Honda Fit Real World MPG
1568101151
  • crimsonacrimsona Member Posts: 153
    I'm hitting 200 km at the halfway point, which works out to 125 miles (if I'm lucky). Sometimes it's halfway at approx 190 km
  • fitman548fitman548 Member Posts: 172
    200km...are you in Canada? Maybe your pumps shut off sooner or something. That would explain the needle difference. But your MPG calculation wouldn't be affected. Ethanol blend? Do you have a CVT?
    I would have it looked at if you're consistenly getting 25mpg.
    The CA Spec is identical to the US spec with the exception of metric/imperial and a few safety things (Daytime running lights, front bumper).
    Same engine, same suspension.
    My trips practically never go more than 20 km round trip, including commuting to work. I have a stoplight probably every kilometer or so on the 7 km commute to downtown Vancouver every morning. (EDIT: Just looked at a map, it's about one stop light every 250-400 meters, less once you hit downtown, then it's once per block)
    I have complained once, but got brushed off saying it's due to my driving habits and Vancouver's relative hilliness, without giving the engine a chance to break in (currently 1200 km)
  • hqly2001hqly2001 Member Posts: 92
    It appears that some folks might be unlucky..
    i do not gun it on the green light nor go beyond 70 mph cruising.. i try to keep my rpm between 2500-3000.. i only gas up for a few second when i occasionally go uphill ..my needle at half way from first tank was about 141 and just recently my mile at the halfway is currently at 132.. consider yourself lucky.. i may have either a lemon or somethign is wrong with my car.. hard to believe.. my corolla is getting 36-38 considering that i drive more agressive with that car..
    i'm
  • kipkkipk Member Posts: 1,576
    Give the Fit a chance to break in before getting too excited.
    Dealer probably won't do much until you get some miles on the FIT odometer. Still, it would be a good idea to get the problem documented at the dealer. LET THEM CHECK IT OUT.
    Kip
  • velociracervelociracer Member Posts: 9
    Can you explain in what way the front bumper is different between US and CAD models?
    Congrats on your new acquisition! That is one short and stressful commute crimsona. Your car never reaches and maintains a cruising speed. because of all the shifting, your average speed at 3000 rpm is probably 40 kph. In comparison, if you cruise at 100-120 kph to stay around 3000rpm it should boost your economy by 10+ mpg. Have you tried a freeway road trip averaging 110 kph for the whole tank? You will be surprised.
    My commute is 80 miles (130 km) round trip averaging 70mph/110kph, and my 99 Civic EX Coupe (Canada's Si) averages 35mpg, sometimes in the low 40s if I am careful with the throttle. I've got 155k miles (250k km) on it right now. What was your mileage in your previous car for the same commute?
    The good thing about your commute is that it is good break-in for your engine. But heavy duty for your transmission (assuming you have the 5MT). I would change the tranny oil at 20k miles (32k km) with Honda MTF. Watch the color of the used trans oil. Observation based on my first year or two with my 5MT.
    Another 12 months (~15k km) your engine should be fully broken-in and a freeway trip should show its true efficiency.
  • Kip: There are too many factors that determine gas mileage tha you can't simply get double the gas mileage because one vehicle is half the size of another. Also with the Fit having half the power, you still have losses do to acceleration. You alos have to look at how an engine is tuned and how "in synch" it is with the transmission. I'm sure others cna add to this list.
    The reason for getting the Fit over your current Pilot is the reduced gas consumption for you. Based on what you were describing as your commute, you would only have to fill up once a month in a Fit! And at over $3.00 a gallon for gas......
    Originally I could have sworn the US bumper was a little longer, but looking at more side profile pics, I'm probably wrong.
    I used to bus downtown, since Vancouver's public transit system is honestly not that bad. It's no Tokyo/Hong Kong/Singapore, but it's respectable in its own right.
    I got the Automatic (sport) since I had anticipated a ton of stop and go traffic, and was not confidant in learning a manual transmission in such a position. Since Vancouver is fenced in by mountains in the north, the US border in the south and the ocean in the west, the city's area is actually quite small, and you don't have to go very far to get anywhere.
