2007 Honda CR-V
There was one case of glass breakage, not "a lot".
The hesitation is a valid issue, but I'm sure the new CR-V will have its own issues when those come out, noboby's perfect.
-juice
Here are some things about the '07 that "blow" me away.
Compared to the '06,
1)Has on 5" ground clarance, so it will get stuck in situations where the '06 CRV would travel with ease
2)Has a lot less cargo space, so it won't be as good a road trip car
3) Costs more $
I am currently looking to buy an '06 CRV. The '07 CRV? Overpriced, overweight and soon to be overhyped. It will take its place with the Del Sol as a Honda mistake...
The ground clearance is 7.3" (and how the suspension is set up could also have its impact on it), and the new CR-V actually has more cargo room (72.9 cu ft compared to 72 cu ft, not less). Information for 2007 CR-V is available on autodeadline.com.
First, I think the current CR-V has over 8 inches in ground clearance? That is more than the new CR-V.
Second, the new CR-V with the rear seats up will have less space than the old one. There is no way they are going to get the same functionality without the height of the current model. They have sacrificed interior room for styling, unlike the GEN 2, which appears to have been styled for interior room. And don't forget that they also appear to have sacrificed the great rear seat leg room in the new model.
On the EX model there will be a dual deck cargo shelf system for two levels of storage in the rear cargo area. There will be 13 inches of vertical space underneath. The top shelf would have a weight limit of 20 lbs.
The second row seatbacks have a 40/20/40 configuration to allow a pass through of long items with the second row up.
If this info from autodeadline.com is correct, this vehicle will meet my requirements for cargo carrying capability.
Indeed. But it isn't 5" (which I called wrong information).
Where are you getting your numbers from? 2002-2006 CR-V cargo space with upright rear seats is 33.5 cu ft. This goes up to 35.7 cu ft in 2007. Rear seats folded down, the cargo space is up from 72.0 cu ft to 72.9 cu ft.
And unlike 2002-2006 CR-V which has 60-40 rear seat split, 2007 gets 40-20-40 split.
And unlike 2002-2006 CR-V which has 60-40 rear seat split, 2007 gets 40-20-40 split."
I'm basing my comments on the fact that they streamlined the top instead of boxing it. I realize the CR-V will be somewhat wider, but I am not convinced it will be as useable a space as the Gen 2. I will wait until the official Honda 2007 CR-V US specs are published to comment further.
You should note that the rear volume can be expanded in the Gen 2 by putting the seat forward by about 3 inches. I think the Gen 3 loses the sliding rear seats...
I am going from the Acura RDX specs. The two vehicles share a platform and (presumably) basic shapes.
The RDX (US Specs):
Interior cargo volume: 28.8 feet.
Rear legroom: 37.7.
Gen 2 cargo volume: 33 cu ft (around 38 with the seats forward, in my experience.)
Rear Legroom: 39.
I consider these official Acura specs to be a better indicator than car sites. We will know for sure when Honda releases the specs. But I will be surprised if they allow their CR-V to have greater room than the RDX. That would be a major marketing mistake.
But they ARE different vehicles. Would you tell me that Accord is about as big as TSX since they share platform and basic shape? Marketing mistake? Well, Accord is larger than TSX and TL. Pilot is larger than MDX. It is nothing new at Honda. RDX is about sportiness more practicality less. CR-V is designed to be the sensible choice.
Have you even looked at specifications on autodeadline? This is official from Honda (note the date and place on top). It will be posted "as is" at Honda's website in a few days. THAT is not just another car site that is faking numbers.
I"ll take it, should you ever get one for free
http://en.wikipedia.org/wiki/RDX
It's absolutely amazing how some people will make a statement or base a decision on something so assinine.
You say your dealership will get some from Europe (Swindon I presume). Do you know if Japanese produced CR-Vs will also come to North America?
When we receive our On Order Report it doesn't spell out wether we are getting them from Swindon or Japan. The only way we know where they are coming from is after they are built and we have a VIN.
That being said the "On Order Report" gives us a 4 day window for a car being built in the US...for example a Civic would be 9-15 to 9-19. A CR-V or Hybrid or S2000 would simply say 9-15. It's not uncommon to see a car, for example a CR-V that is still listed as a build date of 8-09 (I have a 07 2wd EX listed as scheduled to be built 8-09) even though it is 8-29.
It's hard to get an approximate delivery time until the factory kicks everything into production, then we can start with estimates.
