2007 Honda CR-V
Since Honda doesn't produce the 3.0L (244hp/211lb-ft) in the old Accord, could they not shovel that engine into the CR-V now? Anybody know the answer to that one?
I imagine a good many people would be interested in that, making it a solid competitor with the CX-7 set. It still wouldn't be as quick as the turbo RD-X, but it WOULD get 0-60 times down from 10 to around 8. It'd also be useful when traveling loaded with people.
Thanks for your help!!!
Gen 2 and 2.5 with manual are getting to 60 mph in 8 - 8.3 seconds.
Another benefit of Diesel is that Honda only sells it with a 6 spd manual which would fit niceley where Honda left us, manual drivers, out with the redesign of the CR-V.
Since less than 5% of CR-V's sold in the US were manual, and it is expected that Diesel CR-V will garner 5% of the sales, it is not too far fetched to say that if Honda brings Diesel 6 spd manual over here, it will fulfill that 5% gap.
Also, Diesel can run on filtered used frying oil. And judging the bulging pant and dress sizes of the US population, there should be no problem getting hold of used frying oil.
When one's top teeth overlap the bottom teeth by a large amount.
IMHO, the CRV has a severe underbite not an overbite.
In general...
Diesel will offer better fuel economy, but it will not provide better emissions.
Diesel will certainly add torque, but it will not provide increased speed. A diesel CR-V will probably leave a stop sign quite smartly, but passing at highway speeds may be hurt.
Diesel engines, being rather heavy, will degrade the handling of the vehicle.
I welcome the addition of a diesel to the CR-V line, but it is simply another option. It is not necessarily the better option. Diesels have both pros and cons to be considered.
I mean, think about it, no spark plus to change...ever!
Resale values for diesels are much better, and deservedly so because diesels have greater durability. The engines weigh more (as varmint mentioned) but are therefore a lot more robust.
Kip
i believe the miles you drive a year would determine the savings. if you drive 15,000 miles a year, the savings is about $400 a year in fuel. i have no idea how much more a diesel cr-v will be, so i have no idea how many years it would take to make up difference.
everyone talks about durability... a well maintained gas operated car will last 200,000 miles.... not many will keep a car that long.
the other issue is diesel fuel prices rising faster than gas prices. every time diesel fuel prices go up faster than gas prices, it cuts into the savings,
if you are an average car buyer and trade in every 4 years, i don't see much, if any savings. if you plan to keep the diesel powered car till it falls apart, then you will save as long as the cost of diesel doesn't go crazy.
just my two cents and i'm not posting as an authority.
Chances are that people who want the diesel are the same people who want the manual i.e. Automotive Enthusiasts, not the drones you see on the road every day.
I highly doubt that the 3.3L V6 from Hyundai is achieving anywhere close to 30 mpg.
Ford Escape with a 3.0L V6 Auto is just as slow as the CR-V 2.4 L auto.
So, yes you can solve the acceleration with added displacement, or you can take a more efficeint route with what you already have.
I pick latter. 0-60 in 8 seconds and 30 mpg, CR-V 5 MAN is kind of like Jeckyl and Hyde. Some days I feel like 0-60 is important, and some days I feel like 30 mpg is important and I can do it all with one vehicle, without the added expense of having two different vehicles.
But, hey, some days (pretty much every day from April through September), I feel like 0-60 in 3 seconds is more fun (and get 50 mpg), and I take out the other Honda from the stable and just wring her out
When gas prices spiked right before summer, diesel prices didn't go up as much, at least around here.
As for the durability of the engine mentioned in other posts, let us not forget that any diesel is also going to be a turbo-fed engine. The block itself may be robust, but how many times do you read, "My block broke"? Turbos on the other hand, are only moderately reliable.
I think Suzuki offers one on the Grand Vitara, but it's not tuned to be sporty. Did I forget any?
Honda and Toyota gave up on the manual. Too bad. I understand why they did it, but still.
I can't say mpg. I drive where and when I need to go rather than daily driving to work. But some weeks I fill up twice, others I can go about 9 days without re-filling. I think I do pretty well with gas considering erratic driving. Much bigger engine that our little old car, but the gas mileage is way better than the old caravan.
I think it's worth it. But if you can go even smaller, look at the civic. You'll drive so long on one tank you may forget to gas up again.
Did have an opportunity to use the 4wd on a rain soaked muddy field. Wasn't muddy when we parked there. But a heavy down pour turned it into slurry. Cars were "stuck" all over the field but the CR-V pulled off with very little wheel spin. Don't know when the 4wd kicked in, but all went well, as it was supposed to.
FWIW I never felt the 4wd engage, but I know it did because of the mud slung up the side above the rear tires. It was more than the tire just moving through the mud would have done.
In heavy snow, the best 4wd system in the world won't do much without really good snow type tires. Also in snow country with lots of hills I might seriously consider Jeep or Subaru. Both of those have systems available that will make sure both the wheels on the same axle will pull. Kind of a limited slip side to side as well as front to rear. Don't know or don't think the CR-V will do that. I'm thinking the CR-V simply shifts more or less torque to the rear wheels as needed. In effect it could have one rear and one front trying to pull while the other two just sit there.
Someone else might be able to add some light on the CR-V 4wd system.
Kip
The VSA applies brakes to the wheels that are slipping, essentially locking them up, so that the wheels that have grip can transfer the power to the ground. It basically has digital LSD. One caveat though, if all 4 wheels are slipping then the VSA cuts the power to the engine.
That would effectively allow (force) all wheels to turn, even though some may be on ice. Is that on all the later models of CR-V? Does it do it without any input from the driver?
Kip
Kip
2005 and up CR-V's have it. The Helms manual also describes the "Panic Braking" mode, even though the Owner's Manual, nor the brochure mention it.
VSA also applies brakes to the inside wheels when a tight turn becomes a slide :P
I have concluded that the seat is just too short to support my thigh. I have started to measure my friends' cars and have found that the CR-V's seats are anywhere from 3/4s of an inch to an 1 and 1/2 inch shorter than other cars' seats.
Anyone have any suggested remedies?
I am also trying to figure out what can be done about this issue. I just started driving this vehicle and would hate to need a hip replacement years from now because of years of driving this CR-V.
An upholstery shop solution is probably costly and a cushion does not seem like it would fit the seat properly. I am seeking other possible solutions as well.
I suck. I don't pay attention to the nav buttons anymore. Guess they are in my head now and I don't think about it. If mommy brain here remembers, I'll check tonight.
Voice commands do not control everything. Just the radio and the climate control. But I would not depend on them for even that. Sometimes you say find a certain street and it mistakes the street you said. Find nearest gas station, now that works. And heaven forbid I start coughing and choking while changing XM stations....lol
Why would you want it to control climate? It's a fairly small car to really even need dual climate. I found that amusing.
Seriously though, mommy brain remembered yesterday to look and yes, the buttons are illuminated. And the nav system screen has an auto setting that will change the birhgtness of the screen when you are in night mode (turning on headlights) and it has day or night mode so you can override if you have lights on in daytime due to rain and don't need night screen.
I found a list of voice commands online - so that'll be fun to play with.
ROFL.......
nah, we prefer the Bee Gees :shades:
Other than oil changes per the electronic gauge, what are the other maintenance things you guys do? (frequency of tire rotations, brake/tire checks/replacements, etc.)
Air filters, transmission fluid changes, brake fluid, etc... will all need to be done eventually.
I had a torn axle boot on a Mazda 626 and I observed the same symptom. Could also be a bad wheel bearing (also observed on that car).