  • ramoramo Member Posts: 66
    AT LX, 12756 kms, 33.46 mpg (US) last tank. 70% air conditioning, 295 lbs. load. Lots of highway driving, no sudden starts. I am very happy with the results achieved, given all factors.
  • johnnyb11johnnyb11 Member Posts: 50
    my sport m/t now has over 4800 miles. Most recent tank - 26.9 mpg. WTF!!!! My first few tanks were always over 30, sometimes mid 30's. My last 3 tanks, below 30, getting worse everytime. AGain, love the car, but this mileage is b.s. My tire have been at 35-38 psi since day one, I almost always travel alone, 75% AC in last month or so, no fast starts or stops and shifting around 3500 rpm or lower. This is an m/t for #$% sake!
  • bluebell2bluebell2 Member Posts: 21
    A few days back I posted a similar experience. Changed gas stations and the milage went back to how it was. 33-35 stop and go/city, 40+ highway. I am keeping every gasoline receipt with odometer reading recorded. My concern is stations doing something to the gas. Time to look into contact information for a local consumer affairs agency. Try getting gas at another station - see what happens.
  • 3geezy3geezy Member Posts: 2
    I have an AT Base Fit. Run AC 100%, travel 30 freeway, 70 surface streets. Odometer around 1000 miles.
    Last fill up
    268.9 miles
    9.372 gallons
    28.69 miles per gallon
    It is going up from last fill up at the exact same pump with auto cut off.
    I would like real world tips on cranking that up over 30...I have not checked or changed tire pressure...if you are getting 35+ how do you do it....
  • fit2drivefit2drive Member Posts: 1
    I've never averaged less than 34mpg on a tank in my Fit with the 5MT. I have driven from home in AZ to Oklahoma and on a another trip to San Diego... one tank going to OK gave 39 MPG, another 38... albeit, almost all highway. To SD a bit less, 34 because of some steep passes. The car does great as it closes in on 5000 miles.
    David
  • petro33petro33 Member Posts: 192
    I really like the red. Easy to find you car in the parking lot! When your 60 you need all the help you can get!!! I have read about the front protectors but I can live with the road chips. In my opinion I would rather have a few rock dings than have the front covered in the clear protector. I read about it on a MR2 spyder forum (my other car) and some people had problems with things getting behind it and doing more damage.
    Anyway has anyone tried to remove the lower rocker panels on the sport model. Not a big fan of those but part of the sport model. In my opinion the look great if you are in your 20s. In a practical sense they hit the cement parking barriers. Now maby even without the rocker panels it would still hit, don't know??
    When accelerating, I almost never get above 3500 rpm. If I see a red light up ahead I lift off the gas and coast. etc etc, all basic mpg boosting things. I can't imagine how you must be driving to NOT be getting over 30 mpg.
  • getnfittywiditgetnfittywidit Member Posts: 50
    I haven't gotten over 27mpg since owning the car either and I am in no way heavy on the pedal. (except when I took a road trip once on the interstate)
    It's just a base AT driving in the hot city/suburbs thing, I believe...according to other posts.
    My AT is sport, but I'm driving in Phoenix. So....can 1" on the tires really make that big of a difference?
    I didn't think it was just the wheels. I thought the sport engine was different. I'm not following all the mechanical threads, i.e. HOW the engine is different, but I think it has been mentioned that those of us with Base ATs are the ones getting the lower mileage.
  • hungarian83hungarian83 Member Posts: 678
    There is no difference in terms of suspension, transmission, engine, etc. between a base and sport Fit. Granted, the sport has the paddle shifters, and a slightly different shifter layout (P R N D S) vs. whatever it says on the base model, but that's it.
    Apart from the slightly lower profile tires, and the paddle shifters, everything else the Sport adds is for looks.
    If anything, it's the Sport ATs that are getting the lowest mileage (fits with the EPA ratings and Canadian ratings) due to the extra weight of parts.
    Kip: There are too many factors that determine gas mileage tha you can't simply get double the gas mileage because one vehicle is half the size of another....
    I agree! Just trying to understand WHY ! :cry:
    In the case of the Fit and other vehicles of this type, it would seem that they would have strived to wring every ounce of fuel economy possible from it.
