It's been perfect the first 3,000 miles. I get around 29mpg around the city with no AC. Took it to Toronto last week. 400 miles mostly 65mph, cruise, and no AC. 40.2 mpg.
Others do the same - back in the day for GM, when the cavalier was selling like blazes in both the US and Canada, all of them were still being built at the Lordstown facility and then shipped to dealers in both countries (the Lordstown complex is massive!).
Because of this, a lot of NA cars are produced to meet emissions in either country (ie. they build them to the highest determining standard). Usually what needs to be dealt with is safety issues, but even a lot of that is becoming standard (rear child seat safety restraints were mandated in Ontario before most US states, so you had to have a kit for your US imported car - I remember that one). The civics all digital speedo and odometer should make the miles-to-kilometers (and vice versa) simple - just altering a software setting default should do it.
At highway speeds (65-75 mph) I began to hear a "bell like sound" as the wheels passed over the spacers between sections of the road, which was poorly maintained. It was not very loud but it was noticeable. I had a passenger who was ~250 pounds and wonder if this was it, or the poor condition of the road. He heard the noise too, and it stopped as soon as we were on a smoother section of road.
The car had less than 1000 miles at that time, now up to 1700 and did not occur again.
Could it be the struts? No leaks on garage floor...
Also, I sometimes note that the automatic transmission is sort of jerky as it goes from start to first-second gear. I drive the car very gently and when I drive a bit more aggressively, it does not happen. Anyone thinks that this could be the start of a trans problem?
Otherwise, the car has been great, about 30-33 mpg in town (I am a very gentle driver) and 40 mpg in the hwy. Thanks.
George
Smaller engines do seem to shift a bit harder in my experience, as they lose a larger portion of their overall power when shifting. The load on the engine also seems to affect the hardness of the shifts, so even little things like having the AC on may affect it.
Those are some great mileage numbers, I get nowhere near that but I've never been called a gentle driver....
What brand tires are on your car, the brigies or goodyears?
The civics (my 06 LX included) tend to have alot of road noise , especially over concrete roads.
All because you don't have leaks on the garage floor does not mean the suspension is not leaking.
I consider myself lucky at 13K to not yet have leaky shocks or struts. I had my mechanic check and they are nice and dry on the outside, however, this is around the time when others started getting leaky shocks and struts.
You car is also green (new) so give it a few thousand to break in and then go from there.
Between here and 8thgencivic.com, there are plenty of resoursces to help once you determine there is still a problem.
That's probably my only real complaint about the civic - the DBW throttle response under certain driving conditions has too much lag (it's not enough to have deterred me from my purchase, but it's an item for Honda to improve on).
I will check the air pressure in my tires, although I do that regularly and suspect it is not the cause.
As far as the trans: it occurs when starting from a dead stop if I am very gentle on the gas, if I am a bit aggressive, it does not happen.
I agree that the car needs to age a bit more, to allow it to break in.
As far as what tires the car has: Bridgestone.
And yes, the drive by wire sometimes results in a delay when I press the gas.
I will visually check every so often that the struts/shocks are OK, not leaking oil, etc.
I always try to see how high mpg I can get from a car. I gave my son a 1993 Nissan Sentra, 5 speed, that I got 40 mpg time and again when taking long trips to East coast, through the mountains of PA, and this was with the car at 165K miles. He's got almost 180K miles on it, and still loves the mpg. I hope my Civic performs and is as reliable as that old Nissan. The Civic is capable of high mpg, but it has to be treated very gently. Although, I am surprised at the pep the car has if I push it! I chased an Audi the other day that went around me like I was an obstacle. So I pressed the gas pedal, keeping right behind him, till I noticed I was going 82 mph in a 55 zone and still accelerating! Do not do that often, but nice to know I can!
Overall, I remain impressed with this car.
I feel my civic without AC on is kind of a snail. I have a hard time keeping up with regular traffic sometimes. Here on LI though, people drive really fast and have big engines in their fancy shmancy beemers, benzes and so forth.
