Hi... I just bought a 2000 Dodge Dakota Sport. 105000 miles, 3.9L magnum, automatic transmission. I got too good of a deal on it even if it needs a tranny rebuild. When the truck is cold it does not shift into second without with RPM's hitting 4000. It is almost as if it will not shift into overdrive. It is not consistent when it does this. The check engine light is not on. After driving about 10 minutes it starts shifting normally and drives great. I have checked all fluids and they are good. The guy I got if from put some Lucus transmission "stuff" in it and really no change. I have found no leaks. I have done some research but want some more opinions. Govenor Pressure Solenoid?? or Speed Sensors?? In low and High Gear (1 and 2) truck runs and shifts fine. Thanks, first_truck
A binding or loose Throttle Position Cable can cause this, or a weak or missing Throttle Return Spring.
I highly recommend that you get that Lucas stuff out of there. Mopar automatics use a special ATF (ATF+4) that can be easily destabilized by incorrect or incompatible fluids.
I have a 2003 quad cab with auto transmission. If I depress the throttle hard in order to pass or climb a hill the transmission seems to go into nuetral and the engine rpms peg. When I release the throttle, the transmission goes back into gear. Is this some type of safety feature or is there a problem? Thanks in advance for your help. Tony
I've owned my 3.9L V6 2000 Dodge Dakota 2WD since buying it brand new in well 2000. Over the last three years or so once in awhile while making a left turn the tranny (automatic) will slip out of gear and hesitate. I've gotten used to it and it doesn't seem to really harm the truck but I'd like to fix it if possible to prolong the life of the truck. I intend to replace the throttle position sensor as I've read on here to see if that works but I wanted to see if anyone else on here was having a similar issue.
Based on your description of the symptom I would say there is a problem. Some possibilities are list as follows:
*Low fluid level or foaming (possible transmission overheating)
*Clogged transmission filter
*Clogged cooler lines
*Throttle Position Cable misadjusted
*Gear shift linkage out of adjustment; kinked or binding shift cable
*Partially restricted Anti-drain Back Valve (excessively dirty fluid)
*Low hydraulic pressure caused by a weak pump, Valve Body malfunction or warpage, leaking clutch or ring seals, leaking Servo.
*Rear Clutch malfunction;worn clutch or leaking clutch seals.
Valve body wear is usually found on high mileage vehicles. Sticking valve body components usually indicate expired or very dirty ATF. Rear clutch wear at lower mileage usually indicates that the transmission had been overheated at one time, probably from pulling an excessively heavy load or towing with the overdrive engaged, or pulling heavy loads/towing in hilly country with the overdrive engaged.
This is also one of the classic symptoms in Mopar transmissions where the incorrect transmission fluid was used, probably Dexron-Mercon. All Dodge trucks and most Chrysler-built cars require ATF+3 (older vehicles) or ATF+4. Your's requires ATF+4.
Hey I think I have a huge problem. i have a 99 Dodge Dakota 5.2l 4x4 it has about 117000 miles on it. some times when you take off from a stop it acts like it is in neutral then it will jump hard in to gear. It also pulses when driving down the highway the problem is intermittent. The pulsing is slow like every 10 to 15 seconds the RPMs will jump about 500 to 750. The transmission also slips some times when it shift. Is this something I can fix my self or should i take it in. I have about two years of automotive schooling. But I am a college Student and Broke.
Hi, I'm new here and I sure hope you can help me... I just bought a 94 Dakota Ext, cab with the 3.9L V-6 and automatic trans. When I bought it, I drove it home and everything seemed fine as far as shifting... After about a week, it got to where it would shift fine when cold, but after the truck warmed up, it didn't want to shift out of 2nd. But you could sometimes manually shift it and it would go threw the shifts. Then it got to where it just didn't want to come out of second at all. I figured it was the filter picking up slug as it heated up, and restricting the filter. So I changed the filter and fluid. (I used the ATF+4, right?). Shifted fairly good for a couple of days, and the more I drive it the better it shifts. Now it seems to be doing fine except for... Now the darn thing doesn't go into overdrive... At all... I'm just a backyard mechanic, and not at all a transmission guy... What would cause it to not go into overdrive, when it was when I first bought it about a month ago... Help please...