    With the differences in size, weight, displacement to feed , and what appears to be much considerable differences in aerodynamics, on paper the Fit should get better mileage than it does. OR the Pilot should get less!
    Could it be that the 1.5 engines are too small? From what I'm seeing here, the Civic and the Corolla with their 1.8 engines will equal or better the mileage of their 1.5 engined stable mates.
    As stated earlier, I'm not disparaging these super enono-boxes. For scooting around town, parking, and trips to the vet with large dogs, nursery, Home Depot, and simply fun to drive, they seem to be just the ticket. Just wondering what the economy tuned 1.8 engine would do for it! ;)
    Kip
    Hardly. If that was true, they would offer the 1.3L engine with CVT (89 hp) that is offered elsewhere in the world. But how well would that go in the US?
    "Could it be that the 1.5 engines are too small? From what I'm seeing here, the Civic and the Corolla with their 1.8 engines will equal or better the mileage of their 1.5 engined stable mates."
    Actually, the 1.5 is not too small, and as crimsona correctly pointed out, there are smaller engines like the 1.3L i-DSI found throughout the world. There is even a 1.2L. However, seeing that a NA Fit is about 400 pounds heavier than the 1.2L European Jazz, the 1.3 would probably be a better choice.
    "Just wondering what the economy tuned 1.8 engine would do for it!"
    Don't forget that the R-series found in the Civic is a brand new design with several benefits over the older L-series found in the Fit. The L15A1 which is found in the NA Fit debuted in Japan in 2002. An updated version of this engine (or perhaps an R15) in the next generation Fit with a 6-speed manual would offer better fuel economy surpassing the Civic and lower emissions. There is no need to offer a larger engine when a new 1.5 could do the trick.
    What I would like to see in the US/Canada market is a choice of two engines: Updated versions of the L13 and L15 both attached to 6-speed manuals...with a CVT-7 option. Or maybe a smaller-displacement and even cleaner version of the amazing diesel Honda has already developed for other markets. :)
    "If anything, it's the Sport ATs that are getting the lowest mileage (fits with the EPA ratings and Canadian ratings) due to the extra weight of parts. "
    Nah, my Sport AT consistenyly get 35-36mpg. I think maybe it's mismatching trannies and purpose. Those who bought MT's driving over 50% on the highway, or AT's doing errands all over town.
    I've posted my route earlier (stop lights every 250 meters until I get downtown, every ~50 meters (1 block) downtown, 7 km trip). I'd be scared driving a manual in that kind of situation I think. I can honestly say I drive in the city 100% of the time. I haven't even been on a highway (there are highways in Vancouver?)
    So far I've been getting 25-27 MPG (US Gallon). My last fillup got me 300 km for 26 liters. (At $1.13 CAD per L)
    Besides being disappointed in the milage, I've noticed that I struggle to go up any incline.. I would need to rev up to 4k+ to increase speed and the engine feels like it's working super hard..
    was going to take it to LA but am afraid that it will struggle going up the grapevine..
    maybe i should use paddle going up the incline? it'll probably be revign at 4.5k the whole time lol...
    I think i got maybe .5 mpg more my second tank.. wahoo!
    can i expect a little more the next tank?
    "Nah, my Sport AT consistenyly get 35-36mpg. I think maybe it's mismatching trannies and purpose. Those who bought MT's driving over 50% on the highway, or AT's doing errands all over town."
    I don't think so. I got nearly 42 mpg doing almost 100% highway driving in my 5MT. It's not as much where you go, it's about your driving style. I usually average 33-35 and that is always with 50% or more highway driving.
    However, it is true that the AT mileage will suffer in mostly city driving.
  • mtngalmtngal Member Posts: 1,911
    "was going to take it to LA but am afraid that it will struggle going up the grapevine.. "
    Well, I drive the Grapevine, Newhall and Sepulveda passes every day in a Fit AT Sport. We get 33-37 mpg all the time (unless there's some type of major accident or brush fire in the Newhall Pass). I have the cruise control on most of the time - I'll take it off when we go up the steepest parts of the LA side (Castaic to Templin Hwy) or from the Grapevine exit to almost Ft. Tejon going south, only because the tranny will shift to 3rd and the rpms will be around 5k) if you try to maintain 65 or 70. I'll let it slow to 60, along with half the other people on that stretch. Otherwise, driving at 65, the rpms run around 3k. I have done the steep part with the engine in 3rd gear going 70, but it's noisy and does affect gas mileage.
    i'm guessing u use the paddles? i wonder if it would be better to use the paddles since i could control the shifting
    "What I would like to see in the US/Canada market is a choice of two engines: Updated versions of the L13 and L15 both attached to 6-speed manuals...with a CVT-7 option."