Thanks in advance
"Remember, Consumer Reports (last month maybe?) had the new RAV4 4 cylinder quicker than the outgoing CR-V, and the new one is heavier. Don't make any bets for Pinks, you'll probably lose."
True, but the 1st gen CR-V was lighter than the 2nd. And yet the second was both faster and more fuel efficient.
Comparing at the gear ratios between the 2006 and 2007 models, it looks like Honda has gone back to the extremely short gearing they used for the 1st gen. And while the 3rd gen is heavier, we're only talking about 50lbs. So, the 2007 could very well seem quicker than the 2006.
If the interior is more or less the same size as the old model, I think this CR-V has a chance. I think the interior styling, content, pricing, performance, and pretty much everything else is looking very good. Honda has a chance of keeping their market share if people can get over the looks.
Hopefully the sales will prove your initial prediction wrong and your revised prediction correct
Some may prefer that their Japanese vehicle actually comes from Japan. YMMV.
Have you even looked at specifications on autodeadline? This is official from Honda (note the date and place on top). It will be posted "as is" at Honda's website in a few days. THAT is not just another car site that is faking numbers."
I suggest you read the headline, especially the date of 1 September, 2006. Today is the 29th. There is no such memo on the official Honda website. Those numbers may be correct, or they may not be correct.
Don't get me wrong, it would be great if those numbers are correct. But I am suspicious of a "Honda link" that doesn't have a link involved.
M
You're comparing a CR-V that has had the bugs worked out over the course of five years with a Civic that is in it's first year.
Had you bought a 2002 CR-V in it's initial run, it would have been towed from your home or office back to the dealership for a seatbelt recall only weeks after it went on sale. You'd also be looking forward to a seat which rocks back and forth and brakes that "clunk". There were a number of other issues with the first run of the CR-V, and yes that includes the ones from Japan.
As for CR-V vs. RDX, I expect the former to have more room. The Pilot is bigger than the MDX inside, so there is a precedent. Plus, in pics the CR-V seems taller, so I bet it fits more cargo.
harvey: you bought a v1.0. I'm sure that has a lot more to do with your 3 issues then the place of manufacture. Honda has won all kinds of awards for their plants here.
-juice
Keep in mind, you bought a first year model, known for problems in any make of cars.
We had a 2003 Accord EX built in Japan that had numerous rattles and build goofs, one that included removing part of the headliner.
Dad's 2005 was built in Ohio, and had MUCH better initial quality, and less rattles in the long haul so far (he kept the 2003 about the same length he's had the 2005 right now, or 55,000 miles or so). That Japanese 2003 was a rattle-trap compared to our 05 and 06, both built in Ohio.
M
I think Honda has done a great job with the 2007 CRV. The apprearance mixes styling cues from BMW and Volvo. Love the crease along the side. The front end does not bother me and I love the headlights. Overall a much more upscale appearence in my opinion. Infiniti and Lexus are going to launch new small crossovers next year that will price about $10,000 more than the CRV.
My girlfriend has a 2004 CRV and the interior is weird with all the contrasting cheap plastics, downscale appearance, weird ergonomics and cheap sounding stereo. Her CRV also does not seem well insulated, too much road noise comes in the cabin.
Honda has made a great choice moving to an upscale appearance like the Acura RDX. This will probably allow them to compete well with the Toyota RAV4 which does not have an upscale appearance, more on the sporty side.
Well Done Honda
He disagreed with stats/info provided earlier, and doesn't like the nose on the new CR-V. I don't either.
Looks Nice!
Car And Driver
Look at "Photos" under multimedia.
I think that if you can do w/o the V-6, the CR-V is the way to go. If you need a V-6 or puny 3rd row seat, then it's not. Too bad the 3.0L V-6 from the Accord wasn't offered in the CR-V. Even that motor would be relatively impressive and you wouldn't interfere with the 3.5 V-6 in the Pilot.
Someone with the right attitude about the front end. When I am driving a vehicle I'm not looking at the front end. And I certainly don't care what anyone else thinks of it. YMMV
Yes, but our point is Honda hasn't. One exception doesn't change that.
Look at Toyota - the big recall that invovled the Prius and other models affected ONLY models that were made in Japan.
The US transplants for the established brands have done quite well, including Honda, Toyota, and Subaru. Nissan, Mercedes, and BMW have had problems.
The navy blue color looks to hide that controversial beak
That I agree with. But the gen II also looked better in dark colors, since the black plastic bumper wrapped up around the sides of its grille.
-juice
The rest of the CR-V package looks great.