The symptoms seem to indicate a possible intermittent loss of hydraulic pressure, although there are quite a few other possible explanations. Because of the age and mileage...coupled with lack of proper maintenance...you have a restricted flow problem. Potential candidates are a partially clogged transmission filter or cooling lines, or a clogged anti-drain back valve.
Of course, you could also have a weak of bad pump, bad seals, or rear clutch problems.
If you have not already repaired your transmission problem...or been gouged with a full transmission rebuild...your problem is one that I have experienced with two Dakotas I've owned. The overdrive problem can be solved by having a reputable transmission shop pull the overdrive unit and change out the two bearings in the unit.The whining noise is caused by pitting on the bearing races. If you drive the vehicle too long, you can freeze up the bearing and cause a full rebuild of the overdrive unit that costs in the range of $1200. Change out of the bearings, inspection, clean-up, and changing out the three sensors should be less than $600. Hope this helped...in time.
I have a 1998 Dodge Dakota 5.2, 2wd, 160k miles with an automatic transmission. For quite some time I've been noticing a shift quality issue that only occurs between 2nd and 3rd gear when the transmission is cold. When the tranny is cold, and the weather is cool, the engine revs quite high for quite a while before the truck will shift from 2nd into 3rd gear. the colder the weather, the higher and longer the motor will rev before shifting. The truck shifts perfectly after the truck is warmed up (after 5 miles or so of driving).
I've changed the transmission fluid and filter, and have also changed the output speed sensor on the advice of some folks, but neither step resolved the problem. The fluid change did help a little, but it hasn't resolved the problem.
I did note during the fluid change there were some very small black particules suspended in the fluid as well as some very fine metal particles stuck to the magnet in the bottom of the transmission pan. I belive the fluid was last changed about 100k miles ago, so the fluid didn't seem too bad considering.
Any ideas on what might be causing this? I'm really hoping this is a simple fix so I can avoid a costly transmission service here...
I posted on here a few years ago and still have the same problem. 93 dak 3.9 auto with 160k on it. It runs fine and shifts fine except when you have to pass it won't kick down. You can manually downshift and it works. I changed the fluid and filter right after I bought it. This is a 3rd vehicle for me and doesnt get used much at all except to haul things. I did replace the atf with the wrong type but it did the same before that. I am going to replace it again with the correct atf+4 and filter since the fluid looked brown and dirty. Anything to check while I am in there? The od works but you cannot manually shut it off at the switch, it is definitely NOT the switch as I replaced with a known good one. When you do hit the button, it seems to rev up a few like it is trying to kick out but then drops back into OD. The cable is adjusted properly. Had a guy in town drive it that rebuilds trannies for a living. He didnt think the tranny was bad per se, might be a valve body sticking or dirty??? Can't stick alot of money into it as its a spare but need it to be reliable. TPS? Od solenoid? It just doesn't have any downshifting ability. PLEASE ANY suggestions would be greatly appreciated!!!!!!!!!!! :confuse:
My 2004 Dakota 4X4 has 193,000 kms (about 125,000 miles) on it. when I stop at a stop sign or stop light I have to manually shift to first gear or the truck will rev. high. 2nd and third are the only gears that work when it does this, first and overdrive don't work. If I restart the truck the problem clears. I took it to a transmission shop they could not find anything physically wrong with the tranny, they suggested it was electrical. I had the fluid and both filters changed,was okay for three days then started again, when the tranny was being flushed the tech. said the pump was real slow. Is there a sensor that could be bad or may be the pump is going?
UPDATE..........Ran seafoam tranny cleaner before the flush. Replaced filter and flushed out all the old fluid, replaced with walmart atf4. Has never worked better!!! Now it downshifts and upshifts in all gears and OD now can be turned on/off. I am truly a believer in the flush and refill with atf+4. :shades:
I noticed this little problem at the end of last winter. I did a tranny flush and it went away until this slight cold spell. Now here's the problem.