    I'm familiar with a CVT. What is the CVT-7?
    Kip
    Sorry...the CVT-7 is the CVT Honda has in the Japanese Fit and European Jazz for the CVT with the 7-speed mode. It allows you to either drive the car in shiftless CVT mode, or being able to use seven computer-selected "gears" that give the feeling of shift points, when you use the paddle shifters. Honda also sells the conventional CVT (without this 7-speed mode) in the 1.3L versions of the Fit in Japan.
  • herrkaleuherrkaleu Member Posts: 62
    At work we have 2 honda Fit (automatic) and they get 32-35 mpg in city driving (I work for the city of Madison,WI, so they never really leave city boundaries). Once on a long trip to an exhibition I had one of the fit and got 38 mpg driving 75 mph.
    Averages 26 on first tank..
    second tank I got 28.. AT sport..
    Still disappointed since I've been driving conservatively each time.. I hope that the switch to Shall gas will give me a little more..
    I hope to break 30 someday.. i drive mostly highway..
    I wonder why people say to give it time to break in because I read that others get over 30 to start off.. I mean if i need to wait for the engine to break in.. then why do others get over 30+ right off the bat? Shouldn;t they be getting 20's+ also? Something just isn't right.. i would be happy to get 31 mpg at this moment.. and i do mainly highway driving..
    I don't know if this would apply to the FIT.
    Part of a dealers NEW CAR GET READY for the Pilot is called
    "Idle Learn Procedure".
    http://www.hondalac.com/service/Bulletins/x02-029e.pdf
    Sometime the folks in New Car Get Ready are a little slack in their duties.
    I don't know why it is necessary, just that it is part of their GET READY.
    Over on the Pilot forums, folks have posted where really crappy mileage was improved drastically by the procedure.
    One soccer mom that was getting something like 11-13 daily driving, improved to 17+ and so on.
    If you want to try it, you have nothing to loose except your preset radio stations. You will have to reset them.
    1. With a cold engine: Turn off all accessories.
    Disconnect battery for a few minutes. Leave the hood
    open.
    2. Reconnect the battery. Do not turn on any accessories.
    3. Do not touch the throttle. Start the engine and let it idle. Watch the radiator cooling fan(s). After a while it will come on for a short period and shut off.
    Keep watching. Eventually it will come on and shut off a second time.
    4. That is it! Turn off ignition switch, close the hood.
    Now you will need to reset radio stations and possibly the drivers "AUTO" window feature. If the "Auto" feature stopped working, activate the auto feature and while holding it in auto, run the window to the bottom. Then activate and hold the switch and run the window to the top and continue holding the switch an additional 3 seconds. Now the auto feature should work.
    On the Pilot, Honda recommends this procedures when the battery is replaced, has discharged, or certain fuses have been blown or pulled.
  • mymeta4mymeta4 Member Posts: 9
    Replying to:
    "I don't know if this would apply to the FIT.
    Sometime the folks in New Car Get Ready are a little slack in their duties. I don't know why it is necessary, just that it is part of their GET READY."
    We've had low MPG for 1,000+ miles and wondering about the discrepancy between the "Happy Mid+Upper 30's" and ourselves (hi - 20's) So this concept sounds interesting - but then again I'm often hooked by urban myths! So, now I'm waiting to see which adventurous soul(s) will try this procedure and report back here.
    MyMeta4
    That URL is a Honda Service bulletin for new car get ready. It is not an urban myth. There it is in black and white. :)
    When our Pilot had a few thousand miles on it, a bare wire on a trailer shorted, and a fuse in the Pilot was blown. I disconnected the battery and found and replaced the fuse but noticed the "Auto" feature on the drivers window not working and the Radio was asking for a code. Everything else worked. A service writer at the local Honda dealer told me how to "Fix" the radio and window.
