Once the car is waiting for a contact:
1. Select “Menu”
2. Select “Address Book”
3. Highlight any entry you wish to transfer
4. Select Options
5. Scroll to "Share Phonebook Entry" and Select
6. Select “Look for Devices”
7. Select "Handsfree"
We live, we learn..
Thanks so much for your help!
Haven't tried to pair it yet, but just wondered if anyone has any experience with this phone. Hoping you'll be able to help me stay sane during the entire process. My carrier is Cingular.
I'm thinking Bluetooth is going to be awesome!
Take a demo car out and show the IDIOT salesman how well it works. You do not have to own the cell phone or the car to test program it and make phone calls.
I love my blutooth in my 07 Camry, using Cingular RAZR.
I was wondering if you have had any of the same problems. The service dept at the dealership where I bought the car doesn't have a clue about bluetooth..all new to them. I have the JBL and also have the satellite radio installed. These problems seemed to occut after that was installed.
Did anyone propose a solution to this Bluetooth pairing problem?
I still can't get my Treo 650 to connect with my 2007 Camry.
Thanks, Travis
thank you!
Or do I understand your question incorrectly?
Thank you for contacting our Verizon Wireless website. We are happy to assist you with your OBEX question.
We apologize for any confusion. The agreements we have with our Get It Now content providers preclude our allowing anyone to download applications beyond the phone. It is for this reason that none of our Get It Now enabled Bluetooth capable handsets have Bluetooth Object Exchange (OBEX) or file transfer capabilities enabled. Only our PDA-based handsets such as the XV6700, Treo 700w/700p, Motorola Q, etc. have OBEX enabled.
My current cell phone plan is with Sprint. I dropped by one of their stores the other day and the salesperson directed me to their LG LX-350 cell phone. It's Bluetooth-enabled and a pretty handsome looking phone. I really liked it but knew I'd have to check back here before purchasing it.
So, the obvious question is: Has anyone had experience with the LG LX-350 and their 2007 Camry? If so, how well does it work? Thanks!
I have a quick question for you, if you don't mind: If you HAD to choose one Bluetooth phone from Sprint's arsenal, which on would you select and why?
bluetoothguy, also, what do you think of the Samsung A900 and the Samsung MM-A920? Have you heard good things about either/both of these phones?
I'm at a point where I'm ready to buy a bluetooth phone, but it's going to have to be through Sprint, unfortunately. I'm just trying to get the one that's the very best bluetooth phone, with the most compatibility with my 2007 Camry. Thanks!
I have a 2006 BMW 330i and it transfers the phonebook entry of a paired cellphone automatically. If I add a phonebook entry to my cellphone, this new entry will be downloaded to the car's phonebook the next time I get it. I have paired 2 cellphones: a moto v600 and Sony T637 (both cingular).
Can this be achieved in the latest 2007 Camry or Lexus 350.
Can we scroll through the car's or cell phone'e phonebook entries through a buttonon the steering wheel ?
I have the Nav-equipped Camry Hybrid...
The item that caused trouble was that my phone numbers on the phone are all formatted: xxx yyy zzzz (with no punctuation - just spaces). These numbers only transferred the area code in most instances. I had a number that was formatted like xxxyyyzzzzpp1244#2342 (this was a voicemail phone number with "p" for pauses). This one actually transferred correctly. It seems like you want the number to have no spaces (just the number) - but I had trouble reproducing this.
I tried editing one entry on my phone and re-sending it, but this one was cut off too.
What I ended up doing was going into my contacts list on the phone (I use Pocket Informant as my PIM application), selecting multiple entries, tap and hold on one of the selected contacts, and then choose "Beam". This brings up a screen that will search for bluetooth devices (along with IR - but we don't care about those).
Now go to the phone screen on the car, and pick the "Settings" button on the screen. Then pick phonebook. Then "start transfer". Pick a group. (If you already have entries in the car's phonebook, it will tell you this, and give you the option to overwrite or add to the phonebook - you should probably choose "Add to".) A screen will then tell you to initiate the transfer with the cell phone. Wait patiently. Look at the cell phone screen - it should find the bluetooth device in the camry (I renamed mine to "Camry" in the bluetooth setup). Tap this line item on the cell phone screen. It should say "pending", and then it will do the transfer within about 10-15 seconds.
You should see a note that the transfer was successful on the Nav screen.
After all of this, I went in and edited the phone numbers for each entry. It was a pain in the butt, but it worked. You might have better luck with cleanly formatted phone numbers.
xxxyyyzzzz
I will try this later with a new entry, but this is unfortunate, since this format makes the phone numbers harder to read on the mobile phone...