At crank up when cold the transmission seems like it slips in 2nd and 3rd gears. 75% of the time I can turn off and on the OD and it will engaged into gear. All this happens only when it is cold. When it the tranny warms up about 2 or 3 miles it shifts fine from there on out.
If anyone has eny ideas, any help would be greatly appreciated. Sorry if this is a former question.
I have a Dak '02 that has about 100K miles. Last night the truck would not shift into park. I can turn the truck of and on, shift into reverse and drive and it works. I had noticed in last several weeks the shifter handle had lots of "play" when in drive. Meaning, I could move the lever up and down a inch or so before it would hit another gear such as D1 or Neutral. Any help would be greatly appreciated. :confuse:
i have 02dak they sent me a recall paper talking there have been some 02 dak shifting out of park into neutral might wont check local dealer to see if it covers the recall
my 02 dak wont shift out of first until it hits 5000 rpms and im not sure if it starts out in first sometimes it has 12000 miles my cousin had it first and he had the same prom.but he changed the fluid and filters and it worked fine for a while but now it is acting up again .i dont know much about it i know it my have some censors on it but i dont know were some told me it could be a censor.if someone could tell me i would appreciate it
I have a 1997 Dodge Dakota Sport 4x4 with the 3.9L V6 engine and auto transmission. In the last week the truck has been losing power and doesn't want to pull up hills now. At first, it wasn't too bad, but now it basically comes to a complete stop when going up a decent sized hill, and even struggles on level ground. The codes came back for the torque converter, shift solenoid A, O2 sensor, and Pres Cntrl Sol A.
I'm not sure where to start, as I have had the truck to a couple mechanics already and they tell me to take it somewhere else because they aren't sure where to start to pinpoint the problem either. The problem is that I'm not sure the truck can make it to where I need to take it, and I can't really afford to have it towed plus get the repairs done. I have read several threads about Dakota tranny problems and can't really find the info I need.
The transmission linkage is loose, and has been for a while now, but the truck still ran fine. I just have to start it in neutral and shift first to second to drive on takeoff. But now as soon as I put it in first it starts sputtering and doesn't want to pull. Out on the road every now and then, it does pretty well once it gets to about 40 mph. But it runs smoother in first gear than in drive, still not good in any gear, but better in first. The truck idles fine in park or neutral.
Sorry for the long thread, but I just wanted to try to give all the necessary info. Any help, tips, or suggestions would be much appreciated. I am just trying to pinpoint the problem as best I can without unnecessarily spending money on parts or repairs which may not be needed. Thanks to all who can help.
BTW, the error codes I received were: P0743, P0753, P0132, P0748.
I have a 1994 Dakota that has the 3.9 V-6 with automatic transmission... Can anyone tell me what other Dodge "years" or other Dodge vehicles that the transmissions will interchange in my Dakota? I guess mind is shot and I am wanting to go to the salvage yard and pull one, but don't know what other years or vehicles will interchange. Does anyone know?
I have a 1995 Dodge Dakota Auto with 145,000 miles. I have gotten the tranny flushed ever 30,000 miles since I bought it with 32,000 miles. I recently, only in cold weather ~45-50 degrees have been having a hard time getting it to shift into 2nd and 3rd gear. I just had it flushed with no resolve. What should I do?
I have a 1996 Dodge Dakota with a 3.9L V-6. Up to this point, I've had no problems. A while back I had a problem starting my truck. I turned the key and nothing, just silence. I was baffled. Somehow or another I took the truck out of park into neutral and then put it back into park and it started right up. I was thinking my Transmission might be slipping. The Other day, I pulled into work and put the truck in park and went to reach over to get my gym bag and the truck took off in reverse almost hitting a car behind me. Scared sensless and thinking I had mistakenly put it in reverse I drove back to my spot and put the truck in park again. Took my foot off of the break and it again took off in reverse. I pulled back forward, put the truck in park, shut it off and put the E brake on. The indicator that shows what gear I'm in (P-R-N-D-2-1) is now off by a half a mark, ie. Neutral now shows as reverse, etc. The truck is still driveable right now but will not shift into Park. Any help would be appreciated. :confuse:
I saw that someone else had this problem but I never saw a response to his particular problem. I have a 1996 Dodge Dakota with a 3.9L V-6. Up to this point, I've had no problems. A while back I had a problem starting my truck. I turned the key and nothing, just silence. I was baffled. Somehow or another I took the truck out of park into neutral and then put it back into park and it started right up. I was thinking my Transmission might be slipping. The Other day, I pulled into work and put the truck in park and went to reach over to get my gym bag and the truck took off in reverse almost hitting a car behind me. Scared sensless and thinking I had mistakenly put it in reverse I drove back to my spot and put the truck in park again. Took my foot off of the break and it again took off in reverse. I pulled back forward, put the truck in park, shut it off and put the E brake on. The indicator that shows what gear I'm in (P-R-N-D-2-1) is now off by a half a mark, ie. Neutral now shows as reverse, etc. The truck is still driveable right now but will not shift into Park. Any help would be appreciated.
