I ordered a 2007 XLE and I'm looking into phones that may work well with it when it shows up in late August/September. However, I have to use Sprint or Nextel for work reasons. I saw the Sprint discussion above, and there does not seem to be a strong winner in that category.
Has anyone connected one of the Nextel bluetooth phones to a 2007 Camry? Any problems? I'd appreciate any information if anyone has already tried this.
rk
1 When I use my handsfree system to dial voicemail and connect to it, is there any way to use the handsfree system to navigate within voicemail -- for example, punch "3" to delete the message I just listened to? Or do I have to pick up the cellphone to do that?
2 What is the purpose of the "speed tone" feature? What would I use it for?
Any info, many thanks.
i.e. 8001234567p1234
Thank you in advance.
I now push "talk" on the steering wheel, say the name, the name is repeated, I push off hook and the number is dialed.
If you have a minute go over what you did to make it work.
Final question can you press talk from the nav screen and have it work??
- Romesh
How are you getting it to work from the nav screen??
I don't know, lost as heck on why you can get it to work from the nav screen, that is really the way I want it to work, but can't get it to.
Have you by chance found any additional information on a Sprint phone that will work well? The website www.phonescoop.com gives some good info on various phones. Here is what it says about the MM-A900 Samsung's (Sprint) bluetooth functionality...
Supported Profiles: HSP, HFP, DUN, OPP, FTP, BPP
version 1.2
I have copied the descriptions of these profiles below.
"For example, most phones support the Headset (HSP) and Handsfree (HFP) profiles, for connecting the phones to headsets and car kits, respectively. But not all phones support the Object Exchange (OBEX) profiles, which let you transfer files (like photos) (FTP) and/or information (like contacts and events) (OPP) to and from other devices. Another profile supported by only some phones is Dial-Up Networking (DUN), which lets you connect a laptop or PDA to the Internet via the phone. Other optional profiles support connecting to printers (BPP), keyboards (HID), and stereo headphones (A2DP, AVRC)."
Based on this report the A900 has OPP which (if I am reading this right)I think allows contact transfer. However the wording is confusing...we may need phones with OBEX...I don't know.
I've seen the past posts with no sprint success...Anyone out there?
Thanks for all the posts here. This forum has been very helpful.
As for requirements, the Toyota handsfree systems use HFP for hansdfree functionality and OPP for phonebook contact transfer. OPP uses OBEX as an underlying protocol (If a phone has OPP, it has OBEX).
The Sanyo Katana should work well with the Toyota handsfree systems. Also, the LG LX350 and Fusic should also be better than the Samsung phones.
I love the look of the katana too, and I really don't think i need all the extra features...
One last question, since you seem to be the only one alive with any knowledge...you say it should work well - does that mean it will pass the phonebook to the NAV and display battery life and caller info, etc?
Thanks again!
Thanks for your posting.
hpace
Don't feel alone I have basically the same thread going on 2 different forums and can't get any help. It just doesn't work unless I am at the phone menu or say "dial by name" first. If you dont mind doing that, then just press the voice thing and say "dial by name" and it will switch and you can dial by any name that is in your address book. One warning don't use the word "and" it doesn't like it. We had my wifes parents in there and when you would say "larry and arleta **lastname**" it never gets it. But now we changed most of them over to just one of the persons names and it works. Hope that helps you some, don't read the manual it is completely worthless.
Ask your kid:
Have your kid tell you what he did to get it to dial straight from the nav screen I and a million other people would love to know.
So what you are telling me is you are at the navigation screen (watching your car move down the road) and when you hit the voice icon on the steering wheel you can just say "dial (persons name) " and it will dial them??
I saw your posting of Jun.16th. Has you paired your Nokia 6102i successfully with your new Camry? Please advise. Thanks.
New TCH with Nav: Can I transfer numbers with the Sony Ericsson Z525a (Cingular)
Please note that some Sony Ericsson phones have been observed randomly disconnecting from the vehicle. It seems to be an issue specific to certain phones, but there is no good way to tell which ones it affects (they don't expose the software versions).
I hope that helps.
No tab for multiple trsfrs -- However, i can send to the Nav system phone book -- individually -- by: 'send to bluetooth'
Not as good but, better than manual.
Re: TCH with Nav: I can not access the Voice Tag registration page?
I can use the talk button to 'voice' a number -- but, the manual states you must register a 'voice tag' --
Help???
Just wanted to report that I ended up with the Sprint Katana as recommended by BluetoothGuy (thanks!). It paired easily. It transfers phone book entries just fine. At first it wouldn't dial. I changed a setting on the phone to something like "always allow bluetooth connections" and then dialing worked just fine, too.
Very happy with both the car and phone so far.
Regardless, good job on trouble-shooting and resolving and thanks for pointing the issue out.
My husband called me twice on the way to work this morning (the real test) and the sound quality was fine for both of us.
Now I just have to take a walk around the building here at work and see how good reception is. It should be fine, just like Nextel, from what my colleagues have told me.
Thanks for all your help and great advice, bluetoothguy.
Go to edit phone book screen----select name for editing----touch left bottom arrow of edit contact data screen----touch "voice Rec" of voice recognition:off screen----touch "Rec" to record a voice tag.
Repeat above procedure to register up to 20 voice tags. Once this has been done, one can use the voice command of "dial by name" during driving without inputting the phone number.
How about transferring contacts via the VX-8100? Thanks!
