Make sure not to lose the dished washers, those eliminate the rattle in the jumpseat linkage once it's put back together.
FWIW, I found my jumpseats at a wrecking yard and put them in myself. It was a one-afternoon job. They're very useful and kids love to ride back there!
In Germany we have to pay Euro 680,- for a new one. Original part number is: ESR4672
We would be pleased to here from You in case You could help us, may be just mailing an idea where to ask for it in UK.
Thank You and best regards
Jürgen Dieterich
I had a persistent problem withthe horm buttons getting stuck and coming off for about 2 months, then it was fixed permanently. Your warranty should cover this type of repair.
Has anyone noticed excessive wind noise from any of the doors, I have replaced the weather stripping and had the doors adjusted and I still hear the wind noise. Any suggestions?
Odiopus
I have a 96 Discovery also. Lets see how I can help.
In order to shift from AWD to 4WD all you do is shift the differential shifter (the front one) to the right. You will notice a little orange picture light on the instrument panel. This means you have locked the differential and are now in 4WD. If you need to shift to 4WD LOW you will have to slow to 5 Mph or less, and put the transmission in NEUTRAL, then put the differential shifter all the way forward, and shift back into DRIVE, and you are now in LOW 4WD, you can shift into LOW AWD by moving the shifter to the right. Follow this procedure in reverse to go back into HIGH.
As for the buttons on the dash. The one with a picture of a bridge that is under the clock is the master switch for the Cruise Control. You have to have it on for the Cc to work. then pull(not push) the set button to set your speed. If it doesn't engage, look under the hood on the left side for the vacuum hose and make sure it isn't leaking.(Mine was) easy 5 minute repair you can do with a knife. On the left of the Instrument binnacle are in order top to bottom: Rear defrost, Rear fog light, radio volume up and radio volume down. Right side: Rear window washer, rear wiper, Radio seek, radio mode. Your best bet is going to see if you can find an owner's manual on e-bay, or the workshop manual CD. Usually they come with an owners manual on it too, and you can print out what you need. :shades:
With regards to Land Rover 4 wheel drive, you should do a search and read up on how differentials work and all the other tech stuff to understand what goes on. Most people believe AWD and 4WD mean the engine turns all 4 wheels all the time, but the reality is that you can get into a situation where you are in 4 wheel drive, but are stuck because one wheel has no traction. Engaging the differential lock on your truck will divide power equally between your front and rear, so now if one front wheel has no traction and one rear wheel has no traction, only then are you stuck. Hard core off roaders will put additional locks on the front and rear - this is the only way to get equal power to each wheel all the time. Not many vehicles have a center differential lock, be happy you have it, it comes in handy sometimes
I like dragging my boat to the back of my van and picking up the bow and resting it on the rear edge, then picking up the stern. I'm not familiar with the Disco's rack, but maybe if you stick a towel on the paint, when you pick up the stern, hopefully the bow will then reach the rear rack and you can slide it forward without having to slide it on the towel.
They also make rack attachments that have a rod that pulls out, so you would pull out the rod on the front rack, prop the bow on it, and then lift the rear of the kayak onto the rear bars. Then move the bow over and slide the extension bar back in.
If you have a garage, you can buy pulley systems that allow you to store your kayak from the garage ceiling and lower it onto the Disco. When you get to the water, you flag down a passer-by or fellow boater and get help getting the boat on and off. Back home you crank it back up to the ceiling by yourself.
A good boat shop or kayak club should be able to help or you can try some kayaking suppliers like Cascade Outfitters or Northwest River Supplies. The rack stuff sure isn't cheap though.
Check out Roof racks, Bike Racks and Cargo Carriers (OEM, Thule, Yakima) too.
bradesp
While waiting for responses in here, check out the estimated repair costs in the Edmunds Maintenance Guide.
And you may want to also check out Real-World Trade-In Values and What is the "Kelley Blue Book" Price?.