When merging on the highway, it can be scary sometimes as I can't get up to speed safely in certain conditions.
My gripe is that the 1.8L engine needs more power or a bump up to 2.0L or so.
Now, put 3 people in the car like I do when camping and such, and man, an old toyota tercel can kick my [non-permissible content removed] on the highway.
THIS IS NOT NORMAL - Do not let your dealer tell you that- That is JUST BS- We need to unite - against this - I have heard the noise 20+ times in 6 weeks- My friends who are driving with me - ARE like DUDE- this is a BRAND new CAR? - Why the noise- It comes out of Left FRONT and Right FRONT - 10 to 15 MPH ONLY when turning into an elevation change - I heard 3 times in a ROW last week - within 5 minutes- the NOISE is getting LOUDER - I have an acura - 15 yrs old - NO FRONT END NOISES.. Going into shop next week - will let you know - they are giving me a RENTAL until fixed - Will update..
How/Where can I read the TSB?
If got my car in Mexico (imported from US), do you think the TSB is still valid?
I appreciate your answer,
Actually when i was there, i test drove a Si sedan, i thought it was incredibly nice, and noticed no problems what so ever with the suspension or any weird road noises, and we hit several large bumps. oh yea it was a used Si too, with like 12,000 miles.. Sadly though, someone painted the rims gold with [non-permissible content removed] paint, and put a carbon fiber hood that wasnt painted, along with a front lip and side skirts that werent painted. lol was the ugliest thing in the world.
Do I need to register in other page to read it?
Does anyone could send me a copy?
You could help me to know if I am experiencing the same problem..
Thanks a lot!
Does anyone know why its not covered by warranty and/or if honda have or will issue a recall?
The service guy i spoke to told me that he had a few others come in with the same problem and that it WAS covered under warranty. They ordered me one, but it came in the wrong color, so it was back ordered but i never got it because we got rid of the car. But still, it was totally covered and i never paid a cent. He also mentioned that there would be a recall/redesign of that visor soon as the prev gen didn't have this problem.
There is no reason you should have to pay for this if you are still under warranty!!
I am 100% I posted a picture/image of the TSB you need in this thread or one of the other threads.
I think it was the 2006 civic lug bug thread.
keRo
I didn't have a single problem with the visors in my previous Civic. Someone really screwed up the design in the new models.
From everything I've heard, they are covered by warranty. I'm going to my dealership soon to have the broken one replaced. Will let you know what they say.
There is no reason to wait.
I think it was broken for a while but I just didn't bother noticing..
I live 800 miles away from the dealership where I bought my vehicle (it's 06 Honda civic coupe LX). Is it okay to bring my car to a near Honda dealerships?
Everything was covered by warranty and the tech said they've had many complaints about the visors on the new Civics. I think you can take your car to any dealer to get new ones.
One of the above posts said Honda wouldn't issue a visor recall because it's not a safety issue, but I disagree. When one of my visors broke in the middle of a trip, I couldn't flip it up back to its original position anymore. It was stuck facing down. Thankfully, it was on the passenger side, but if it happened on the driver's side, it would have had a big impact on visibility.
What a big pain in the @#$% for such a small part.
The Sandman
Work done thus far:
Motor mount replaced
belt kit installed
panels popping out inside (corrected by me thanks to a helpfull person on 8thgencivic.com)
A front end crack that is yet to be diagnosed and is rather loud and annoying
Pulling to the right despite multiple alignments (there is a tsb out on this but I am not going to take it in since I plan on trading shortly)
Major front brake problems, 15K on the car and the brakes are grinding like crazy and the car is not abused nor do I drive like a maniac, nor do I ride my brakes.
Glass that is terribly scratched despite the fact I only use micro fiber cloths and water. Nothing abrasive has touched the glass. My glass looks like a car that has 10 years of driving on it.
Gas mileage that is less than stellar.
Interior plastic looks much older than the car is.
Other than that, the car is fine.
If I did not have the problem I have/had, I would keep the car a long time, my particular car, well it has not been a great feeling.