    A while after that I took a 200 mile trip and noticed the mileage was 24+ rather than the usual 27+ for that trip.
    I also was aware that my daily driving was 2-3 MPG less than "NORMAL" for the last few fill ups, which I had contributed to hotter weather.
    I had read about the IDLE LEARN PROCEDURE (ILP), and it's purpose, and decided to try it even though the car idled just fine.
    The mileage returned to normal! Further investigation revealed that the ILP doesn't mean it is learning to idle. In fact it is reading the characteristics of that engine from start up through good and warm. The computer is learning while the car is at idle. For some reason it needs to read from cold engine through the two cooling fan cycles.
    I didn't write the bulletin and don't understand whe reasoning from Honda. I don't know if it is part of the "GET READY" for the FIT. I do know that it "FIXED" my Pilot and others on that forum.
    FWIW: The Pilot is 5 SPD AT/4WD and delivers 17-19 every time I fill it up. Most driving is very short trips of 3-6 miles. On the road it will deliver 27+ when driven the speed limit. Our CR-V is a 4 Spd AT/4WD and averages 23-25 MPG under same local conditions and 29-32 MPG on a trip(with me driving). I did the ILP on the CR-V as soon as we brought it home from the dealer. Don't know if it needed it or if it did any good. But I "Got er Done"!
    There is some good explanation as to why most of those reporting on this forum are getting considerably better mileage than you. If the ILP doesn't work, the most you have spent is a little time!
    What do you have to loose? ;) Sooner or later that battery will be disconnected for some reason!
    Good luck,
    Kip
    Don't have the numbers, but it was 35.99 MPG.
    I received about 35 MPG after my first post-dealer fill up. SO the wear-in period is NOT causing a 10 MPG discrepancy in your car.
  • kagedudekagedude Member Posts: 407
    My Sport Fit 5spd from new to now (8000+ miles) has always averaged over 35mpg may it be city or highway driving.
    The last 3 fill ups, I've averaged 35.5mpg (city/hwy), 39mpg (hwy) and 37mpg (hwy). On the highway, the average speed is between 70-80mph.
    Have you brought it back to the dealer? Do you drive mostly in the city to get the high 20's range?
    Sport Auto, average 1 traffic light or stop sign every quarter mile, under 8 mile commute (yes, 100% City), Fit Sport Auto. Stop go all day long. 24.97 MPG (US Gallon), 9.5L/100 km.
    Commented to the dealer, they said an equivelent to "too bad, so sad - it's not broken in and you have a very non-fuel friendly route to work."
    Not surprised really.
    I would think even with 100% city traffic, you should still hit over 30mpg. I've gotten stuck in traffic for 2 hours where you stop, idle for a bit and move an inch but once it picked up, it still averaged over 35mpg.
    You should test and do all highway one day. Fill up your tank, go 50 miles and then back (100miles total) and then fill up your tank again. Divide the miles driven by the gallons you just put in and if you get over 37mpg and up, then your car is normal.
    No i have not brought it back to the dealer.. I have about 500 miles on it.. manual said it will be brken in at 600 miles. I've read that some people who have brought it in have said that the service deparment doesn't do anything. Some even mentioned that they were told to give it for 10k mile then bring it in once it has been borken in 10k miles.
    If i bring it in now, will they just say that it's because the car has not been borken in and to wait?
    I drive about 95% hwy and between 65-75.
    I guess you eithe rhave a freak car or you're working correctly :)
    i tried hard to get 28mpg on mostly all hwy..
    Wow, 500 miles is not a lot to go on. In that case, keep driving and do the highway test to put to rest your concern. If you drive between 60-65, you should get a good mileage rating. My car has 8K miles and its been consistently getting the same mileage so not sure why 10K would make a difference at this point.
    "i'm guessing u use the paddles? i wonder if it would be better to use the paddles since i could control the shifting "
    I don't use the paddles at all. In fact, I use cruise control as much as possible (I take it off for the steep portions of the Grapevine and drive about 60 so that the car won't shift to 3rd). I had been noticing my gas mileage dropping, so Friday I eased off on acceleration (didn't try to keep up with everyone else for a change), and since traffic was lighter through Santa Clarita I put the cruise on earlier than normal - got 39 mpg that day, vs. the 33-36 I've been getting recently.