Your linkage is out of adjustment. possibly caused by worn out parts in the mechanical linkages on the transmission or in your steering column. Your transmission will be damaged if you do not have the problem repaired as the selector in the transmission itself will be between gear selections and cause internal transmission problems and damage. Even though your selector says D your transmission could be locked between N and D and really wreck your day. That's why it won't start for you or only starts when you move the gear selector.
A sticky or binding Throttle Position Cable can easily cause this symptom, and a strong suspect since the problem started to occur in the cold weather.
Another possible cause could be the Throttle Position Sensor, especially in that high mileage of a vehicle.
I have a 1998 Dakota Sport with a 5.2, Auto. I just bought it 5 days ago and now the transmission is gone. It just barely moves in reverse and will not shift out of first gear. I love the truck and want to get it going again ASAP.
I have a friend who has a 1995 Dakota 5.2, 5sp that I can get REAL cheap. What I want to know is does this truck have everything I would need for a trans swap??? Or are the clutch/brake pedal assembly, slave cylinder/clutch master cyl set up, crossmember, mounts, and so on different
Or am I just better off getting another auto from the junkyard(though after reading all these posts and based on my own experiences im not sure I want another auto.
Look. I may sound like a voice in the wilderness to you, but Dodge automatic truck transmisions are pretty sound, durable, and reliable units despite what anyone says. If you maintain the vehicle properly and don't abuse it, the RH or RE series Mopar tranny will out live a 4L60 or 4R75 any day.
If your symptom is as described, the likely problem is severe loss of pump pressure. In my experience this is caused by a clogged Anti-Drain Back Valve, Transmission Filter, or clogged cooling lines. The problem is that insufficient fluid flow may have caused burned clutches or overdrive unit. However, there are other possible causes that may may not require a complete overhaul.
I will bet this vehicle's transmission was not properly maintained. Unfortunately, you are likely stuck with the problem now. I would have the transmission overhauled and rebuild by a reputable transmission technician that will ensure that all of the updates have been performed (there are a number of them). Once this is done and you change fluid and filters regularly per the scheduled service interval, you should be able to have a reliable transmission for at least 100,000 miles.
What you speak is the truth, When I got the truck the first thing I did was change all of the fluids, brakes and so on. When I dropped the trans pan the first thing I found that really dissapointed me about the previous owner(yes it was a one owner truck with 308,000km on it) was that it had the original filter from the factory and the magnet in the pan looked like a nice big donut there was so much debris on it. I had a good indication at this point I was going to be needing a trans soon, just didnt think it was going to be this soon.
I bought another trans from a local yard(it was alot cheaper than an over haul, and im on a VERY strict budget) I also ordered a Transgo shift kit for it, which I hope as their site says will remedy the problems that cause trans failure. I will take care of this new trans like it is my son, I love my truck and it kills me to see it just sitting in my driveway.
Thanks again Dusty, after spending a night reading EVERY post in this section I was hoping you would be the one who responded to me.
Well don't feel bad friend, I've asked two questions on here and haven't gotten an answer yet.. I'm beginning to think that no one on here knows the answers... Although my problem wasn't the same as yours, I didn't get an answer either... Good luck...
I'm glad to have been helpful. I'm honored by your comments.
