I think this problem is widespread enough to have its own thread. Hopefully, if Honda sees enough complaints, they will do something about this problem.
vinny
But...what is it? :confuse:
Sad...but under warranty!
Anyway, I hope that my car will be spared from this evil "Lug Bug"
I did go back to the other threads and search lug bug but I could not get a sense of the risk of purchasing a civic right now OR the response from honda in correcting the problem . . .
The other, is an idle vibration. This occurs at about 600-800 RPM when the car is in drive but at a full stop - much worse in cold weather. This is a separate issue and probably has a separate cause. Most people have the lug bug but only a lucky few, such as me have the idle vibration. No idea what's causing this one. Doesn't concern me that much although I may invest in the extended warranty to cover myself.
Marc
Marc
The idle vibration is a different matter. Your dealer needs to fix that.
:P :shades:
Never worry getting bumper to bumper, dents from other door etc.... :P
I've actually noticed the threads quite a bit, as I have the same noise for ">my civic too... (New Zealand/Japan version, 1.8S).. Talked to Honda Direct (doesn't work on a dealership basis here), very good service, they send a tech out to ride with me, noted the noise....
Few days later, they confirmed that even for their own Civics, it was making the same noise, so it's a "model-wide" thing over here I guess.... They assured me it should cause no problem though, so I guess maybe I'll just live with it and try not to hover around the 1500rpm mark....
Till hopefully they find some sort of magic solution!
That's the type btw...
I took mine in yesterday. They fixed for me without any questions. I have test my car while I was driving it to work this morning. The noise and the vibration seems to be reduced a lot. It definitely worth to get this fix done!
Is the "lugbug" problem only with the automatic transmissions?
Someone asked whether automatics only were affected, nope, since it is a matter of the serpentine drive belt and belt tensioner I imagine manual transmissions are also subject. Now if only I can get rid of the "glove box" noise.
Thanks very much!!
The Sandman
The Sandman
Have any other 2007 owners had similar lug bug or idle vibration problems?
My wife even asks me what the hell is that droning sound?
Since my car is chock full o problems, honda car is involved and when I bring it in, I will mention the TSB as well.
I was thinking of getting a FIT for my wife. But after this Honda Civic experience. No more Honda in my life!!!
I've been waiting for this bulletin for a year on my 2006 LX. This service bulletin does not resolve the growling noise at idle in very cold weather. Hopefully, that will be resolved soon. Thanks God for the internet. Good luck!
