Infiniti M35/M45 and Bluetooth
What are your Bluetooth experiences? Questions? Issues? Here's the place to talk about them.
Also, how do I edit an existing entry in the M's phonebook? I can't seem to find any way to do this.
captnorm35, "Infiniti M35/M45 2006+" #2616, 8 May 2005 2:08 pm
It's a bit messy as you need to specify which razr entry & which directory # in the M. Once you transfer a few entries, will find can streamline this process.
Norm
Is there any additional input from anyone who's gotten a Treo? The Verizon store was "iffy" about compatibility, but I suspect their main concern was that the voice commands wouldn't go through the Treo and that's not an issue with me. I'm a "lite" user ... want hands free, and if the Treo will perform for me the way the V710 does I'll be perfectly happy.
Any and all input will be greatly appreciated.
(Oh, and the sooner the better ... I'm hoping to make a decision by mid-week. Again, thanks.)
Thank you, scoop; I didn't realize it was that long ago but you've answered my question. As long as its functionality is decent and at least consistent with my V710 I can go ahead and get one. I'll give the V710 to my wife. It will still work in my M-car, but unfortunately her '04 Lexus isn't Bluetooth enabled. I'm a low-tech kind of guy so basic functionality is all I want ... and I'll have less "stuff" to lug around.
1. You cant currently use the voice recognition on the M to dial a number hands free.
2. you cant transfer phone numbers - but as I mentioned above you can't initiate a call from the car itself you have to dial from the phone then it will transfer to the car so sending numbers to the car is useless right now anyway! :mad:
I am so miffed at how these companies took a "Universal protocal" - Bluetooth - and screwed it all up
Pete
I will check into the Treo,
Thank you Pete.
David
Can't wait to get the m45 deliver from Santa Monica to Honolulu.
Scoop said he can dial up using voice on his Treo OR the car's voice recognition. While I agree it's all fouled up, I'm content entering all of my phone frequently dialed numbers in my voice rec system and dialing that way. I want the Treo for convenience of carrying one piece of hardware, not two ... and I want some internet connectivity (but not as much as the Blackberry provides). As long as I can receive and send calls through the car's VR system I'll be content.
This is contrary to Scoop's experience. Understood that you can't dial a number that's not preset in the car's VR system, but if that's the only glitch it's no biggie (at least to me). :shades:
Are you saying that the V710 w/ Verizon worked fine but the Treo through Verizon doesn't work as well? Does the Treo automatically disconnect after each call? That's bizarre --- because the car should recognize it constantly when on and in/near the car. But if that's the case, I don't want the Treo.
Pleeeeeeeze clarify. I'm interpreting your comment to mean that the V710 worked and the Treo doesn't work.
Tell me more about the Samsung I730.
It's completely eliminated the disconnect problem, and the inability to dial out from the infiniti phonebook. I understand, however, your legitimate concern about using a sprint update for a verizon phone -- probably a very bad idea. I'd contact palm and verizon and see if they've got any comparable update for your phone.
I'll be buying the i730 also (exciting isn't it?), but I'm waiting to see which provider is the first to actually go live with evdo in my section of the SF bay area. If you do it, please tell us about your i730/M45 experience (and i730 experience in general). I'm, anxiously waiting for the first M/i730 reports.
Pete
ct1211: It seems you and scoop have two different experiences with your Treo's. Are they both the same vintage? Or is one more updated than the other?
I'm going to take a look at the I730. Bart
I should have read more carefully. Seems you and ct1211 are saying the same thing ... you can't initiate a call through the car's nav system, so the compatibility doesn't really give you "hands free" funcitonality. Are you running into ct's problem with disconnects after a call? If you enter your frequently called numbers into the car's phone system, can you access them hands free using the car's sound system alone? Push the button and respond to the voice prompt by saying (eg) "call home"? That's what I'm doing now with my V710 ... and if that works it's all I'm asking the Treo to do. Bart
Absolutely helps. Just had to ask the right question(s) and read the right answer(s). Maybe the Samsung will connect better? And if all else fails I can get the Parrot ...
Annoying. But good to have folks with experience upon which to draw.