One thing I'd like to add is the importance of flushing the cooling lines after a rebuilt or a swap. The way you describe the magnet, I am worried that the cooling lines are restricted. This is a VERY common problem, and not just on Mopars.
The Shift Cable is binding or is badly out of adjustment. You could have a problem with the Transmission Range Sensor, but this is very rare and equally doubtful.
If you look on the side of the transmission housing, there should be either an "RH" or "RE" in raised letters cast into the housing. You should be able to use any RH downwards to '89. The RE series is a little more complicated since there could be a computer-to-transmission compatibility issue.
You can't use an "RH" to replace a "RE," and vice-versa.
Swaping transmissions from different years is not an approach I recommend, since there are often changes and differences (axle ratio, for example) that will have a bearing on transmission performance, reliability, and sometimes suitability.
What you are describing sounds a lot like a catalytic converter problem. Had the same symptoms on two different trucks and the catalytic converter was clogged up on both. After putting a new one in (not inexpensive) they worked great. that may explain why the o2 sensor was appearing. Good luck.
dUSTY I HAVE A FEW PROBLEMS WITH MY SON'S 02 DAK .FIRST IT IS GETTING TERRIBLE FUEL MILEAGE .NEXT IT CUT'S OFF WHEN IT IS SHIFTED INTO REVERSE NEXT IT HAS A SHIFTING PROBLEM IN HIG GEAR AND OD I HAVE REPLACED THE TPS SAME PROBLEM REPLACED ONE O2 SENSOR AND IT THROWS A CODE OF 0748 WHEN SHIFTING INTO HIGH GEAR AND OD .ANY SUGGESTION'S? IT IS A 2002 3.9 AUTO DAKOTA .I AM GETTING READY TO CHANGE THE PRESSURE CONTROL SOLENOID AND THE FILTER AND FLUID WHILE IN THERE .ANY MORE SUGGESTION'S?
This needs problem needs to start with a pressure check. Could be a locked torque converter, broken planetary gearset, a stuck or dragging clutch, stuck valve body, there are too many things that might cause this.
the truck had a rod knocking and it sat for 2 years before we had the motor rebuilt .andn this is the problem we had after we installed new motor .i am going to replace both solenoids in the trans plus filter and fluid
Here's my opinion on using transmission additives. The types that are advertised for curing worn, dried, or cracked seals and gaskets rarely work. If a seal is bad there is no chemical known to man that can repair it. A seal that has a tear will not become whole again with any chemical additive.
Some of the so-called "tune up" additives contain chemicals designed to loosen gum, varnish and debris deposits formed by loose clutch or other internal materials. There are two problems with these types of products.
One. They sometimes work! Yes, they can soften debris materials but then this material is circulating around in the system where it often moves on to other areas that were not previously affected. This can be acute in older, high mileage or poorly maintained transmission where there may be a lot of debris material built up over time. Softened debris will then be re-entered into the fluid flow as loose particles increasing component wear and cause blockage in another area or stop fluid flows altogether.
This can be especially acute in Chrysler transmissions because they all use a Anti-Drain Back Valve to prevent siphoning of the torque converter at cool-down. The anti-drainback valves used in most Chrysler automatics are susceptible to becoming clogged, the lone exception is the 545RFE which uses an internal anti-drainback valve and has a coolant return filter just in front of it.
If you have ever seen transmission cooling lines that were literally packed solid of debris you'd understand that just adding something to the fluid to "loosen things up" could have grave repercussions. In fact, in the transmission service and rebuilding industry system flushing is highly controversial for this very reason. There is a point when deposits inside the transmission are so great that the only correct way to ensure that the system is completely clean is to tear it down and bench clean.
Two. They de-stabilize ATF, especially ATF+. Chrysler's ATF+ series is a very specialized lubricant/hydraulic fluid. It contains a number of additives that lower the pour-point, raise the operating temperature (viscosity index), make the fluid resistant to moisture build-up, prevent foaming and oxidation, and most importantly...give the fluid a specific friction quality to match the design of the transmission clutches and other internal components to ensure design shift operation.