While the maneuvers you've listed are correct, the things they do are not!! There is no AWD on a Discovery. Just 4wd high and 4wd low. Yes, moving the lever left/right will lock the center differential. Do NOT drive on firm surfaces with the differential locked. You WILL cause massive damage. ONLY lock the differential if you are driving on very slippery surfaces without many turns. You are always in 4wd in a Discovery. Moving the lever up/down will put you in 4wd high/low. The lever is a transfer box selector. A transfer box is a 2nd transmission with 2 gears.
None. It would have been at the dealers on a recall and not on the road.
Also, Sears has brake tools; spring removers, pad compressors, etc. Which tools will make the job easier and which do I absolutely need to buy?
Thanks for any info>
Vandy
2002 Disco SE Westminster
On my truck (Series I) no special tools are required. Needlenose pliers... spanner, wire brush... piece of cake.
Pull the cotter pins, slide out the two pad keeper pins. Pop out the old pads.
Use the wire brush to clean the area, then crack open the bleed screw and push the pistons back into the caliper... brake fluid squirts everywhere. Close the bleed screw before releasing pressure on the pistons so no air gets back in.
Slide in the new pads, insert the pad retainer pins, put in two new cotters... you're done.
I'm at 101,000 miles on my original rotors. If you use SOFT PADS you can make them last. Avoid metallic, get the cheap organic pads. Plan on replacing them every 15-20k miles. It's simple and fun.
Does anyone have any recommendation in either direction?
Thanks for your time.
Sorry to hear about your issues. Best of luck to you.
Intake manifold gasket
Spark Plugs
Alternator
Alternator cable
Battery (Recommend replacement with Optima Spiralcell Red Top)
Trailer light module
Various lamps and bulbs
Exhaust.( I replaced the old one with a Stainless Steel Borla, and got better power and fuel economy, plus it sounds really cool)
That's about it. I do recommend using K& N Air and oil filters and the standard spark plugs. I replaced the serpentine belt, and kept the old one for a spare.
* The viscous coupler died and took out the water pump.
* A lightbulb in the rear bumper burned out.
* I got a rock chip in my windshield.
* The battery finally died (must have been all the offroading that beat it to death)
There's got to be more. I mean... c'mon. It's a ROVER, right? (tongue in cheek) Seriously, that is all.
In the last 5 years what has gone wrong with my wife's Windstar minivan (driven slowly and carefully in town)?
* Timing cover gasket failure, mixing oil and water. Pull the engine.
* Torque converter seal failure, lost all trans fluid. Pull the engine.
* Differential failed. Pull the engine and replace the transmission.
* Axle failed. Finally didn't have to pull the engine.
* Front hub failed.
* Side and rear door sensors don't work, interior lights stay on forever.
* ABS failed.
* Cat converter failed.
They both get the same maintenance, and one of them lives a HARD life. The other is treated like a creampuff.
(And yeah, I saw the PFD number.)
I am thinking a voltage problem, but I really don't have a clue as to where to start.
Any ideas or similar experiences?
Thanx
It fixed all kinds of electrical weirdness for me. Good luck!
I did perform the LORD LUCAS incantation, maybe it helped!! LOL
Thanks for the response.
Ben
Thanks for any input
Ron (newbee)
*Is there a Discovery year or years that are more reliable and have less issues than others?
*What type of issues have Discovery owners experienced? Are they major or mostly minor?
*Any other pertinent information or tips that you guys might have I would really appreciate.
Thanks for your help!
Alex.
Can anyone tell me if I purchased the wrong NAV CD? I put it into the cd slot and get Nada? When I made the purchase, the info on EBAy said this CD covers the eastern seaboard and it is compatable with, among other Euro vehicles, Disco II's.
I tried to "reset" my system to no avail...I'm out $70 and still no Nav sys.
Experienced Disco Nav Sys users please reply.
If your LR dealer told you that the heads can't be reused because they are too thin (from resurfacing) ask him what the minimum head thickness spec is, who in his shop measured it, and what did they measure it to be. Maybe before you ask him this, you call the AERA, ask for their Tech Line and ask THEM what the minimum head thickness spec is. Something doesn't sound right. This is a very common, low tech job.