    I got unbelievably good gas mileage going to Vegas (I often do - it's mostly downhill for me and Saturday I had a tailwind). I never post the figures here because I'd hate to get others thinking this car could routinely get such fabulous mileage (drove 300 miles and had noticably more than a quarter tank left when I filled up).
    Sunday's drive back was "interesting." I left Vegas at around 8:30am, then spent 3 hours going about 10 miles between Jean and Primm. I would shut the engine off for about 5-30 minutes, restart it to creep forward a couple of car lengths, then stop and turn it off again. I don't know how many times I turned it off and turned it back on - I accidentally ground the starter a couple of times thinking I had turned it off when I hadn't.
    I finally passed Primm (at the Nevada-California state line) around 12:30 pm, and ended up fighting a head wind or a cross wind the rest of the way. This wasn't a breeze - Edwards AFB reported the wind at 20 mph with gusts up to 30. Set the cruise control at 65, except across the part between Afton Canyon and Barstow, when I didn't want to accelerate and brake all the time. Then I set the cruise at around 62-63 because that's what the 18-wheelers seemed to be doing. I left it at 65 most of the time I was on Hwy 58.
    I stopped for gas at the small community outside Edwards. My gas mileage still came out to 33 mpg!
    My conclusion from this:
    1. Always carry water in your car (I didn't), even when it's a routine trip you've done a million times. The Starbucks coffee I had didn't last long.
    2. Always carry sunscreen. It doesn't matter if you never get out of the car long enough to need it - I had the windows open to keep as cool as I could and got sunburned.
    3. As hard as it is (this car is quite peppy), easing off of the accelerator makes a huge difference. I'm not talking about jack-rabbit starts, I'm talking about not pushing it as much as most people in SoCal routinely do when starting up at a stop sign or traffic light.
    4. Use the cruise control set at 65 as much as possible - the car does a better job at not over-accelerating or driving faster than planned than I do. If you drive this little car like an economy car, it will give you wonderful economy. If you drive it like a performance car, it will do a pretty good imitation of one, but won't give you any economy.
    5. I might have gotten home quite a bit sooner if I had been driving the Wrangler - there are several dirt roads that I could have taken. But it would have been a very expensive trip - I would have been lucky to get 16 mpg with that much wind, and it would have been a constant struggle.
    Final note - have I said that I love this little car?
    It also seems that folks in CA get about 5 mpg less than everyone else.
    "It also seems that folks in CA get about 5 mpg less than everyone else."
    :confuse:
    Base 5MT, Southern California
    Average tanks: 33-35 mpg
    Highest tank: 41.7 mpg
    I don't know about SoCal people getting about 5 mpg less. I just figured up my overall average:
    miles: 14,660.3
    gallons: 409.349
    mpg: 35.813
    That's definitely lower than before (had been running overall average over 36). I still can't complain at all. I actually have just over 15,000 on the odo - I missed recording two tanks. Driving is almost all SoCal freeways - very little city driving. It does include large elevation differences (live at almost 6,000 feet and work at sea level, commute is 150 miles round trip). Some short trips on the weekends (around 10 - 15 miles), along with a number of 300 mile one-way trips to Vegas (go about every 3 weeks).
    Oil is down to 30% so I'm starting to think about when I can fit our second oil change in within the next month or so.
    Please tell me that your first few tanks were below 28 and then it improved as oyu got closer to 15k..:)
    I know that 500 miles is not a lot to go on.. I hope to see improvement but after reading some of the stuff on here
    I kinda doubt that I will improve 5-7 miles per gallon when it's finally borken in.. hope i'm wrong though..
    If you check out some posts on the Real World MPG site, some folks has over 10k-15k and their milage is still around 24-28 MPG.. which is discouraging.. Especially sicne i drive hwy95% of the time and do everything to try to save gas and only get 26-28 mpg.. kinda disaapointing.. I'm not even getting the low end of city.. With that said.,. besides ur first tank.. i don't think you've gotten below 30 driving normal right?
    How did you fix the auto feature of the power windows?
    I wanna try it for my Fit but will need to know how to fix the window