ATF+3 and ATF+4 are the easiest to de-stabilize because they are a much more complex fluid than Dexron or Type F. One quart of Dexron-Mercon will kill a Chrysler tranny in just a few thousand miles. Additives are even worse, in my opinion. When they are used you now have committed yourself to the complete removal of the additive to the transmission, which means you must flush the entire system at the very least.
My advice is if you think you need to put an additive in the transmission, what you really need is to have the transmission correctly diagnosed and serviced. Many times this will be less costly and time consuming.
Had the dreaded "Stuck in Park" happen on my 2001 Dakota Sport Club Cab AWD yesterday. Happened in a friends driveway ... had to crawl under it a disconnect shift cable and manually shift it into neutral and push it out of the driveway. Have read all posts re this issue. Looks like lubricating the sliding and rotating parts on the locking pawl mechanism is the only fix??? Only way out was to push the locking pawl in with my finger, then it started working again, didn't have to step on the brake pedal. This morning after sitting all night in a warm garage it did the same thing... had to push the pawl in with my finger ... then it released again just using the key. Looks like this is going to be a real pain. :mad: Any permanent fixes for this that anyone has come up with??
ok I am looking for an aftermarket transmission so i can do away with this piece of stuff dodge is calling a transmission if anyone can help me it would be appreciated
Went mudding and after two days, my auto transmission started to slip. Checked the dip stick and it had water on it. I had the trans flushed out but it still slips. it is a 2004 dakota with a 4.7 v-8. Before i spend 2000.00 on a rebuilt one, is there anything else i can try. What about replacing the transmission filter and fluid?
I'm not sure what "lubricating the sliding and rotating parts on the locking pawl mechanism" means to you. Although it can happen on a transmission that has a damaged parking pawl or sprag, this is very rare.
This problem is usually the result of an out-of-adjustment Brake Transmission Shift Interlock (BTSI) mechanism that's located in the steering column, or a damaged or improperly lubricated shift cable that connects to it.
Remove the trim on the steering column and watch the movement as you move the gearshift lever. If the lever is moved but you see no corresponding movement in the cable, its a binding problem. Lubrication mat resolve the issue if it's not an adjustment or damaged shift cable problem. There's a special grease that must be used available from your Dodge dealer. Do not use axle or bearing grease.
There is a adjustment procedure, but I recommend having your dealer check this out. This is a common symptom on older or high mileage vehicles. It shouldn't take a tech. too long to fix this if there are no parts required.
You have a 545RFE transmission. 545RFEs are pretty sophisticated. They are not only fully electronic but also fully adaptive, meaning they constantly adjust for driver input and operating conditions. If you've done a full flush of the system, you should've replaced both transmission filters (Yes, there are two in a 545RFE). If you haven't replaced the filters, you may have packed either one, especially the Coolant Return Filter, with water. This will block fluid flow.
First, can you please describe how you flushed this transmission?
Second, what fluid did you use when the flush was done? If you didn't use ATF+4 you may be in trouble!
Possibilities. You may not have flushed all of the water out of this system. In addition, if mud has gotten into the system a flush may not be adequate enough to remove all debris.
545RFEs compensate for clutch slippage over time by counting Clutch Volume Indexes (CVI) and internally adjusting clutch pressure. When the transmission was slipping, the Powertrain Control Module (PCM) may now believe there is so much slippage that the CVI has overshot. This may possibly be corrected by disconnecting the battery for one minute and allowing the PCM to reset.
Personally, I would recommend taking this to a Dodge dealer and having them diagnose the problem. These trannys are really tough and near bulletproof. Tear downs and rebuilds are extremely rare, and usually unnecessary.
Thanks, first_truck
Dusty
Tony
Dusty
It is a V6
Tony
Sorry about the late response.
You have a 42RE transmission.
Good luck and best regards,
Dusty
Best regards,
Dusty
Dusty
Tim
Thanks Chad
Best regards,
Dusty
Any help and info would be appreciated.
Dusty
Best regards,
Dusty
I suggest taking it to the dealer for repair.
Best regards,
Dusty
Good luck,
Dusty
Dusty
Good luck and let us know how you make out.
Dusty
Lee
Dusty
Dusty
