have a portable unit in the car.
It may sound trivial, but the reason I went with another truck when I upgraded from my 2002 TLC was that I couldn't order the new TLC without the NAV package. Although they do say it is an option, you can't get one in without it. Basically it is *mandatory option*.
Thanks again
wm
The Calendar also won't work...related to not having a disc too?
I'm in the process of getting a new disc.
Please help.
Yep, i'm one of those Landcruiser owners that has a blacked out nav system as of Dec 07 when I put in a new car battery. The local dealer took a big swallow when they quoted some $5500 for a replacement........
Frankly, I am fed up with the attitude of Toyota. They basically told me I must have crossed the wires when I changed out the battery, adding that had I come to them for a new battery it wouldn't have happened-they have a device that safes all car systems. And, most consumers don't know this. I ask who goes to a dealer to put in a new battery? I'm sure they've had several customers that have had this happen to them and I think it's unethical that their manuals that came with the car don't warn owners not to touch their batteries or else it could "take out" a computer sensor, or the nav system etc. I was actually thinking of a class action suit.
W. Marsh
I can get the thing to follow voice commands though. this no voice is probably something REALLY easy to fix, i'm just blind to it....
Will post a review once i get it. Thought others may be interested too?
http://www.strongengineering.com/onescreenprotectorfits8displayautonavigationsyt- emfortoyotalandcruiser.aspx
