Towing bill Truck $75
Towing bill Trailer $40
Rescue Pickup by Girl Friend $30
Assistant to drop tank $40
Fuel sender Module $300
Fuel Filter $ 9.00
Time to Drain/Drop tank 3 hrs.
For sure in the future I will be changing my $9 fuel filter at 50k or less.
4 - 5 gallon gas cans $38.00 apx
I have a new body style 07 gmc ext cab truck. After a good heavy rain my carpet will be soaked in the drivers and pass floor boards. Water will be pooling up in the rear floor boards. I park my truck front up hill on my driveway. The dealer says they can not find the leak? Anyone else having this issue.
I am thinking it is probably the BCM or a defective ground somewhere.
Robert.
I have just bought a 2007 Sierra crew cab and found after a heavy rain the front passenger floor completely soaked after it rained. Has anyone found a solution to this problem. I have 38,000 miles on the vehicle. Would this still be covered by GM as it appears to be a design/quality issue
Please advise
WITH BRAND NEW BULBS. MINE WORKS GREAT, AND IT'S CHEAP AND FAST TOO.
radios@replacementradios.com
THANKS,
CARL LESLIE
Jennifer
IT'S BEEN A WHILE SINCE I REPLACED IT, SO I CAN'T REMEMBER
IF I PURCHASED IT FROM FROM THE DEALERSHIP OR ON EBAY,BUT IT WAS BRAND NEW
BUT IT WASN'T THAT MUCH AND IS EASY TO REPLACE.THANKS,CARL
My windshield washer motor/pump is not working either. That makes me wonder....since it is on the turn signal arm also. But, I haven't had time to troubleshoot that problem yet so it may just be the pump.
Thanks for the help.
Jennifer