Bart
ct1211: please do. I stopped by Verizon today and they were clueless about any car compatibility (not surprising). I called Infiniti and it's not supported as of today, although she did mention that the list on the website is quite obsolete as many new models have been added. She couldn't email me the list, but was willing to enumerate each model supported. I declined, as I'm only interested in the 650 (we now know it's not fully supported - thanks for the previous posts - and Infiniti confirmed that to me) and the i730.
It sounds like it works pretty well so far, just want to make sure before I buy it since I don't have my M yet to test it out.
Thanks again!
There are many posts on this thread going back to May, so cruise through them.
Your best bet is to go to Infiniti's website and see what Verizon phones THEY say couple well; unfortunately, by their own admission the list isn't up to date. I had the Motorola E815 and it had to be connected every time I got into the car ... they say it turns the Bluetooth feature off to save energy when not in Bluetooth range. I went back to my Motorola V710 and it couples to the car every time, no hassle. Neither transfers the phone's phonebook so you need to hand enter your frequently dialed numbers into the car's system ... then they work fine hands free. The sound's a tad better with the E815 but it's a nuisance to have to couple every time.
According to two Verizon dealers here in Tucson they have NO phone that's fully compatible with any car other than Lexus. This will clearly change with time, but right now all Verizon has that seems to work reasonably well (given my caveat above re: hand-entering frequently dialed numbers) would seem to be the V710. The absurdity of it all is that the E815 is supposedly an upgraded V710!
Good luck. Hope to find a Verizon store that's willing to get into your car with you. Verizon tells its dealerships NOT to get into cars, and the Infiniti dealers tell you to take your troubles to Verizon. We have one store here that's willing to break the rules and sit in my car with me to get me set up. Bart :shades:
I have the VX8100 and it works well with the M. It connects automatically every time with no button pushes. There seems to be some debate over whether the E815 will do this or not. The Verizon rep told me I would have to turn on the Bluetooth every time. Maybe firmware versions in the phone have something to do with this.
Neither of them will transfer phonebook entries. The outgoing audio quality on the VX8100 seems to be better than the incoming when using the M's Bluetooth. If you get it be sure to set the call privacy setting to "Standard" as "enhanced" reduces the clarity of the audio.
I think the VX8100 menus and options are more logical than the Motorola but others may differ on this. I really like the way the voice dial and phonebook are set up on the VX8100. It's too bad that you can't use the LG's voice dial feature through the M's Bluetooth. The last Motorola I had was a pain with multiple numbers for the same contact. Unless the E815 is better at this, both Samsung and LG appear to handle multiple numbers more logically.
My local Verizon guy said he'd be willing to try coupling he E815 again by first deleting all prior coupling attempts. Now that I have regular connectivity and have changed our numbers, it's not worth more of my time. The shortcut that was set up worked ... but it's easier to simply get into the car and have connectivity.
I may go back to Verizon, but the phones are the same and their inability to transfer the phonebook nullifies the difference. Bart :shades:
Dew
One other poster here has constant connectivity with his 815 and I believe that my problem was with the coupling process with my car's system. I'm confident that if I re-coupled, after eliminating all existing couples, it would work just fine but I'm happy with my V710 and my wife has threatened me with bodily harm if I take the E815 back and leave her to re-enter her favorite numbers. Married 40 years, I know not to push the envelope!
Bart
Thanks, sjc ... They just did it for me ... switched the numbers between my E815 and V710 ... no charge ... I've done them a couple of favors so they're willing to do it again but the functionality of the two phones is almost identical and I'm satisfied with the V710's connectivity. My wife's concern (and I can't blame her) is that she'd have to re-enter her phonebook in the V710 if we swap and it's not worth the effort.
I will ask them for another favor, however, and that is for them to help get our Parrott Bluetooth connection work for my wife's car. I have friends for whom it works just fine, but it's quirky for her right now. Bart
You can get more information at http://www.datapilot.com/
PM me if you want more info on this.
On my end, the volume of the hands free speaker needs to be louder.
Otherwise, the address book transfer works, but you have to do one number at a time and it's basically quicker just to do it manually.
Joe
Bart :shades:
