Chevy Silverado and GMC Sierra Suspension and Ride
http://www.youtube.com/watch?v=EWjTbiYo3x0
http://www.youtube.com/watch?v=zRfE_XAk2mE
Not sure on the Dodges as the only experience I've had are a couple of rentals and the only thing I remember was the dismal gas mileage. Course that couldve improved by now.
One thing interesting that I noticed was that I test drove all the trucks before buying my last one. The silverado/sierra had the best ride of them all. Unfortunately couldnt come to an agreement with the dealers on pricing forcing me to buy something else. Course one of the items on the table was that the dealer replace those crappy Generals before I would take delivery.
I should have walked away.
I had an '00 Silverado ext. cab that I bought new but didn't keep it long. GM bought it back under the Lemon Law. The "vibration problem".
When the fourth set shipped I asked the service manager if it would be possible to replace them with Michelins. He asked the zone rep and got approval with me paying the difference (wholesale). Thats when I found out the value of the General tires as it cost me close to $400 to do the swap.
When the service advisor was rolling the Generals then the Michelins around the shop he had commented the the Generals weighed less than half of the Michelins and when pressing down on the Generals there was a great amount of flex in the sidewalls.
BTW, the vibration problem was solved with a TSB issued by the general to replace the rack and pinion and welding part of the rack to the frame for additional support. Lo and behold the vibrations were gone.
You might get a little bit for those Generals at a Michelin dealership or try to sell them on your own. Regardless they are not worth much even as new. I saw my equivalent on sale at tirerack.com for $35 each. That wasn't funny. Course with the Chinese driving up oil costs, tire costs have risen though the quality hasn't. You could check tirerack and see what they are worth.
TSB/Recall
Has anyone on the forum had the same problem?
I have had good luck and performance from this 4wd, 2K, Sierra - but I could not justify purchasing another GM product knowing their poor quality on these safety issues.
Ed
I am getting a hum/vibration above 30 mph when I turn to the right. I believe the left front bearing is about to fail.
How do I know it is the left or right side and how tough a job is it? Are special tools that GM is so famous fro required?
I talked to the dealer and they said right off the bat it was the bearing.
They said the part was $408 new and about $300 after market.
$95 for labor.
I am looking online for the part and I will do it myself.
Because I'm picky about tires and stuff, I've changed mine out when the truck had less than 3K miles and sold them to a worker who had the same model but much higher mileage. I agree with you when I test drove the 2wd it had a substantially better ride than the 4wd.
Took it to the dealership's service department and they said "it's just the nature of the '06" and that "there's nothing wrong with the suspension".
I say nonsense and went to the General Manager of the dealership - who got the Service manager to ride with me - he sort of agreed with the service foreman but said they'd keep the truck and check it out further.
I know there's something wrong and not just "something inherent with that year".
Anyone else had problems similiar ? Thanks - Bill
thanx
If you look at your rear spring pack do you have two leafs? That in itself could be an issue. But I'd go back to the rims for vibrations.
My 2005 C1500 regular cab V6 5 spd has what sounds like a shock absorber rattle in the left front suspension. It started at about 28K miles and at 29K it is getting progressively worse. I've inspected everything and find nothing suspicious looking.
I'm told that ther is a TSB on a shock absorber bushing that corrects a shock misalignment issue. I'm told that replacing the shock will not help.
Can anyone direct me to the proper TSB or offer other advice. I'm getting worried that something critical is about to break.
the upper and lower ones i bought look like ford ones and are a pressed in type, with a snap ring on the top. but the ones on the truck have a large cap and looks like i rivited on or a replacement one would bolt on.
I crawled under my 2000 Silverado 2500 Ext. 8 Ft bed yesterday to change my shocks. Starting at the rear drivers side I noticed that the bracket that attaches the shock to the frame was broken. The bracket looks to be rusted and Im sure most of the rust is from the truck spending alot of its life up north. Upon futher inspection all other shock brackets look fine its just the drivers side rear top bracket that attaches to the frame. The million $ question is will I have to fab a new bracket or is there a place to buy this.
